Executing NICE CXone Data Actions Against MongoDB with Node.js Aggregation Pipelines
- A CXone Studio Data Action that receives flow variables, constructs dynamic MongoDB aggregation pipelines, and returns validated results to the conversation flow.
- Uses the CXone Data Action Node.js runtime, Mongoose for connection pooling, and AJV for strict JSON Schema validation.
- Covers Node.js 18 LTS with async/await, circuit breaker patterns, structured audit logging, and query profiling for production deployment.
- CXone Studio environment with Data Actions enabled
- MongoDB cluster (Atlas or self-hosted) with a dedicated read/write database user
- CXone OAuth application with the
data_actions:executescope - Node.js runtime dependencies:
mongoose@8.x,ajv@8.x,ajv-formats@3.x,winston@3.x,uuid@9.x - CXone Flow configured to pass input variables to the Data Action
CXone Data Actions run in a sandboxed AWS Lambda environment. External database authentication bypasses CXone OAuth and relies on MongoDB credentials. You must store the MongoDB connection string in CXone Data Action environment variables to avoid hardcoding secrets.
The CXone platform invokes your Data Action via the following endpoint:
POST /api/v2/dataactions/{dataActionId}/execute
Host: api.mypurecloud.com
Authorization: Bearer <CXone_OAuth_Access_Token>
Required CXone OAuth scope: data_actions:execute
Request body structure:
"inputs": {
"customer_id": "1029384756",
"status_filter": "active",
"min_balance": 500,
"date_from": "2024-01-01T00:00:00.000Z"
Response structure:
"outputs": {
"records": [],
"execution_time_ms": 142,
"profiling_stats": {},
"audit_id": "a1b2c3d4-e5f6-7890-abcd-ef1234567890"
Step 1: Mongoose Connection Pooling and Schema Definition
Mongoose manages connection pooling automatically. You must configure timeout thresholds and disable command buffering to prevent Lambda cold starts from hanging.
const mongoose = require('mongoose');
// Configure connection behavior for serverless execution
mongoose.set('serverSelectionTimeoutMS', 5000);
mongoose.set('socketTimeoutMS', 45000);
mongoose.set('bufferCommands', false);
const MONGO_URI = process.env.MONGODB_URI || 'mongodb://localhost:27017/cxone_data';
async function getDbConnection() {
if (mongoose.connection.readyState === 1) {
return mongoose.connection;
await mongoose.connect(MONGO_URI, {
maxPoolSize: 5,
minPoolSize: 1,
maxIdleTimeMS: 30000,
retryWrites: true,
w: 'majority'
} catch (error) {
throw new Error(`MongoDB connection failed: ${error.message}`);
Step 2: Dynamic Type Coercion and Aggregation Pipeline Construction
CXone Flow variables arrive as strings. You must coerce them to native types before injecting them into MongoDB query operators. The pipeline builder accepts a configuration map that defines stage definitions and filter expressions.
function coerceType(value, targetType) {
if (value === null || value === undefined) return null;
if (targetType === 'number') {
const parsed = Number(value);
return Number.isNaN(parsed) ? value : parsed;
if (targetType === 'boolean') return value === 'true';
if (targetType === 'date') {
const parsed = new Date(value);
return isNaN(parsed.getTime()) ? value : parsed;
return value;
function buildAggregationPipeline(inputs, schemaConfig) {
const pipeline = [];
// Stage 1: Match filter with dynamic type coercion
const matchConditions = {};
for (const [key, config] of Object.entries(schemaConfig.filters)) {
const rawValue = inputs[key];
if (rawValue !== undefined && rawValue !== '') {
const coerced = coerceType(rawValue, config.type);
matchConditions[key] = config.operator === 'gte'
? { $gte: coerced }
: { $eq: coerced };
if (Object.keys(matchConditions).length > 0) {
pipeline.push({ $match: matchConditions });
// Stage 2: Lookup if referenced in config
if (schemaConfig.lookups) {
for (const lookup of schemaConfig.lookups) {
pipeline.push({
$lookup: {
localField: lookup.localField,
foreignField: lookup.foreignField,
as: lookup.as
// Stage 3: Projection
if (schemaConfig.projection) {
pipeline.push({ $project: schemaConfig.projection });
// Stage 4: Sort and Limit
if (schemaConfig.sort) {
pipeline.push({ $sort: schemaConfig.sort });
if (schemaConfig.limit) {
pipeline.push({ $limit: schemaConfig.limit });
return pipeline;
Step 3: Circuit Breaker and Retry Logic for Network Failures
Network timeouts and replica set elections require exponential backoff with a circuit breaker to prevent cascade failures. This implementation tracks failure counts and opens the circuit after three consecutive errors.
class CircuitBreaker {
constructor(options = {}) {
this.failureThreshold = options.failureThreshold || 3;
this.resetTimeout = options.resetTimeout || 10000;
this.maxRetries = options.maxRetries || 2;
this.failureCount = 0;
this.state = 'CLOSED';
this.lastFailureTime = null;
async execute(fn) {
if (this.state === 'OPEN') {
const elapsed = Date.now() - this.lastFailureTime;
if (elapsed < this.resetTimeout) {
throw new Error('Circuit breaker is OPEN. Waiting for reset timeout.');
this.state = 'HALF-OPEN';
let lastError;
for (let attempt = 0; attempt <= this.maxRetries; attempt++) {
const result = await fn();
this.onSuccess();
return result;
} catch (error) {
lastError = error;
this.onFailure();
if (attempt < this.maxRetries) {
const delay = Math.pow(2, attempt) * 1000;
throw lastError;
onSuccess() {
onFailure() {
this.failureCount++;
this.lastFailureTime = Date.now();
if (this.failureCount >= this.failureThreshold) {
this.state = 'OPEN';
Step 4: JSON Schema Validation and Audit Logging
You must validate aggregation results against a strict JSON Schema before returning them to the flow. Structured audit logging captures execution context, input hashes, and outcome for compliance.
const Ajv = require('ajv');
const addFormats = require('ajv-formats');
const winston = require('winston');
const { v4: uuidv4 } = require('uuid');
const ajv = new Ajv({ allErrors: true, strict: true });
addFormats(ajv);
const auditLogger = winston.createLogger({
level: 'info',
format: winston.format.json(),
transports: [new winston.transports.Console()]
function validateResponse(data, schema) {
const validate = ajv.compile(schema);
const valid = validate(data);
if (!valid) {
throw new Error(`JSON Schema validation failed: ${JSON.stringify(validate.errors)}`);
return true;
function logAuditTrail(auditId, inputs, success, error, executionTimeMs) {
auditLogger.info({
type: 'data_action_audit',
audit_id: auditId,
inputs_hash: Buffer.from(JSON.stringify(inputs)).toString('base64'),
success: success,
error: error ? error.message : null,
execution_time_ms: executionTimeMs
Step 5: Query Profiling and Metrics Tracking
MongoDB explain mode with executionStats provides diagnostic data. You must wrap aggregation execution with high-resolution timing to track performance metrics.
async function executeWithProfiling(collection, pipeline, profilerEnabled) {
const start = performance.now();
let profilingStats = {};
const results = await collection.aggregate(pipeline).toArray();
const end = performance.now();
const executionTimeMs = Math.round(end - start);
if (profilerEnabled) {
const explainResult = await collection.explain('executionStats').aggregate(pipeline);
profilingStats = {
totalDocsExamined: explainResult.stages?.[0]?.$cursor?.executionStats?.totalDocsExamined || 0,
executionTimeMs: explainResult.stages?.[0]?.$cursor?.executionStats?.executionTimeMillis || executionTimeMs,
indexUsed: explainResult.stages?.[0]?.$cursor?.executionStats?.executionStages?.inputStage?.indexPrefix || 'none'
return { results, executionTimeMs, profilingStats };
} catch (error) {
throw new Error(`Aggregation failed after ${Math.round(end - start)}ms: ${error.message}`);
Deploy this file as index.js in your CXone Data Action. Configure environment variables MONGODB_URI, DB_NAME, and COLLECTION_NAME in the CXone Studio Data Action settings.
// Initialize dependencies
addFormats(ajv);
level: 'info',
// Circuit Breaker Implementation
constructor() {
this.failureThreshold = 3;
this.resetTimeout = 10000;
this.maxRetries = 2;
async execute(fn) {
if (Date.now() - this.lastFailureTime < this.resetTimeout) {
let lastError;
return result;
} catch (error) {
lastError = error;
await new Promise(resolve => setTimeout(resolve, Math.pow(2, attempt) * 1000));
throw lastError;
const circuitBreaker = new CircuitBreaker();
// Type Coercion and Pipeline Builder
return value;
function buildAggregationPipeline(inputs) {
// Dynamic filter mapping with type coercion
if (inputs.customer_id) matchConditions.customer_id = { $eq: inputs.customer_id };
if (inputs.status_filter) matchConditions.status = { $eq: coerceType(inputs.status_filter, 'string') };
if (inputs.min_balance) matchConditions.balance = { $gte: coerceType(inputs.min_balance, 'number') };
if (inputs.date_from) matchConditions.created_at = { $gte: coerceType(inputs.date_from, 'date') };
pipeline.push({
$lookup: {
localField: '_id',
foreignField: 'customer_ref',
as: 'recent_transactions'
pipeline.push({ $project: { _id: 1, customer_id: 1, status: 1, balance: 1, recent_transactions: { $slice: ['$recent_transactions', 5] } } });
pipeline.push({ $sort: { created_at: -1 } });
pipeline.push({ $limit: 100 });
return pipeline;
// Validation Schema
const RESPONSE_SCHEMA = {
type: 'object',
required: ['records', 'execution_time_ms', 'profiling_stats', 'audit_id'],
properties: {
records: { type: 'array', items: { type: 'object' } },
execution_time_ms: { type: 'number', minimum: 0 },
profiling_stats: { type: 'object' },
audit_id: { type: 'string', format: 'uuid' }
additionalProperties: false
// Main Handler
exports.handler = async (event, context) => {
const auditId = uuidv4();
const inputs = event.inputs || {};
const profilerEnabled = inputs.enable_profiling === 'true';
const db = await mongoose.connect(process.env.MONGODB_URI || 'mongodb://localhost:27017/cxone_data', {
maxPoolSize: 5,
minPoolSize: 1,
const collection = db.collection(process.env.COLLECTION_NAME || 'customers');
const pipeline = buildAggregationPipeline(inputs);
const executeQuery = async () => {
const executionTimeMs = Math.round(performance.now() - start);
const explain = await collection.explain('executionStats').aggregate(pipeline);
profilingStats = {
totalDocsExamined: explain.stages?.[0]?.$cursor?.executionStats?.totalDocsExamined || 0,
executionTimeMs: explain.stages?.[0]?.$cursor?.executionStats?.executionTimeMillis || executionTimeMs,
indexUsed: explain.stages?.[0]?.$cursor?.executionStages?.inputStage?.indexPrefix || 'none'
const { results, executionTimeMs, profilingStats } = await circuitBreaker.execute(executeQuery);
const payload = {
records: results,
execution_time_ms: executionTimeMs,
profiling_stats: profilingStats,
audit_id: auditId
validateResponse(payload, RESPONSE_SCHEMA);
logAuditTrail(auditId, inputs, true, null, executionTimeMs);
return { outputs: payload };
} catch (error) {
logAuditTrail(auditId, inputs, false, error, 0);
context.log(`Data Action failed: ${error.message}`);
return { outputs: { error: error.message, audit_id: auditId } };
if (!validate(data)) {
auditLogger.info({
audit_id: auditId,
success: success,
Common Errors and Debugging
Error: MongooseServerSelectionError: Could not connect to any servers
- Cause: MongoDB cluster IP allow list blocks the CXone Lambda execution environment, or the connection string lacks authentication parameters.
- Fix: Add
0.0.0.0/0to your MongoDB Atlas network access list for testing, then restrict to CXone Lambda VPC endpoints in production. Verify the URI format matchesmongodb://<username>:<password>@<cluster-url>/<database>?retryWrites=true&w=majority.
Error: MongoTimeoutError: Server selection timed out after 5000ms
- Cause: Network latency between the Lambda region and your MongoDB cluster exceeds the configured timeout.
- Fix: Increase
socketTimeoutMSandserverSelectionTimeoutMSinmongoose.set(). Deploy the Data Action in the same AWS region as your MongoDB cluster to reduce cross-region latency.
Error: JSON Schema validation failed
- Cause: The aggregation pipeline returns a shape that does not match the defined
RESPONSE_SCHEMA. Missing required fields or incorrect data types trigger AJV validation failures. - Fix: Align the
$projectstage output with the schema properties. Use AJV error details to identify missing fields. Update the schema to allow optional fields if your pipeline conditionally excludes them.
Error: Circuit breaker is OPEN. Waiting for reset timeout.
- Cause: Three consecutive query failures triggered the circuit breaker state.
- Fix: Monitor the underlying MongoDB health. Check for replica set elections, primary stepdowns, or exhausted connection pools. The circuit will automatically transition to
HALF-OPENafter 10 seconds and test recovery on the next invocation.
