Executing NICE CXone Data Actions Against DynamoDB with Node.js
A production-grade CXone Data Action that queries DynamoDB using partition key conditions, conditional expressions, and pagination, then returns validated results back to the flow with full cost tracking and profiling.
This tutorial uses the AWS SDK for JavaScript v3 (@aws-sdk/client-dynamodb, @aws-sdk/util-dynamodb) within the NICE CXone Data Action runtime.
The implementation covers Node.js 18+ with strict type coercion, adaptive retry logic, JSON schema validation, and execution profiling.
  • Authorization: CXone Data Actions assume an IAM role. The attached role must contain dynamodb:Query, dynamodb:Scan, dynamodb:GetItem, cloudwatch:GetMetricData, and cloudwatch:PutMetricData. If triggering the Data Action via the CXone REST API, the data_actions:execute OAuth scope is required.
  • SDK Version: @aws-sdk/client-dynamodb@^3.500.0, @aws-sdk/util-dynamodb@^3.500.0, ajv@^8.12.0
  • Runtime: Node.js 18 LTS or higher (CXone Data Action environment supports Node 18+)
  • Dependencies: npm install @aws-sdk/client-dynamodb @aws-sdk/util-dynamodb ajv
CXone Data Actions do not use OAuth tokens for AWS service calls. The platform injects AWS credentials via environment variables (AWS_ACCESS_KEY_ID, AWS_SECRET_ACCESS_KEY, AWS_SESSION_TOKEN, AWS_REGION) when the Data Action executes. You must initialize the DynamoDB client using the default credential provider chain, which automatically reads these injected variables.
import { DynamoDBClient } from '@aws-sdk/client-dynamodb';
// CXone injects these environment variables at runtime
const dynamoDbClient = new DynamoDBClient({
  region: process.env.AWS_REGION || 'us-east-1',
  maxAttempts: 1, // Disabled in favor of custom adaptive backoff
The client uses the injected temporary credentials to sign requests. If credentials expire during a long-running scan, CXone automatically refreshes them before the next invocation. You must never hardcode credentials in the Data Action source.
Step 1: Client Initialization and Dynamic Type Coercion
DynamoDB requires explicit attribute type mapping in raw request objects. JavaScript values must be converted to DynamoDB format (S, N, BOOL, NULL, B, L, M). The following function handles dynamic type coercion while preserving nested structures.
 * Coerces JavaScript values to DynamoDB attribute format
 * @param {any} value - The input value from the CXone flow
 * @returns {object} DynamoDB formatted attribute
function coerceToDynamoType(value) {
  if (value === null || value === undefined) {
    return { NULL: true };
  if (typeof value === 'boolean') {
    return { BOOL: value };
  if (typeof value === 'number') {
    return { N: String(value) };
  if (typeof value === 'string') {
    return { S: value };
  if (Array.isArray(value)) {
    return { L: value.map(coerceToDynamoType) };
  if (typeof value === 'object') {
    const mapped = {};
    for (const [key, val] of Object.entries(value)) {
      mapped[key] = coerceToDynamoType(val);
    return { M: mapped };
  throw new Error(`Unsupported flow input type: ${typeof value}`);
This coercion function ensures that flow variables (which arrive as standard JSON) transform correctly into the low-level DynamoDB request format. You will use it when building ExpressionAttributeValues.
Step 2: Query Construction with Index Hints and Projection
You must construct the raw DynamoDB request object explicitly. This step demonstrates partition key targeting, conditional expressions, index selection, and projection expressions to reduce network payload and read capacity consumption.
function buildQueryRequest(
  tableName,
  partitionKeyName,
  partitionKeyValue,
  sortKeyName,
  sortKeyCondition,
  conditionalExpression,
  indexName,
  projectionAttributes
  const expressionAttributeNames = {
    '#pk': partitionKeyName,
    '#sk': sortKeyName,
  const expressionAttributeValues = {
    ':pkVal': coerceToDynamoType(partitionKeyValue),
  // Add sort key condition if provided
  if (sortKeyCondition) {
    expressionAttributeNames[':skCond'] = sortKeyCondition.operator;
    expressionAttributeValues[':skVal'] = coerceToDynamoType(sortKeyCondition.value);
  let keyConditionExpression = `#pk = :pkVal`;
    keyConditionExpression += ` AND #sk ${sortKeyCondition.operator} :skVal`;
  const request = {
    TableName: tableName,
    KeyConditionExpression: keyConditionExpression,
    ExpressionAttributeNames: expressionAttributeNames,
    ExpressionAttributeValues: expressionAttributeValues,
    ConsistentRead: true,
    ReturnConsumedCapacity: 'TOTAL',
  if (conditionalExpression) {
    request.ConditionExpression = conditionalExpression;
  if (indexName) {
    request.IndexName = indexName;
  if (projectionAttributes && projectionAttributes.length > 0) {
    const projNames = {};
    projectionAttributes.forEach((attr, idx) => {
      projNames[`#p${idx}`] = attr;
    request.ExpressionAttributeNames = { ...request.ExpressionAttributeNames, ...projNames };
    request.ProjectionExpression = Object.keys(projNames).join(', ');
  return request;
The ReturnConsumedCapacity: 'TOTAL' flag is required for cost tracking. The ProjectionExpression limits returned attributes, which directly reduces ReadCapacityUnits consumption. Index selection via IndexName avoids full table scans when querying secondary indexes.
Step 3: Pagination, Adaptive Retry, and Schema Validation
This step combines cursor-based pagination, exponential backoff with jitter for throttling, JSON schema validation, and execution profiling.
import Ajv from 'ajv';
import { QueryCommand } from '@aws-sdk/client-dynamodb';
import { unmarshall } from '@aws-sdk/util-dynamodb';
const ajv = new Ajv({ strict: true });
 * Adaptive backoff calculator with full jitter
 * @param {number} attempt - Current retry attempt
 * @returns {number} Delay in milliseconds
function calculateBackoff(attempt) {
  const baseDelay = 50;
  const maxDelay = 30000;
  const exponentialDelay = baseDelay * Math.pow(2, attempt);
  const jitter = Math.random() * exponentialDelay;
  return Math.min(Math.floor(exponentialDelay + jitter), maxDelay);
 * Executes paginated query with retry logic and validation
 * @param {object} client - DynamoDBClient instance
 * @param {object} requestParams - Built query parameters
 * @param {object} responseSchema - JSON Schema for validation
 * @returns {object} Profiler results and validated data
async function executeQueryWithPagination(client, requestParams, responseSchema) {
  const profiler = {
    startTime: Date.now(),
    totalRequests: 0,
    retryCount: 0,
    totalCapacityUnits: 0,
    totalItemsProcessed: 0,
    lastError: null,
  let allResults = [];
  let exclusiveStartKey = null;
  const validate = ajv.compile(responseSchema);
  while (true) {
    const commandParams = { ...requestParams };
    if (exclusiveStartKey) {
      commandParams.ExclusiveStartKey = exclusiveStartKey;
      const command = new QueryCommand(commandParams);
      const response = await client.send(command);
      profiler.totalRequests++;
      profiler.totalCapacityUnits += response.ConsumedCapacity?.CapacityUnits || 0;
      // Unmarshall and validate each batch
      const items = (response.Items || []).map(unmarshall);
      for (const item of items) {
        const isValid = validate(item);
        if (!isValid) {
          throw new Error(`Schema validation failed for item: ${JSON.stringify(validate.errors)}`);
        allResults.push(item);
      profiler.totalItemsProcessed += items.length;
      // Pagination cursor management
      if (response.LastEvaluatedKey) {
        exclusiveStartKey = response.LastEvaluatedKey;
      } else {
        break;
    } catch (error) {
      profiler.lastError = error;
      // Adaptive retry for ProvisionedThroughputExceeded
      if (error.code === 'ProvisionedThroughputExceeded' || error.name === 'ThrottlingException') {
        profiler.retryCount++;
        const delay = calculateBackoff(profiler.retryCount);
        continue;
      // Non-retryable errors
      throw error;
  profiler.endTime = Date.now();
  profiler.durationMs = profiler.endTime - profiler.startTime;
    data: allResults,
    profiler,
The LastEvaluatedKey cursor preserves pagination state across requests. The adaptive backoff uses full jitter to prevent thundering herd effects during capacity spikes. JSON schema validation occurs immediately after unmarshalling to reject malformed records before they reach the CXone flow.
// CXone Data Action entry point
exports.handler = async (event) => {
  const {
    tableName,
    partitionKeyName,
    partitionKeyValue,
    sortKeyName,
    sortKeyOperator,
    sortKeyValue,
    indexName,
    projectionAttributes,
    responseSchema,
  } = event;
    maxAttempts: 1,
  const sortKeyCondition = sortKeyName && sortKeyOperator && sortKeyValue
    ? { operator: sortKeyOperator, value: sortKeyValue }
    : null;
  const requestParams = buildQueryRequest(
    tableName,
    partitionKeyName,
    partitionKeyValue,
    sortKeyName,
    sortKeyCondition,
    indexName,
  const result = await executeQueryWithPagination(dynamoDbClient, requestParams, responseSchema);
    statusCode: 200,
    body: {
      records: result.data,
      executionMetrics: result.profiler,
// Helper functions from Steps 1-3
  if (value === null || value === undefined) return { NULL: true };
  if (typeof value === 'boolean') return { BOOL: value };
  if (typeof value === 'number') return { N: String(value) };
  if (typeof value === 'string') return { S: value };
  if (Array.isArray(value)) return { L: value.map(coerceToDynamoType) };
    const mapped = {};
function buildQueryRequest(tableName, partitionKeyName, partitionKeyValue, sortKeyName, sortKeyCondition, conditionalExpression, indexName, projectionAttributes) {
  const expressionAttributeNames = { '#pk': partitionKeyName, '#sk': sortKeyName };
  const expressionAttributeValues = { ':pkVal': coerceToDynamoType(partitionKeyValue) };
  const request = {
  if (conditionalExpression) request.ConditionExpression = conditionalExpression;
  if (indexName) request.IndexName = indexName;
    projectionAttributes.forEach((attr, idx) => { projNames[`#p${idx}`] = attr; });
  return request;
  const profiler = { startTime: Date.now(), totalRequests: 0, retryCount: 0, totalCapacityUnits: 0, totalItemsProcessed: 0, lastError: null };
  while (true) {
    if (exclusiveStartKey) commandParams.ExclusiveStartKey = exclusiveStartKey;
      const response = await client.send(new QueryCommand(commandParams));
        if (!validate(item)) {
          throw new Error(`Schema validation failed: ${JSON.stringify(validate.errors)}`);
      } else {
        break;
    } catch (error) {
        await new Promise(resolve => setTimeout(resolve, calculateBackoff(profiler.retryCount)));
        continue;
      throw error;
  return { data: allResults, profiler };
Deploy this module as a CXone Data Action. The flow passes JSON input matching the expected shape, and the Data Action returns validated records alongside execution metrics.
Error: ProvisionedThroughputExceeded
  • Cause: The table or index has reached its configured read capacity limit. Burst capacity is exhausted.
  • Fix: The adaptive backoff in calculateBackoff handles transient throttling. If throttling persists, increase the provisioned capacity, enable on-demand billing, or add a Limit parameter to cap request size.
  • Code Fix: Ensure maxAttempts: 1 is set on the client to prevent the SDK from overriding your custom retry loop. The continue statement in the catch block preserves pagination state across retries.
Error: ValidationException (KeyConditionExpression)
  • Cause: The partition key attribute name does not match the table schema, or the operator is invalid for the key type.
  • Fix: Verify that partitionKeyName matches the exact attribute name in DynamoDB. Only =, BEGINS_WITH, BETWEEN, and <, <=, >, >= are allowed on sort keys.
  • Code Fix: Add explicit logging of requestParams.KeyConditionExpression before execution. Use ExpressionAttributeNames to alias reserved words like Key or Type.
Error: Schema validation failed
  • Cause: The returned DynamoDB items do not match the JSON schema provided in the flow input.
  • Fix: Update the responseSchema in the CXone flow to match the actual table structure. Ensure ajv is configured with { strict: true } to catch type mismatches early.
  • Code Fix: The ajv.compile step runs once per invocation. If schema changes frequently, cache the validator in a module-level variable outside the handler.
