Diagnosing Zoom Contact Center WebRTC Audio Quality Issues Related to Packet Loss and Jitter
This guide provides the technical framework for isolating and resolving audio degradation (choppiness, robotic voice, or one-way audio) in Zoom Contact Center (ZCC) environments utilizing WebRTC. You will learn how to analyze the RTP stream, identify network congestion points, and implement the necessary QoS and firewall optimizations to stabilize voice traffic.
  • Licensing: Zoom Contact Center license (any tier) with WebRTC enabled.
  • Permissions:
    • Zoom Admin role with Contact Center Management permissions.
    • Network Administrator access to the local LAN/WAN and Firewall/Edge router.
    • Access to the end-user’s browser developer tools (Chrome/Edge).
  • External Dependencies:
    • Ability to capture PCAP files via Wireshark or similar packet analyzers.
    • Access to a network testing tool (e.g., MTR or iPerf3) on the client machine.
1. Capturing WebRTC Internal Statistics
Before analyzing the network fabric, you must determine if the issue is occurring at the browser level or the transport layer. Zoom utilizes the WebRTC getStats() API, which exposes real-time metrics on jitter and packet loss.
To diagnose a live call, open the browser’s Developer Tools (F12) and navigate to the Console. While the audio issue is occurring, you must examine the rtcStats provided by the Zoom client. You are looking for three specific metrics:
  • jitter: Measured in milliseconds. Values exceeding 30ms typically result in audible “robotic” voice.
  • packetsLost: The cumulative number of packets that failed to arrive.
  • fractionLost: The percentage of lost packets. Anything above 2% is perceptible; above 5% is disruptive.
The Trap: Many engineers rely on a standard “ping” test to the Zoom domain. This is a mistake. ICMP traffic (ping) is handled differently by routers than UDP traffic (WebRTC). A ping test may show 0% loss while the UDP stream is being throttled or dropped by a policing policy on a firewall. Always prioritize RTP stream statistics over ICMP diagnostics.
Architectural Reasoning: WebRTC uses a Jitter Buffer to collect arriving packets and play them back at a steady rate. When jitter exceeds the buffer’s capacity, the browser is forced to discard packets, which the user perceives as “chopping.” By analyzing the internal stats, you can confirm whether the network is delivering packets late (jitter) or not at all (loss).
2. Analyzing the UDP Transport and Port Strategy
Zoom Contact Center relies on UDP for media transport to minimize latency. If the network environment is overly restrictive, the WebRTC client may attempt to fall back to TCP or use a TURN server (Traversal Using Relays around NAT), which introduces significant latency and increases the likelihood of jitter.
Verify that the following port ranges are open and prioritized:
  • UDP 8801 - 8810: Primary media ports.
  • UDP 3478 - 3481: STUN/TURN traffic.
If you observe that the connection is utilizing a TURN relay (visible in the WebRTC internal logs as a relay candidate rather than a host or srflx candidate), the audio is taking an indirect path through a relay server. This adds an extra hop, increasing the probability of packet loss.
The Trap: Implementing “Deep Packet Inspection” (DPI) on VoIP traffic. Many security appliances attempt to inspect the contents of the RTP stream. Because RTP is time-sensitive, the milliseconds spent inspecting the packet often push the jitter beyond the acceptable threshold for the WebRTC jitter buffer.
Architectural Reasoning: We prioritize UDP over TCP because TCP’s retransmission mechanism is antithetical to real-time voice. A retransmitted voice packet arrives too late to be useful and only serves to congest the link further. Ensuring a clean UDP path is the only way to maintain “toll-quality” audio.
3. Validating Quality of Service (QoS) and DSCP Tagging
In a converged network where voice and data share the same pipe, “bursty” data traffic (such as a large file upload or a software update) can saturate the uplink, causing “micro-burst” packet loss for WebRTC streams.
You must implement DSCP (Differentiated Services Code Point) tagging. For Zoom WebRTC traffic:
  • Tagging: Ensure voice packets are tagged as EF (Expedited Forwarding) or DSCP 46.
  • Queueing: Configure your switches and routers to place EF traffic into a Priority Queue (PQ), ensuring it is processed before standard Best Effort (BE) traffic.
To validate this, use Wireshark on the agent’s workstation. Capture a sample of the outgoing traffic and inspect the IP header. Look for the Differentiated Services Field. If it is 0x00, the traffic is not being prioritized, and the agent is competing with background data.
The Trap: Tagging traffic at the workstation but failing to trust those tags at the first-hop switch. If the switch port is not configured for mls qos trust dscp, the switch will strip the EF tag and reset it to 0, rendering the workstation’s QoS configuration useless.
Architectural Reasoning: We use a Priority Queue rather than Weighted Fair Queueing (WFQ) for voice because voice cannot tolerate the variable delay associated with weighted sharing. It must be “first out” of the interface buffer regardless of other traffic volume.
Edge Case 1: The “Home Office” Bufferbloat
The failure condition: Agents working from home experience intermittent audio cutting out only when other people in their household are using the internet (e.g., streaming 4K video).
The root cause: This is typically “Bufferbloat.” The home router’s buffer fills up with large TCP packets from the video stream, causing the small, time-sensitive UDP packets from Zoom to be queued behind them or dropped entirely.
The solution: Implement a “Smart Queue Management” (SQM) or “Cake” algorithm on the home router. If the hardware does not support this, the agent must be moved to a wired Ethernet connection and the router’s “Gaming” or “VoIP” priority mode must be enabled to prioritize the Zoom UDP port range.
Edge Case 2: Asymmetric Routing and One-Way Audio
The failure condition: The agent can hear the customer, but the customer cannot hear the agent, or the audio is heavily distorted in only one direction.
The root cause: Asymmetric routing occurs when the outgoing packet takes one path through the network and the returning packet takes another. If one of those paths involves a stateful firewall that did not see the initial “outbound” request, it will drop the “inbound” RTP packets as unsolicited traffic.
The solution: Verify that the firewall is configured to allow the UDP port ranges bidirectionally and that there are no conflicting routing tables (e.g., a VPN tunnel for data but a local breakout for voice) that split the traffic path.
Edge Case 3: Browser-Based CPU Throttling
The failure condition: High jitter and packet loss are reported in getStats(), but the network hardware shows 0% loss and low latency.
The root cause: The agent’s machine is under heavy CPU load (e.g., too many open browser tabs or a memory-intensive CRM). When the CPU spikes, the browser cannot process the WebRTC audio buffer fast enough, leading to “internal” packet loss where packets arrive at the NIC but are dropped before they reach the audio driver.
The solution: Monitor the browser’s Task Manager (Shift+Esc in Chrome). If the Zoom tab is hitting CPU limits, disable hardware acceleration or close unnecessary extensions that may be injecting scripts into the page.
