Dispatching NICE CXone Post-Interaction Surveys via Go with Validation and Audit Tracking
The code constructs and transmits survey dispatch payloads to the NICE CXone platform, validates opt-in status and frequency constraints, executes atomic POST operations with exponential backoff, tracks dispatch latency, and generates structured audit logs. It uses the CXone Survey Dispatch API (POST /api/v1/surveys/{surveyId}/dispatch) and Contact Management endpoints. The implementation is written in Go using the standard library with explicit context propagation, retry mechanics, and metrics collection.
- OAuth client type: Confidential client registered in CXone with
surveys:write,contacts:read, andinteractions:readscopes. - API version: CXone API v1 (Survey, Contact, and Interaction Management).
- Language/runtime: Go 1.20 or newer.
- External dependencies: None. The code uses only the Go standard library (
net/http,context,time,sync,log/slog,encoding/json,os,fmt,errors).
NICE CXone uses standard OAuth 2.0 client credentials flow. The token endpoint issues short-lived access tokens that require caching and automatic refresh. The following implementation demonstrates a thread-safe token cache with expiry validation.
package main
import (
"context"
"encoding/json"
"fmt"
"io"
"net/http"
"os"
"sync"
"time"
type OAuthToken struct {
ExpiresIn int64 `json:"expires_in"`
FetchedAt time.Time
type TokenCache struct {
mu sync.RWMutex
token *OAuthToken
func NewTokenCache() *TokenCache {
return &TokenCache{}
func (c *TokenCache) GetToken(ctx context.Context) (string, error) {
c.mu.RLock()
if c.token != nil && time.Until(c.token.FetchedAt.Add(time.Duration(c.token.ExpiresIn)*time.Second)) > 30*time.Second {
accessToken := c.token.AccessToken
c.mu.RUnlock()
return accessToken, nil
c.mu.RUnlock()
return c.fetchNewToken(ctx)
func (c *TokenCache) fetchNewToken(ctx context.Context) (string, error) {
c.mu.Lock()
defer c.mu.Unlock()
// Double-check after acquiring write lock
return c.token.AccessToken, nil
clientID := os.Getenv("CXONE_CLIENT_ID")
clientSecret := os.Getenv("CXONE_CLIENT_SECRET")
payload := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s", clientID, clientSecret)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, "https://platform.nicecxone.com/oauth/token", nil)
if err != nil {
return "", fmt.Errorf("failed to create oauth request: %w", err)
req.Header.Set("Content-Length", fmt.Sprintf("%d", len(payload)))
req.Body = io.NopCloser([]byte(payload))
resp, err := http.DefaultClient.Do(req)
if err != nil {
return "", fmt.Errorf("oauth request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("oauth authentication failed with status %d: %s", resp.StatusCode, string(body))
var tokenResp OAuthToken
return "", fmt.Errorf("failed to decode oauth response: %w", err)
c.token = &OAuthToken{
AccessToken: tokenResp.AccessToken,
ExpiresIn: tokenResp.ExpiresIn,
FetchedAt: time.Now(),
return tokenResp.AccessToken, nil
OAuth Scopes Required: surveys:write, contacts:read
Error Handling: The code returns wrapped errors for network failures, non-200 responses, and JSON decoding issues. The cache implements a 30-second buffer before expiry to prevent race conditions during concurrent requests.
Step 1: Constraint Validation and Frequency Verification
Before dispatching a survey, you must verify the respondent opt-in status and check against maximum frequency limits to prevent survey fatigue. CXone provides contact opt-in endpoints and respondent history endpoints. This step constructs the validation pipeline and enforces business rules before payload generation.
type ValidationConfig struct {
MaxSurveysPerMonth int
OptInRequired bool
type ContactValidator struct {
cache *TokenCache
baseURL string
config ValidationConfig
logger *slog.Logger
func NewContactValidator(cache *TokenCache, cfg ValidationConfig) *ContactValidator {
return &ContactValidator{
cache: cache,
baseURL: "https://platform.nicecxone.com",
config: cfg,
logger: slog.Default(),
func (v *ContactValidator) ValidateRespondent(ctx context.Context, contactID, surveyID string) error {
token, err := v.cache.GetToken(ctx)
if err != nil {
return fmt.Errorf("token retrieval failed during validation: %w", err)
if v.config.OptInRequired {
if err := v.checkOptIn(ctx, token, contactID); err != nil {
return fmt.Errorf("opt-in validation failed: %w", err)
if err := v.checkFrequency(ctx, token, contactID, surveyID); err != nil {
return fmt.Errorf("frequency limit exceeded: %w", err)
return nil
func (v *ContactValidator) checkOptIn(ctx context.Context, token, contactID string) error {
// Scope: contacts:read
req, err := http.NewRequestWithContext(ctx, http.MethodGet, fmt.Sprintf("%s/api/v1/contacts/%s/optin", v.baseURL, contactID), nil)
if err != nil {
return err
if err != nil {
return err
if resp.StatusCode == http.StatusNotFound {
return fmt.Errorf("contact %s does not exist", contactID)
return fmt.Errorf("opt-in check failed with %d: %s", resp.StatusCode, string(body))
var optin map[string]interface{}
if err := json.NewDecoder(resp.Body).Decode(&optin); err != nil {
return err
status, ok := optin["status"].(string)
if !ok || status != "OPTIN" {
return fmt.Errorf("contact %s is not opted in", contactID)
return nil
func (v *ContactValidator) checkFrequency(ctx context.Context, token, contactID, surveyID string) error {
// Scope: surveys:write, contacts:read
req, err := http.NewRequestWithContext(ctx, http.MethodGet, fmt.Sprintf("%s/api/v1/surveys/%s/respondents/%s/history", v.baseURL, surveyID, contactID), nil)
if err != nil {
return err
if err != nil {
return err
return fmt.Errorf("frequency check failed with %d: %s", resp.StatusCode, string(body))
var history []map[string]interface{}
if err := json.NewDecoder(resp.Body).Decode(&history); err != nil {
return err
// Count surveys sent in the last 30 days
now := time.Now()
count := 0
for _, entry := range history {
sentAtRaw, ok := entry["sentAt"].(float64)
if !ok {
sentAt := time.Unix(int64(sentAtRaw/1000), 0)
if now.Sub(sentAt) < 30*24*time.Hour {
count++
if count >= v.config.MaxSurveysPerMonth {
return fmt.Errorf("respondent %s has exceeded maximum frequency limit (%d/%d)", contactID, count, v.config.MaxSurveysPerMonth)
return nil
OAuth Scopes Required: contacts:read, surveys:write
Error Handling: The validator returns explicit errors for missing contacts, non-optin status, and frequency threshold breaches. HTTP 404 and 4xx responses are captured and wrapped with context.
Step 2: Payload Construction and Send Directive Configuration
The dispatch payload requires a form reference, survey matrix configuration, send directive, respondent targeting array, and reminder trigger settings. This step assembles the JSON structure and validates format compliance before transmission.
type DispatchPayload struct {
SurveyID string `json:"surveyId"`
FormID string `json:"formId"`
SendDirective string `json:"sendDirective"`
Respondents []RespondentTarget `json:"respondents"`
Reminders *ReminderConfig `json:"reminders,omitempty"`
Matrix map[string]interface{} `json:"matrix,omitempty"`
type RespondentTarget struct {
ContactID string `json:"contactId"`
Channel string `json:"channel"`
type ReminderConfig struct {
Enabled bool `json:"enabled"`
IntervalHours int `json:"intervalHours"`
MaxRetries int `json:"maxRetries"`
func ConstructDispatchPayload(surveyID, formID string, targets []RespondentTarget, enableReminders bool) DispatchPayload {
payload := DispatchPayload{
SurveyID: surveyID,
FormID: formID,
SendDirective: "IMMEDIATE",
Respondents: targets,
Matrix: map[string]interface{}{
"layoutVersion": "2.0",
"routingStrategy": "CHANNEL_PREFERENCE",
"fallbackChannel": "EMAIL",
if enableReminders {
payload.Reminders = &ReminderConfig{
Enabled: true,
IntervalHours: 48,
MaxRetries: 2,
return payload
Error Handling: Payload construction is deterministic. Runtime validation occurs during JSON marshaling. The matrix configuration enforces channel routing calculation and fallback behavior.
Step 3: Atomic Dispatch with Retry Logic and Latency Tracking
This step executes the POST request to the CXone dispatch endpoint. It implements exponential backoff for 429 rate-limit responses, measures request latency, and updates success metrics. The operation is atomic and idempotent at the application level.
type DispatchMetrics struct {
mu sync.Mutex
TotalDispatch int
Successful int
Failed int
TotalLatency time.Duration
func (m *DispatchMetrics) RecordDispatch(success bool, latency time.Duration) {
m.mu.Lock()
defer m.mu.Unlock()
m.TotalDispatch++
m.TotalLatency += latency
if success {
m.Successful++
} else {
m.Failed++
func (m *DispatchMetrics) GetSuccessRate() float64 {
m.mu.Lock()
defer m.mu.Unlock()
if m.TotalDispatch == 0 {
return 0.0
return float64(m.Successful) / float64(m.TotalDispatch)
func (m *DispatchMetrics) GetAvgLatency() time.Duration {
m.mu.Lock()
defer m.mu.Unlock()
return 0
return m.TotalLatency / time.Duration(m.TotalDispatch)
func ExecuteDispatch(ctx context.Context, cache *TokenCache, payload DispatchPayload, metrics *DispatchMetrics, logger *slog.Logger) (string, error) {
token, err := cache.GetToken(ctx)
if err != nil {
return "", fmt.Errorf("dispatch aborted: %w", err)
jsonBytes, err := json.Marshal(payload)
if err != nil {
return "", fmt.Errorf("payload serialization failed: %w", err)
maxRetries := 3
baseDelay := 1 * time.Second
var lastErr error
for attempt := 0; attempt <= maxRetries; attempt++ {
start := time.Now()
req, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("https://platform.nicecxone.com/api/v1/surveys/%s/dispatch", payload.SurveyID), nil)
if err != nil {
return "", fmt.Errorf("request creation failed: %w", err)
req.Body = io.NopCloser(bytes.NewReader(jsonBytes))
latency := time.Since(start)
if err != nil {
lastErr = fmt.Errorf("network error on attempt %d: %w", attempt+1, err)
logger.Error("dispatch network failure", "attempt", attempt+1, "error", err)
time.Sleep(baseDelay)
baseDelay *= 2
respBody, _ := io.ReadAll(resp.Body)
lastErr = fmt.Errorf("rate limited on attempt %d: %s", attempt+1, string(respBody))
logger.Warn("dispatch rate limited", "attempt", attempt+1, "body", string(respBody))
baseDelay *= 2
if resp.StatusCode >= 500 {
lastErr = fmt.Errorf("server error on attempt %d: %s", attempt+1, string(respBody))
logger.Error("dispatch server error", "attempt", attempt+1, "status", resp.StatusCode)
baseDelay *= 2
if resp.StatusCode != http.StatusCreated && resp.StatusCode != http.StatusOK {
metrics.RecordDispatch(false, latency)
return "", fmt.Errorf("dispatch failed with %d: %s", resp.StatusCode, string(respBody))
metrics.RecordDispatch(true, latency)
logger.Info("dispatch successful", "surveyId", payload.SurveyID, "latency", latency.String())
return string(respBody), nil
metrics.RecordDispatch(false, 0)
return "", lastErr
Error Handling: The retry loop handles 429, 5xx, and transient network errors. Latency is measured per attempt. Metrics are thread-safe. Final failure returns the last encountered error.
Step 4: Audit Logging and External Webhook Synchronization
Governance requires immutable dispatch records and external system alignment. This step generates structured audit logs and constructs webhook payloads for downstream feedback platforms.
type AuditEvent struct {
RespondentID string `json:"respondentId"`
Status string `json:"status"`
LatencyMs int64 `json:"latencyMs"`
Error string `json:"error,omitempty"`
WebhookSync bool `json:"webhookSynced"`
type WebhookPayload struct {
Event string `json:"event"`
Tenant string `json:"tenant"`
Payload AuditEvent `json:"payload"`
func GenerateAuditLog(event AuditEvent, logger *slog.Logger) {
logger.Info("audit: survey dispatch",
"survey_id", event.SurveyID,
"respondent_id", event.RespondentID,
"status", event.Status,
"latency_ms", event.LatencyMs,
"webhook_synced", event.WebhookSync,
func SyncToWebhook(ctx context.Context, webhookURL string, event AuditEvent) error {
payload := WebhookPayload{
Event: "survey.dispatched",
Tenant: "cxone-enterprise",
Payload: event,
if err != nil {
return fmt.Errorf("webhook payload serialization failed: %w", err)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, webhookURL, nil)
if err != nil {
return fmt.Errorf("webhook request creation failed: %w", err)
if err != nil {
return fmt.Errorf("webhook delivery failed: %w", err)
if resp.StatusCode < 200 || resp.StatusCode >= 300 {
return fmt.Errorf("webhook returned %d: %s", resp.StatusCode, string(body))
return nil
OAuth Scopes Required: None (external system)
Error Handling: Webhook failures are captured and returned. Audit logs are written synchronously to ensure governance compliance. The payload structure aligns with standard event-driven architectures.
The following module combines authentication, validation, payload construction, dispatch execution, metrics tracking, and audit synchronization into a single runnable dispatcher.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"io"
"log/slog"
"net/http"
"os"
"sync"
"time"
// [OAuthToken, TokenCache, ValidationConfig, ContactValidator,
// DispatchPayload, RespondentTarget, ReminderConfig,
// ConstructDispatchPayload, DispatchMetrics, ExecuteDispatch,
// AuditEvent, WebhookPayload, GenerateAuditLog, SyncToWebhook]
// definitions from previous steps are included here for a single-file build.
func main() {
ctx := context.Background()
logger := slog.New(slog.NewJSONHandler(os.Stdout, nil))
slog.SetDefault(logger)
cache := NewTokenCache()
metrics := &DispatchMetrics{}
validator := NewContactValidator(cache, ValidationConfig{
MaxSurveysPerMonth: 3,
OptInRequired: true,
surveyID := os.Getenv("SURVEY_ID")
formID := os.Getenv("FORM_ID")
contactID := os.Getenv("CONTACT_ID")
webhookURL := os.Getenv("WEBHOOK_URL")
if surveyID == "" || formID == "" || contactID == "" {
logger.Error("missing environment variables: SURVEY_ID, FORM_ID, CONTACT_ID")
os.Exit(1)
// Step 1: Validate constraints
logger.Info("validating respondent constraints", "contact_id", contactID, "survey_id", surveyID)
if err := validator.ValidateRespondent(ctx, contactID, surveyID); err != nil {
logger.Error("validation failed", "error", err)
os.Exit(1)
// Step 2: Construct payload
targets := []RespondentTarget{
{ContactID: contactID, Channel: "EMAIL"},
payload := ConstructDispatchPayload(surveyID, formID, targets, true)
// Step 3: Execute dispatch
logger.Info("executing survey dispatch", "survey_id", surveyID)
respBody, err := ExecuteDispatch(ctx, cache, payload, metrics, logger)
if err != nil {
logger.Error("dispatch failed", "error", err)
audit := AuditEvent{
Timestamp: time.Now(),
SurveyID: surveyID,
RespondentID: contactID,
Status: "FAILED",
LatencyMs: 0,
Error: err.Error(),
GenerateAuditLog(audit, logger)
os.Exit(1)
// Step 4: Audit and webhook sync
SurveyID: surveyID,
Status: "SUCCESS",
LatencyMs: metrics.GetAvgLatency().Milliseconds(),
WebhookSync: false,
if webhookURL != "" {
if err := SyncToWebhook(ctx, webhookURL, audit); err != nil {
logger.Error("webhook sync failed", "error", err)
} else {
audit.WebhookSync = true
logger.Info("webhook sync completed", "url", webhookURL)
logger.Info("dispatch complete",
"success_rate", metrics.GetSuccessRate(),
"avg_latency", metrics.GetAvgLatency().String(),
"response_body", respBody)
Run Instructions: Set CXONE_CLIENT_ID, CXONE_CLIENT_SECRET, SURVEY_ID, FORM_ID, CONTACT_ID, and optionally WEBHOOK_URL. Execute with go run main.go. The program validates constraints, dispatches the survey, tracks metrics, logs audit events, and synchronizes with external systems.
- Cause: Expired OAuth token, incorrect client credentials, or missing
Authorizationheader. - Fix: Verify
CXONE_CLIENT_IDandCXONE_CLIENT_SECRETenvironment variables. Ensure the token cache refreshes before expiry. Check that the request includesBearer <token>in the header. - Code Fix: The
TokenCacheimplementation automatically refreshes tokens when within 30 seconds of expiry. If the error persists, validate credentials against the CXone admin console.
Error: 403 Forbidden
- Cause: Missing OAuth scopes or insufficient role permissions for the survey or contact.
- Fix: Grant
surveys:writeandcontacts:readscopes to the OAuth client. Verify the executing role has Survey Administrator or equivalent permissions. - Code Fix: Log the exact HTTP response body. CXone returns scope-specific error codes. Adjust client scope configuration in the platform settings.
- Cause: Exceeding CXone API rate limits (typically 100 requests per minute per client).
- Fix: Implement exponential backoff. The
ExecuteDispatchfunction handles this automatically by sleeping and retrying up to three times. - Code Fix: Increase
baseDelayormaxRetriesif volume is high. Distribute dispatch calls across multiple client IDs if scaling beyond platform limits.
Error: 400 Bad Request
- Cause: Invalid JSON structure, missing required fields, or malformed survey matrix.
- Fix: Validate
DispatchPayloadfields before serialization. EnsuresurveyId,formId,sendDirective, andrespondentsare present and correctly typed. - Code Fix: Add JSON schema validation prior to
json.Marshal. Log the exact request payload for inspection.
