We are using a Nortel 1000 w/ symposium. We have an issue where now every calls is getting hung up on. We have had our switch guy on the phone with Genesys trying to resolve the issue but it is at a stand still. Originally we started with just a transfer delay from the time the customer said hello to the time the CSSR received the call, so we stopped it completly and during testing it was dropping every call- I know this is probably vague but any ideas to where I should start looking? We are running Accurate_AM_detection in both the dialogic boards and in CME. The dialer is supposed to hang up on answering machine calls only.
You will have to check the call result on the calling list first. If itâs not recorded as Dropped then something is happening while itâs moving the call to CSSR. If itâs recorded as Dropped then there is something wrong with AM detection.
This option can be configured in OCServer properties as global value or in campaign objectâs properties as local campaign-level value.
If dropped call issue occurs still, it could be caused by switch call path issue.
To quickly verify voice call path (with logged-in agent, of course), make a call to the âorigination DNâ of campaign agent group object.
What transfer method is being configured? 2-step or single-step?
Is Genesys URS server being used? It would be âeasierâ if URS is in place.
Behaviors of symposium-link (as in 1Q 2007) + Genesys T-server (7.2) are quite difference from previous version.
Once CDN is registered and defined as Route Point or ACD queue object in CME, CDNâs CNTRL flag is set to YES automatically; the flag required manual configuration in switch in some previous Nortel switch/Symposium versions.
Impacts:
CDN âcannotâ be defined as ACD queue object in CME (Genesys T-server is monitor-only to the CDN and has Nortel switch to do call routing).
If ACD queue object is defined in CME anyway, Nortel switch sets CDNâs CTNL=YES and waits for 4 seconds for every call to let external application to do routing.
Please correct me on this if Iâm wrong! Any idea to configure such case (switch CDN CTNL=NO as ACD queue in Genesys monitor-only) is appreciated!
