Does Genesys ORS need a license ?
I would like to know if Genesys orchestration needs a license.
Thanks !
Commercial or Technical?
Does it need a commercial and/or technical license ?
ORS is an intrinsic part of the (Interaction/Voice) Routing Solution, which is licensed.
Do you mean “Can I deploy multiple ORS instances?”
I think he means, on his current Genesys environment with conventional URS, can he deploy ORS without any new license? I think you can without problems.
Correct Cavagnaro : we already have a Genesys Contact Center in place with URS, GVP and would like to add ORS.
…inclusive…
Inclusive? Don’t understand
Sorry Cav
If you have URS, you can use ORS… it’s inclusive.
