Hi all,
Dealing with some weird latency on our EventBridge pipeline. We’ve got a Node.js Lambda handler processing conversation events via SQS. Normally it’s snappy, but during peak hours, we’re seeing a MASSIVE spike in the Dead Letter Queue.
The logic is simple: trigger from EventBridge, push to SQS, Lambda processes. We’ve already implemented exponential backoff to avoid hitting API rate limits - always a priority to keep the tenant healthy - but we’re still seeing events land in the DLQ with no clear reason.
Tried checking the event definitions via GET /api/v2/usage/events/definitions/{eventDefinitionId} to see if the schema changed, but nothing there. The Lambda isn’t crashing; it’s just timing out or getting throttled. I’ve bumped the memory to 1024MB and increased the concurrency limit, but the lag persists.
CloudWatch shows the events are arriving at the EventBridge rule, but the gap between the eventTime in the payload and the Lambda execution start is stretching to 30+ seconds.
"eventTime": "2023-10-27T14:20:01.123Z",
"eventType": "ConversationUpdate",
"errorMessage": "Task timed out after 3.01 seconds",
"awsRequestId": "c688-4b12-8d34-efg567",
"stack": "TimeoutError: execution exceeded allocated timeout"
We’re following security best practices by using IAM roles with least-privilege access, but I’m wondering if there’s some hidden throttle on the EventBridge side for specific event types. Just a reminder to everyone: don’t use long-lived credentials in your Lambda env vars.
The logs show the function is just hanging before it even attempts the first API call.
