Dynamically Updating Queue Membership and Wrap-up Codes via the CXone API During Peak Volume Events Using a Node.js Scheduler
  • A Node.js cron-based scheduler that automatically adds agents to overflow queues and activates temporary wrap-up codes when peak volume thresholds are met.
  • This uses the NICE CXone REST API for routing configuration management.
  • The tutorial covers JavaScript/Node.js with axios and node-cron.
  • OAuth client credentials (confidential client) with scopes: routing:queue:write, routing:user:write, routing:wrapupcode:write, oauth:client-credentials
  • CXone deployment URL format: https://<your-deployment>.cxone.com
  • Node.js 18+ LTS
  • npm dependencies: axios, node-cron, dotenv
CXone uses the OAuth 2.0 client credentials grant. You must cache the access token and handle expiration before each API call. The token endpoint returns an expires_in value in seconds. You should subtract a safety margin (typically 60 seconds) to avoid mid-request expiration.
require('dotenv').config();
const CXONE_BASE = process.env.CXONE_BASE_URL;
const CLIENT_ID = process.env.CXONE_CLIENT_ID;
const CLIENT_SECRET = process.env.CXONE_CLIENT_SECRET;
let accessToken = null;
let tokenExpiry = 0;
async function getAccessToken() {
  const safetyMarginMs = 60000;
  if (accessToken && Date.now() < tokenExpiry - safetyMarginMs) {
    return accessToken;
  const tokenUrl = `${CXONE_BASE}/api/v2/oauth/token`;
  const payload = new URLSearchParams({
    client_id: CLIENT_ID,
    client_secret: CLIENT_SECRET
    const response = await axios.post(tokenUrl, payload, {
    accessToken = response.data.access_token;
    tokenExpiry = Date.now() + (response.data.expires_in * 1000);
    return accessToken;
  } catch (error) {
    const status = error.response?.status;
    const detail = error.response?.data?.error_description || error.message;
    throw new Error(`[AUTH] Token fetch failed (${status}): ${detail}`);
Required Scope: oauth:client-credentials
Expected Response:
  "token_type": "bearer",
  "expires_in": 3600,
  "scope": "routing:queue:write routing:user:write routing:wrapupcode:write"
Step 1: Scheduler Initialization & Peak Detection Logic
You need a reliable scheduler to trigger configuration changes. The node-cron package handles minute-level precision. Peak detection in production typically pulls from CXone analytics or an external metrics endpoint. This example uses a deterministic placeholder that simulates peak hours (Monday through Friday, 09:00-11:00 and 13:00-15:00).
const cron = require('node-cron');
function isPeakVolume() {
  const now = new Date();
  const day = now.getDay();
  const hour = now.getHours();
  const minute = now.getMinutes();
  const isWeekday = day >= 1 && day <= 5;
  const isPeakBlock1 = hour === 9 || hour === 10;
  const isPeakBlock2 = hour === 13 || hour === 14;
  const isEarly15 = hour === 15 && minute < 30;
  return isWeekday && (isPeakBlock1 || isPeakBlock2 || isEarly15);
// Runs every minute
cron.schedule('* * * * *', async () => {
  console.log(`[${new Date().toISOString()}] Scheduler tick. Peak status: ${isPeakVolume()}`);
  // Peak logic triggers in Step 3
Step 2: Dynamic Queue Membership Toggling
CXone queue membership uses a POST request to add members and a DELETE request to remove them. The API returns 200 OK on success. You must handle 409 Conflict if the agent is already in the queue, and 404 Not Found if the queue or user ID is invalid.
Required Scopes: routing:queue:write, routing:user:write
async function updateQueueMembership(queueId, userId, addMember) {
  const token = await getAccessToken();
  const baseUrl = `${CXONE_BASE}/api/v2/routing/queues/${queueId}/members`;
  const config = {
    headers: {
      'Content-Type': 'application/json'
    maxRedirects: 0
    if (addMember) {
      const payload = {
        userId: userId,
        routingType: 'ROUTED',
        split: 1,
        afterHoursAvailable: false
      const res = await axios.post(`${baseUrl}`, payload, config);
      console.log(`[QUEUE] Added ${userId} to ${queueId}. Status: ${res.status}`);
      return res.data;
    } else {
      const res = await axios.delete(`${baseUrl}/${userId}`, config);
      console.log(`[QUEUE] Removed ${userId} from ${queueId}. Status: ${res.status}`);
      return res.data;
  } catch (error) {
    if (status === 409) {
      console.warn(`[QUEUE] Agent ${userId} is already in queue ${queueId}. Skipping.`);
      return { skipped: true, reason: 'already_member' };
    if (status === 404) {
      throw new Error(`[QUEUE] Queue ${queueId} or User ${userId} not found.`);
    throw new Error(`[QUEUE] Membership update failed (${status}): ${error.response?.data?.description || error.message}`);
HTTP Request Example:
POST /api/v2/routing/queues/8a81b9876c4e5f001c4e5f001c4e5f00/members HTTP/1.1
Host: acme.cxone.com
Authorization: Bearer <token>
  "userId": "8a81b9876c4e5f001c4e5f001c4e5f01",
  "routingType": "ROUTED",
  "split": 1,
  "afterHoursAvailable": false
HTTP Response Example:
HTTP/1.1 200 OK
  "id": "8a81b9876c4e5f001c4e5f001c4e5f00",
  "split": 1,
  "afterHoursAvailable": false,
  "dateCreated": "2024-05-15T10:30:00.000Z",
  "dateUpdated": "2024-05-15T10:30:00.000Z"
Step 3: Wrap-up Code Activation & Rate Limit Handling
Wrap-up codes are updated via PUT. CXone enforces strict rate limits. You must implement exponential backoff with jitter when receiving a 429 Too Many Requests response. The Retry-After header specifies the wait time in seconds. This step also demonstrates pagination handling for listing codes before update.
Required Scope: routing:wrapupcode:write
async function fetchWrapUpCodesWithPagination(token, page = 1, pageSize = 25) {
  const url = `${CXONE_BASE}/api/v2/routing/wrap-up-codes`;
  const params = { page, pageSize };
  const response = await axios.get(url, {
    headers: { 'Authorization': `Bearer ${token}` },
    params
  const codes = response.data.entities || [];
  const hasNext = response.headers['x-next-page'];
  if (hasNext) {
    const nextPage = parseInt(hasNext, 10);
    const remaining = await fetchWrapUpCodesWithPagination(token, nextPage, pageSize);
    return [...codes, ...remaining];
  return codes;
async function toggleWrapUpCode(wrapUpCodeId, isAvailable) {
  const url = `${CXONE_BASE}/api/v2/routing/wrap-up-codes/${wrapUpCodeId}`;
  const payload = {
    available: isAvailable,
    wrapUpType: 'CALL'
  const config = {
    headers: {
    maxRedirects: 0
  // Retry logic for 429
  const maxRetries = 3;
  let attempt = 0;
  while (attempt < maxRetries) {
      const res = await axios.put(url, payload, config);
      console.log(`[WRAPUP] Updated ${wrapUpCodeId} to available=${isAvailable}. Status: ${res.status}`);
      return res.data;
    } catch (error) {
      if (status === 429) {
        attempt++;
        const retryAfter = error.response?.headers['retry-after'];
        const waitSeconds = retryAfter ? parseInt(retryAfter, 10) : Math.pow(2, attempt) + Math.random();
        console.warn(`[WRAPUP] Rate limited (429). Retrying in ${waitSeconds}s (attempt ${attempt}/${maxRetries})`);
        await new Promise(resolve => setTimeout(resolve, waitSeconds * 1000));
        continue;
        throw new Error(`[WRAPUP] Code ${wrapUpCodeId} not found.`);
      throw new Error(`[WRAPUP] Update failed (${status}): ${error.response?.data?.description || error.message}`);
  throw new Error(`[WRAPUP] Max retries exceeded for ${wrapUpCodeId}`);
PUT /api/v2/routing/wrap-up-codes/8a81b9876c4e5f001c4e5f001c4e5f10 HTTP/1.1
  "available": true,
  "wrapUpType": "CALL"
HTTP/1.1 200 OK
  "id": "8a81b9876c4e5f001c4e5f001c4e5f10",
  "name": "Peak Hold Callback",
  "available": true,
  "wrapUpType": "CALL",
  "dateCreated": "2024-01-10T08:00:00.000Z",
  "dateUpdated": "2024-05-15T14:05:00.000Z"
This script combines authentication, scheduling, queue membership updates, and wrap-up code toggling. Replace the placeholder IDs and environment variables with your CXone tenant values.
const OVERFLOW_QUEUE_ID = process.env.OVERFLOW_QUEUE_ID;
const AGENT_ID = process.env.AGENT_ID;
const PEAK_WRAPUP_CODE_ID = process.env.PEAK_WRAPUP_CODE_ID;
let currentPeakState = false;
    return accessToken;
    return accessToken;
  } catch (error) {
    throw new Error(`[AUTH] Token fetch failed: ${error.response?.data?.error_description || error.message}`);
  return day >= 1 && day <= 5 && (hour === 9 || hour === 10 || hour === 13 || hour === 14);
  const config = { headers: { 'Authorization': `Bearer ${token}`, 'Content-Type': 'application/json' } };
    if (addMember) {
      await axios.post(`${baseUrl}`, { userId, routingType: 'ROUTED', split: 1, afterHoursAvailable: false }, config);
    } else {
  } catch (error) {
    if (error.response?.status === 409) return;
    console.error(`[QUEUE] Error: ${error.response?.status} - ${error.response?.data?.description}`);
  const payload = { available: isAvailable, routingType: 'ROUTED', wrapUpType: 'CALL' };
  let attempt = 0;
  while (attempt < 3) {
      return;
    } catch (error) {
        attempt++;
        const wait = error.response?.headers['retry-after'] ? parseInt(error.response.headers['retry-after']) : Math.pow(2, attempt);
        await new Promise(r => setTimeout(r, wait * 1000));
        continue;
      console.error(`[WRAPUP] Error: ${error.response?.status} - ${error.response?.data?.description}`);
      return;
async function handlePeakTransition(isPeak) {
  if (isPeak === currentPeakState) {
    console.log('Peak state unchanged. Skipping.');
    return;
  console.log(`Peak state changed to: ${isPeak ? 'ACTIVE' : 'INACTIVE'}`);
  currentPeakState = isPeak;
  await updateQueueMembership(OVERFLOW_QUEUE_ID, AGENT_ID, isPeak);
  await toggleWrapUpCode(PEAK_WRAPUP_CODE_ID, isPeak);
  const peak = isPeakVolume();
  await handlePeakTransition(peak);
console.log('Peak routing scheduler initialized.');
  • What causes it: The access token has expired, or the client credentials are invalid. CXone invalidates tokens immediately after expiry.
  • How to fix it: Verify the expires_in calculation in getAccessToken. Ensure the safety margin accounts for network latency. Check that CXONE_CLIENT_ID and CXONE_CLIENT_SECRET match the confidential client registered in the CXone admin portal.
  • Code showing the fix:
// Add token refresh on 401 interceptor
axios.interceptors.response.use(
  response => response,
  async error => {
    if (error.response?.status === 401 && error.config?.url?.includes('oauth') === false) {
      console.warn('[INTERCEPTOR] 401 detected. Refreshing token and retrying...');
      error.config.headers['Authorization'] = `Bearer ${accessToken}`;
      return axios(error.config);
    return Promise.reject(error);
Error: 403 Forbidden
  • What causes it: The OAuth token lacks the required routing scopes. CXone enforces scope validation at the API gateway level.
  • How to fix it: Navigate to the CXone admin console, locate the OAuth client, and ensure routing:queue:write, routing:user:write, and routing:wrapupcode:write are explicitly checked. Regenerate the token after scope changes.
  • What causes it: CXone enforces per-client and per-endpoint rate limits. Bursting queue membership updates during peak transitions triggers throttling.
  • How to fix it: Implement the exponential backoff pattern shown in Step 3. Always read the Retry-After header. Do not retry faster than the server specifies.
Error: 404 Not Found
  • What causes it: Invalid queue ID, user ID, or wrap-up code ID. CXone uses UUID-like strings prefixed with 8a. Copying IDs from the UI sometimes includes trailing slashes or whitespace.
  • How to fix it: Trim environment variables. Validate IDs against the CXone API explorer before deployment. Use GET /api/v2/routing/queues/{id} to verify existence.
