Easy application !! not so easy ...
I am working on a java application using genji.jar libraries and j2se1.6.0
Purpose: to connect to a Tserver and register a DN. if it is logged in, then based on a input-logout that DN.
I know I have this functionality in genesys toolkit app, but I want to create this app to give to a client who can use only this functionality of logging out a DN. that’s it.
now I faced with hurdles of developing it.
my app doesn’t open the teleline.
private void connectTeleLine() {
	this.phTLine = null;
	System.out.println("?open line Tserver ");
		System.out.println("?open line Tserver2 "); /// IT STOPS HERE... NO MESSAGES AFTER THIS... NEITHER IN MY APP NOR IN TSERVER LOGS...
		this.phTLine = new PhTeleLine(new TeleServerContext(strHost,intPort), strTsName, this);
		phTLine.setAppName("testApp");
		phTLine.open();
		System.out.println("?open line Tserver3 ");
		registerDN(strTsName, "7001" );
	} catch (TeleLineException e) {
		System.out.println("Cannot open line Tserver --" + e.getMessage());
		//e.printStackTrace();
	} catch (TeleServerContextException e) {
		System.out.println("Cannot get Tserver context --" + e.getMessage());
Can someone please help me fix it?
what am I missing?
I would suggest you to try older version of Java SDK. Java Desktop Toolkit has been built with JDK 1.4.2.
René
did u mean Genji was built around jdk1.4.2?
The answer is yes. You can find that information in “Desktop Toolkit 7.2 Java Developer’s Guide”.
René
The genji library comes with examples, check TestSoftPhone_ansCall.java for an idea on logging that DN out.
;D :slight_smile: :wink: :slight_smile: ;D ;D 8) :)> :)> :)> >:smiley: >:smiley: >:D[move][shadow=red,left][shadow=red,left][url][url]`
<blockquote>- <hr/>
[glow=red,2,300][/glow]
- </blockquote>
`[/url][/url][/shadow][/shadow][/move]
Where can i get the sample code? E.J. TestSoftPhone_ansCall.java Thanks
Sample code is part of Genesys SDK - Platform SDK has tonns of it. What exactly are you having problem with?
S:
Java 1.4.2 is the answer to your prayer. I think you are using 1.6, right?
