We installed the solution Genesys Express 4.5 with MSSQL Server 2005 on Windows 2003 Enterprise SP3.
Since it was created incorrectly in the DMA a number of variables to store historical data (these variables were created several times with the same name) is not being transferred data and therefore have no historical data from that day.
We eliminated these variables in DMA and in the tables and views in the database ETL and ODS. Now we get the following error in the log of ETL.
Starter: Process [ETL_Trans_Only] is still running [PID=704], skipping the start point Fri Oct 29 21:09:00 2010
Starter: Fri Oct 29 21:09:00 2010 [ETL_Trans_Only] will be started on Fri Oct 29 21:10:00 2010 start in 60 seconds
Starter: Waiting for process [ETL_Trans_Only] to exitâŚ
Starter: Process [ETL_Trans_Only] has terminated with exit code 5
Starter: Starting âETL_Trans_Onlyâ on Fri Oct 29 21:10:00 2010
Starter: Current directory is set to .
Starter: Executing "java -jar transform.jar -conf etl.properties -jdbcurl=jdbc:jtds:sqlserver://genesys01:1433;DatabaseName=ETL -user=genesys -passEncrypted="
Starter: Pipe 300 â\.\pipe\063760000107748_CCAâ and Event 208 created for ETL_Trans_Only
Starter: waiting for a client to connect to the pipe 300.
Starter: client connected to the pipe 300.
Starter: Fri Oct 29 21:10:00 2010 [ETL_Trans_Only] will be started on Fri Oct 29 21:11:00 2010 start in 60 seconds
ETL_Trans_Only: Time Origin Message
ETL_Trans_Only: ------------ -------------------------- ----------------------------------------
ETL_Trans_Only: 21:10:00.990 Main ETL Runtime, Version: 7.2.002.02, Build: 2006/10/23 12:34 (C) Copyright 1994-2005 Genesys Telecommunications Laboratories, Inc.
ETL_Trans_Only*:* 21:10:01.194 Main.Env Runtime info: {java.runtime.name=Java⢠2 Runtime Environment, Standard Edition, sun.boot.library.path=C:\GCTI\MCR\jre\bin, java.vm.version=1.4.2_14-b05, java.vm.vendor=Sun Microsystems Inc., java.vendor.url=http://java.sun.com/, path.separator=;, java.vm.name=Java HotSpot⢠Client VM, file.encoding.pkg=sun.io, user.country=ES, sun.os.patch.level=Service Pack 2, java.vm.specification.name=Java Virtual Machine Specification, user.dir=C:\GCTI\CC_Analyzer\etl_runtime, java.runtime.version=1.4.2_14-b05, java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment, java.endorsed.dirs=C:\GCTI\MCR\jre\lib\endorsed, os.arch=x86, java.io.tmpdir=C:\WINDOWS\TEMP, line.separator=, java.vm.specification.vendor=Sun Microsystems Inc., user.variant=, os.name=Windows 2003, sun.java2d.fontpath=, java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\system32;C:\WINDOWS;C:\Program Files\HP\NCU;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Microsoft SQL Server\80\Tools\Binn;C:\Program Files\Microsoft SQL Server\90\DTS\Binn;C:\Program Files\Microsoft SQL Server\90\Tools\binn;C:\Program Files\Microsoft SQL Server\90\Tools\Binn\VSShell\Common7\IDE;C:\Program Files\Microsoft Visual Studio 8\Common7\IDE\PrivateAssemblies;C:\Program Files\Java\jdk1.5.0_12\jre\bin\server, java.specification.name=Java Platform API Specification, java.class.version=48.0, java.util.prefs.PreferencesFactory=java.util.prefs.WindowsPreferencesFactory, os.version=5.2, user.home=C:\WINDOWS\system32\config\systemprofile, user.timezone=Europe/Paris, java.awt.printerjob=sun.awt.windows.WPrinterJob, file.encoding=Cp1252, java.specification.version=1.4, java.class.path=transform.jar, user.name=SYSTEM, java.vm.specification.version=1.0, java.home=C:\GCTI\MCR\jre, sun.arch.data.model=32, user.language=es, java.specification.vendor=Sun Microsystems Inc., awt.toolkit=sun.awt.windows.WToolkit, java.vm.info=mixed mode, java.version=1.4.2_14, java.ext.dirs=C:\GCTI\MCR\jre\lib\ext, sun.boot.class.path=C:\GCTI\MCR\jre\lib\rt.jar;C:\GCTI\MCR\jre\lib\i18n.jar;C:\GCTI\MCR\jre\lib\sunrsasign.jar;C:\GCTI\MCR\jre\lib\jsse.jar;C:\GCTI\MCR\jre\lib\jce.jar;C:\GCTI\MCR\jre\lib\charsets.jar;C:\GCTI\MCR\jre\classes, java.vendor=Sun Microsystems Inc., file.separator=, java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi, sun.io.unicode.encoding=UnicodeLittle, sun.cpu.endian=little, sun.cpu.isalist=pentium i486 i386}
ETL_Trans_Only*:* 21:10:01.194 Main.Options Options: {jdbcurl=jdbc:jtds:sqlserver://genesys01:1433;DatabaseName=ETL, user=genesys, passEncrypted=7F7245B9D06A87A6}
ETL_Trans_Only*:* 21:10:01.210 Main TRANSFORM started
ETL_Trans_Only*:* 21:10:01.492 Write.Heartbeat Pulse: 2010/10/29, CEST, 900, 1.9M
ETL_Trans_Only*:* 21:10:01.523 LFolder Connected database: Microsoft SQL Server, version: 09.00.3042, driver: 1.2
ETL_Trans_Only*:* 21:10:01.853 LFolder views OK in LayoutFolder[l:1_1,f:1]
ETL_Trans_Only*:* 21:10:01.853 LFolder views OK in LayoutFolder[l:1_10,f:10]
ETL_Trans_Only*:* 21:10:01.868 LFolder views OK in LayoutFolder[l:1_11,f:11]
ETL_Trans_Only*:* 21:10:01.884 LFolder views OK in LayoutFolder[l:1_12,f:12]
ETL_Trans_Only*:* 21:10:01.884 LFolder views OK in LayoutFolder[l:1_13,f:13]
ETL_Trans_Only*:* 21:10:01.884 LFolder views OK in LayoutFolder[l:1_14,f:14]
ETL_Trans_Only*:* 21:10:01.900 LFolder views OK in LayoutFolder[l:1_15,f:15]
ETL_Trans_Only*:* 21:10:01.900 LFolder views OK in LayoutFolder[l:1_16,f:41]
ETL_Trans_Only*:* 21:10:01.915 LFolder views OK in LayoutFolder[l:1_17,f:42]
ETL_Trans_Only*:* 21:10:01.915 LFolder views OK in LayoutFolder[l:1_18,f:43]
ETL_Trans_Only*:* 21:10:01.931 LFolder views OK in LayoutFolder[l:1_2,f:2]
ETL_Trans_Only*:* 21:10:01.947 LFolder views OK in LayoutFolder[l:1_3,f:3]
ETL_Trans_Only*:* 21:10:01.963 LFolder views OK in LayoutFolder[l:1_4,f:4]
ETL_Trans_Only*:* 21:10:01.963 LFolder views OK in LayoutFolder[l:1_5,f:5]
ETL_Trans_Only*:* 21:10:01.978 LFolder views OK in LayoutFolder[l:1_6,f:6]
ETL_Trans_Only*:* 21:10:01.978 LFolder views OK in LayoutFolder[l:1_7,f:7]
ETL_Trans_Only*:* 21:10:01.994 LFolder views OK in LayoutFolder[l:1_8,f:8]
ETL_Trans_Only*:* 21:10:01.994 LFolder views OK in LayoutFolder[l:1_9,f:9]
ETL_Trans_Only*:* 21:10:02.010 Source.SourceDef starting monitoring: DatabaseAccessPoint[ name:source#1, ConnectObject[ url:jdbc:jtds:sqlserver://genesys01:1433;DatabaseName=ODS, user: genesys, pass: ***** ] ], Database: Microsoft SQL Server, Version: 09.00.3042, Driver: 1.2
ETL_Trans_Only*:* 21:10:02.966 Thread.DstChunkWritersManager caught an exception. Monitor: Writer#1 Message: Writer#1: unable to execute command: WRITE
ETL_Trans_Only*:* SQLState: 42S22
ETL_Trans_Only*:* Vendor: 207
ETL_Trans_Only*:* Stack Trace:
ETL_Trans_Only*:* java.sql.BatchUpdateException: Invalid column name âSLR_ENTERED_CIU_1â.
ETL_Trans_Only*:* at net.sourceforge.jtds.jdbc.JtdsStatement.executeBatch(JtdsStatement.java:901)
ETL_Trans_Only*:* at ETL.Writer.ChunkWriterJob.doInsertData(Unknown Source)
ETL_Trans_Only*:* at ETL.Writer.ChunkWriterJob.processChunks(Unknown Source)
ETL_Trans_Only*:* at ETL.Writer.ChunkWriterJob.perform(Unknown Source)
ETL_Trans_Only*:* at ETL.Writer.WriterMonitor.executeCommand(Unknown Source)
ETL_Trans_Only*:* at ETL.Threads.BasicMonitor.run(Unknown Source)
ETL_Trans_Only*:* at java.lang.Thread.run(Unknown Source)
ETL_Trans_Only*:* Caused by:
ETL_Trans_Only*:* java.sql.SQLException: Invalid column name âSLR_ENTERED_CIU_2â.
ETL_Trans_Only*:* at net.sourceforge.jtds.jdbc.SQLDiagnostic.addDiagnostic(SQLDiagnostic.java:365)
ETL_Trans_Only*:* at net.sourceforge.jtds.jdbc.TdsCore.tdsErrorToken(TdsCore.java:2781)
ETL_Trans_Only*:* at net.sourceforge.jtds.jdbc.TdsCore.nextToken(TdsCore.java:2224)
ETL_Trans_Only*:* at net.sourceforge.jtds.jdbc.TdsCore.getBatchCounts(TdsCore.java:1435)
ETL_Trans_Only*:* at net.sourceforge.jtds.jdbc.JtdsStatement.executeBatch(JtdsStatement.java:880)
ETL_Trans_Only*:* java.sql.SQLException: Invalid column name âSLR_ENTERED_CIUâ.
ETL_Trans_Only*:* java.sql.SQLException: Invalid column name âSLR_ABAND_CIU_1â.
ETL_Trans_Only*:* java.sql.SQLException: Invalid column name âSLR_ABAND_CIUâ.
ETL_Trans_Only*:* java.sql.SQLException: Invalid column name âSLR_T_ANSW_CIUâ.
What could we do to solve the problem?
Thanks for your help
