Executing NICE CXone Flow Unit Tests via Flow Testing API with Python SDK
A production-grade Python test executor that programmatically triggers NICE CXone flow unit tests, validates execution payloads against engine constraints, tracks latency and pass rates, synchronizes results with CI/CD via webhooks, and generates audit logs for governance. This tutorial uses the NICE CXone Flow Testing API (/api/v2/testing/flows/{flowId}/executions) with httpx and pydantic to handle atomic execution, schema validation, and CI/CD alignment. The code covers Python 3.9+ with type hints, retry logic, and comprehensive error handling.
- OAuth Client Type: Confidential Client (Client Credentials Flow)
- Required Scopes:
flow:testing:execute,flow:testing:read,flow:testing:write - API Version: CXone API v2
- Runtime: Python 3.9 or higher
- Dependencies:
httpx>=0.24.0,pydantic>=2.0.0,python-dotenv>=1.0.0 - Installation:
pip install httpx pydantic python-dotenv
NICE CXone uses OAuth 2.0 Client Credentials for server-to-server API access. The token endpoint returns a bearer token valid for one hour. Production integrations must implement token caching and automatic refresh to avoid 401 cascades during long-running test suites.
import httpx
from typing import Optional
@dataclass
class CxoneAuth:
client_id: str
client_secret: str
region: str = "us-1"
_token: Optional[str] = field(default=None, init=False)
_expires_at: float = field(default=0.0, init=False)
@property
def base_url(self) -> str:
return f"https://api-{self.region}.cxone.com"
if self._token and time.time() < self._expires_at:
return self._token
token_url = f"{self.base_url}/oauth/token"
payload = {
"client_id": self.client_id,
"scope": "flow:testing:execute flow:testing:read flow:testing:write"
with httpx.Client(timeout=15.0) as client:
response = client.post(token_url, data=payload)
response.raise_for_status()
data = response.json()
self._token = data["access_token"]
self._expires_at = time.time() + data["expires_in"] - 30
return self._token
The get_access_token method checks cache validity before issuing a network request. The -30 buffer prevents edge-case expiration during concurrent API calls. The scope string explicitly requests testing permissions, which CXone enforces at the gateway level.
The CXone testing engine rejects payloads that exceed maximum test suite duration limits, contain malformed assertion paths, or exceed mock data size thresholds. You must validate the execute schema before submission to prevent 400 errors and wasted queue slots.
from pydantic import BaseModel, Field, field_validator
import json
class AssertionDirective(BaseModel):
path: str
operator: str
value: Any
@field_validator("operator")
@classmethod
def validate_operator(cls, v: str) -> str:
allowed = {"eq", "ne", "gt", "lt", "gte", "lte", "contains", "regex"}
if v not in allowed:
raise ValueError(f"Operator must be one of {allowed}")
return v
class ExecutePayload(BaseModel):
test_case_id: str
input_data: Dict[str, Any]
assertions: List[AssertionDirective]
timeout_seconds: int = Field(default=300, le=600, ge=10)
generate_coverage_report: bool = True
webhook_url: Optional[str] = None
@field_validator("timeout_seconds")
@classmethod
def validate_engine_limit(cls, v: int) -> int:
if v > 600:
raise ValueError("CXone testing engine enforces a 600s maximum duration. Reduce timeout_seconds.")
return v
@field_validator("input_data")
@classmethod
def validate_mock_matrix(cls, v: Dict[str, Any]) -> Dict[str, Any]:
payload_bytes = json.dumps(v).encode("utf-8")
if len(payload_bytes) > 256 * 1024:
raise ValueError("Mock data matrix exceeds 256KB limit. Compress or simplify test inputs.")
return v
def to_api_format(self) -> Dict[str, Any]:
"testCaseId": self.test_case_id,
"inputData": self.input_data,
"assertions": [a.model_dump() for a in self.assertions],
"timeoutSeconds": self.timeout_seconds,
"generateCoverageReport": self.generate_coverage_report,
"webhookUrl": self.webhook_url
The ExecutePayload model enforces CXone engine constraints at the application layer. The timeout_seconds field caps at 600 seconds because the testing engine hard-fails executions that exceed this window. The input_data validator prevents oversized mock matrices that trigger gateway rejections. The to_api_format method maps Python snake_case to CXone camelCase expectations.
Step 2: Atomic POST Execution and Format Verification
Test run initiation requires an atomic POST operation. The CXone API expects a single request that returns an executionId. You must verify the response format immediately to confirm queue acceptance before polling for results.
import logging
logger = logging.getLogger("cxone.test.executor")
class TestExecutor:
def __init__(self, auth: CxoneAuth):
self.auth = auth
self.base_url = auth.base_url
self._client = httpx.Client(
timeout=httpx.Timeout(30.0, connect=10.0),
headers={"Content-Type": "application/json", "Accept": "application/json"},
transport=httpx.HTTPTransport(retries=3)
def initiate_execution(self, payload: ExecutePayload, flow_id: str) -> Dict[str, Any]:
endpoint = f"{self.base_url}/api/v2/testing/flows/{flow_id}/executions"
headers = {"Authorization": f"Bearer {self.auth.get_access_token()}"}
start_time = time.time()
response = self._client.post(
endpoint,
json=payload.to_api_format(),
headers=headers
self._log_audit("INITIATE", flow_id, payload.test_case_id, "SUCCESS", latency_ms)
retry_after = int(response.headers.get("Retry-After", 2))
logger.warning("Rate limited. Retrying in %ds", retry_after)
time.sleep(retry_after)
return self.initiate_execution(payload, flow_id)
result = response.json()
if "executionId" not in result:
raise ValueError("Unexpected response format: missing executionId")
return result
self._log_audit("INITIATE", flow_id, payload.test_case_id, "FAILED", 0)
logger.error("Execution initiation failed: %s", e.response.text)
raise
self._log_audit("INITIATE", flow_id, payload.test_case_id, "ERROR", 0)
logger.error("Unexpected error during initiation: %s", str(e))
raise
def _log_audit(self, action: str, flow_id: str, test_case_id: str, status: str, latency_ms: float):
audit_entry = {
"action": action,
"flow_id": flow_id,
"test_case_id": test_case_id,
"status": status,
"latency_ms": latency_ms
logger.info("AUDIT: %s", json.dumps(audit_entry))
The initiate_execution method performs an atomic POST to /api/v2/testing/flows/{flowId}/executions. The request includes the bearer token and the validated payload. A 429 response triggers an exponential backoff retry using the Retry-After header. The response is verified for the executionId field before proceeding. Audit logging captures initiation events for governance tracking.
Step 3: Execution Validation and Path Traversal Checking
After initiation, you must poll the execution status endpoint. The CXone testing engine processes flows asynchronously. You implement a polling loop with exponential backoff to check status, validate assertion results, and verify path traversal coverage.
def poll_execution(self, flow_id: str, execution_id: str, max_polls: int = 60) -> Dict[str, Any]:
endpoint = f"{self.base_url}/api/v2/testing/flows/{flow_id}/executions/{execution_id}"
for attempt in range(max_polls):
time.sleep(2 ** attempt) # Exponential backoff
response = self._client.get(endpoint, headers=headers)
status = data.get("status", "UNKNOWN")
logger.info("Execution %s status: %s", execution_id, status)
if status in ["COMPLETED", "FAILED", "CANCELLED"]:
return data
raise TimeoutError(f"Execution {execution_id} did not complete within {max_polls} polls")
def validate_path_traversal(self, execution_result: Dict[str, Any]) -> bool:
trace = execution_result.get("trace", [])
if not trace:
logger.warning("No path trace returned. Coverage validation skipped.")
return True
visited_nodes = {step.get("nodeId") for step in trace}
expected_paths = {"start", "route", "action", "end"}
coverage_ratio = len(visited_nodes & expected_paths) / len(expected_paths)
logger.info("Path coverage: %.2f%%", coverage_ratio * 100)
if coverage_ratio < 0.75:
logger.warning("Low path coverage detected. Review flow routing logic.")
return coverage_ratio >= 0.75
The poll_execution method queries /api/v2/testing/flows/{flowId}/executions/{executionId} with exponential backoff to respect CXone rate limits. The loop terminates on terminal statuses. The validate_path_traversal method analyzes the execution trace to verify that critical flow nodes were visited. This prevents deployment regressions by ensuring test cases exercise expected routing paths rather than short-circuiting on default branches.
Step 4: Webhook Synchronization and CI/CD Quality Gate Alignment
External CI/CD pipelines require synchronous quality gate signals. You deliver execution results to a webhook endpoint with standardized payloads. The webhook delivery uses idempotency keys and retry logic to guarantee alignment with deployment pipelines.
def deliver_webhook(self, webhook_url: str, payload: Dict[str, Any], execution_id: str) -> bool:
delivery_payload = {
"executionId": execution_id,
"result": payload,
"qualityGate": "PASS" if payload.get("status") == "COMPLETED" and payload.get("passed", True) else "FAIL"
for attempt in range(3):
with httpx.Client(timeout=10.0) as webhook_client:
resp = webhook_client.post(
webhook_url,
json=delivery_payload,
headers={"X-Idempotency-Key": execution_id, "Content-Type": "application/json"}
if resp.status_code in (200, 201):
logger.info("Webhook delivered successfully for %s", execution_id)
return True
logger.warning("Webhook delivery failed with %s. Retry %d", resp.status_code, attempt + 1)
logger.error("Webhook network error: %s", str(e))
logger.error("Webhook delivery exhausted retries for %s", execution_id)
return False
The deliver_webhook method sends a structured result to the CI/CD endpoint. The X-Idempotency-Key header prevents duplicate pipeline triggers if the CI server retries delivery. The qualityGate field provides a boolean signal for deployment gates. Three retry attempts with exponential backoff ensure delivery despite transient network failures.
The following module integrates authentication, validation, execution, polling, and webhook synchronization into a single reusable executor. Replace placeholder credentials before running.
import os
import httpx
import logging
import json
from typing import Dict, Any, List, Optional
class CxoneAuth:
def __init__(self, client_id: str, client_secret: str, region: str = "us-1"):
self.client_id = client_id
self.region = region
self._expires_at: float = 0.0
@property
return self._token
payload = {
return self._token
test_case_id: str
assertions: List[Dict[str, Any]]
"assertions": self.assertions,
class FlowTestExecutor:
self.auth = auth
self.metrics = {"total_runs": 0, "passed": 0, "failed": 0, "avg_latency_ms": 0.0}
def run_test(self, flow_id: str, test_case_id: str, mock_data: Dict[str, Any],
assertions: List[Dict[str, Any]], webhook_url: Optional[str] = None) -> Dict[str, Any]:
payload = ExecutePayload(
test_case_id=test_case_id,
input_data=mock_data,
assertions=assertions,
generate_coverage_report=True,
webhook_url=webhook_url
init_result = self._initiate_execution(payload, flow_id)
execution_id = init_result["executionId"]
self.metrics["total_runs"] += 1
logger.info("Initiated execution %s for flow %s", execution_id, flow_id)
result = self._poll_execution(flow_id, execution_id)
is_passed = result.get("status") == "COMPLETED" and result.get("passed", False)
if is_passed:
self.metrics["passed"] += 1
else:
self.metrics["failed"] += 1
self.metrics["avg_latency_ms"] = ((self.metrics["avg_latency_ms"] * (self.metrics["total_runs"] - 1)) + latency_ms) / self.metrics["total_runs"]
self._validate_path_traversal(result)
if webhook_url:
self._deliver_webhook(webhook_url, result, execution_id)
self._log_audit(result, latency_ms)
return result
def _initiate_execution(self, payload: ExecutePayload, flow_id: str) -> Dict[str, Any]:
response = self._client.post(endpoint, json=payload.to_api_format(), headers=headers)
return self._initiate_execution(payload, flow_id)
return response.json()
def _poll_execution(self, flow_id: str, execution_id: str, max_polls: int = 60) -> Dict[str, Any]:
if data.get("status") in ["COMPLETED", "FAILED", "CANCELLED"]:
return data
raise TimeoutError(f"Execution {execution_id} timed out")
def _validate_path_traversal(self, execution_result: Dict[str, Any]) -> None:
if not trace:
return
visited = {step.get("nodeId") for step in trace}
logger.info("Path traversal nodes visited: %s", visited)
def _deliver_webhook(self, webhook_url: str, result: Dict[str, Any], execution_id: str) -> None:
delivery = {
"status": result.get("status"),
"passed": result.get("passed"),
"qualityGate": "PASS" if result.get("passed") else "FAIL"
with httpx.Client(timeout=10.0) as client:
resp = client.post(webhook_url, json=delivery, headers={"X-Idempotency-Key": execution_id})
if resp.status_code not in (200, 201):
logger.warning("Webhook delivery failed: %s", resp.text)
def _log_audit(self, result: Dict[str, Any], latency_ms: float) -> None:
audit = {
"flow_id": result.get("flowId"),
"execution_id": result.get("executionId"),
"latency_ms": latency_ms,
"metrics": self.metrics
logger.info("AUDIT: %s", json.dumps(audit))
auth = CxoneAuth(
client_id=os.getenv("CXONE_CLIENT_ID"),
client_secret=os.getenv("CXONE_CLIENT_SECRET"),
region="us-1"
executor = FlowTestExecutor(auth)
test_result = executor.run_test(
flow_id="YOUR_FLOW_ID",
test_case_id="YOUR_TEST_CASE_ID",
mock_data={"caller_id": "+15550001234", "intent": "billing_inquiry", "priority": "high"},
assertions=[{"path": "$.outcome", "operator": "eq", "value": "success"}],
webhook_url="https://hooks.example.com/cxone/test-results"
print(json.dumps(test_result, indent=2))
Error: 400 Bad Request (Schema Validation Failure)
- Cause: The execute payload violates CXone testing engine constraints. Common triggers include
timeoutSecondsexceeding 600, malformed assertion paths, or oversizedinputDatamatrices. - Fix: Validate payloads locally before submission. Use the
ExecutePayloadmodel to enforce limits. Ensure assertion paths use valid JSONPath syntax ($.outcome,$.route.result). - Code Fix: The
ExecutePayloadclass includesfield_validatormethods that reject invalid configurations at instantiation.
- Cause: Expired OAuth token or missing scopes. CXone requires explicit
flow:testing:executeandflow:testing:readscopes. - Fix: Verify the OAuth client has the correct scopes assigned in the CXone Admin Console. Implement token caching with a refresh buffer. The
CxoneAuthclass handles automatic refresh before expiration.
- Cause: Rate limit cascade from rapid polling or concurrent test initiations. CXone enforces per-tenant and per-endpoint rate limits.
- Fix: Implement exponential backoff for polling and respect the
Retry-Afterheader on 429 responses. The_poll_executionand_initiate_executionmethods include backoff logic.
Error: 504 Gateway Timeout or Execution Timeout
- Cause: The flow execution exceeds the configured
timeoutSecondsor the testing engine queue is saturated. - Fix: Reduce
timeoutSecondsfor unit tests. Ensure mock data does not trigger external API calls that hang. Monitor thetracearray to identify blocking nodes. Adjust flow routing to avoid synchronous external dependencies during testing.
