Diagnosing WebSocket Stability and Audio Latency in Genesys Cloud AppFoundry Integrations
- A diagnostic Python script that establishes a persistent WebSocket connection to Genesys Cloud to monitor real-time conversation events and calculate audio latency metrics.
- A Node.js middleware module for AppFoundry that implements exponential backoff reconnection logic to prevent bot session drops during network instability.
- A Go-based latency probe that measures round-trip time between the AppFoundry endpoint and the Genesys Cloud routing engine to identify network bottlenecks.
- Platform: Genesys Cloud CX
- API/SDK: Genesys Cloud Python SDK (
genesyscloud), Native WebSocket libraries, REST API v2 - Language: Python 3.9+, Node.js 18+, Go 1.20+
- Dependencies:
- Python:
pip install genesyscloud requests websocket-client - Node:
npm install axios ws - Go:
go get github.com/gorilla/websocket
- Python:
- Permissions: OAuth Client with scope
analytics:conversation:readanduser:presence:read. - AppFoundry: An active AppFoundry integration with a configured endpoint URL.
Genesys Cloud APIs require OAuth 2.0 Client Credentials flow for server-to-server communication. The WebSocket streaming APIs also require a valid access token in the query parameters or headers.
Python Token Acquisition
import os
import requests
from typing import Optional
class GenesysAuth:
def __init__(self, region: str, client_id: str, client_secret: str):
self.region = region
self.client_id = client_id
self.base_url = f"https://{region}.mypurecloud.com"
self.token_expiry: Optional[int] = None
def get_token(self) -> str:
Retrieves an OAuth2 access token using Client Credentials flow.
Implements basic caching to avoid unnecessary token refreshes.
if self.access_token:
return self.access_token
url = f"{self.base_url}/oauth/token"
headers = {
data = {
"client_id": self.client_id,
"scope": "analytics:conversation:read user:presence:read"
response = requests.post(url, headers=headers, data=data)
response.raise_for_status()
token_data = response.json()
raise RuntimeError("Invalid Client ID or Secret.") from e
elif response.status_code == 403:
raise RuntimeError("Client lacks required scopes.") from e
else:
raise RuntimeError(f"Auth failed: {e}") from e
raise RuntimeError(f"Network error during auth: {e}") from e
Step 1: Establishing a Stable WebSocket Connection with Reconnection Logic
WebSocket connections to Genesys Cloud for real-time data (such as conversation events or presence updates) are prone to drops due to NAT timeouts, firewall interference, or platform-side scaling events. A robust integration must implement exponential backoff and jitter to prevent thundering herd problems.
We will use the websocket-client library in Python to connect to the real-time events endpoint.
import websocket
import json
import logging
import random
from datetime import datetime
class GenesysWebSocketMonitor:
def __init__(self, auth: GenesysAuth, user_id: str):
self.auth = auth
self.user_id = user_id
self.ws_url = f"wss://{auth.region}.mypurecloud.com/api/v2/analytics/conversations/events/ws"
self.ws = None
self.is_connected = False
self.reconnect_delay = 1 # Base delay in seconds
self.max_reconnect_delay = 60 # Max delay in seconds
def _connect(self):
Initiates the WebSocket connection with the access token.
token = self.auth.get_token()
# Genesys WS endpoints often require the token in query params or headers.
# For analytics events, we typically pass it in the query string or as a header.
# Here we use query params for simplicity with websocket-client.
ws_uri = f"{self.ws_url}?access_token={token}"
logger.info("Connecting to Genesys WebSocket...")
self.ws = websocket.WebSocketApp(
ws_uri,
on_open=self._on_open,
on_message=self._on_message,
on_error=self._on_error,
on_close=self._on_close
# Run forever until closed
self.ws.run_forever()
def _on_open(self, ws):
logger.info("WebSocket connection established.")
self.is_connected = True
self.reconnect_delay = 1 # Reset delay on successful connection
# Subscribe to conversation events for a specific user
subscribe_message = {
"type": "subscribe",
"topic": f"conversation:user:{self.user_id}"
ws.send(json.dumps(subscribe_message))
logger.info(f"Subscribed to user {self.user_id}")
def _on_message(self, ws, message):
data = json.loads(message)
# Calculate latency based on server timestamp if available
if "timestamp" in data:
server_time = datetime.fromisoformat(data["timestamp"].replace("Z", "+00:00"))
local_time = datetime.now(server_time.tzinfo)
latency_ms = (local_time - server_time).total_seconds() * 1000
logger.debug(f"Event received. Latency: {latency_ms:.2f} ms")
except json.JSONDecodeError:
logger.warning(f"Received non-JSON message: {message}")
logger.error(f"Error processing message: {e}")
def _on_error(self, ws, error):
logger.error(f"WebSocket error: {error}")
def _on_close(self, ws, close_status_code, close_msg):
logger.warning(f"WebSocket closed. Status: {close_status_code}, Msg: {close_msg}")
self._reconnect()
def _reconnect(self):
Implements exponential backoff with jitter for reconnection.
if not self.is_connected:
jitter = random.uniform(0, self.reconnect_delay)
delay = self.reconnect_delay + jitter
logger.info(f"Reconnecting in {delay:.2f} seconds...")
time.sleep(delay)
# Increase delay for next attempt, capped at max
self.reconnect_delay = min(self.reconnect_delay * 2, self.max_reconnect_delay)
# Attempt to reconnect
self._connect()
logger.error(f"Reconnection failed: {e}")
self._reconnect()
# Usage
auth = GenesysAuth(
region="us-east-1",
client_id=os.getenv("GENESYS_CLIENT_ID"),
client_secret=os.getenv("GENESYS_CLIENT_SECRET")
monitor = GenesysWebSocketMonitor(auth, user_id="12345678-1234-1234-1234-123456789012")
monitor._connect()
Step 2: Implementing AppFoundry Middleware with Timeout and Retry Logic
When integrating with Cognigy or other bot platforms via AppFoundry, the HTTP request from Genesys Cloud to your endpoint is strict about timeouts. If your bot logic takes too long, Genesys returns a 504 Gateway Timeout, causing the conversation to hang or drop.
This Node.js example shows how to structure an AppFoundry endpoint that handles partial failures and ensures the response is sent within the Genesys SLA (typically 3-5 seconds for initial response, with async follow-ups).
const express = require('express');
const crypto = require('crypto');
const app = express();
app.use(express.json());
// Configuration
const GENESYS_REGION = process.env.GENESYS_REGION || 'us-east-1';
const GENESYS_API_URL = `https://${GENESYS_REGION}.mypurecloud.com/api/v2`;
const OAUTH_TOKEN = process.env.GENESYS_ACCESS_TOKEN; // Pre-fetched token for brevity
* Handles the incoming request from Genesys Cloud AppFoundry.
* @param {Object} req - Express request object
* @param {Object} res - Express response object
async function handleAppFoundryRequest(req, res) {
const { conversationId, userId, transcript, input } = req.body;
// 1. Validate Input
if (!conversationId || !input) {
return res.status(400).json({ error: "Missing conversationId or input" });
const startTime = Date.now();
const timeoutMs = 4000; // Genesys expects a response within ~5s
// 2. Call External Bot Logic (e.g., Cognigy, LLM, DB)
// Use AbortController to enforce timeout on downstream calls
const controller = new AbortController();
const timeoutId = setTimeout(() => controller.abort(), timeoutMs);
let botResponse = "";
// Simulate external bot call
botResponse = await callExternalBot(input, { signal: controller.signal });
} catch (botError) {
if (botError.name === 'AbortError') {
console.error(`Bot call timed out for conversation ${conversationId}`);
// Fallback: Send a partial response to Genesys to keep the channel alive
botResponse = "I am experiencing a slight delay. Please hold on.";
// Optionally, queue the real response for async delivery later
queueAsyncResponse(conversationId, input);
} else {
throw botError;
} finally {
clearTimeout(timeoutId);
const endTime = Date.now();
const latency = endTime - startTime;
console.log(`Response generated in ${latency}ms`);
// 3. Construct Genesys AppFoundry Response
// The structure depends on the AppFoundry profile, but typically includes text and/or actions
const responsePayload = {
text: botResponse,
// Optional: Include metadata for logging
_latency_ms: latency,
_timestamp: new Date().toISOString()
// 4. Send Response
res.json(responsePayload);
} catch (error) {
console.error("Critical error in AppFoundry handler:", error);
// Return a graceful error message to the user
res.json({
text: "Sorry, I encountered an error. Please try again later."
* Simulates an external bot call with abort support.
async function callExternalBot(input, options) {
// Example: Calling a mock Cognigy-like endpoint
// In production, this would be your actual bot integration
const mockBotUrl = "https://your-bot-engine.example.com/predict";
const response = await axios.post(mockBotUrl, {
text: input,
sessionId: crypto.randomUUID()
}, options);
return response.data.response;
* Queues an async response to be sent to Genesys via API later.
async function queueAsyncResponse(conversationId, input) {
// In a real app, push this to a message queue (SQS, RabbitMQ)
// A worker process would then call Genesys API to add a message to the conversation
console.log(`Queued async response for ${conversationId}: ${input}`);
app.post('/appfoundry/callback', handleAppFoundryRequest);
const PORT = process.env.PORT || 3000;
app.listen(PORT, () => {
console.log(`AppFoundry endpoint listening on port ${PORT}`);
Step 3: Measuring Network Latency with Go
To diagnose audio latency or WebSocket drops, you need to measure the network path between your AppFoundry server and Genesys Cloud. This Go script sends periodic HTTP probes to the Genesys Cloud API to measure round-trip time (RTT). High RTT correlates with WebSocket latency and potential drops.
package main
import (
"fmt"
"net/http"
"os"
"time"
// ProbeGenesysLatency sends an HTTP request to Genesys Cloud and measures RTT.
func ProbeGenesysLatency(region string, token string) error {
url := fmt.Sprintf("https://%s.mypurecloud.com/api/v2/users/me", region)
client := &http.Client{
Timeout: 5 * time.Second,
req, err := http.NewRequest("GET", url, nil)
if err != nil {
return fmt.Errorf("failed to create request: %w", err)
start := time.Now()
resp, err := client.Do(req)
if err != nil {
return fmt.Errorf("request failed: %w", err)
defer resp.Body.Close()
elapsed := time.Since(start)
return fmt.Errorf("unexpected status code: %d", resp.StatusCode)
fmt.Printf("Latency to %s.mypurecloud.com: %v\n", region, elapsed)
return nil
func main() {
region := os.Getenv("GENESYS_REGION")
if region == "" {
region = "us-east-1"
token := os.Getenv("GENESYS_ACCESS_TOKEN")
if token == "" {
fmt.Println("Error: GENESYS_ACCESS_TOKEN environment variable not set")
os.Exit(1)
fmt.Println("Starting latency probe... Press Ctrl+C to stop.")
ticker := time.NewTicker(10 * time.Second)
defer ticker.Stop()
for {
<-ticker.C
err := ProbeGenesysLatency(region, token)
if err != nil {
fmt.Printf("Probe error: %v\n", err)
Below is the complete Python script for monitoring WebSocket stability. Save this as websocket_monitor.py.
import os
import sys
import requests
import websocket
import json
import logging
import random
# Configure Logging
level=logging.INFO,
format='%(asctime)s - %(name)s - %(levelname)s - %(message)s'
class GenesysAuth:
Handles OAuth2 Client Credentials flow for Genesys Cloud.
self.token_expiry: Optional[float] = 0
Retrieves an OAuth2 access token. Caches token until near expiry.
# Check if token is still valid (buffer 60 seconds)
if self.access_token and time.time() < self.token_expiry - 60:
data = {
self.token_expiry = time.time() + token_data["expires_in"]
logger.info("Token refreshed successfully.")
else:
Monitors Genesys Cloud WebSocket connections for drops and latency.
self.auth = auth
self.ws = None
self.message_count = 0
def _connect(self):
Initiates the WebSocket connection.
logger.info(f"Connecting to {ws_uri}")
ws_uri,
# Run forever
# Subscribe to user events
logger.error(f"Failed to send subscribe message: {e}")
self.message_count += 1
if latency_ms > 200: # Log only high latency
logger.warning(f"High latency detected: {latency_ms:.2f} ms")
logger.warning(f"Non-JSON message received")
self._reconnect()
Exponential backoff with jitter.
time.sleep(delay)
self._connect()
self._reconnect()
def main():
region = os.getenv("GENESYS_REGION", "us-east-1")
user_id = os.getenv("GENESYS_USER_ID")
if not all([client_id, client_secret, user_id]):
logger.error("Missing environment variables: GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET, GENESYS_USER_ID")
sys.exit(1)
auth = GenesysAuth(region=region, client_id=client_id, client_secret=client_secret)
monitor = GenesysWebSocketMonitor(auth, user_id=user_id)
monitor._connect()
except KeyboardInterrupt:
logger.info("Monitoring stopped by user.")
logger.error(f"Fatal error: {e}")
sys.exit(1)
main()
Error: 401 Unauthorized on WebSocket Connect
Cause: The access token provided in the WebSocket URI is expired, invalid, or lacks the required analytics:conversation:read scope.
Fix: Ensure your GenesysAuth class correctly fetches the token before establishing the connection. Verify the OAuth client credentials have the correct scopes in the Genesys Cloud Admin Console under Security > OAuth Clients.
Code Fix:
# In GenesysAuth.get_token()
# Ensure scope is correct
data = {
"scope": "analytics:conversation:read" # Critical
Error: WebSocket Connection Drops Frequently (Status 1006)
Cause: Network instability, firewall timeouts, or the Genesys Cloud platform scaling events.
Fix: Implement the exponential backoff reconnection logic shown in Step 1. Ensure your infrastructure (load balancers, proxies) has a WebSocket idle timeout longer than the Genesys Cloud ping/pong interval (typically 30-60 seconds).
Code Fix:
# In GenesysWebSocketMonitor._reconnect()
# Add jitter to prevent thundering herd
time.sleep(delay)
Error: AppFoundry 504 Gateway Timeout
Cause: The external bot logic (Cognigy, LLM, etc.) took longer than 5 seconds to respond, causing Genesys Cloud to abort the request.
Fix: Implement async processing. Send a placeholder response immediately (e.g., “Processing…”) and then use the Genesys Cloud REST API to add the final message to the conversation asynchronously.
Code Fix:
// In Node.js AppFoundry handler
res.json({ text: "Please hold on, I am working on that." });
// Queue async response
Error: High Audio Latency (>200ms)
Cause: Network path latency between the client and Genesys Cloud, or between Genesys Cloud and your AppFoundry endpoint.
Fix: Use the Go latency probe to identify if the issue is network-related. If the RTT to Genesys Cloud is high, consider deploying your AppFoundry endpoint in a region closer to the Genesys Cloud data center. If the RTT is low but latency is high, check your bot logic for blocking operations.
Code Fix:
// Run the Go probe
// If latency > 100ms consistently, check network path
go run latency_probe.go
