Dynamically Adjust NICE CXone Outbound Campaign Pacing with Node.js
A Node.js service that polls CXone Analytics API metrics, calculates real-time agent capacity, adjusts dial ratios using a proportional feedback control loop, implements circuit breakers to pause campaigns during system degradation, and logs pacing decisions for post-campaign analysis. This tutorial uses the CXone REST API v2 endpoints and modern JavaScript with axios. The language covered is Node.js 18+.
- OAuth 2.0 Client Credentials flow enabled in CXone Admin
- Required scopes:
campaigns:read,campaigns:write,analytics:read,oauth:client-credentials - Node.js 18 or higher
- External dependencies:
axios,dotenv,winston - CXone environment URL (e.g.,
https://your-org.nice.incontact.com) - Campaign ID for the target outbound campaign
CXone uses standard OAuth 2.0 client credentials. The token endpoint requires basic authentication with the client ID and secret, and returns a Bearer token with an expiration window. Token caching prevents unnecessary credential exchanges.
import axios from 'axios';
import dotenv from 'dotenv';
dotenv.config();
const CXONE_BASE = process.env.CXONE_BASE_URL;
const CLIENT_ID = process.env.CXONE_CLIENT_ID;
const CLIENT_SECRET = process.env.CXONE_CLIENT_SECRET;
let accessToken = null;
let tokenExpiry = 0;
export async function getAccessToken() {
const now = Date.now();
if (accessToken && now < tokenExpiry - 60000) {
return accessToken;
const authString = Buffer.from(`${CLIENT_ID}:${CLIENT_SECRET}`).toString('base64');
const tokenUrl = `${CXONE_BASE}/api/v2/oauth/token`;
const response = await axios.post(tokenUrl, {
scope: 'campaigns:read campaigns:write analytics:read'
headers: {
Authorization: `Basic ${authString}`,
'Content-Type': 'application/x-www-form-urlencoded',
'Accept': 'application/json'
accessToken = response.data.access_token;
tokenExpiry = now + (response.data.expires_in * 1000);
return accessToken;
HTTP Cycle Example
POST /api/v2/oauth/token
Authorization: Basic base64(client_id:client_secret)
grant_type=client_credentials&scope=campaigns:read+campaigns:write+analytics:read
Response 200:
"access_token": "eyJhbGciOiJSUzI1NiIs...",
"token_type": "Bearer",
"expires_in": 3600,
"scope": "campaigns:read campaigns:write analytics:read"
Step 1: HTTP Client with Retry Logic and 429 Handling
CXone enforces strict rate limits. The HTTP wrapper implements exponential backoff for 429 responses and propagates other errors for circuit breaker evaluation.
const baseHttpClient = axios.create({
timeout: 10000,
headers: { 'Accept': 'application/json', 'Content-Type': 'application/json' }
export async function cxoneRequest(method, path, token, data = null) {
const maxRetries = 3;
let attempt = 0;
let delay = 1000;
while (attempt < maxRetries) {
const url = `${CXONE_BASE}${path}`;
const config = {
method,
url,
headers: { Authorization: `Bearer ${token}` },
data
const response = await baseHttpClient(config);
return response.data;
} catch (error) {
const status = error.response?.status;
if (status === 429 || (status >= 500 && status < 600)) {
attempt++;
if (attempt >= maxRetries) throw error;
await new Promise(r => setTimeout(r, delay));
delay *= 2; // Exponential backoff
continue;
throw error;
Step 2: Poll Campaign Analytics and Calculate Agent Capacity
The Analytics API returns time-series data. We request the latest five-minute interval to calculate active calls, wrap-up times, and available agent capacity. Pagination is handled by following the nextPage token until the dataset is complete, though pacing logic only requires the most recent interval.
export async function fetchCampaignMetrics(token, campaignId) {
const path = '/api/v2/analytics/campaigns/details/query';
const payload = {
aggregate: [],
dateFrom: new Date(Date.now() - 10 * 60000).toISOString(),
dateTo: new Date().toISOString(),
groupBy: ['campaignId'],
interval: 'PT5M',
metrics: [
'callsOffered', 'callsAnswered', 'callsAbandoned',
'avgWrapUpTime', 'agentsAvailable', 'agentsBusy'
queryFilter: {
type: 'or',
predicates: [
{ type: 'string', field: 'campaignId', operator: 'equal', value: campaignId }
let allData = [];
let nextPage = null;
do {
const queryParams = nextPage ? `?nextPage=${encodeURIComponent(nextPage)}` : '';
const response = await cxoneRequest('POST', `${path}${queryParams}`, token, payload);
allData = allData.concat(response.entities || []);
nextPage = response.nextPage || null;
} while (nextPage);
// Sort by dateTo descending to get the latest interval
allData.sort((a, b) => new Date(b.dateTo) - new Date(a.dateTo));
const latest = allData[0];
if (!latest) {
throw new Error('No analytics data returned for the specified campaign');
activeCalls: latest.callsAnswered || 0,
avgWrapUpTime: latest.avgWrapUpTime || 30, // seconds
agentsAvailable: latest.agentsAvailable || 0,
agentsBusy: latest.agentsBusy || 0,
abandonedRate: latest.callsOffered > 0
? (latest.callsAbandoned / latest.callsOffered)
: 0
Step 3: Feedback Control Loop and Pace Validation
A proportional controller adjusts the dial ratio based on the difference between target capacity and actual capacity. The algorithm clamps the new dial ratio within CXone bounds (0.1 to 5.0) and validates against abandonment thresholds.
const PACE_CONFIG = {
minDialRatio: 0.1,
maxDialRatio: 5.0,
targetAgentUtilization: 0.85,
maxAbandonmentRate: 0.05,
kp: 0.15 // Proportional gain
export function calculateNewDialRatio(currentDialRatio, metrics, totalAgents) {
const targetCapacity = totalAgents * PACE_CONFIG.targetAgentUtilization;
const actualCapacity = metrics.agentsBusy + (metrics.activeCalls * (metrics.avgWrapUpTime / 60));
const error = targetCapacity - actualCapacity;
let adjustment = PACE_CONFIG.kp * error;
let newDialRatio = currentDialRatio + adjustment;
// Abandonment penalty
if (metrics.abandonedRate > PACE_CONFIG.maxAbandonmentRate) {
newDialRatio *= 0.8; // Reduce pace aggressively
// Clamp to valid bounds
newDialRatio = Math.max(PACE_CONFIG.minDialRatio, Math.min(PACE_CONFIG.maxDialRatio, newDialRatio));
newDialRatio = Math.round(newDialRatio * 100) / 100; // Round to 2 decimals
newDialRatio,
adjustment,
error,
valid: metrics.abandonedRate <= PACE_CONFIG.maxAbandonmentRate
Step 4: Circuit Breaker and Campaign State Management
The circuit breaker tracks consecutive failures. When the threshold is exceeded, it transitions to the open state and pauses the campaign via the Campaign API. After a cooldown period, it transitions to half-open to test system recovery.
export class CircuitBreaker {
constructor(threshold = 3, cooldownMs = 30000) {
this.threshold = threshold;
this.cooldownMs = cooldownMs;
this.failureCount = 0;
this.state = 'closed'; // closed, open, half-open
this.lastFailureTime = null;
recordSuccess() {
recordFailure() {
this.failureCount++;
this.lastFailureTime = Date.now();
if (this.failureCount >= this.threshold) {
this.state = 'open';
async allowRequest() {
if (this.state === 'closed') return true;
if (this.state === 'open') {
if (Date.now() - this.lastFailureTime > this.cooldownMs) {
this.state = 'half-open';
return true;
return false;
return true; // half-open allows one test request
getState() { return this.state; }
export async function updateCampaignPace(token, campaignId, dialRatio, status) {
const path = `/api/v2/campaigns/${campaignId}`;
const payload = {
pacing: {
dialRatio: dialRatio,
maxConcurrentCalls: Math.round(dialRatio * 100) // Example heuristic
status: status // 'active' or 'paused'
return await cxoneRequest('PUT', path, token, payload);
Step 5: Structured Logging and Main Execution Loop
Logging captures every pacing decision, metric snapshot, and circuit breaker state transition. The main loop orchestrates polling, calculation, validation, and state updates at a fixed interval.
import winston from 'winston';
const logger = winston.createLogger({
level: 'info',
format: winston.format.json(),
transports: [new winston.transports.Console()]
export async function runPacingLoop(campaignId, totalAgents, intervalMs = 15000) {
const breaker = new CircuitBreaker(3, 45000);
let currentDialRatio = 1.0;
let campaignStatus = 'active';
logger.info({ event: 'pacing_loop_start', campaignId, totalAgents, intervalMs });
while (true) {
const canProceed = await breaker.allowRequest();
if (!canProceed) {
logger.warn({ event: 'circuit_breaker_open', state: breaker.getState() });
await updateCampaignPace(await getAccessToken(), campaignId, currentDialRatio, 'paused');
await new Promise(r => setTimeout(r, intervalMs));
continue;
const token = await getAccessToken();
const metrics = await fetchCampaignMetrics(token, campaignId);
const pacingDecision = calculateNewDialRatio(currentDialRatio, metrics, totalAgents);
logger.info({
event: 'pacing_decision',
campaignId,
currentDialRatio,
newDialRatio: pacingDecision.newDialRatio,
error: pacingDecision.error,
metrics: {
activeCalls: metrics.activeCalls,
avgWrapUpTime: metrics.avgWrapUpTime,
abandonedRate: metrics.abandonedRate.toFixed(3),
agentsAvailable: metrics.agentsAvailable
circuitBreakerState: breaker.getState()
if (!pacingDecision.valid) {
logger.warn({ event: 'validation_failed', reason: 'abandonment_threshold_exceeded' });
breaker.recordFailure();
continue;
currentDialRatio = pacingDecision.newDialRatio;
await updateCampaignPace(token, campaignId, currentDialRatio, 'active');
breaker.recordSuccess();
} catch (error) {
logger.error({ event: 'pacing_loop_error', message: error.message, status: error.response?.status });
if (breaker.getState() === 'open') {
await updateCampaignPace(token, campaignId, currentDialRatio, 'paused');
logger.info({ event: 'campaign_paused_by_breaker', campaignId });
} catch (pauseError) {
logger.error({ event: 'pause_failed', message: pauseError.message });
dotenv.config();
import { getAccessToken } from './auth.js';
import { fetchCampaignMetrics } from './analytics.js';
import { calculateNewDialRatio, CircuitBreaker, updateCampaignPace } from './pacing.js';
import { runPacingLoop } from './loop.js';
level: 'info',
const CAMPAIGN_ID = process.env.CXONE_CAMPAIGN_ID;
const TOTAL_AGENTS = parseInt(process.env.CXONE_TOTAL_AGENTS, 10) || 20;
const POLL_INTERVAL = parseInt(process.env.POLL_INTERVAL_MS, 10) || 15000;
if (!CAMPAIGN_ID) {
logger.error({ event: 'missing_config', message: 'CXONE_CAMPAIGN_ID is required' });
process.exit(1);
logger.info({ event: 'service_initialized', campaignId: CAMPAIGN_ID, totalAgents: TOTAL_AGENTS });
// Exported from loop.js in the tutorial, combined here for single-file execution
export async function main() {
logger.info({ event: 'pacing_loop_start', campaignId: CAMPAIGN_ID, totalAgents: TOTAL_AGENTS, intervalMs: POLL_INTERVAL });
while (true) {
if (!canProceed) {
await updateCampaignPace(token, CAMPAIGN_ID, currentDialRatio, 'paused');
await new Promise(r => setTimeout(r, POLL_INTERVAL));
continue;
const metrics = await fetchCampaignMetrics(token, CAMPAIGN_ID);
const pacingDecision = calculateNewDialRatio(currentDialRatio, metrics, TOTAL_AGENTS);
logger.info({
currentDialRatio,
metrics: {
continue;
await updateCampaignPace(token, CAMPAIGN_ID, currentDialRatio, 'active');
} catch (error) {
logger.info({ event: 'campaign_paused_by_breaker', campaignId: CAMPAIGN_ID });
main().catch(err => {
logger.error({ event: 'fatal_error', message: err.message });
process.exit(1);
- Cause: Expired or invalid Bearer token, missing
oauth:client-credentialsscope, or incorrect Basic Auth encoding. - Fix: Verify the token refresh logic subtracts a safety buffer. Ensure
Authorization: Basic base64(client_id:client_secret)uses colon separation. Check that the CXone OAuth client is configured forclient_credentialsgrant type. - Code Fix: The
getAccessTokenfunction already implements a 60-second early refresh buffer. Add explicit logging oftokenExpiryto verify clock synchronization.
Error: 403 Forbidden
- Cause: Missing
campaigns:writeoranalytics:readscopes, or the OAuth client lacks role permissions for the target campaign. - Fix: Update the OAuth client scope list in CXone Admin. Assign the
Campaign ManagerorCampaign Administratorrole to the OAuth client identity. - Code Fix: Explicitly request scopes in the token payload:
scope: 'campaigns:read campaigns:write analytics:read'.
- Cause: Exceeding CXone rate limits, typically 100 requests per minute per client for analytics endpoints.
- Fix: The
cxoneRequestwrapper implements exponential backoff. Ensure the polling interval is not shorter than 15 seconds. Aggregate multiple API calls when possible. - Code Fix: The retry loop doubles delay on each 429 response up to three attempts. Log
Retry-Afterheader if CXone provides it.
Error: 400 Bad Request (Pace Validation)
- Cause: Submitting a
dialRatiooutside the 0.1 to 5.0 range, or providing malformed campaign payload. - Fix: The
calculateNewDialRatiofunction clamps values. Verify thepacingobject structure matches CXone schema. EnsuremaxConcurrentCallsis an integer. - Code Fix: Add explicit schema validation before PUT requests. Log the exact payload sent to
/api/v2/campaigns/{id}.
