Exporting and Migrating Genesys Cloud Web Messaging Transcripts with Python
A production-grade Python module that queries Web Messaging conversation transcripts, validates schema and storage constraints, handles pagination and media asset resolution, triggers data exports, configures completion webhooks for external data lake synchronization, and generates structured audit logs with latency tracking. It uses the Genesys Cloud Python SDK and the Analytics Conversations, Data Export, and Webhook APIs. Python 3.9+ is the target runtime.
  • OAuth Client Credentials grant configured in Genesys Cloud Admin
  • Required scopes: analytics:conversation:read, dataexport:read, dataexport:write, webhook:read, webhook:write
  • SDK: genesyscloud>=2.0.0
  • Runtime: Python 3.9 or later
  • External dependencies: httpx>=0.25.0, pydantic>=2.0.0, loguru>=0.7.0
Genesys Cloud uses JWT bearer tokens issued via the OAuth 2.0 client credentials flow. The Python SDK manages token caching and automatic refresh, but you must initialize the platform client with your environment URL, client ID, and client secret. The SDK handles the /login/oauth2/v1/token endpoint internally.
from genesyscloud.platform.client import PlatformClient
from genesyscloud.platform.client.auth import OAuthClientCredentials
def initialize_platform_client(environment_url: str, client_id: str, client_secret: str) -> PlatformClient:
    """Initialize the Genesys Cloud platform client with automatic token management."""
    client = PlatformClient()
    client.set_base_url(environment_url)
    # Configure OAuth client credentials flow
    auth = OAuthClientCredentials(client_id=client_id, client_secret=client_secret)
    client.set_auth(auth)
    # Verify connectivity and token acquisition
        client.login()
        raise RuntimeError(f"Authentication failed: {e}")
    return client
The SDK caches the access token and refreshes it before expiration. You do not need to implement manual token rotation. The client throws a genesyscloud.platform.client.auth.exceptions.AuthenticationError if credentials are invalid or the token expires mid-request.
Step 1: Query Web Messaging Transcripts and Handle Pagination
Transcript retrieval uses the Analytics Conversations Details Query endpoint. The API returns paginated results via a nextSequence token. You must filter by type: "webchat" to isolate Web Messaging conversations. The SDK maps this to AnalyticsApi.query_post_conversations_details_query.
Required scope: analytics:conversation:read
from genesyscloud.analytics.api import AnalyticsApi
from genesyscloud.analytics.model import PostConversationsDetailsQueryRequestBody
from httpx import HTTPStatusError
import logging
def query_webchat_transcripts(
    analytics_api: AnalyticsApi,
    start_date: str,
    end_date: str,
    page_size: int = 100
) -> list[dict]:
    """Fetch all Web Messaging transcripts within a date range using pagination."""
    all_transcripts = []
    next_sequence = None
    query_body = PostConversationsDetailsQueryRequestBody(
        type="webchat",
        date_from=start_date,
        date_to=end_date,
        page_size=page_size,
        groupings=[{"type": "conversation"}]
    while True:
        query_body.next_sequence = next_sequence
            response = analytics_api.query_post_conversations_details_query(body=query_body)
        except HTTPStatusError as e:
            if e.response.status_code == 429:
                retry_after = int(e.response.headers.get("Retry-After", 2))
                logger.warning(f"Rate limited. Retrying in {retry_after} seconds.")
                time.sleep(retry_after)
            raise
        if not response.entities:
            break
        all_transcripts.extend(response.entities)
        next_sequence = response.next_sequence
        if not next_sequence:
            break
    logger.info(f"Retrieved {len(all_transcripts)} Web Messaging transcripts.")
    return all_transcripts
The Analytics API groups results by conversation by default. Each entity contains a metrics object and a groups array holding the conversation details. The nextSequence token enables stateless pagination. You must always check for 429 responses and honor the Retry-After header to prevent cascade failures.
Step 2: Validate Schema, Storage Constraints, and PII Redaction
Before migrating, you must verify that transcript payloads match the expected schema and do not exceed export size limits. Genesys Cloud data exports enforce a maximum definition size and partition limits. You will use Pydantic to enforce structure and check PII redaction flags.
from pydantic import BaseModel, Field, ValidationError
from typing import Optional, List
class TranscriptMessage(BaseModel):
    timestamp: str
    from_: str  # 'from_' avoids Python reserved keyword conflict
    type: str
    content: Optional[str] = None
    media: Optional[List[dict]] = None
class TranscriptSchema(BaseModel):
    type: str = Field(..., pattern="^webchat$")
    start_timestamp: str
    end_timestamp: str
    messages: List[TranscriptMessage]
    pii_redacted: bool = False
def validate_transcript_payload(transcript: dict, max_size_bytes: int = 5 * 1024 * 1024) -> bool:
    """Validate transcript structure and enforce storage constraints."""
        validated = TranscriptSchema(**transcript)
    except ValidationError as e:
        logger.error(f"Schema validation failed for transcript {transcript.get('id')}: {e}")
        return False
    payload_size = len(str(transcript).encode("utf-8"))
    if payload_size > max_size_bytes:
        logger.warning(f"Transcript {transcript.get('id')} exceeds size limit: {payload_size} bytes.")
        return False
    if not validated.pii_redacted:
        logger.warning(f"Transcript {validated.id} contains unredacted PII. Migration blocked.")
        return False
    return True
Genesys Cloud applies PII redaction at the analytics layer when configured in Admin. The pii_redacted flag indicates whether sensitive data was masked. You must enforce this check before writing to external storage to prevent information leakage during scaling events. The size limit prevents export definition rejection by the Data Export API.
Step 3: Handle Message Reordering and Media Asset Linking
Transcript messages may arrive out of order due to network latency or system retries. You must sort messages by timestamp before migration. Media assets require atomic verification to ensure link integrity.
from httpx import Client
import json
def process_transcript_messages(transcript: dict, base_url: str, token: str) -> dict:
    """Sort messages and verify media asset links via atomic GET operations."""
    messages = transcript.get("groups", [{}])[0].get("metrics", {}).get("messages", [])
    # Sort by timestamp to guarantee chronological order
    sorted_messages = sorted(messages, key=lambda m: m.get("timestamp", ""))
    verified_media = []
    http_client = Client(base_url=base_url, headers={"Authorization": f"Bearer {token}"})
    for msg in sorted_messages:
        media_list = msg.get("media", [])
        for asset in media_list:
            asset_url = asset.get("url")
            if asset_url:
                    response = http_client.get(asset_url, follow_redirects=True, timeout=5.0)
                    if response.status_code == 200:
                        verified_media.append(asset)
                    else:
                        logger.warning(f"Media asset verification failed: {asset_url}")
                    logger.error(f"Network error verifying media {asset_url}: {e}")
    transcript["groups"][0]["metrics"]["messages"] = sorted_messages
    transcript["groups"][0]["metrics"]["verified_media"] = verified_media
    return transcript
The API does not guarantee message order in batch queries. Sorting ensures deterministic export structure. Media verification uses atomic GET requests with strict timeouts to prevent hanging threads. You must capture the bearer token from the SDK client for authenticated asset access.
Step 4: Configure Data Export and Webhook Synchronization
Data exports move validated transcripts to external storage. You will create an export definition, trigger a request, and configure a webhook to synchronize completion events with your data lake.
Required scopes: dataexport:read, dataexport:write, webhook:read, webhook:write
from genesyscloud.dataexports.api import DataexportsApi
from genesyscloud.dataexports.model import PostDataexportsDefinitionsRequestBody
from genesyscloud.webhooks.api import WebhooksApi
from genesyscloud.webhooks.model import PostWebhooksRequestBody
import uuid
def create_export_and_webhook(
    dataexports_api: DataexportsApi,
    webhooks_api: WebhooksApi,
    callback_url: str,
    export_name: str = "WebChat_Transcript_Migration"
) -> tuple[str, str]:
    """Create a data export definition and a completion webhook for external sync."""
    # Define export structure
    export_def = PostDataexportsDefinitionsRequestBody(
        name=export_name,
        definition={
            "type": "analytics",
            "query": {
                "type": "webchat",
                "groupings": [{"type": "conversation"}]
            "format": "json",
            "partition": "daily"
        destinations=[{
            "type": "webhook",
            "url": callback_url,
            "format": "json"
    export_response = dataexports_api.post_dataexports_definitions(body=export_def)
    export_id = export_response.id
    # Configure webhook for export completion events
    webhook_body = PostWebhooksRequestBody(
        name=f"Export_Completion_{export_id}",
        enabled=True,
        api_version="v2",
        event="dataexport:export:complete",
        address=callback_url,
        method="POST",
        security_scheme="bearer",
        content_type="application/json"
    webhook_response = webhooks_api.post_webhooks(body=webhook_body)
    webhook_id = webhook_response.id
    logger.info(f"Created export {export_id} and webhook {webhook_id}.")
    return export_id, webhook_id
The Data Export API partitions results automatically. The webhook triggers on dataexport:export:complete, delivering a payload containing the export ID, status, and file locations. You must use a secure callback URL with bearer token validation to prevent unauthorized data lake ingestion.
Step 5: Track Latency, Success Rates, and Generate Audit Logs
Migration efficiency requires structured telemetry. You will measure query latency, export success rates, and write immutable audit logs for governance compliance.
import json
from pathlib import Path
from datetime import datetime
class MigrationAuditor:
    def __init__(self, log_directory: str = "./audit_logs"):
        self.log_dir = Path(log_directory)
        self.log_dir.mkdir(parents=True, exist_ok=True)
        self.metrics = {"total_queries": 0, "successful_exports": 0, "failed_exports": 0}
    def record_event(self, event_type: str, transcript_id: str, duration_ms: float, success: bool):
        timestamp = datetime.utcnow().isoformat()
        audit_entry = {
            "timestamp": timestamp,
            "event": event_type,
            "transcript_id": transcript_id,
            "duration_ms": duration_ms,
            "success": success,
            "metrics_snapshot": self.metrics.copy()
        log_file = self.log_dir / f"migration_{datetime.utcnow().strftime('%Y%m%d')}.jsonl"
        with open(log_file, "a", encoding="utf-8") as f:
            f.write(json.dumps(audit_entry) + "\n")
        if success:
            self.metrics["successful_exports"] += 1
        else:
            self.metrics["failed_exports"] += 1
        self.metrics["total_queries"] += 1
    def generate_summary(self) -> dict:
        total = self.metrics["total_queries"]
        success_rate = (self.metrics["successful_exports"] / total * 100) if total > 0 else 0
            "total_processed": total,
            "success_rate_percent": round(success_rate, 2),
            "failed_count": self.metrics["failed_exports"]
The auditor appends JSON Lines entries to daily files. This format supports efficient streaming into data lakes and SIEM tools. You must record timestamps in UTC and include metric snapshots to correlate latency spikes with export failures.
import logging
from httpx import HTTPStatusError, Client
import json
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
    timestamp: str
    from_: str
    type: str
    end_timestamp: str
        audit_entry = {
            "success": success,
        if success:
        else:
        return {"total_processed": total, "success_rate_percent": round(success_rate, 2), "failed_count": self.metrics["failed_exports"]}
    except ValidationError:
        return False
    if len(str(transcript).encode("utf-8")) > max_size_bytes:
        return False
    return transcript.get("pii_redacted", False)
    verified_media = []
        for asset in msg.get("media", []):
            if asset_url:
                except Exception:
                    pass
    return transcript
def run_migration(environment_url: str, client_id: str, client_secret: str, callback_url: str):
    client.set_auth(OAuthClientCredentials(client_id=client_id, client_secret=client_secret))
    client.login()
    analytics_api = AnalyticsApi(client)
    dataexports_api = DataexportsApi(client)
    webhooks_api = WebhooksApi(client)
    auditor = MigrationAuditor()
    start_date = "2023-01-01T00:00:00.000Z"
    end_date = "2023-01-31T23:59:59.999Z"
        type="webchat", date_from=start_date, date_to=end_date, page_size=100, groupings=[{"type": "conversation"}]
    while True:
                time.sleep(int(e.response.headers.get("Retry-After", 2)))
            raise
            break
        for entity in response.entities:
            transcript_id = entity.get("id", "unknown")
            if validate_transcript_payload(entity):
                processed = process_transcript_messages(entity, environment_url, client.get_access_token())
                duration_ms = (time.perf_counter() - start_time) * 1000
                auditor.record_event("transcript_validated", transcript_id, duration_ms, True)
            else:
                auditor.record_event("transcript_rejected", transcript_id, 0, False)
            break
        name="WebChat_Transcript_Migration",
        definition={"type": "analytics", "query": {"type": "webchat", "groupings": [{"type": "conversation"}]}, "format": "json", "partition": "daily"},
        destinations=[{"type": "webhook", "url": callback_url, "format": "json"}]
        name=f"Export_Completion_{export_response.id}", enabled=True, api_version="v2",
        event="dataexport:export:complete", address=callback_url, method="POST",
        security_scheme="bearer", content_type="application/json"
    logger.info(json.dumps(auditor.generate_summary(), indent=2))
    run_migration(
        environment_url="https://api.mypurecloud.com",
        client_id="YOUR_CLIENT_ID",
        client_secret="YOUR_CLIENT_SECRET",
        callback_url="https://your-data-lake.example.com/webhooks/genesys-export"
  • Cause: Invalid client credentials, expired token, or missing OAuth scope.
  • Fix: Verify client_id and client_secret in Admin. Ensure the OAuth application has analytics:conversation:read and dataexport:write scopes. The SDK throws AuthenticationError immediately if the token request fails.
Error: 403 Forbidden
  • Cause: The OAuth application lacks permissions for the specific environment or organization.
  • Fix: Check Admin under Organization > OAuth Applications. Grant the required scopes. Verify the environment URL matches the tenant region.
  • Cause: Exceeded API rate limits. Analytics queries and webhook creation share tenant-level quotas.
  • Fix: Implement exponential backoff. The script already checks the Retry-After header. Reduce page_size if queries trigger cascading limits.
  • Cause: Transient platform failure or malformed export definition.
  • Fix: Validate JSON structure against the OpenAPI spec. Retry with a fixed delay. Check Genesys Cloud status page for regional outages.
Error: Schema Validation Failure
  • Cause: Transcript structure changed or PII redaction is disabled.
  • Fix: Enable PII redaction in Admin under Security > PII. Update the Pydantic model if Genesys Cloud introduces new fields. The pii_redacted flag must be true for migration approval.
