Executing NICE CXone Data Actions Against Snowflake with Python
This tutorial delivers a production-ready Python module that triggers NICE CXone Data Actions to execute parameterized Snowflake queries, manages result pagination through cursor chunking, validates outputs against JSON schemas, and exposes execution metrics. It uses the CXone REST API for action invocation and snowflake-connector-python for warehouse interaction. The implementation covers Python.
- NICE CXone OAuth 2.0 Client Credentials flow configured with scopes:
data:actions:execute,data:actions:read - Snowflake account with an AWS IAM role attached to a database user or external OAuth provider
- Python 3.10 or higher
- External dependencies:
httpx,snowflake-connector-python,jsonschema,tenacity,boto3,pydantic - CXone Data Action ID targeting a Snowflake query template
- Snowflake warehouse with read permissions on
SNOWFLAKE.ACCOUNT_USAGE.QUERY_HISTORY
NICE CXone requires an OAuth 2.0 bearer token before invoking Data Actions. The token endpoint accepts client credentials and returns a short-lived access token. You must cache the token and refresh it before expiration to avoid 401 responses during long-running query batches.
import httpx
from typing import Optional
class CXoneAuthManager:
def __init__(self, tenant: str, client_id: str, client_secret: str):
self.base_url = f"https://{tenant}.my.cxone.com/api/v2"
self.client_id = client_id
self.token_expiry: float = 0
def get_token(self) -> str:
if self.token and time.time() < self.token_expiry - 60:
return self.token
url = f"{self.base_url}/oauth/token"
payload = {
"client_id": self.client_id,
"scope": "data:actions:execute data:actions:read"
response = httpx.post(url, data=payload)
response.raise_for_status()
data = response.json()
self.token = data["access_token"]
self.token_expiry = time.time() + data["expires_in"]
return self.token
Snowflake IAM role authentication bypasses static passwords by leveraging AWS STS temporary credentials. The Python connector accepts authenticator="EXTERNALBROWSER" which automatically resolves the attached IAM role. You must construct a JDBC-compatible connection string for system documentation, then translate it into connector parameters for execution.
from snowflake.connector import connect
from snowflake.connector.pooling import SessionPool
def build_jdbc_connection_string(account: str, region: str, role: str, aws_region: str) -> str:
return (
f"jdbc:snowflake://{account}.{region}.snowflakecomputing.com"
f"?authenticator=EXTERNALBROWSER"
f"&role={role}"
f"&aws_region={aws_region}"
f"&session_keep_alive=true"
f"&server_session_keep_alive=true"
def create_session_pool(account: str, region: str, role: str, aws_region: str, pool_size: int = 3) -> SessionPool:
jdbc_url = build_jdbc_connection_string(account, region, role, aws_region)
print(f"JDBC Reference: {jdbc_url}")
conn_kwargs = {
"account": f"{account}.{region}",
"authenticator": "EXTERNALBROWSER",
"role": role,
"warehouse": "COMPUTE_WH",
"database": "ANALYTICS_DB",
"schema": "PUBLIC",
"client_session_keep_alive": True
return SessionPool(conn_kwargs, min_size=2, max_size=pool_size)
Step 1: Session Pool Initialization and JDBC String Construction
The session pool maintains persistent TCP connections to the Snowflake warehouse, eliminating handshake latency for repeated Data Action invocations. You create the pool once at application startup and check out connections per request. The JDBC string construction serves as an auditable reference for infrastructure teams while the Python connector handles the actual network binding.
from typing import Any
from snowflake.connector.errors import DatabaseError
def checkout_connection(pool: SessionPool) -> Any:
conn = pool.checkout()
return conn
def release_connection(pool: SessionPool, conn: Any) -> None:
pool.checkin(conn)
Step 2: Dynamic Type Coercion and Chunked Cursor Execution
NICE CXone flow variables arrive as untyped JSON values. Snowflake requires explicit parameter binding to prevent injection and ensure dialect compliance. The coercion function maps Python primitives to Snowflake SQL types using native casting. You execute the query with a server-side cursor and fetch results in configurable chunks to prevent memory exhaustion during large dataset returns.
import json
from typing import Dict, Any, Iterator, List
from snowflake.connector.cursor import SnowflakeCursor
def coerce_flow_variable(value: Any) -> str:
if value is None:
return "NULL"
if isinstance(value, bool):
return "TRUE" if value else "FALSE"
if isinstance(value, int):
return f"TO_NUMBER('{value}')"
if isinstance(value, float):
if isinstance(value, str):
return f"'{value.replace(chr(39), chr(39)+chr(39))}'"
if isinstance(value, (list, dict)):
return f"PARSE_JSON('{json.dumps(value)}')"
return f"TO_VARCHAR('{value}')"
def execute_chunked_query(
cursor: SnowflakeCursor,
sql_template: str,
params: Dict[str, Any],
chunk_size: int = 5000
) -> Iterator[List[Dict[str, Any]]]:
param_names = ", ".join(params.keys())
param_values = ", ".join(coerce_flow_variable(v) for v in params.values())
final_sql = sql_template.replace(f"{{{param_names}}}", param_values)
cursor.execute(final_sql)
columns = [desc[0] for desc in cursor.description]
while True:
rows = cursor.fetchmany(chunk_size)
if not rows:
break
chunk = [dict(zip(columns, row)) for row in rows]
yield chunk
cursor.close()
Step 3: Retry Logic, Result Caching, and Cost Tracking
Warehouse suspension events occur when credit limits are reached or maintenance windows activate. You implement exponential backoff with jitter to handle transient suspension errors. Result caching reduces redundant warehouse scans by hashing the executed SQL and storing outputs locally. Materialized views improve performance by precomputing aggregations. You track execution costs by querying the SNOWFLAKE.ACCOUNT_USAGE.QUERY_HISTORY view immediately after execution.
import hashlib
from functools import lru_cache
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
from snowflake.connector.errors import OperationalError, ProgrammingError
@lru_cache(maxsize=128)
def cached_query_result(query_hash: str) -> List[Dict[str, Any]]:
raise KeyError("Cache miss")
def get_query_cost(conn: Any, query_id: str) -> Dict[str, Any]:
cursor = conn.cursor()
cursor.execute("""
SELECT
TOTAL_ELAPSED_TIME,
EXECUTION_STATUS,
BYTES_SCANNED,
CREDITS_USED_CLOUD_SERVICES,
CREDITS_USED_COMPUTE
FROM SNOWFLAKE.ACCOUNT_USAGE.QUERY_HISTORY
WHERE QUERY_ID = ?
LIMIT 1
""", (query_id,))
row = cursor.fetchone()
cursor.close()
if not row:
return {"status": "unknown", "elapsed_ms": 0, "bytes_scanned": 0}
"status": row[1],
"elapsed_ms": row[0],
"bytes_scanned": row[2],
"cloud_credits": row[3],
"compute_credits": row[4]
@retry(
stop=stop_after_attempt(4),
wait=wait_exponential(multiplier=2, min=4, max=30),
retry=retry_if_exception_type((OperationalError, ProgrammingError)),
reraise=True
def execute_with_retry_and_tracking(
pool: SessionPool,
sql_template: str,
conn = checkout_connection(pool)
query_hash = hashlib.sha256(f"{sql_template}:{json.dumps(params, sort_keys=True)}".encode()).hexdigest()
return {"source": "cache", "data": cached_query_result(query_hash)}
except KeyError:
pass
start_time = time.time()
chunks = list(execute_chunked_query(cursor, sql_template, params, chunk_size))
all_rows = [item for sublist in chunks for item in sublist]
cached_query_result(query_hash) # Populate cache for next run
cached_query_result.cache_info() # Force registration if needed
cached_query_result.cache_clear() # Reset for demo; use TTL in production
finally:
query_id = cursor.sfqid if hasattr(cursor, 'sfqid') else "UNKNOWN"
cost_metrics = get_query_cost(conn, query_id)
execution_time_ms = (time.time() - start_time) * 1000
"source": "warehouse",
"data": all_rows,
"profiler": {
"query_id": query_id,
"execution_time_ms": execution_time_ms,
"rows_returned": len(all_rows),
"cost_tracking": cost_metrics
finally:
release_connection(pool, conn)
Step 4: JSON Schema Validation and Profiler Exposure
Before returning data to the CXone flow, you validate the output against a predefined JSON schema. This prevents downstream parsing errors when flow variables expect specific structures. The profiler dictionary captures timing, row counts, query identifiers, and cost metrics for performance tuning dashboards.
import jsonschema
from jsonschema import validate, ValidationError
def validate_output_schema(data: List[Dict[str, Any]], schema: Dict[str, Any]) -> bool:
validate(instance=data, schema=schema)
return True
except ValidationError as err:
print(f"Schema validation failed: {err.message}")
return False
def invoke_cxone_data_action(
auth: CXoneAuthManager,
action_id: str,
payload: Dict[str, Any]
token = auth.get_token()
url = f"https://{auth.base_url.split('/')[2]}/api/v2/data/actions/{action_id}/execute"
headers = {
"Accept": "application/json"
response = httpx.post(url, headers=headers, json=payload)
return response.json()
The following script demonstrates the full execution pipeline. Replace placeholder credentials with your environment values. The script initializes authentication, creates a session pool, executes a parameterized query against a materialized view, validates the output, and prints the profiler metrics.
import os
import json
def main() -> None:
# Configuration
CXONE_TENANT = os.getenv("CXONE_TENANT")
CXONE_CLIENT_ID = os.getenv("CXONE_CLIENT_ID")
CXONE_CLIENT_SECRET = os.getenv("CXONE_CLIENT_SECRET")
ACTION_ID = os.getenv("CXONE_ACTION_ID")
SNOWFLAKE_ACCOUNT = os.getenv("SNOWFLAKE_ACCOUNT")
SNOWFLAKE_REGION = os.getenv("SNOWFLAKE_REGION")
SNOWFLAKE_ROLE = os.getenv("SNOWFLAKE_ROLE")
AWS_REGION = os.getenv("AWS_REGION")
# Initialize CXone Auth
auth_manager = CXoneAuthManager(CXONE_TENANT, CXONE_CLIENT_ID, CXONE_CLIENT_SECRET)
# Initialize Snowflake Session Pool
pool = create_session_pool(SNOWFLAKE_ACCOUNT, SNOWFLAKE_REGION, SNOWFLAKE_ROLE, AWS_REGION, pool_size=3)
# Define Query Template targeting a Materialized View
sql_template = """
/*+ MATERIALIZE */
SELECT CUSTOMER_ID, LIFETIME_VALUE, SEGMENT
FROM ANALYTICS_DB.PUBLIC.MTV_CUSTOMER_SEGMENTS
WHERE SEGMENT = {{segment_filter}}
AND LIFETIME_VALUE > {{min_value}}
# Flow Input Variables
flow_params = {
"segment_filter": "ENTERPRISE",
"min_value": 10000
# Execute with Retry, Caching, and Tracking
result = execute_with_retry_and_tracking(pool, sql_template, flow_params, chunk_size=2500)
# Define JSON Schema for Output Validation
output_schema = {
"type": "array",
"items": {
"type": "object",
"required": ["CUSTOMER_ID", "LIFETIME_VALUE", "SEGMENT"],
"properties": {
"CUSTOMER_ID": {"type": "string"},
"LIFETIME_VALUE": {"type": "number"},
"SEGMENT": {"type": "string"}
# Validate Output
is_valid = validate_output_schema(result["data"], output_schema)
print(f"Schema Valid: {is_valid}")
# Expose Profiler
profiler = result["profiler"]
print(f"Query ID: {profiler['query_id']}")
print(f"Execution Time: {profiler['execution_time_ms']:.2f} ms")
print(f"Rows Returned: {profiler['rows_returned']}")
print(f"Bytes Scanned: {profiler['cost_tracking']['bytes_scanned']}")
print(f"Compute Credits: {profiler['cost_tracking']['compute_credits']}")
# Trigger CXone Data Action with Validated Payload
action_payload = {
"variables": {
"customer_data": result["data"][:50],
"validation_status": "PASSED",
"execution_profiler": profiler
action_response = invoke_cxone_data_action(auth_manager, ACTION_ID, action_payload)
print(f"CXone Action Response: {action_response.get('status', 'UNKNOWN')}")
main()
Error: 401 Unauthorized on CXone Token Endpoint
- Cause: Incorrect client credentials, expired secret, or missing
client_credentialsgrant type in the CXone developer console configuration. - Fix: Verify the client ID and secret match the registered OAuth application. Ensure the
grant_typefield is exactlyclient_credentials. Check that the application has thedata:actions:executescope enabled. - Code Fix: Add explicit logging for the token response payload before raising the exception. Inspect
response.json().get("error_description")for account lockout messages.
Error: 429 Too Many Requests on Data Action Execution
- Cause: CXone enforces rate limits per tenant and per action ID. Rapid polling or unbounded concurrent executions trigger throttling.
- Fix: Implement exponential backoff on the
httpxclient. Add a retry decorator to theinvoke_cxone_data_actionfunction identical to the Snowflake retry logic. - Code Fix: Wrap the
httpx.postcall withtenacity.retrytargetinghttpx.HTTPStatusErrorwhereresponse.status_code == 429.
Error: Warehouse Suspended or Pausing
- Cause: The Snowflake warehouse exceeded credit limits, hit auto-suspend thresholds, or encountered platform maintenance.
- Fix: The
@retrydecorator inexecute_with_retry_and_trackinghandles this automatically. Verify the warehouse auto-resume setting is enabled. Increase thewait_exponentialmaximum interval if suspension events persist beyond thirty seconds. - Code Fix: Monitor the
cost_trackingoutput. Ifcompute_creditsapproaches your daily budget, adjust thechunk_sizeto reduce memory pressure or switch to a smaller warehouse size.
Error: JSON Schema Validation Mismatch
- Cause: The Snowflake query returned unexpected null values, type mismatches, or missing columns compared to the flow contract.
- Fix: Review the
ValidationErrormessage. Update the JSON schema to mark optional fields as non-required, or adjust the SQL template to useCOALESCEand explicitCASToperations. - Code Fix: Add a fallback transformation step that sanitizes null values before validation. Log the raw output alongside the schema error for rapid debugging.
