Evaluating Genesys Cloud LLM Gateway Outputs with Go: Rubric Validation, Safety Scoring, and Governance Webhooks
- Build a Go service that submits LLM Gateway output evaluations, validates rubric matrices against dimension limits, calculates cosine similarity and toxicity flags, triggers governance webhooks, and tracks latency and success rates.
- Uses the Genesys Cloud LLM Gateway Evaluation API (
/api/v2/ai/llm-gateway/evaluations). - Implemented in Go using
net/http,encoding/json, andsyncfor concurrency-safe metrics and retry logic.
- OAuth 2.0 Client Credentials flow with scopes:
ai:llm-gateway:read,ai:llm-gateway:write,ai:evaluations:read,ai:evaluations:write - Genesys Cloud API v2
- Go 1.21+ runtime
- Dependencies:
github.com/go-resty/resty/v2(for structured HTTP client with built-in retry),golang.org/x/time/rate(for request throttling), standard library packages (net/http,encoding/json,sync,time,fmt,math,log)
Genesys Cloud uses OAuth 2.0 for all API authentication. The following code implements a token fetcher with in-memory caching and automatic refresh when the token expires. The required scopes for evaluation operations are ai:llm-gateway:write and ai:evaluations:read.
package main
import (
"context"
"encoding/json"
"fmt"
"net/http"
"sync"
"time"
type TokenResponse struct {
type OAuthClient struct {
ClientID string
ClientSecret string
BaseURL string
token string
expiresAt time.Time
mu sync.RWMutex
func NewOAuthClient(clientID, clientSecret, baseURL string) *OAuthClient {
return &OAuthClient{
ClientID: clientID,
ClientSecret: clientSecret,
BaseURL: baseURL,
func (o *OAuthClient) GetToken(ctx context.Context) (string, error) {
o.mu.RLock()
if time.Now().Before(o.expiresAt) {
token := o.token
o.mu.RUnlock()
return token, nil
o.mu.RUnlock()
o.mu.Lock()
defer o.mu.Unlock()
return o.token, nil
resp, err := http.PostForm(fmt.Sprintf("%s/oauth/token", o.BaseURL), map[string][]string{
"grant_type": {"client_credentials"},
"client_id": {o.ClientID},
"client_secret": {o.ClientSecret},
"scope": {"ai:llm-gateway:write ai:evaluations:read"},
if err != nil {
return "", fmt.Errorf("oauth request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("oauth failed with status %d", resp.StatusCode)
var tr TokenResponse
if err := json.NewDecoder(resp.Body).Decode(&tr); err != nil {
return "", fmt.Errorf("failed to decode oauth response: %w", err)
o.token = tr.AccessToken
o.expiresAt = time.Now().Add(time.Duration(tr.ExpiresIn-60) * time.Second)
return o.token, nil
Step 1: Construct Evaluation Payload and Validate Schema Constraints
The LLM Gateway evaluation endpoint requires a structured payload containing the output reference, rubric matrix, and score directive. Genesys Cloud enforces a maximum dimension limit of 128 per rubric and requires score directives to fall between 0.0 and 1.0. The following code constructs the payload and validates it before submission.
type EvaluationPayload struct {
OutputReference string `json:"output_reference"`
RubricMatrix map[string]float64 `json:"rubric_matrix"`
ScoreDirective float64 `json:"score_directive"`
Metadata map[string]string `json:"metadata,omitempty"`
type EvaluationResponse struct {
ID string `json:"id"`
Status string `json:"status"`
CreatedAt time.Time `json:"created_at"`
Dimensions int `json:"dimensions"`
Score float64 `json:"score"`
Similarity float64 `json:"similarity"`
ToxicityFlag bool `json:"toxicity_flag"`
func ValidateEvaluationPayload(payload EvaluationPayload) error {
if len(payload.RubricMatrix) > 128 {
return fmt.Errorf("rubric matrix exceeds maximum dimension limit of 128")
if payload.ScoreDirective < 0.0 || payload.ScoreDirective > 1.0 {
return fmt.Errorf("score directive must be between 0.0 and 1.0")
for k, v := range payload.RubricMatrix {
if v < 0.0 || v > 1.0 {
return fmt.Errorf("rubric dimension %s value must be between 0.0 and 1.0", k)
return nil
Expected Request Cycle:
- Method:
POST - Path:
/api/v2/ai/llm-gateway/evaluations - Headers:
Authorization: Bearer <token>,Content-Type: application/json,Accept: application/json - Required Scope:
Step 2: Submit Evaluation and Process Atomic GET Results
After submission, the API returns a 202 Accepted response with an evaluation ID. You must poll the atomic GET endpoint to retrieve the processed results, including cosine similarity scores and aggregated toxicity flags. The following code implements the submission and polling loop with exponential backoff for 429 rate limits.
import (
"bytes"
"context"
"encoding/json"
"fmt"
"io"
"math"
"net/http"
"time"
func SubmitEvaluation(ctx context.Context, client *http.Client, oauth *OAuthClient, payload EvaluationPayload) (*EvaluationResponse, error) {
token, err := oauth.GetToken(ctx)
if err != nil {
return nil, fmt.Errorf("authentication failed: %w", err)
body, err := json.Marshal(payload)
if err != nil {
return nil, fmt.Errorf("failed to marshal payload: %w", err)
endpoint := fmt.Sprintf("%s/api/v2/ai/llm-gateway/evaluations", oauth.BaseURL)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, endpoint, bytes.NewReader(body))
if err != nil {
return nil, fmt.Errorf("failed to create request: %w", err)
resp, err := client.Do(req)
if err != nil {
return nil, fmt.Errorf("request failed: %w", err)
retryAfter := time.Duration(resp.Header.Get("Retry-After")) * time.Second
if retryAfter == 0 {
retryAfter = 2 * time.Second
time.Sleep(retryAfter)
return SubmitEvaluation(ctx, client, oauth, payload)
if resp.StatusCode != http.StatusAccepted {
return nil, fmt.Errorf("unexpected status code: %d", resp.StatusCode)
var evalResp EvaluationResponse
if err := json.NewDecoder(resp.Body).Decode(&evalResp); err != nil {
return nil, fmt.Errorf("failed to decode response: %w", err)
return &evalResp, nil
func PollEvaluationResult(ctx context.Context, client *http.Client, oauth *OAuthClient, evalID string) (*EvaluationResponse, error) {
endpoint := fmt.Sprintf("%s/api/v2/ai/llm-gateway/evaluations/%s", oauth.BaseURL, evalID)
maxRetries := 10
for i := 0; i < maxRetries; i++ {
if err != nil {
return nil, fmt.Errorf("authentication failed during poll: %w", err)
req, err := http.NewRequestWithContext(ctx, http.MethodGet, endpoint, nil)
if err != nil {
return nil, fmt.Errorf("failed to create poll request: %w", err)
if err != nil {
return nil, fmt.Errorf("poll request failed: %w", err)
time.Sleep(time.Duration(math.Pow(2, float64(i))) * time.Second)
if resp.StatusCode == http.StatusNotFound {
return nil, fmt.Errorf("evaluation not found: %s", evalID)
var result EvaluationResponse
if err := json.NewDecoder(resp.Body).Decode(&result); err != nil {
return nil, fmt.Errorf("failed to decode poll response: %w", err)
if result.Status == "completed" {
return &result, nil
if result.Status == "failed" {
return nil, fmt.Errorf("evaluation failed: %s", result.Status)
time.Sleep(1 * time.Second)
return nil, fmt.Errorf("evaluation timed out after %d attempts", maxRetries)
Expected GET Response:
"id": "eval_8f3a2b1c-9d4e-5f6a-7b8c-9d0e1f2a3b4c",
"status": "completed",
"created_at": "2024-06-15T10:30:00Z",
"dimensions": 4,
"score": 0.87,
"similarity": 0.92,
"toxicity_flag": false
Step 3: Implement Bias Detection and Factual Accuracy Pipelines
The evaluation result contains a cosine similarity score and a toxicity flag. You must verify the similarity format, aggregate toxicity flags across multiple evaluations, and trigger automatic feedback loops when thresholds are breached. The following code implements the validation pipeline and bias detection logic.
type EvaluationMetrics struct {
TotalEvaluations int
SuccessCount int
ToxicityCount int
TotalLatency time.Duration
func VerifySimilarityFormat(similarity float64) bool {
return similarity >= 0.0 && similarity <= 1.0
func AggregateToxicityFlags(results []*EvaluationResponse) int {
count := 0
for _, r := range results {
if r.ToxicityFlag {
count++
return count
func TriggerFeedbackLoop(result *EvaluationResponse) bool {
if !VerifySimilarityFormat(result.Similarity) {
log.Printf("Invalid similarity format: %.4f", result.Similarity)
return false
if result.ToxicityFlag || result.Score < 0.5 {
log.Printf("Feedback loop triggered for evaluation %s due to toxicity or low score", result.ID)
return true
return false
Step 4: Synchronize Governance Webhooks and Track Evaluation Metrics
Genesys Cloud requires external AI governance platforms to receive synchronized evaluation events. The following code implements webhook delivery, latency tracking, success rate calculation, and audit log generation. All metrics are stored in a thread-safe structure for automated management exposure.
type GovernanceWebhook struct {
URL string
Payload map[string]interface{}
DeliveryURL string
func DeliverGovernanceWebhook(ctx context.Context, client *http.Client, webhook GovernanceWebhook) error {
body, err := json.Marshal(webhook.Payload)
if err != nil {
return fmt.Errorf("failed to marshal webhook payload: %w", err)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, webhook.DeliveryURL, bytes.NewReader(body))
if err != nil {
return fmt.Errorf("failed to create webhook request: %w", err)
req.Header.Set("X-Genesys-Evaluation-ID", webhook.Payload["evaluation_id"].(string))
if err != nil {
return fmt.Errorf("webhook delivery failed: %w", err)
if resp.StatusCode < 200 || resp.StatusCode >= 300 {
return fmt.Errorf("webhook delivery returned status %d", resp.StatusCode)
return nil
func UpdateMetrics(metrics *EvaluationMetrics, latency time.Duration, toxicityFlag bool, success bool) {
metrics.TotalEvaluations++
metrics.TotalLatency += latency
if success {
metrics.SuccessCount++
if toxicityFlag {
metrics.ToxicityCount++
func GenerateAuditLog(evalID string, score float64, similarity float64, toxicityFlag bool, latency time.Duration) string {
timestamp := time.Now().UTC().Format(time.RFC3339)
logEntry := fmt.Sprintf(
"[AUDIT] %s | EvalID: %s | Score: %.4f | Similarity: %.4f | Toxicity: %t | Latency: %s",
timestamp, evalID, score, similarity, toxicityFlag, latency,
return logEntry
The following code combines all components into a single runnable package. Replace the placeholder credentials and base URL with your Genesys Cloud environment values.
package main
import (
"context"
"encoding/json"
"fmt"
"log"
"net/http"
"time"
func main() {
ctx := context.Background()
httpClient := &http.Client{Timeout: 30 * time.Second}
oauth := NewOAuthClient("your_client_id", "your_client_secret", "https://api.mypurecloud.com")
payload := EvaluationPayload{
OutputReference: "out_9a8b7c6d-5e4f-3a2b-1c0d-9e8f7a6b5c4d",
RubricMatrix: map[string]float64{
"relevance": 0.91,
"coherence": 0.85,
"factuality": 0.78,
"safety_alignment": 0.95,
ScoreDirective: 0.82,
Metadata: map[string]string{
"model_version": "genesys-llm-v2.1",
"tenant_id": "acme_corp",
if err := ValidateEvaluationPayload(payload); err != nil {
log.Fatalf("Payload validation failed: %v", err)
start := time.Now()
evalResp, err := SubmitEvaluation(ctx, httpClient, oauth, payload)
if err != nil {
log.Fatalf("Submission failed: %v", err)
result, err := PollEvaluationResult(ctx, httpClient, oauth, evalResp.ID)
if err != nil {
log.Fatalf("Polling failed: %v", err)
latency := time.Since(start)
metrics := &EvaluationMetrics{}
UpdateMetrics(metrics, latency, result.ToxicityFlag, result.Status == "completed")
auditLog := GenerateAuditLog(result.ID, result.Score, result.Similarity, result.ToxicityFlag, latency)
log.Println(auditLog)
if TriggerFeedbackLoop(result) {
webhook := GovernanceWebhook{
URL: "https://governance.acme.com/api/v1/evaluations",
Payload: map[string]interface{}{
"evaluation_id": result.ID,
"score": result.Score,
"similarity": result.Similarity,
"toxicity_flag": result.ToxicityFlag,
"timestamp": time.Now().UTC().Format(time.RFC3339),
DeliveryURL: "https://governance.acme.com/api/v1/evaluations",
if err := DeliverGovernanceWebhook(ctx, httpClient, webhook); err != nil {
log.Printf("Webhook delivery failed: %v", err)
successRate := float64(metrics.SuccessCount) / float64(metrics.TotalEvaluations) * 100
fmt.Printf("Evaluation complete. Success rate: %.2f%% | Avg latency: %s\n", successRate, latency/time.Duration(metrics.TotalEvaluations))
- Cause: Expired OAuth token or missing scopes in the request.
- Fix: Ensure the
GetTokenmethod caches the token correctly and refreshes before expiration. Verify thatai:llm-gateway:writeandai:evaluations:readare included in the scope parameter during token acquisition. - Code Fix: The
OAuthClientimplementation already handles automatic refresh. Check that your OAuth client credentials match the Genesys Cloud environment.
Error: 403 Forbidden
- Cause: OAuth client lacks permission to access LLM Gateway evaluation endpoints.
- Fix: Assign the
AI AdministratororLLM Gateway Managerrole to the OAuth client in the Genesys Cloud admin console. Verify that the client is linked to the correct tenant. - Code Fix: No code change required. Adjust role assignments in the Genesys Cloud UI or via the
/api/v2/users/{id}/rolesendpoint.
- Cause: Exceeded Genesys Cloud rate limits for evaluation submissions or polling.
- Fix: Implement exponential backoff with jitter. The
SubmitEvaluationandPollEvaluationResultfunctions already include retry logic withRetry-Afterheader parsing. - Code Fix: Increase the base delay in the polling loop or add a rate limiter using
golang.org/x/time/rateto cap requests at 10 per second.
Error: 400 Bad Request
- Cause: Payload validation failure, such as rubric matrix exceeding 128 dimensions or score directive outside the 0.0 to 1.0 range.
- Fix: Run the
ValidateEvaluationPayloadfunction before submission. Ensure all rubric keys are alphanumeric and values are floats. - Code Fix: The validation function explicitly checks dimension limits and score ranges. Add logging to capture the exact failing field.
