EventBridge Lambda concurrency spikes on Genesys interaction events
Spiking Lambda concurrency to the max during peak hours. The EventBridge rule is catching interaction events from Genesys Cloud, but the batch size seems inconsistent. I’ve got a simple handler that just logs and puts to SQS for async processing.
export const handler = async (event: EventBridgeEvent<GenesysInteraction, any>) => {
 const records = event.detail?.records || [];
 const promises = records.map(r => sqs.send({ Message: JSON.stringify(r) }));
 return Promise.all(promises);
The issue is that EventBridge retries on 429s from SQS, which causes the Lambda to scale out aggressively. I’m hitting the account concurrency limit. Is there a way to configure the EventBridge target to throttle or batch differently? Or should I be using a different pattern for high-volume interaction streams?
