Enhancing Entity Resolution in NICE Cognigy.AI with a Node.js Temporal Buffer Webhook
  • A Node.js webhook service that intercepts partial user utterances across multiple conversation turns and aggregates them using a sliding temporal window buffer.
  • A disambiguation pipeline that batches fragmented entity references and invokes a named entity recognition service to resolve ambiguous or incomplete inputs.
  • A REST API client that pushes resolved entity objects back into the Cognigy.AI dialog context for precise intent routing and slot filling.
  • Implementation covers Node.js 18+ with native fetch, exponential backoff retry logic, and production-grade error handling.
  • NICE Cognigy.AI platform with webhook execution enabled and REST API access provisioned
  • OAuth 2.0 client credentials for Cognigy.AI API (client_id, client_secret, token_endpoint)
  • Node.js 18 or higher (native fetch support required)
  • External dependencies: npm install express dotenv
Cognigy.AI REST API operations require a valid Bearer token. The following implementation uses the OAuth 2.0 client credentials grant to obtain and cache tokens. The token cache implements automatic refresh when the access token expires or returns a 401 status.
import { readFileSync } from 'node:fs';
import { parse } from 'dotenv';
const env = parse(readFileSync('.env'));
const AUTH_CONFIG = {
  tokenUrl: env.COGNIGY_TOKEN_URL || 'https://api.cognigy.ai/oauth/token',
  clientId: env.COGNIGY_CLIENT_ID,
  clientSecret: env.COGNIGY_CLIENT_SECRET,
  scopes: ['api:read', 'api:write', 'context:update']
let tokenCache = {
  accessToken: null,
  expiresIn: 0,
  expiresAt: 0
async function acquireCognigyToken() {
  if (tokenCache.accessToken && Date.now() < tokenCache.expiresAt - 60000) {
    return tokenCache.accessToken;
  const body = new URLSearchParams({
    client_id: AUTH_CONFIG.clientId,
    client_secret: AUTH_CONFIG.clientSecret,
    scope: AUTH_CONFIG.scopes.join(' ')
  const response = await fetch(AUTH_CONFIG.tokenUrl, {
    method: 'POST',
    body
  if (!response.ok) {
    const errorText = await response.text();
    throw new Error(`Token acquisition failed with status ${response.status}: ${errorText}`);
  const data = await response.json();
  tokenCache.accessToken = data.access_token;
  tokenCache.expiresIn = data.expires_in;
  tokenCache.expiresAt = Date.now() + (data.expires_in * 1000);
The acquireCognigyToken function caches the token and checks expiration before making network requests. It subtracts a sixty second safety margin to prevent edge case 401 responses during active calls. The required scopes (api:read, api:write, context:update) grant permission to read session state and patch context objects.
Step 1: Webhook Server and Temporal Buffer Initialization
The webhook server exposes a single POST endpoint that Cognigy.AI invokes during dialog execution. The temporal buffer stores partial entity fragments per session ID and applies a sliding window to discard stale inputs.
import express from 'express';
const app = express();
app.use(express.json());
class TemporalBuffer {
  constructor(windowMs = 300000) {
    this.windowMs = windowMs;
    this.sessions = new Map();
  addFragment(sessionId, fragment, timestamp = Date.now()) {
    if (!this.sessions.has(sessionId)) {
      this.sessions.set(sessionId, []);
    this.sessions.get(sessionId).push({ fragment, timestamp });
    this._prune(sessionId);
  getAggregated(sessionId) {
    const fragments = this.sessions.get(sessionId) || [];
      sessionId,
      fragments: fragments.map(f => f.fragment),
      lastUpdated: fragments.length > 0 ? fragments[fragments.length - 1].timestamp : 0
  _prune(sessionId) {
    const sessionData = this.sessions.get(sessionId);
    if (!sessionData) return;
    const cutoff = Date.now() - this.windowMs;
    const valid = sessionData.filter(entry => entry.timestamp >= cutoff);
    this.sessions.set(sessionId, valid);
    if (valid.length === 0) {
      this.sessions.delete(sessionId);
const entityBuffer = new TemporalBuffer(300000);
app.post('/webhook/entity-resolver', async (req, res) => {
    const { session, user, context } = req.body;
    const sessionId = session?.id;
    const rawInput = user?.input || '';
    if (!sessionId || !rawInput) {
      return res.status(400).json({ error: 'Missing session.id or user.input' });
    entityBuffer.addFragment(sessionId, rawInput);
    const aggregated = entityBuffer.getAggregated(sessionId);
    const resolvedEntities = await resolveEntitiesWithNER(aggregated);
    await updateCognigyContext(sessionId, resolvedEntities);
    res.json({
      status: 'success',
      context: {
        resolved_entities: resolvedEntities,
        buffer_state: {
          fragment_count: aggregated.fragments.length,
          window_seconds: entityBuffer.windowMs / 1000
  } catch (error) {
    console.error('Webhook execution failed:', error);
    res.status(500).json({ error: 'Internal processing error', details: error.message });
const PORT = process.env.PORT || 3000;
app.listen(PORT, () => console.log(`Entity resolver webhook listening on port ${PORT}`));
The TemporalBuffer class maintains a Map of session IDs to timestamped fragment arrays. The _prune method removes entries older than the configured window (default thirty seconds). The webhook endpoint extracts the session ID and raw input, pushes the fragment into the buffer, and proceeds to disambiguation.
Step 2: Fragment Aggregation and NER Disambiguation
Partial inputs often lack sufficient context for accurate classification. This step concatenates buffered fragments, sends them to a named entity recognition service, and implements retry logic for rate limiting.
const NER_SERVICE_URL = process.env.NER_SERVICE_URL || 'https://ner-service.example.com/v1/disambiguate';
async function resolveEntitiesWithNER(aggregatedData) {
  const combinedText = aggregatedData.fragments.join(' ');
  const requestBody = {
    text: combinedText,
    language: 'en',
    confidence_threshold: 0.75,
    entity_types: ['PERSON', 'ORGANIZATION', 'LOCATION', 'PRODUCT']
  return await executeWithRetry(async () => {
    const response = await fetch(NER_SERVICE_URL, {
      method: 'POST',
      headers: {
        'Accept': 'application/json'
      body: JSON.stringify(requestBody)
    if (response.status === 429) {
      const retryAfter = response.headers.get('Retry-After');
      const delay = retryAfter ? parseInt(retryAfter, 10) * 1000 : 2000;
      throw new Error(`Rate limited. Retrying after ${delay}ms`);
    if (!response.ok) {
      const errorBody = await response.text();
      throw new Error(`NER service failed with status ${response.status}: ${errorBody}`);
    return data.entities || [];
  }, 3, 1000);
async function executeWithRetry(fn, maxRetries, baseDelay) {
  let lastError;
  for (let attempt = 0; attempt <= maxRetries; attempt++) {
      return await fn();
    } catch (error) {
      lastError = error;
      if (attempt === maxRetries || !error.message.includes('Rate limited')) {
        throw error;
      const jitter = Math.random() * 500;
      const delay = baseDelay * Math.pow(2, attempt) + jitter;
  throw lastError;
The resolveEntitiesWithNER function merges buffered fragments into a single string and sends it to the NER endpoint. The executeWithRetry wrapper implements exponential backoff with linear jitter. It specifically catches 429 responses, parses the Retry-After header if present, and retries up to three times. Other HTTP errors fail immediately to prevent masking configuration or payload issues.
Step 3: Context Update via Cognigy REST API
After disambiguation, the resolved entities must be written back to the active Cognigy session. The following function patches the dialog context using the authenticated REST API.
const COGNIGY_API_BASE = process.env.COGNIGY_API_BASE || 'https://api.cognigy.ai';
async function updateCognigyContext(sessionId, resolvedEntities) {
  const token = await acquireCognigyToken();
  const endpoint = `${COGNIGY_API_BASE}/api/v1/sessions/${sessionId}/context`;
  const payload = {
    context: {
      resolved_entities: resolvedEntities.map(entity => ({
        type: entity.type,
        value: entity.value,
        confidence: entity.confidence,
        source: 'temporal_buffer_resolver',
        resolved_at: new Date().toISOString()
      entity_resolution_status: 'completed',
      buffer_fragments_consumed: resolvedEntities.length > 0 ? true : false
  const response = await fetch(endpoint, {
    method: 'PATCH',
    headers: {
      'Authorization': `Bearer ${token}`
    body: JSON.stringify(payload)
  if (response.status === 401) {
    tokenCache.accessToken = null;
    throw new Error('Authentication failed. Token cleared for refresh.');
  if (!response.ok) {
    throw new Error(`Context update failed with status ${response.status}: ${errorText}`);
  return await response.json();
The updateCognigyContext function constructs a context patch payload that maps NER results to Cognigy-friendly entity objects. It includes metadata fields (source, resolved_at) to track resolution provenance. A 401 response triggers token cache invalidation, forcing the next call to request a fresh token. The PATCH method merges the new context keys without overwriting existing dialog state.
The following script combines all components into a single runnable module. Create a .env file with COGNIGY_TOKEN_URL, COGNIGY_CLIENT_ID, COGNIGY_CLIENT_SECRET, COGNIGY_API_BASE, and NER_SERVICE_URL before execution.
let tokenCache = { accessToken: null, expiresIn: 0, expiresAt: 0 };
    method: 'POST',
    body
  if (!response.ok) {
    if (!this.sessions.has(sessionId)) this.sessions.set(sessionId, []);
    return { sessionId, fragments: fragments.map(f => f.fragment), lastUpdated: fragments.length > 0 ? fragments[fragments.length - 1].timestamp : 0 };
  _prune(sessionId) {
    if (valid.length === 0) this.sessions.delete(sessionId);
const NER_SERVICE_URL = env.NER_SERVICE_URL || 'https://ner-service.example.com/v1/disambiguate';
const COGNIGY_API_BASE = env.COGNIGY_API_BASE || 'https://api.cognigy.ai';
  let lastError;
    try { return await fn(); }
    catch (error) {
      lastError = error;
      if (attempt === maxRetries || !error.message.includes('Rate limited')) throw error;
  throw lastError;
  const requestBody = { text: combinedText, language: 'en', confidence_threshold: 0.75, entity_types: ['PERSON', 'ORGANIZATION', 'LOCATION', 'PRODUCT'] };
    const response = await fetch(NER_SERVICE_URL, { method: 'POST', headers: { 'Content-Type': 'application/json', 'Accept': 'application/json' }, body: JSON.stringify(requestBody) });
    if (!response.ok) {
  }, 3, 1000);
  const payload = { context: { resolved_entities: resolvedEntities.map(entity => ({ type: entity.type, value: entity.value, confidence: entity.confidence, source: 'temporal_buffer_resolver', resolved_at: new Date().toISOString() })), entity_resolution_status: 'completed', buffer_fragments_consumed: resolvedEntities.length > 0 } };
  const response = await fetch(endpoint, { method: 'PATCH', headers: { 'Content-Type': 'application/json', 'Authorization': `Bearer ${token}` }, body: JSON.stringify(payload) });
  if (response.status === 401) { tokenCache.accessToken = null; throw new Error('Authentication failed. Token cleared for refresh.'); }
  if (!response.ok) { const errorText = await response.text(); throw new Error(`Context update failed with status ${response.status}: ${errorText}`); }
    if (!sessionId || !rawInput) { return res.status(400).json({ error: 'Missing session.id or user.input' }); }
    res.json({ status: 'success', context: { resolved_entities: resolvedEntities, buffer_state: { fragment_count: aggregated.fragments.length, window_seconds: entityBuffer.windowMs / 1000 } } });
  } catch (error) {
Error: 401 Unauthorized on Context Patch
  • Cause: The OAuth token expired during webhook execution, or the client credentials lack the context:update scope.
  • Fix: The implementation clears the token cache on 401 and forces a refresh on the next call. Verify that COGNIGY_CLIENT_ID and COGNIGY_CLIENT_SECRET match the registered OAuth application. Ensure the scope list includes context:update.
  • Code showing the fix: The if (response.status === 401) block in updateCognigyContext invalidates tokenCache.accessToken, guaranteeing a fresh token on retry.
Error: 429 Too Many Requests on NER Service
  • Cause: The disambiguation endpoint enforces rate limits that exceed concurrent webhook volume.
  • Fix: The executeWithRetry function implements exponential backoff with jitter. It reads the Retry-After header if provided. If the service does not support retries, implement request queuing at the webhook level or increase the temporal window to reduce call frequency.
  • Code showing the fix: The retry loop checks error.message.includes('Rate limited') and applies baseDelay * Math.pow(2, attempt) + jitter before retrying.
Error: 400 Bad Request on Cognigy Webhook Endpoint
  • Cause: The incoming payload lacks session.id or user.input, or the JSON structure does not match Cognigy’s webhook schema.
  • Fix: Validate the request body before processing. Cognigy webhooks require a consistent payload structure. Add schema validation using zod or joi in production environments. The current implementation returns a 400 response with a clear error message when required fields are missing.
  • Code showing the fix: The if (!sessionId || !rawInput) guard clause returns a structured 400 JSON response immediately.
