Display Interaction ID in softphone
Hi I just want you to copy value of interactionid to new key and display new key. InteractionId is not changing during interaction life cycle. So you cant loose it.
As I wrote previously, if this will not work, then I cant help anymore. Issue can be possibly between keyboard, chair and screen :-D.
Br Robert
Odoslané z D5803 pomocou Tapatalku
try toast.case-data.format-business-attribute
Hi Jones,
toast is popup window displayed at rifht-bottom corner of the screen. When interaction is ringing, it appears. By this option you enable user data there.
Br
Robert
I thought that is what he wanted?
Not sure what else he means with “pop-up” ?
