Enriching Genesys Cloud Interaction Contexts with Third-Party CRM Data Using EventBridge and Node.js
A Node.js AWS Lambda function that listens to Genesys Cloud EventBridge events, retrieves customer records from a third-party CRM, and patches the Genesys Cloud interaction context with the enriched data. This implementation uses the Genesys Cloud Interaction API (PATCH /api/v2/interactions/{interactionId}) and the OAuth 2.0 Client Credentials flow. The code runs on Node.js 18+ with Axios for HTTP requests.
- Genesys Cloud OAuth confidential client with
interaction:readandinteraction:writescopes - AWS EventBridge rule configured to route
source: "genesys.cloud"events to a Lambda function - Node.js 18+ runtime environment
- Third-party CRM REST API endpoint and authentication credentials
- Dependencies:
axios(install vianpm install axios)
Genesys Cloud requires OAuth 2.0 for all API requests. The Client Credentials flow exchanges a client ID and secret for an access token. Lambda execution environments persist between invocations, so you must cache the token and validate its expiration before making API calls.
The following function handles token acquisition, caching, and TTL validation. It requires interaction:read and interaction:write scopes.
import axios from 'axios';
* @typedef {Object} OAuthToken
* @property {string} access_token
* @property {number} expires_in
* @property {string} token_type
* @typedef {Object} TokenCache
* @property {string | null} token
* @property {number | null} expiryTimestamp
const tokenCache = /** @type {TokenCache} */ ({
token: null,
expiryTimestamp: null
* Retrieves a valid Genesys Cloud access token.
* @returns {Promise<string>}
async function getAccessToken() {
const now = Date.now();
if (tokenCache.token && tokenCache.expiryTimestamp && now < tokenCache.expiryTimestamp) {
return tokenCache.token;
const clientId = process.env.GENESYS_CLIENT_ID;
const clientSecret = process.env.GENESYS_CLIENT_SECRET;
const environment = process.env.GENESYS_ENVIRONMENT || 'mypurecloud.com';
const response = await axios.post(`https://api.${environment}/oauth/token`, null, {
params: {
client_id: clientId,
client_secret: clientSecret,
scope: 'interaction:read interaction:write'
headers: {
'Content-Type': 'application/x-www-form-urlencoded'
const data = /** @type {OAuthToken} */ (response.data);
tokenCache.token = data.access_token;
tokenCache.expiryTimestamp = now + (data.expires_in * 1000);
return data.access_token;
Step 1: Parse EventBridge Payload and Extract Interaction Identifier
Genesys Cloud publishes interaction lifecycle events to AWS EventBridge. The payload follows the standard EventBridge schema. You must extract the interactionId from the detail object to target the correct interaction in the Interaction API.
* @typedef {Object} GenesysEventDetail
* @property {string} interactionId
* @property {string} type
* @property {string} direction
* @property {string} initiationTimestamp
* @typedef {Object} EventBridgeEvent
* @property {string} version
* @property {string} id
* @property {string} detail-type
* @property {string} source
* @property {string} time
* @property {string} region
* @property {string[]} resources
* @property {GenesysEventDetail} detail
* Validates and extracts the interaction ID from an EventBridge payload.
* @param {EventBridgeEvent} event
* @returns {string}
* @throws {Error} If the payload is malformed or missing the interaction ID.
function extractInteractionId(event) {
if (event.source !== 'genesys.cloud') {
throw new Error('Invalid event source. Expected genesys.cloud');
if (!event.detail || !event.detail.interactionId) {
throw new Error('Missing interactionId in event.detail');
return event.detail.interactionId;
Expected EventBridge payload structure:
"version": "0",
"detail-type": "Genesys Interaction Event",
"source": "genesys.cloud",
"account": "123456789012",
"time": "2024-06-15T14:32:10Z",
"region": "us-east-1",
"resources": [],
"detail": {
"interactionId": "8f7e6d5c-4b3a-2109-8765-4321fedcba09",
"type": "voice",
"direction": "inbound",
"initiationTimestamp": "2024-06-15T14:32:08Z"
Step 2: Retrieve Customer Data from Third-Party CRM
Once you have the interaction ID, you must identify the customer associated with that interaction. In this example, you will simulate a CRM lookup using the caller ID or external identifier embedded in the Genesys event. The CRM endpoint returns account metadata that will be written to the Genesys interaction context.
* @typedef {Object} CrmCustomerData
* @property {string} crmAccountId
* @property {number} lifetimeValue
* @property {string} loyaltyTier
* @property {string} lastPurchaseDate
* Fetches customer data from a third-party CRM system.
* @param {string} externalCustomerId
* @returns {Promise<CrmCustomerData>}
* @throws {Error} If the CRM returns a 404 or non-2xx status.
async function fetchCrmCustomerData(externalCustomerId) {
const crmUrl = process.env.CRM_API_BASE_URL;
const crmApiKey = process.env.CRM_API_KEY;
const response = await axios.get(`${crmUrl}/customers/${externalCustomerId}`, {
headers: {
'Authorization': `Bearer ${crmApiKey}`,
'Accept': 'application/json'
timeout: 3000
if (response.status !== 200) {
throw new Error(`CRM lookup failed with status ${response.status}`);
return response.data;
Realistic CRM response:
"crmAccountId": "ACCT-99281",
"lifetimeValue": 14250.75,
"loyaltyTier": "Platinum",
"lastPurchaseDate": "2024-05-28T09:15:00Z"
Step 3: Update Genesys Cloud Interaction Context
The Genesys Cloud Interaction API accepts a PATCH request to update interaction metadata. You will map the CRM data into the context object. The API requires the interaction:write scope. The request must include the Content-Type: application/json header.
* Updates the Genesys Cloud interaction context with CRM data.
* @param {string} interactionId
* @param {CrmCustomerData} crmData
* @param {string} accessToken
* @returns {Promise<void>}
* @throws {Error} If the API returns a 4xx or 5xx status.
async function updateInteractionContext(interactionId, crmData, accessToken) {
const apiUrl = `https://api.${environment}/api/v2/interactions/${interactionId}`;
const payload = {
context: {
crmAccountId: crmData.crmAccountId,
lifetimeValue: crmData.lifetimeValue,
loyaltyTier: crmData.loyaltyTier,
lastPurchaseDate: crmData.lastPurchaseDate
const response = await axios.patch(apiUrl, payload, {
headers: {
'Authorization': `Bearer ${accessToken}`,
'Content-Type': 'application/json'
timeout: 5000
if (response.status !== 200 && response.status !== 204) {
throw new Error(`Interaction update failed with status ${response.status}`);
HTTP Request Example:
PATCH /api/v2/interactions/8f7e6d5c-4b3a-2109-8765-4321fedcba09 HTTP/1.1
Host: api.mypurecloud.com
Authorization: Bearer eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9...
"context": {
HTTP Response Example:
HTTP/1.1 200 OK
"id": "8f7e6d5c-4b3a-2109-8765-4321fedcba09",
"type": "voice",
"context": {
Step 4: Implement Rate-Limit Handling and Retry Logic
Genesys Cloud enforces rate limits at the API gateway level. When you exceed the limit, the API returns HTTP 429 with a Retry-After header. You must implement exponential backoff with jitter to avoid cascading failures.
* Calculates exponential backoff delay in milliseconds with jitter.
* @param {number} attempt
* @returns {number}
function calculateBackoff(attempt) {
const maxDelay = 8000;
const exponentialDelay = Math.pow(2, attempt) * 1000;
const jitter = Math.random() * 1000;
return Math.min(exponentialDelay + jitter, maxDelay);
* Executes an async function with retry logic for 429 responses.
* @param {Function} fn
* @param {number} maxRetries
* @returns {Promise<any>}
async function executeWithRetry(fn, maxRetries = 3) {
let lastError;
for (let attempt = 0; attempt <= maxRetries; attempt++) {
return await fn();
} catch (error) {
lastError = error;
if (error.response && error.response.status === 429) {
const retryAfter = error.response.headers['retry-after'];
const delay = retryAfter ? parseInt(retryAfter, 10) * 1000 : calculateBackoff(attempt);
continue;
throw error;
throw lastError;
The following module combines authentication, EventBridge parsing, CRM retrieval, and Interaction API updates into a single deployable Lambda handler. Deploy this code to AWS Lambda with Node.js 18+ runtime. Configure the environment variables GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET, GENESYS_ENVIRONMENT, CRM_API_BASE_URL, and CRM_API_KEY in the Lambda console.
// Token cache for Lambda execution environment persistence
const tokenCache = {
token: null,
params: {
const data = response.data;
headers: {
timeout: 3000
const payload = {
context: {
headers: {
timeout: 5000
let lastError;
return await fn();
} catch (error) {
lastError = error;
continue;
throw error;
throw lastError;
export const handler = async (event) => {
const interactionId = extractInteractionId(event);
const externalCustomerId = event.detail.externalCustomerId || 'DEFAULT-CUSTOMER-ID';
const accessToken = await getAccessToken();
const crmData = await fetchCrmCustomerData(externalCustomerId);
await executeWithRetry(() => updateInteractionContext(interactionId, crmData, accessToken));
statusCode: 200,
body: JSON.stringify({ message: 'Interaction context enriched successfully', interactionId })
} catch (error) {
console.error('Enrichment failed:', error.message);
statusCode: 500,
body: JSON.stringify({ error: 'Enrichment failed', details: error.message })
- Cause: The OAuth token is expired, malformed, or missing in the
Authorizationheader. The client credentials may also be incorrect. - Fix: Verify that
GENESYS_CLIENT_IDandGENESYS_CLIENT_SECRETmatch a confidential client in Genesys Cloud. Ensure the token cache validatesexpires_incorrectly. Add logging before the API call to print the token prefix for verification. - Code adjustment: Log the token acquisition timestamp and expiry window. Validate that the
grant_typeis exactlyclient_credentials.
Error: 403 Forbidden
- Cause: The OAuth client lacks the required
interaction:writescope, or the client is restricted to specific IP ranges that do not include the Lambda execution environment. - Fix: Navigate to Genesys Cloud Admin > Security > OAuth Clients. Edit the client and add
interaction:writeto the scope list. Remove IP restrictions or add the AWS Lambda CIDR ranges. - Code adjustment: Print the exact scope string passed to
/oauth/tokento confirm it matches the admin configuration.
- Cause: The Lambda function triggers concurrently for multiple interactions, exceeding the Genesys Cloud API rate limit for the tenant or client.
- Fix: The provided
executeWithRetryfunction parses theRetry-Afterheader and applies exponential backoff with jitter. Ensure your EventBridge rule does not fan out to multiple Lambda instances without a throttling mechanism. Configure AWS Lambda concurrency limits to match your API quota. - Code adjustment: Increase
maxRetriesto 5 if your workload experiences sustained throttling. Log theRetry-Aftervalue to monitor gateway behavior.
Error: 404 Not Found
- Cause: The
interactionIdextracted from the EventBridge payload does not exist in the Genesys Cloud tenant, or the interaction was deleted before the Lambda executed. - Fix: Validate that the EventBridge rule filters for
genesys.interaction.createdorgenesys.interaction.updatedevents only. Add a pre-check usingGET /api/v2/interactions/{interactionId}before attempting the PATCH operation if strict existence validation is required. - Code adjustment: Wrap the PATCH call in a try-catch that specifically handles 404 status codes and returns a graceful response without failing the Lambda invocation.
Error: CRM Timeout or 5xx Response
- Cause: The third-party CRM endpoint is unresponsive or returns a server error, causing the Lambda to timeout.
- Fix: Set explicit timeouts on the Axios request. Implement a dead-letter queue (DLQ) in AWS EventBridge to capture failed enrichment events for later processing. Do not retry CRM failures indefinitely.
- Code adjustment: Add
timeout: 3000to the CRM Axios config. Catchaxios.errors.TimeoutErrorseparately and route to a fallback or DLQ.
