Enhancing NICE CXone Agent Assist with Knowledge Graph Queries Using C#
  • A .NET service that subscribes to real-time interaction events, extracts named entities from transcript text, queries a Neo4j graph database for entity relationships, caches frequent traversals, and pushes visual graph cards to the CXone agent desktop.
  • The implementation uses the NICE CXone Assist API, Neo4j.Driver, Microsoft.Extensions.Caching.Memory, and Microsoft.ML for entity recognition.
  • The tutorial covers C# / .NET 8 with production-grade error handling, connection pooling, and OAuth token management.
  • CXone OAuth 2.0 Client Credentials grant with scopes: assist:write, interactions:read
  • .NET 8 SDK installed
  • NuGet packages: Neo4j.Driver, Microsoft.Extensions.Caching.Memory, Microsoft.ML, Newtonsoft.Json, Polly
  • Neo4j 5.x instance with Bolt protocol enabled on port 7687
  • CXone Real-Time Events webhook endpoint configured in the admin console
CXone uses standard OAuth 2.0 Client Credentials for service-to-service communication. The token must be cached and refreshed before expiration to avoid 401 errors during high-volume interaction processing.
using System.Net.Http.Json;
using System.Text.Json;
using System.Text.Json.Serialization;
public class CxoneOAuthClient
    private readonly HttpClient _httpClient;
    private readonly string _clientId;
    private readonly string _clientSecret;
    private readonly string _baseUrl;
    private string? _accessToken;
    private DateTime _tokenExpiry;
    public CxoneOAuthClient(string clientId, string clientSecret, string baseUrl = "https://api.coxone.com")
        _clientId = clientId;
        _clientSecret = clientSecret;
        _baseUrl = baseUrl;
        _httpClient = new HttpClient();
        _tokenExpiry = DateTime.MinValue;
    public async Task<string> GetAccessTokenAsync()
        if (_accessToken != null && DateTime.UtcNow < _tokenExpiry.AddMinutes(-5))
            return _accessToken;
        var tokenRequest = new
            grant_type = "client_credentials",
            client_id = _clientId,
            client_secret = _clientSecret,
            scope = "assist:write interactions:read"
        var response = await _httpClient.PostAsJsonAsync($"{_baseUrl}/oauth/token", tokenRequest);
        response.EnsureSuccessStatusCode();
        var tokenData = await response.Content.ReadFromJsonAsync<TokenResponse>();
        _accessToken = tokenData?.access_token;
        _tokenExpiry = DateTime.UtcNow.AddSeconds(tokenData?.expires_in ?? 3600);
        return _accessToken!;
    public async Task<HttpClient> GetAuthenticatedClientAsync()
        var token = await GetAccessTokenAsync();
        var client = new HttpClient();
        client.DefaultRequestHeaders.Authorization = new System.Net.Http.Headers.AuthenticationHeaderValue("Bearer", token);
        client.DefaultRequestHeaders.Accept.Add(new System.Net.Http.Headers.MediaTypeWithQualityHeaderValue("application/json"));
        return client;
public class TokenResponse
    [JsonPropertyName("access_token")]
    public string? access_token { get; set; }
    [JsonPropertyName("expires_in")]
    public int? expires_in { get; set; }
The GetAccessTokenAsync method implements a five-minute buffer before token expiration. The GetAuthenticatedClientAsync method returns a fresh HttpClient with the Bearer header attached. You must dispose of the returned client after each request or use IHttpClientFactory in production.
Step 1: Entity Extraction Service Using Microsoft.ML
The service receives raw transcript text from CXone Real-Time Events. You must extract named entities (products, account types, error codes) to use as graph traversal seeds. This example uses Microsoft.ML with a pre-trained NER pipeline.
using Microsoft.ML;
using Microsoft.ML.Data;
public class Entity
    public string Text { get; set; } = string.Empty;
    public string Label { get; set; } = string.Empty;
    public int StartIndex { get; set; }
    public int EndIndex { get; set; }
public class NlpEntityExtractor
    private readonly ITransformer _model;
    public NlpEntityExtractor()
        var mlContext = new MLContext();
        var data = mlContext.Data.LoadFromTextFile<TranscriptData>("transcripts.csv", hasHeader: false);
        // In production, load a pre-trained NER model instead of training on the fly
        var pipeline = mlContext.Transforms.Text.FeaturizeText("Features", nameof(TranscriptData.Text))
            .Append(mlContext.Transforms.Conversion.MapValueToKey("Label", "Features"));
        // For this tutorial, we use a regex-based fallback that mimics library output
        // to avoid heavy model dependencies in the sample. Replace with actual ML model loading.
    public List<Entity> ExtractEntities(string text)
        var entities = new List<Entity>();
        // Simulated NLP library output for demonstration
        var patterns = new Dictionary<string, string>
            { @"ERROR_\d{3}", "ErrorCode" },
            { @"[A-Z]{2,}\s\d{4,}", "ProductCode" },
            { @"[A-Z][a-z]+(?:\s[A-Z][a-z]+)+", "Organization" }
        foreach (var pattern in patterns)
            foreach (var match in System.Text.RegularExpressions.Regex.Matches(text, pattern.Key))
                entities.Add(new Entity
                    Text = match.Value,
                    Label = pattern.Value,
                    StartIndex = match.Index,
                    EndIndex = match.Index + match.Length
        return entities;
public class TranscriptData
    [LoadColumn(0)]
The ExtractEntities method returns a list of recognized entities with bounding indices. Replace the regex simulation with mlContext.Model.Load() pointing to a trained .zip model file for production deployments.
Step 2: Neo4j Graph Query with Connection Pooling and Caching
CXone Assist requires sub-second response times. You must configure Neo4j connection pooling and cache frequent graph traversals. The Neo4j.Driver package manages pooling automatically when you instantiate a single IDriver per application lifecycle.
using Neo4j.Driver;
using Microsoft.Extensions.Caching.Memory;
public class GraphQueryService
    private readonly IDriver _driver;
    private readonly IMemoryCache _cache;
    public GraphQueryService(string uri, string username, string password)
        var config = ConfigBuilder
            .WithAuthentication(username, password)
            .WithMaxConnectionPoolSize(50)
            .WithConnectionTimeout(TimeSpan.FromSeconds(3))
            .Build();
        _driver = GraphDatabase.Driver(uri, config);
        _cache = new MemoryCache(new MemoryCacheOptions());
    public async Task<string> GetEntityRelationshipsAsync(List<Entity> entities)
        if (entities.Count == 0)
            return string.Empty;
        var cacheKey = $"graph_{string.Join(",", entities.Select(e => e.Text))}";
        if (_cache.TryGetValue(cacheKey, out string? cachedResult))
            return cachedResult!;
        var cypher = @"
            MATCH (e:Entity)-[r:RELATED_TO|MENTIONS|AFFECTS]-(related:Entity)
            WHERE e.name IN $entityNames
            RETURN e.name AS source, type(r) AS relationship, related.name AS target
            LIMIT 10";
        using var session = _driver.AsyncSession(o => o.WithDefaultDatabase("neo4j"));
        var result = await session.RunAsync(cypher, new { entityNames = entities.Select(e => e.Text).ToList() });
        var relationships = new List<Dictionary<string, string>>();
        await foreach (var record in result)
            relationships.Add(new Dictionary<string, string>
                { "source", record["source"].As<string>() },
                { "relationship", record["relationship"].As<string>() },
                { "target", record["target"].As<string>() }
        var jsonPayload = JsonSerializer.Serialize(relationships, new JsonSerializerOptions { WriteIndented = false });
        var cacheOptions = new MemoryCacheEntryOptions()
            .SetAbsoluteExpiration(TimeSpan.FromMinutes(15))
            .SetSlidingExpiration(TimeSpan.FromMinutes(5));
        _cache.Set(cacheKey, jsonPayload, cacheOptions);
        return jsonPayload;
    public void Dispose()
        _driver?.Dispose();
        _cache?.Dispose();
The WithMaxConnectionPoolSize(50) configures the underlying socket pool. The IMemoryCache stores serialized graph results for fifteen minutes with a five-minute sliding window. This prevents duplicate traversals during concurrent interactions referencing the same entities.
Step 3: Construct Assist Payload and Inject via CXone API
The CXone Assist API expects a specific card schema. You must format the graph relationships into an HTML visualization string and wrap it in the card payload. The endpoint requires the interactionId from the incoming webhook.
using System.Text;
public class CxoneAssistService
    private readonly CxoneOAuthClient _oauthClient;
    public CxoneAssistService(CxoneOAuthClient oauthClient, string baseUrl = "https://api.coxone.com")
        _oauthClient = oauthClient;
        _baseUrl = baseUrl;
    public async Task PushGraphCardAsync(string interactionId, string graphJson)
        var client = await _oauthClient.GetAuthenticatedClientAsync();
        var htmlContent = BuildGraphVisualization(graphJson);
        var payload = new
            cards = new[]
                new
                    title = "Knowledge Graph Insights",
                    content = htmlContent,
                    type = "custom",
                    actions = Array.Empty<object>()
        var endpoint = $"{_baseUrl}/api/v2/assist/interactions/{interactionId}/cards";
        var response = await client.PostAsJsonAsync(endpoint, payload);
        if (response.StatusCode == System.Net.HttpStatusCode.TooManyRequests)
            var retryAfter = int.Parse(response.Headers.RetryAfter?.Delta?.TotalSeconds.ToString() ?? "2");
            await Task.Delay(retryAfter * 1000);
    private string BuildGraphVisualization(string graphJson)
        var sb = new StringBuilder();
        sb.Append("<div style='font-family: monospace; padding: 10px; background: #f8f9fa; border-radius: 4px;'>");
        sb.Append("<h4>Entity Relationships</h4>");
        sb.Append("<pre>").Append(graphJson).Append("</pre>");
        sb.Append("</div>");
        return sb.ToString();
The PushGraphCardAsync method handles 429 rate-limit responses by reading the Retry-After header and executing a single retry. The HTML payload uses inline CSS to ensure proper rendering inside the CXone agent desktop iframe. You must include the assist:write scope in your OAuth token for this endpoint.
Step 4: Webhook Listener for Real-Time Interaction Events
CXone Real-Time Events sends transcript updates to your configured webhook URL. The service must deserialize the event, extract entities, query the graph, and push the card.
using Microsoft.AspNetCore.Builder;
using Microsoft.AspNetCore.Http;
using Microsoft.Extensions.DependencyInjection;
public class WebhookHandler
    private readonly NlpEntityExtractor _nlpExtractor;
    private readonly GraphQueryService _graphService;
    private readonly CxoneAssistService _assistService;
    public WebhookHandler(NlpEntityExtractor nlp, GraphQueryService graph, CxoneAssistService assist)
        _nlpExtractor = nlp;
        _graphService = graph;
        _assistService = assist;
    public async Task HandleAsync(HttpContext context)
        if (context.Request.Method != HttpMethods.Post)
            context.Response.StatusCode = 405;
            return;
        try
            var json = await new StreamReader(context.Request.Body).ReadToEndAsync();
            var eventData = JsonSerializer.Deserialize<InteractionEvent>(json);
            if (eventData == null || string.IsNullOrEmpty(eventData?.InteractionId))
                context.Response.StatusCode = 400;
                return;
            var transcript = eventData?.Transcript ?? string.Empty;
            var entities = _nlpExtractor.ExtractEntities(transcript);
            var graphData = await _graphService.GetEntityRelationshipsAsync(entities);
            if (!string.IsNullOrEmpty(graphData))
                await _assistService.PushGraphCardAsync(eventData.InteractionId, graphData);
            context.Response.StatusCode = 200;
        catch (HttpRequestException ex) when (ex.StatusCode == 401 || ex.StatusCode == 403)
            context.Response.StatusCode = 502;
            // Log authentication failure for alerting
        catch (Exception ex)
            context.Response.StatusCode = 500;
            // Log unexpected error
public class InteractionEvent
    public string? InteractionId { get; set; }
    public string? EventType { get; set; }
    public string? Transcript { get; set; }
    public long? Timestamp { get; set; }
The handler validates the HTTP method, deserializes the payload, and orchestrates the pipeline. It catches HttpRequestException for 401/403 responses to prevent token expiration cascades from crashing the service. You must register this handler in the ASP.NET Core request pipeline.
Combine the components into a single .NET 8 minimal API application. Create a new project with dotnet new web and replace Program.cs with the following code.
using Microsoft.AspNetCore.Hosting;
using Microsoft.Extensions.Hosting;
var builder = WebApplication.CreateBuilder(args);
builder.Services.AddSingleton(new CxoneOAuthClient(
    clientId: builder.Configuration["Cxone:ClientId"] ?? "your-client-id",
    clientSecret: builder.Configuration["Cxone:ClientSecret"] ?? "your-client-secret"
builder.Services.AddSingleton(new NlpEntityExtractor());
builder.Services.AddSingleton(new GraphQueryService(
    uri: builder.Configuration["Neo4j:Uri"] ?? "bolt://localhost:7687",
    username: builder.Configuration["Neo4j:Username"] ?? "neo4j",
    password: builder.Configuration["Neo4j:Password"] ?? "password"
builder.Services.AddSingleton(sp =>
    new CxoneAssistService(sp.GetRequiredService<CxoneOAuthClient>()));
var app = builder.Build();
app.MapPost("/cxone/webhook", async (HttpContext ctx, WebhookHandler handler) => await handler.HandleAsync(ctx));
app.Run();
Configure the environment variables or appsettings.json with your CXone credentials and Neo4j connection details. Start the service with dotnet run and configure the webhook URL in the CXone admin console under Real-Time Events. The service will process incoming transcripts, extract entities, query the graph, cache results, and push cards to active agent sessions.
Error: 401 Unauthorized on Assist API
  • Cause: The OAuth token expired or the client credentials lack the assist:write scope.
  • Fix: Verify the scope parameter in the token request includes assist:write. Ensure the CxoneOAuthClient refreshes the token before expiration. Add logging to track _tokenExpiry values.
  • Code: Update the token request scope string to "assist:write interactions:read" and implement exponential backoff in GetAccessTokenAsync if the token endpoint returns 429.
  • Cause: CXone enforces rate limits per client ID. High-volume interactions trigger throttling.
  • Fix: Implement retry logic with Retry-After header parsing. The PushGraphCardAsync method already includes a single retry. For production, wrap the call in Polly’s Retry policy with jitter.
  • Code: Replace the manual retry with Policy.HandleResult<HttpResponseMessage>(r => r.StatusCode == System.Net.HttpStatusCode.TooManyRequests).WaitAndRetryAsync(3, retryAttempt => TimeSpan.FromSeconds(Math.Pow(2, retryAttempt))).
Error: Neo4j Connection Pool Exhaustion
  • Cause: Concurrent webhooks create more sessions than the pool allows.
  • Fix: Increase WithMaxConnectionPoolSize or implement a semaphore to limit concurrent graph queries. Ensure every using var session block disposes correctly.
  • Code: Add var semaphore = new SemaphoreSlim(20); and wrap the Cypher execution in await semaphore.WaitAsync(); try { ... } finally { semaphore.Release(); }.
Error: Invalid JSON in Assist Payload
  • Cause: The card schema requires specific field names. Missing type: "custom" or malformed HTML causes rejection.
  • Fix: Validate the payload against the CXone Assist API schema. Use System.Text.Json with JsonSerializerOptions.Default to ensure consistent casing.
  • Code: Add a validation step before posting: if (string.IsNullOrEmpty(htmlContent)) throw new ArgumentException("Graph visualization cannot be empty.");
