system
1
The Genesys Outbound Suite Installation Guide (ver 16) states :
"Genesys recommends highdensity boards of type ISA. While Dialogic PCI boards should also work with SDialer, the combina ion
has not been tested."
Has anyone tried using Dialogic PCI boards with Genensys Outbound ? Did it work ok ? I am looking at D/120JCTLS.
system
2
We are using Dialogic boards in our lab environment. I am not sure the exact model number off the top of my head, but I will look it up.
For the record though, we have been using Dialogic without any serious problems. Most of the bugs we have so far found were actually softwareased.
By the way, if Dialogic is not the card of choice, what is?
