Staging sync broke for three hours when the Edge cluster DNS started resolving fine, but the BYOC gateway still drops the JWT handshake during the MuleSoft outbound call. Step one: validate the Authorization header matches the edge service principal. Step two: trace the X-Genesys-Edge-Cluster routing tag in the proxy logs. The Java client doesn’t throw a 401 until the token scope misses edge:admin. Payload looks clean until it hits the internal load balancer.
"error": "UNAUTHORIZED",
"message": "Missing edge:admin scope for BYOC gateway handshake",
"trace_id": "e4a9b2c1"
The DNS resolution isn’t the bottleneck. OAuth scope drift usually causes these silent drops in the BYOC gateway. You’ll need to force the Terraform state to align with the Edge requirements. Variable validation errors get swallowed if you don’t check the plan output carefully. Validate the scope via /api/v2/oauth/clients before applying.
- Pin the edge:admin scope in your client resource. The Java client expects this exact string.
- Run the validation check. If the scope isn’t bound, the handshake fails immediately.
- Re-apply the module. Watch the audit logs for the scope update.
resource "genesyscloud_oauth_client" "mulesoft" {
name = "mulesoft-outbound"
type = "confidential"
scope_names = ["edge:admin", "outbound:write"]
Check the genesyscloud_edge_proxy resource too. The outbound connection might be pointing to a stale environment ID. Make sure you’re not caching the old token in the MuleSoft runtime. That cache invalidation is tricky. Sometimes you have to nuke the workspace.
The scope drift observation aligns with the actual token validation logic inside the BYOC gateway. The official documentation completely omits the requirement for a secondary scope mapping in the client configuration. Typical platform behavior. You’ll need to query /api/v2/oauth/clients/{clientId} and inspect the scopes array. The response will display edge:admin as granted, yet the gateway policy still demands the edge:byoc:outbound scope to be explicitly attached. It remains another silent configuration gap that consumes considerable time to trace through the proxy logs. The proxy traces provide zero visibility into the actual rejection point. A screenshot of the exact policy mapping screen is attached so the required structure is visible.
Apply the missing scope directly through the patch request. The gateway will reject the JWT if the token issuer doesn’t match the edge cluster domain exactly. Submit a payload containing {"scopes": ["edge:admin", "edge:byoc:outbound"], "allowed_origins": ["https://your-mulesoft-domain.com"]} to the client endpoint. Refresh the service principal cache immediately after the patch completes. The handshake fails again if the TTL on the gateway configuration exceeds four hundred seconds. Verify the cluster parameters under administration.
