Dynamically Updating Flow Node Configurations via the CXone Flow API with Python
  • A Python automation script that retrieves a CXone flow definition, modifies a specific node configuration based on an external REST API response, and publishes the updated flow with optimistic locking.
  • This implementation uses the NICE CXone Flow API (/api/v2/flows/{flowId}) and OAuth 2.0 Client Credentials authentication.
  • The code is written in Python 3.10+ using httpx for async HTTP operations and pydantic for payload validation.
  • OAuth 2.0 Client Credentials grant configured in CXone with flow:flows:read and flow:flows:write scopes
  • CXone API region endpoint (e.g., us-1.api.nicecxone.com or eu-1.api.nicecxone.com)
  • Python 3.10 or higher
  • External dependencies: httpx, pydantic, python-dotenv
  • A valid CXone flow ID and the target node ID within that flow
CXone uses standard OAuth 2.0 client credentials flow. The authentication endpoint returns a bearer token that expires after a fixed duration. The script caches the token and refreshes it automatically when expiration approaches.
OAuth Request Cycle
POST /oauth/token HTTP/1.1
Host: us-1.api.nicecxone.com
grant_type=client_credentials&client_id=YOUR_CLIENT_ID&client_secret=YOUR_CLIENT_SECRET&scope=flow:flows:read+flow:flows:write
OAuth Response
  "expires_in": 3600,
  "token_type": "Bearer",
  "scope": "flow:flows:read flow:flows:write"
import httpx
from typing import Optional
class CxoneAuth:
    def __init__(self, base_url: str, client_id: str, client_secret: str):
        self.client_id = client_id
        self.expires_at: float = 0.0
        if self.token and time.time() < self.expires_at - 60:
            return self.token
            response = await client.post(
                f"{self.base_url}/oauth/token",
                data={
                    "client_id": self.client_id,
            response.raise_for_status()
            token_data = response.json()
            self.token = token_data["access_token"]
            self.expires_at = time.time() + token_data["expires_in"]
            return self.token
Step 1: Fetch Flow Definition and Handle Versioning
CXone stores flow definitions with an internal version integer. Every PUT request must include the current version to prevent concurrent edit conflicts. The API returns a 409 Conflict if the version mismatch occurs.
async def fetch_flow_definition(auth: CxoneAuth, flow_id: str) -> dict:
    token = await auth.get_token()
    async with httpx.AsyncClient(timeout=15.0) as client:
        response = await client.get(
            f"{auth.base_url}/api/v2/flows/{flow_id}",
            headers={"Authorization": f"Bearer {token}"}
        return response.json()
Expected Response Structure
  "flow": {
    "version": 14,
    "name": "Customer Routing Flow",
    "nodes": [
        "id": "node_set_vars",
        "type": "set-variable",
        "configuration": {
          "variables": [
              "name": "routing_priority",
              "value": "standard"
    "edges": []
Step 2: Query External API and Parse Configuration
The script calls an external service that returns dynamic configuration values. This step isolates external network calls and validates the payload structure before merging it into the flow definition.
from pydantic import BaseModel, ValidationError
class ExternalConfig(BaseModel):
    routing_priority: str
    queue_target: str
    max_wait_time_seconds: int
async def fetch_external_config(endpoint_url: str) -> ExternalConfig:
        response = await client.get(endpoint_url)
            return ExternalConfig(**response.json())
        except ValidationError as exc:
            raise ValueError(f"Invalid external configuration payload: {exc}") from exc
Step 3: Locate Target Node and Apply Configuration Updates
The flow definition contains a list of nodes. The script iterates through the nodes, matches the target node ID, and updates the configuration dictionary. The script preserves all other node properties and edges to maintain flow integrity.
def apply_node_configuration(flow_data: dict, target_node_id: str, external_config: ExternalConfig) -> dict:
    flow_def = flow_data.get("flow", {})
    nodes = flow_def.get("nodes", [])
    updated = False
    for node in nodes:
        if node.get("id") == target_node_id:
            config = node.get("configuration", {})
            config["variables"] = [
                {"name": "routing_priority", "value": external_config.routing_priority},
                {"name": "queue_target", "value": external_config.queue_target},
                {"name": "max_wait_time_seconds", "value": external_config.max_wait_time_seconds}
            node["configuration"] = config
            updated = True
            break
    if not updated:
        raise ValueError(f"Target node {target_node_id} not found in flow definition")
    return flow_data
Step 4: Publish Updated Flow with Retry Logic
CXone enforces strict rate limits. The script implements exponential backoff for 429 responses and handles 409 version conflicts by refetching the flow definition. The PUT request sends the complete flow object back to the API.
import asyncio
async def publish_flow_update(auth: CxoneAuth, flow_id: str, flow_data: dict, max_retries: int = 3) -> dict:
            response = await client.put(
                headers={
                json=flow_data
                wait_time = 2 ** attempt
                print(f"Rate limited. Retrying in {wait_time} seconds...")
            if response.status_code == 409:
                print("Version conflict detected. Refetching flow definition...")
                flow_data = await fetch_flow_definition(auth, flow_id)
    raise RuntimeError("Failed to publish flow update after maximum retries")
The following script combines all components into a single runnable module. Replace the environment variables with your CXone credentials and external API endpoint.
import asyncio
import os
load_dotenv()
async def main():
    # Configuration
    CXONE_BASE_URL = os.getenv("CXONE_BASE_URL", "https://us-1.api.nicecxone.com")
    CXONE_CLIENT_ID = os.getenv("CXONE_CLIENT_ID")
    CXONE_CLIENT_SECRET = os.getenv("CXONE_CLIENT_SECRET")
    FLOW_ID = os.getenv("CXONE_FLOW_ID")
    TARGET_NODE_ID = os.getenv("TARGET_NODE_ID")
    EXTERNAL_API_URL = os.getenv("EXTERNAL_API_URL", "https://api.example.com/v1/cx-config")
    if not all([CXONE_CLIENT_ID, CXONE_CLIENT_SECRET, FLOW_ID, TARGET_NODE_ID]):
        raise ValueError("Missing required environment variables")
    auth = CxoneAuth(CXONE_BASE_URL, CXONE_CLIENT_ID, CXONE_CLIENT_SECRET)
        # Step 1: Fetch current flow
        print("Fetching flow definition...")
        flow_data = await fetch_flow_definition(auth, FLOW_ID)
        current_version = flow_data["flow"]["version"]
        print(f"Retrieved flow version: {current_version}")
        # Step 2: Get external configuration
        print("Fetching external configuration...")
        ext_config = await fetch_external_config(EXTERNAL_API_URL)
        print(f"External config: {ext_config.model_dump()}")
        # Step 3: Apply configuration to target node
        print(f"Updating node {TARGET_NODE_ID}...")
        updated_flow_data = apply_node_configuration(flow_data, TARGET_NODE_ID, ext_config)
        # Step 4: Publish changes
        print("Publishing updated flow...")
        result = await publish_flow_update(auth, FLOW_ID, updated_flow_data)
        print(f"Flow updated successfully. New version: {result['flow']['version']}")
        print(f"HTTP Error {e.response.status_code}: {e.response.text}")
        print(f"Automation failed: {e}")
    asyncio.run(main())
  • Cause: Expired or invalid OAuth token, or missing flow:flows:read/flow:flows:write scopes on the client credentials.
  • Fix: Verify the client ID and secret match a CXone OAuth client with the correct scopes. Ensure the token cache logic refreshes before expiration. The get_token method automatically handles refresh, but manual token inspection may be required if the CXone admin revokes the client.
Error: 403 Forbidden
  • Cause: The OAuth client lacks permissions to modify flows, or the flow belongs to a different workspace/environment than the client credentials.
  • Fix: Confirm the client credentials have flow:flows:write scope. Verify the CXONE_BASE_URL matches the environment where the flow resides. CXone isolates API access by subdomain/region.
Error: 409 Conflict
  • Cause: Optimistic locking failure. Another user or process modified the flow between the GET and PUT requests, causing a version mismatch.
  • Fix: The publish_flow_update function automatically detects 409 responses and refetches the flow definition before retrying. If the conflict persists, implement a merge strategy that preserves external changes before applying new configuration.
  • Cause: CXone API rate limit exceeded. The Flow API enforces requests per minute limits per tenant.
  • Fix: The script includes exponential backoff retry logic. If rate limits persist, reduce the frequency of automation runs or implement a request queue with token bucket throttling.
Error: Node Not Found
  • Cause: The TARGET_NODE_ID does not match any node ID in the fetched flow definition. CXone generates node IDs automatically during flow design.
  • Fix: Print the flow definition JSON during development to verify the exact node ID. Use the CXone Flow designer to copy the node ID from the node properties panel, or parse the nodes array programmatically to list available IDs.
