Enforcing Reduced Motion Preferences for Vestibular Sensitivity in Genesys Cloud CX Agent Desktops
Configure deterministic motion reduction across the Genesys Cloud CX agent experience, including browser policy enforcement, Custom HTML5 App runtime injection, and Architect flow transition optimization. The end result is a stable, accessible interface that disables animations, parallax effects, and sudden visual transitions for affected agents while preserving core telephony, WEM, and queue status functionality.
- Licensing Tier: Genesys Cloud CX 2 or CX 3 (required for Custom HTML5 Apps, advanced UI scoping, and custom user attributes)
- Granular Permissions:
Administration > Custom HTML5 Apps > EditAdministration > Users > EditTelephony > Architect > EditAdministration > Organization Settings > Edit
- OAuth Scopes:
customhtml5apps:write,user:edit,architect:edit,organization:edit - External Dependencies: Enterprise MDM/GPO deployment (Microsoft Intune, Jamf, or Active Directory Group Policy), Chromium-based browser (Edge 90+ or Chrome 90+), Genesys Cloud Developer Console with API key or OAuth client credentials
1. System-Level Motion Enforcement via Browser Policy & MDM
Genesys Cloud CX renders its agent desktop as a progressive web application. The platform respects the CSS @media (prefers-reduced-motion: reduce) media query, but it does not enforce it. Relying on manual browser toggles introduces configuration drift and fails during browser cache resets. You must push the preference at the policy layer before the Genesys Cloud JavaScript bundle initializes.
Deploy a browser policy that forces prefers-reduced-motion to reduce for targeted user groups. In Microsoft Intune, configure a JSON payload for the Chrome/Edge policy Preferences. The policy key webkit_prefers_reduced_motion maps directly to the CSS media query.
Policy Payload (Intune/Group Policy JSON):
"webkit_prefers_reduced_motion": true,
"disable_3d_apis": false,
"hardware_acceleration": true
Apply this policy through your MDM to the affected agent security group. Verify deployment by opening chrome://policy or edge://policy and confirming webkit_prefers_reduced_motion reports true. The Genesys Cloud UI will evaluate this flag during the initial DOM hydration phase and suppress CSS transitions, keyframe animations, and viewport scroll effects.
The Trap: Deploying the policy without validating browser cache state causes the Genesys Cloud service worker to cache a previous UI bundle that ignores the media query. Agents experience inconsistent motion reduction until the service worker expires or manually clears storage.
Architectural Reasoning: Browser policy enforcement operates at the rendering engine layer, which executes before the Genesys Cloud JavaScript framework mounts. This guarantees the CSS media query matches during the critical initialization window. Platform-level CSS overrides cannot retroactively disable animations that have already queued in the compositor thread. Policy enforcement eliminates race conditions between UI hydration and preference evaluation.
2. Custom HTML5 App Manifest & Runtime CSS Injection
System policy handles base UI elements, but Genesys Cloud CX injects dynamic components through its internal framework. Custom HTML5 Apps allow you to append scoped styles and runtime listeners that enforce motion reduction across platform-updated components without modifying core files.
Create a Custom HTML5 App that targets the Genesys Cloud agent desktop container. The manifest must declare the correct appType and placement to ensure the script loads in the agent context.
Manifest Configuration (manifest.json):
"id": "reduced-motion-enforcer",
"name": "Vestibular Accessibility Enforcer",
"version": "1.0.0",
"appType": "agent-desktop",
"placement": "global",
"permissions": [
"user:read",
"customhtml5apps:read"
"entryPoint": "main.js",
"stylesheets": ["styles.css"]
Runtime CSS (styles.css):
/* Scope to Genesys Cloud agent desktop to prevent leakage */
.pure-engage-container,
.gc-agent-desktop,
.gc-queue-panel,
.gc-wem-score-panel {
animation-duration: 0.001ms !important;
animation-iteration-count: 1 !important;
transition-duration: 0.001ms !important;
transition-timing-function: linear !important;
/* Preserve functional feedback for queue status and call state */
.gc-queue-panel[data-status="active"],
.gc-call-control[data-state="connected"] {
transition-duration: 0.1s !important;
Runtime JavaScript (main.js):
document.addEventListener('DOMContentLoaded', () => {
const mediaQuery = window.matchMedia('(prefers-reduced-motion: reduce)');
const enforceReducedMotion = (matches) => {
if (matches) {
document.documentElement.setAttribute('data-reduced-motion', 'true');
// Remove any platform-injected animation classes
document.querySelectorAll('.gc-animate-fade, .gc-animate-slide').forEach(el => {
el.classList.remove('gc-animate-fade', 'gc-animate-slide');
el.style.opacity = '1';
el.style.transform = 'none';
enforceReducedMotion(mediaQuery.matches);
mediaQuery.addEventListener('change', (e) => enforceReducedMotion(e.matches));
Deploy the app via the Developer Console using the POST /api/v2/customhtml5apps endpoint. Assign the app to the target security group. The script runs in the agent desktop context, evaluates the media query on load, and strips animation classes that Genesys Cloud injects during dynamic panel updates.
The Trap: Using !important globally on animation-duration and transition-duration breaks WEM score animations and queue priority indicators. Agents lose visual confirmation of state changes, which degrades workflow efficiency and increases handle time.
Architectural Reasoning: Scoped CSS targeting .pure-engage-container and .gc-agent-desktop isolates the override to the Genesys Cloud rendering boundary. The JavaScript listener monitors runtime media query changes, ensuring the preference persists across browser zoom events or OS-level accessibility toggles. Preserving 0.1s transitions for active call states maintains functional feedback while eliminating vestibular triggers. This approach balances accessibility compliance with operational visibility.
3. Architect Flow Transition Optimization & State Management
Vestibular sensitivity is frequently triggered by rapid screen updates, sudden audio cues, or unpredictable UI jumps. Architect flows that rely on wait blocks, setVariable loops, or external API polling can cause erratic desktop behavior when combined with reduced motion settings. You must optimize flow transitions to ensure deterministic state changes.
Replace visual transition triggers with silent state updates. Use the setVariable block to flag accessibility preferences and route flow execution accordingly. Avoid play blocks with sudden volume spikes or wait blocks longer than 3000ms without progress indicators.
Architect Flow Configuration:
- Add a
setVariableblock at flow start:- Variable:
user.accessibility.reducedMotion - Value:
true - Scope:
session
- Variable:
- Route to a
decisionblock evaluatinguser.accessibility.reducedMotion - Branch to optimized sub-flows that disable:
playblocks withvolume>0.8waitblocks withoutmessageparametersupdateScreenactions that trigger full DOM refreshes
Use the restAPI block to push state changes to external systems instead of forcing Genesys Cloud UI updates. This keeps the agent desktop static while background processes handle data synchronization.
The Trap: Over-relying on wait blocks to simulate smooth transitions introduces latency and breaks call flow timing under load. When combined with reduced motion CSS, the flow appears frozen because the UI suppresses loading spinners and progress animations. Agents assume the system is unresponsive and terminate sessions prematurely.
Architectural Reasoning: Deterministic state transitions prevent unexpected UI jumps by decoupling data updates from visual rendering. The setVariable flag routes execution to optimized paths that avoid sudden audio or visual shifts. Using restAPI for background synchronization keeps the agent desktop static, which aligns with vestibular safety requirements. This architecture reduces cognitive load and eliminates false-positive session timeouts caused by suppressed loading indicators.
4. API-Driven Preference Persistence & Session Validation
Browser policies and Custom HTML5 Apps handle runtime enforcement, but accessibility preferences must persist across sessions, browser refreshes, and platform updates. Store the reduced motion preference as a custom user attribute and validate it during authentication.
Use the Genesys Cloud Users API to patch the accessibility flag. The endpoint accepts customAttributes in the request body, which persist to the user profile and load during session initialization.
API Payload:
PATCH https://{your-domain}.mypurecloud.com/api/v2/users/{userId}
Authorization: Bearer {access_token}
"customAttributes": {
"accessibility.reducedMotion": "true",
"accessibility.vestibularSensitivity": "high"
Validate the attribute during flow execution using the getUserAttribute block in Architect. Route agents with accessibility.reducedMotion == true to optimized desktop configurations. The Custom HTML5 App can also read this attribute via the Genesys Cloud SDK to enforce preferences without relying solely on browser policy.
The Trap: Storing accessibility flags in session cache without persistence causes regression on re-login. Agents lose their configured preferences after browser restarts or platform maintenance windows, requiring manual reconfiguration and triggering vestibular symptoms during the gap period.
Architectural Reasoning: Custom user attributes persist in the Genesys Cloud identity store, which survives browser cache clears, service worker resets, and platform version upgrades. Validating the attribute during flow execution ensures deterministic routing regardless of browser state. The Custom HTML5 App reads the attribute via SDK, creating a fallback enforcement layer that operates independently of OS-level media queries. This multi-tier persistence architecture guarantees continuous accessibility compliance across all session lifecycles.
Edge Case 1: CSS Media Query Override Conflict
Failure Condition: Agents report that certain panels still animate despite policy deployment and Custom HTML5 App installation.
Root Cause: Genesys Cloud CX injects inline styles during dynamic component rendering. Inline styles override external CSS and scoped selectors, bypassing the prefers-reduced-motion media query.
Solution: Modify the Custom HTML5 App JavaScript to intercept inline style injection. Use a MutationObserver to detect and neutralize inline animation properties on target containers.
const observer = new MutationObserver((mutations) => {
mutations.forEach((mutation) => {
if (mutation.attributeName === 'style') {
const el = mutation.target;
if (el.closest('.gc-agent-desktop')) {
el.style.animationDuration = '0.001ms';
el.style.transitionDuration = '0.001ms';
observer.observe(document.body, { attributes: true, subtree: true });
This observer runs asynchronously after DOM mutations, ensuring inline styles are neutralized before the compositor thread processes them.
Edge Case 2: WEM Score Animation Interference
Failure Condition: WEM score panels fail to update visually when reduced motion is enforced. Agents cannot verify quality monitoring status.
Root Cause: The CSS override targets .gc-wem-score-panel with animation-duration: 0.001ms, which suppresses the score change animation entirely. WEM relies on this animation to indicate state transitions.
Solution: Scope the CSS override to exclude WEM score containers. Add a specific rule that preserves minimal transition for score updates while disabling vestibular triggers.
.gc-wem-score-panel .score-value {
transition-duration: 0.15s !important;
transition-timing-function: ease-out !important;
This adjustment maintains functional feedback for quality monitoring while eliminating parallax and scroll-triggered animations that cause vestibular discomfort. Cross-reference the WEM configuration guide to ensure score update thresholds align with the reduced transition timing.
Edge Case 3: Architect Flow Timeout on Reduced Motion State
Failure Condition: Flows timeout unexpectedly when routing agents with reduced motion preferences. Session logs show FLOW_TIMEOUT errors.
Root Cause: The flow uses wait blocks to synchronize with external API responses. When reduced motion CSS suppresses loading spinners, the Genesys Cloud client assumes the flow is idle and triggers a timeout.
Solution: Replace wait blocks with restAPI synchronous calls or implement a silent progress indicator. Use the setVariable block to track API request timestamps and evaluate completion status without visual feedback.
"blockType": "restAPI",
"method": "POST",
"url": "https://external-api.example.com/sync",
"timeout": 5000,
"headers": { "Authorization": "Bearer {token}" }
Synchronous API calls eliminate idle detection triggers. The flow progresses based on response status codes rather than visual state changes, which aligns with reduced motion requirements and prevents false timeouts.
