Hey everyone.
We are trying to sync agent state changes from Genesys Cloud to our internal WFM database using AWS EventBridge. The goal is to get real-time adherence data without polling the API every minute. We’ve set up the integration in Genesys Cloud under Integrations → Amazon EventBridge. The connection test passes, and we can see the events arriving in the CloudWatch logs.
The problem is the payload structure. The EventBridge rule triggers, but the detail object doesn’t have the agentId or state fields we need for our Lambda function. It looks like the generic platform event wrapper is stripping out the specific interaction data.
Here is the JSON payload we are receiving in the Lambda handler:
"version": "0",
"id": "a1b2c3d4-...")
"source": "genesys.cloud",
"account": "12345",
"time": "2023-10-27T08:00:00Z",
"region": "us-east-1",
"detail-type": "Genesys Cloud Event",
"resources": ["/api/v2/users/..."],
"detail": {
"eventType": "user.state.changed",
"timestamp": "2023-10-27T08:00:00Z"
We expected the detail object to contain the actual state change data, like userId, state, and teamId. Instead, it’s just the event type and timestamp. We’ve checked the Webhook configuration in Genesys Cloud, and we have enabled all available event types for user.state.changed.
Is there a specific setting in the EventBridge integration that controls payload depth? Or do we need to make a secondary API call to /api/v2/users/{userId} inside the Lambda to get the state? That feels inefficient if the event is supposed to be real-time.
We are using the standard AWS SDK for Python (boto3) to manage the EventBridge rules. The rule pattern is:
"source": ["genesys.cloud"],
"detail-type": ["Genesys Cloud Event"]
Any ideas on how to get the full payload? We don’t want to hit the API rate limits by fetching user details for every state change. It’s a high volume environment.
