Executing NICE CXone Outbound Campaign Dial Strategies via Python SDK
- One sentence: The code constructs and submits outbound campaign execution payloads that enforce pacing matrices, compliance overrides, and atomic call sequencing while validating against dial engine constraints.
- One sentence: This uses the NICE CXone Outbound Campaign REST API surface with direct
requestscalls that mirror the official Python SDK behavior. - One sentence: The tutorial covers Python 3.9+ with strict typing, retry logic, and webhook synchronization.
- OAuth client type: Confidential client (Client Credentials Flow)
- Required scopes:
outbound:campaign:write,outbound:campaign:read,outbound:execute:trigger,outbound:strategy:write,outbound:webhook:write - API version: CXone v2 Outbound APIs
- Language/runtime requirements: Python 3.9 or higher
- External dependencies:
requests>=2.31.0,pydantic>=2.5.0,httpx>=0.25.0(for async webhook polling if extended)
NICE CXone uses OAuth 2.0 client credentials for programmatic access. The following code implements token acquisition, caching, and automatic refresh logic.
import requests
from typing import Optional, Dict, Any
class CxoneAuthManager:
def __init__(self, client_id: str, client_secret: str, base_url: str):
self.client_id = client_id
self.expires_at: float = 0.0
self.token_url = f"{self.base_url}/oauth/token"
def _fetch_token(self) -> Dict[str, Any]:
payload = {
"client_id": self.client_id,
"scope": "outbound:campaign:write outbound:campaign:read outbound:execute:trigger outbound:strategy:write outbound:webhook:write"
response = requests.post(self.token_url, data=payload, headers=headers, timeout=10)
response.raise_for_status()
return response.json()
def get_bearer_token(self) -> str:
if self.token and time.time() < self.expires_at - 30:
return self.token
token_data = self._fetch_token()
self.token = token_data["access_token"]
self.expires_at = time.time() + token_data["expires_in"]
return self.token
def get_headers(self) -> Dict[str, str]:
"Authorization": f"Bearer {self.get_bearer_token()}",
"Accept": "application/json"
HTTP Request Cycle (Token Acquisition)
POST /oauth/token HTTP/1.1
Host: api.ccxone.com
grant_type=client_credentials&client_id=YOUR_CLIENT_ID&client_secret=YOUR_CLIENT_SECRET&scope=outbound:campaign:write+outbound:campaign:read+outbound:execute:trigger
Realistic Response
"expires_in": 3600,
"token_type": "Bearer",
"scope": "outbound:campaign:write outbound:campaign:read outbound:execute:trigger"
Step 1: Validate Dialing Engine Constraints & Concurrent Line Limits
Before executing a campaign, you must verify that the requested pacing parameters do not exceed the tenant or campaign level limits. The dial engine rejects payloads that violate maxConcurrentLines or predictiveRate thresholds.
import requests
from typing import Dict, Any
class DialEngineValidator:
def __init__(self, auth: CxoneAuthManager, campaign_id: str):
self.auth = auth
self.campaign_id = campaign_id
self.base_url = auth.base_url
def fetch_campaign_limits(self) -> Dict[str, Any]:
url = f"{self.base_url}/api/v2/outbound/campaigns/{self.campaign_id}"
headers = self.auth.get_headers()
response = requests.get(url, headers=headers, timeout=10)
def validate_pacing_matrix(self, max_lines: int, predictive_rate: float, abandoned_limit: float) -> bool:
limits = self.fetch_campaign_limits()
engine_max = limits.get("maxConcurrentLines", 100)
if max_lines > engine_max:
raise ValueError(f"Requested {max_lines} lines exceeds engine limit of {engine_max}")
if predictive_rate < 0.0 or predictive_rate > 1.0:
raise ValueError("Predictive rate must be between 0.0 and 1.0")
if abandoned_limit < 0.0 or abandoned_limit > 1.0:
raise ValueError("Abandoned call limit must be between 0.0 and 1.0")
return True
HTTP Request Cycle (Campaign Limits Retrieval)
GET /api/v2/outbound/campaigns/8f3a2c1d-4e5b-6789-abcd-ef0123456789 HTTP/1.1
Authorization: Bearer <token>
Accept: application/json
Realistic Response
"id": "8f3a2c1d-4e5b-6789-abcd-ef0123456789",
"name": "Q4_Promo_Outbound",
"maxConcurrentLines": 50,
"status": "PENDING",
"settings": {
"predictiveDialingEnabled": false,
"abandonedCallLimit": 0.03
Step 2: Construct Execute Payload with Strategy References & Compliance Overrides
The execution payload must reference an existing strategy ID, define pacing matrices, and include compliance override directives. The schema validates against the CXone outbound engine constraints.
class ExecutePayloadBuilder:
def __init__(self, campaign_id: str):
def build_payload(
self,
strategy_id: str,
max_concurrent_lines: int,
abandoned_call_limit: float,
compliance_overrides: List[Dict[str, Any]],
enabled: bool = True
"campaignId": self.campaign_id,
"strategyId": strategy_id,
"enabled": enabled,
"pacing": {
"maxConcurrentLines": max_concurrent_lines,
"predictiveRate": predictive_rate,
"abandonedCallLimit": abandoned_call_limit,
"predictiveDialingEnabled": predictive_rate > 0.0
"complianceOverrides": compliance_overrides,
"executionContext": {
"triggerType": "API",
"initiatedBy": "strategy_executor_v1"
def validate_schema(self, payload: Dict[str, Any]) -> bool:
required_keys = ["campaignId", "strategyId", "pacing", "complianceOverrides"]
for key in required_keys:
if key not in payload:
raise KeyError(f"Missing required schema key: {key}")
if not isinstance(payload["pacing"]["maxConcurrentLines"], int):
raise TypeError("maxConcurrentLines must be an integer")
return True
HTTP Request Cycle (Execution Trigger)
POST /api/v2/outbound/campaigns/8f3a2c1d-4e5b-6789-abcd-ef0123456789/execute HTTP/1.1
"campaignId": "8f3a2c1d-4e5b-6789-abcd-ef0123456789",
"strategyId": "strat_9x8y7z6w5v",
"enabled": true,
"pacing": {
"maxConcurrentLines": 25,
"predictiveRate": 0.65,
"abandonedCallLimit": 0.03,
"predictiveDialingEnabled": true
"complianceOverrides": [
"ruleId": "do_not_call_state_ca",
"overrideAction": "SKIP",
"reason": "manual_review_pending"
Realistic Response
"executionId": "exec_4a3b2c1d0e",
"status": "QUEUED",
"estimatedStartTimestamp": "2024-06-15T14:30:00Z",
"validationResult": "PASSED",
"warnings": []
Step 3: Atomic PATCH Operations for Call Sequencing & Predictive Triggers
Call sequencing requires atomic updates to prevent race conditions. You must use the If-Match header with the entity version returned from the previous GET request. The PATCH operation also triggers automatic predictive calculation updates.
import requests
class AtomicSequenceManager:
self.auth = auth
self.entity_version: Optional[str] = None
def sync_entity_version(self) -> str:
url = f"{self.base_url}/api/v2/outbound/campaigns/{self.campaign_id}/settings"
self.entity_version = response.headers.get("ETag")
if not self.entity_version:
raise RuntimeError("ETag header missing. Cannot perform atomic update.")
return self.entity_version
def update_call_sequence(self, sequence_config: Dict[str, Any]) -> Dict[str, Any]:
self.sync_entity_version()
headers = {
**self.auth.get_headers(),
"If-Match": self.entity_version,
"X-Request-Id": f"seq_patch_{self.campaign_id}"
response = requests.patch(url, json=sequence_config, headers=headers, timeout=15)
if response.status_code == 412:
raise RuntimeError("Precondition failed. Entity version mismatch. Retry sync.")
HTTP Request Cycle (Atomic PATCH)
PATCH /api/v2/outbound/campaigns/8f3a2c1d-4e5b-6789-abcd-ef0123456789/settings HTTP/1.1
If-Match: "v7x9k2m4p1"
"callSequencing": {
"retryAttempts": 3,
"retryIntervalMinutes": 60,
"predictiveCalculationTrigger": "AUTO_ADAPTIVE"
Realistic Response
"id": "settings_8f3a2c1d",
"callSequencing": {
"retryAttempts": 3,
"updatedTimestamp": "2024-06-15T14:32:10Z",
"version": "v7x9k2m4p1"
Step 4: Validation Pipeline for Skill Matching & Timezone Compliance
Before scaling outbound traffic, verify that available agents possess required skills and that dialing windows comply with legal time zones. This pipeline prevents regulatory breaches and abandoned call spikes.
import requests
import pytz
class ComplianceValidationPipeline:
self.auth = auth
def validate_agent_skills(self, required_skill_ids: List[str]) -> bool:
url = f"{self.base_url}/api/v2/outbound/campaigns/{self.campaign_id}/agentSkills"
available_skills = response.json().get("assignedSkillIds", [])
missing = set(required_skill_ids) - set(available_skills)
if missing:
raise ValueError(f"Agents lack required skills: {missing}")
return True
def validate_timezones(self, allowed_timezones: List[str], local_call_window: Dict[str, str]) -> bool:
start_time = local_call_window.get("start", "09:00")
end_time = local_call_window.get("end", "17:00")
for tz_str in allowed_timezones:
pytz.timezone(tz_str)
except pytz.exceptions.UnknownTimeZoneError:
raise ValueError(f"Invalid timezone identifier: {tz_str}")
if start_time >= end_time:
raise ValueError(f"Call window start must precede end in {tz_str}")
return True
HTTP Request Cycle (Agent Skills Validation)
GET /api/v2/outbound/campaigns/8f3a2c1d-4e5b-6789-abcd-ef0123456789/agentSkills HTTP/1.1
Realistic Response
"assignedSkillIds": ["skill_sales_01", "skill_compliance_02", "skill_tier1_support"],
"totalAgents": 45,
"availableAgents": 32
Step 5: Webhook Synchronization, Latency Tracking, & Audit Logging
Synchronize execution events with external workforce management systems via webhook callbacks. Track execution latency and strategy adaptation rates. Generate audit logs for governance.
import requests
class ExecutionMonitor:
def __init__(self, auth: CxoneAuthManager, campaign_id: str, webhook_url: str):
self.auth = auth
self.latency_samples: List[float] = []
self.adaptation_rates: List[float] = []
def register_webhook(self, event_types: List[str]) -> Dict[str, Any]:
payload = {
"callbackUrl": self.webhook_url,
"eventTypes": event_types,
"active": True
url = f"{self.base_url}/api/v2/outbound/webhooks"
response = requests.post(url, json=payload, headers=headers, timeout=10)
def track_latency(self, start_time: float, end_time: float) -> float:
latency = end_time - start_time
self.latency_samples.append(latency)
return latency
def calculate_adaptation_rate(self, target_rate: float, actual_rate: float) -> float:
adaptation = abs(target_rate - actual_rate) / target_rate if target_rate > 0 else 0.0
self.adaptation_rates.append(adaptation)
return adaptation
def fetch_audit_logs(self, limit: int = 50) -> List[Dict[str, Any]]:
url = f"{self.base_url}/api/v2/outbound/audit/logs?campaignId={self.campaign_id}&limit={limit}"
response = requests.get(url, headers=headers, timeout=15)
return response.json().get("logs", [])
HTTP Request Cycle (Webhook Registration)
POST /api/v2/outbound/webhooks HTTP/1.1
"callbackUrl": "https://wfm.example.com/cxone/callback",
"eventTypes": ["CAMPAIGN_STARTED", "DIAL_STRATEGY_ADAPTED", "COMPLIANCE_OVERRIDE_TRIGGERED"],
"active": true
Realistic Response
"webhookId": "wh_5f4e3d2c1b",
"status": "ACTIVE",
"registeredTimestamp": "2024-06-15T14:35:00Z"
The following module combines all components into a production-ready strategy executor. Replace the placeholder credentials and campaign identifiers before execution.
import requests
from typing import Dict, Any, List, Optional
payload = {
return self.token
return self.token
class StrategyExecutor:
def __init__(self, client_id: str, client_secret: str, base_url: str, campaign_id: str, webhook_url: str):
self.auth = CxoneAuthManager(client_id, client_secret, base_url)
def _request_with_retry(self, method: str, url: str, **kwargs) -> requests.Response:
max_retries = 3
response = requests.request(method, url, **kwargs)
retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
print(f"Rate limited. Retrying in {retry_after}s (attempt {attempt+1})")
time.sleep(retry_after)
return response
raise RuntimeError("Max retries exceeded for 429 responses")
def validate_and_execute(
self,
strategy_id: str,
max_lines: int,
abandoned_limit: float,
required_skills: List[str],
# Step 1: Validate constraints
limits_url = f"{self.base_url}/api/v2/outbound/campaigns/{self.campaign_id}"
limits_resp = self._request_with_retry("GET", limits_url, headers=self.auth.get_headers(), timeout=10)
engine_max = limits_resp.json().get("maxConcurrentLines", 100)
# Step 2: Validate skills & timezones
skills_url = f"{self.base_url}/api/v2/outbound/campaigns/{self.campaign_id}/agentSkills"
skills_resp = self._request_with_retry("GET", skills_url, headers=self.auth.get_headers(), timeout=10)
available_skills = set(skills_resp.json().get("assignedSkillIds", []))
if not set(required_skills).issubset(available_skills):
raise ValueError("Agent skill mismatch detected")
for tz in allowed_timezones:
import pytz
pytz.timezone(tz)
raise ValueError(f"Invalid timezone: {tz}")
# Step 3: Construct & validate payload
payload = {
"enabled": True,
"pacing": {
"maxConcurrentLines": max_lines,
"abandonedCallLimit": abandoned_limit,
"executionContext": {"triggerType": "API", "initiatedBy": "strategy_executor_v1"}
# Step 4: Register webhook
webhook_payload = {
"eventTypes": ["CAMPAIGN_STARTED", "DIAL_STRATEGY_ADAPTED"],
"active": True
self._request_with_retry("POST", f"{self.base_url}/api/v2/outbound/webhooks", json=webhook_payload, headers=self.auth.get_headers(), timeout=10)
# Step 5: Execute campaign
start_time = time.time()
exec_url = f"{self.base_url}/api/v2/outbound/campaigns/{self.campaign_id}/execute"
exec_resp = self._request_with_retry("POST", exec_url, json=payload, headers=self.auth.get_headers(), timeout=15)
latency = time.time() - start_time
print(f"Execution latency: {latency:.3f}s")
# Step 6: Atomic PATCH for call sequencing
settings_url = f"{self.base_url}/api/v2/outbound/campaigns/{self.campaign_id}/settings"
settings_resp = self._request_with_retry("GET", settings_url, headers=self.auth.get_headers(), timeout=10)
self.entity_version = settings_resp.headers.get("ETag")
raise RuntimeError("ETag missing for atomic update")
sequence_patch = {
"callSequencing": {
"retryAttempts": 3,
patch_headers = {**self.auth.get_headers(), "If-Match": self.entity_version}
self._request_with_retry("PATCH", settings_url, json=sequence_patch, headers=patch_headers, timeout=15)
# Step 7: Fetch audit logs
audit_url = f"{self.base_url}/api/v2/outbound/audit/logs?campaignId={self.campaign_id}&limit=10"
audit_resp = self._request_with_retry("GET", audit_url, headers=self.auth.get_headers(), timeout=10)
audit_logs = audit_resp.json().get("logs", [])
"execution_result": exec_resp.json(),
"latency_seconds": latency,
"audit_logs": audit_logs,
"status": "SUCCESS"
executor = StrategyExecutor(
client_id="YOUR_CLIENT_ID",
client_secret="YOUR_CLIENT_SECRET",
base_url="https://api.ccxone.com",
campaign_id="8f3a2c1d-4e5b-6789-abcd-ef0123456789",
webhook_url="https://wfm.example.com/cxone/callback"
result = executor.validate_and_execute(
strategy_id="strat_9x8y7z6w5v",
max_lines=25,
predictive_rate=0.65,
abandoned_limit=0.03,
compliance_overrides=[
{"ruleId": "do_not_call_state_ca", "overrideAction": "SKIP", "reason": "manual_review_pending"}
required_skills=["skill_sales_01", "skill_compliance_02"],
allowed_timezones=["America/New_York", "America/Los_Angeles"],
call_window={"start": "09:00", "end": "17:00"}
print("Execution completed successfully.")
print(f"Result: {result}")
Error: 400 Bad Request
- What causes it: The execute payload violates schema constraints, pacing matrices exceed tenant limits, or compliance override rule IDs do not exist in the campaign configuration.
- How to fix it: Validate the payload structure against the CXone outbound schema. Verify that
strategyIdexists and matches the campaign scope. EnsurepredictiveRateandabandonedCallLimitfall within0.0to1.0. - Code showing the fix:
if not (0.0 <= predictive_rate <= 1.0):
if not (0.0 <= abandoned_limit <= 1.0):
raise ValueError("Abandoned limit must be between 0.0 and 1.0")
Error: 403 Forbidden
- What causes it: The OAuth token lacks the
outbound:execute:triggeroroutbound:strategy:writescopes, or the client ID is not authorized for the target tenant. - How to fix it: Regenerate the OAuth token with the complete scope string. Verify client permissions in the CXone admin console under API Access.
Error: 409 Conflict
- What causes it: The campaign is already in an
ACTIVEorEXECUTINGstate, or theIf-MatchETag header does not match the current entity version during atomic PATCH operations. - How to fix it: Synchronize the ETag by performing a fresh GET request before PATCH. If the campaign is active, wait for completion or use the pause/resume endpoints instead.
- What causes it: The dial engine or authentication service enforces rate limits when multiple execution payloads or webhook registrations are submitted rapidly.
- How to fix it: Implement exponential backoff with
Retry-Afterheader parsing. The provided_request_with_retrymethod handles this automatically. - Code showing the fix:
