Diagnosing WebSocket Instability and Audio Latency in Genesys Cloud AppFoundry Integrations
- You will build a Python diagnostic tool that simulates a Genesys Cloud AppFoundry backend to monitor WebSocket connection stability and measure audio latency.
- This tutorial uses the Genesys Cloud REST API for analytics and the
websocketslibrary to simulate the integration layer. - The code is written in Python 3.9+ using
requestsandwebsockets.
- OAuth Client: A Genesys Cloud OAuth client with
agent:read,analytics:read, andintegrations:readscopes. - AppFoundry App: An active AppFoundry application with a defined WebSocket endpoint.
- Python Environment: Python 3.9 or later.
- Dependencies:
requests(for REST API calls)websockets(for WebSocket simulation)purecloudplatformclientv2(optional, for SDK comparison, but this tutorial uses rawrequestsfor clarity on HTTP mechanics).
Before interacting with Genesys Cloud APIs or validating integration logs, you must obtain a valid access token. This tutorial uses the Client Credentials flow, which is standard for server-to-server integrations like AppFoundry backends.
import requests
from typing import Optional, Dict, Any
class GenesysAuth:
def __init__(self, client_id: str, client_secret: str, org_id: str):
self.client_id = client_id
self.org_id = org_id
self.token_url = f"https://{org_id}.mypurecloud.com/oauth/token"
self.token_expiry: float = 0
def get_token(self) -> str:
Retrieves an OAuth2 access token.
Implements simple caching to avoid unnecessary requests.
if self.access_token and time.time() < self.token_expiry:
return self.access_token
data = {
"client_id": self.client_id,
response = requests.post(self.token_url, data=data)
response.raise_for_status()
token_data = response.json()
# Set expiry slightly before actual expiry to handle clock drift
self.token_expiry = time.time() + (token_data["expires_in"] - 10)
if e.response.status_code == 401:
raise Exception("Invalid Client ID or Secret") from e
elif e.response.status_code == 403:
raise Exception("Client lacks permission for client_credentials grant") from e
else:
raise Exception(f"OAuth Error: {e.response.text}") from e
raise Exception(f"Failed to connect to Genesys Cloud OAuth: {e}") from e
def get_headers(self) -> Dict[str, str]:
"""Returns headers required for API calls."""
"Authorization": f"Bearer {self.get_token()}",
"Accept": "application/json"
Step 1: Validate AppFoundry Integration Health via REST API
Before debugging the WebSocket connection itself, you must verify that Genesys Cloud considers the integration active. If the integration is marked as “inactive” or “error” in the platform, no WebSocket connections will be attempted, or they will be terminated immediately by the gateway.
We use the /api/v2/integrations endpoint to retrieve the status.
import json
class IntegrationHealthChecker:
def __init__(self, auth: GenesysAuth):
self.auth = auth
self.base_url = f"https://{auth.org_id}.mypurecloud.com/api/v2"
def get_integration_status(self, integration_id: str) -> Dict[str, Any]:
Retrieves the current status of a specific integration.
Scope Required: integrations:read
endpoint = f"{self.base_url}/integrations/{integration_id}"
headers = self.auth.get_headers()
response = requests.get(endpoint, headers=headers)
return response.json()
if e.response.status_code == 404:
raise ValueError(f"Integration ID {integration_id} not found") from e
raise PermissionError("OAuth client lacks integrations:read scope") from e
else:
raise Exception(f"API Error: {e.response.text}") from e
def check_websocket_endpoint_health(self, integration_id: str) -> bool:
Checks if the integration's webhook/websocket target is reachable according to Genesys records.
status_data = self.get_integration_status(integration_id)
# The 'status' field indicates if the integration is active
if status_data.get("status") != "active":
print(f"Warning: Integration {integration_id} is in state: {status_data.get('status')}")
return False
# Check for recent errors in the integration logs if available
# Note: Detailed logs require analytics:read or specific integration logging configs
return True
Step 2: Simulate WebSocket Connection and Measure Latency
WebSocket drops in AppFoundry often stem from two issues:
- Handshake Failure: The server rejects the connection (401/403/404).
- Keep-Alive Timeout: The server does not respond to ping/pong frames, causing the Genesys gateway to drop the connection after a timeout (typically 30-60 seconds of inactivity).
We will create a mock WebSocket server that measures the time between receiving a message and sending a response. This simulates the “Audio Latency” component. If your backend takes too long to process the request, the Genesys gateway may treat it as a stalled connection.
import asyncio
import websockets
from websockets.exceptions import ConnectionClosed
class MockAppFoundryBackend:
Simulates an AppFoundry backend listening for WebSocket connections.
This helps diagnose if the issue is network-based or processing-based.
def __init__(self, host: str = "localhost", port: int = 8765):
self.host = host
self.port = port
self.connection_count = 0
self.latencies = []
async def handler(self, websocket: websockets.WebSocketServerProtocol, path: str = None):
Handles incoming WebSocket connections.
Measures latency and sends periodic pings to keep the connection alive.
self.connection_count += 1
client_ip = websocket.remote_address[0] if websocket.remote_address else "unknown"
print(f"[WS] New connection from {client_ip} (Total: {self.connection_count})")
# Send initial greeting to verify connection establishment
await websocket.send(json.dumps({"status": "connected", "server": "mock-appfoundry"}))
# Process incoming messages
async for message in websocket:
start_time = time.time()
data = json.loads(message)
print(f"[WS] Received: {data.get('type', 'unknown')}")
# Simulate processing delay (adjust this to test latency thresholds)
# Genesys Cloud typically expects responses within 2-5 seconds for voice bots
await asyncio.sleep(0.5)
# Calculate latency
latency = time.time() - start_time
self.latencies.append(latency)
# Send response
response = {
"type": "response",
"latency_ms": round(latency * 1000, 2),
"content": "Simulated NICE Cognigy Response"
await websocket.send(json.dumps(response))
except json.JSONDecodeError:
await websocket.send(json.dumps({"error": "Invalid JSON"}))
await websocket.send(json.dumps({"error": str(e)}))
except ConnectionClosed as e:
print(f"[WS] Connection closed by client: {e}")
print(f"[WS] Unexpected error: {e}")
finally:
print(f"[WS] Connection from {client_ip} ended.")
async def start_server(self):
"""Starts the WebSocket server."""
async with websockets.serve(self.handler, self.host, self.port):
print(f"[WS] Mock AppFoundry Backend running on ws://{self.host}:{self.port}")
await asyncio.Future() # Run forever
# To run this server, you would typically do:
# loop = asyncio.new_event_loop()
# asyncio.set_event_loop(loop)
# mock_backend = MockAppFoundryBackend()
# loop.run_until_complete(mock_backend.start_server())
Step 3: Analyze Conversation Analytics for Drop Patterns
If your WebSocket server is healthy but calls still drop, the issue may be in how Genesys Cloud handles the media stream. You can query the Analytics API to find conversations with high latency or premature terminations.
We query /api/v2/analytics/conversations/details/query to find voice conversations with specific error codes or durations.
class ConversationAnalyzer:
self.auth = auth
def get_dropped_conversations(self, from_date: str, to_date: str) -> list:
Retrieves voice conversations that ended abnormally.
Scope Required: analytics:read
Args:
from_date: ISO 8601 datetime string (e.g., "2023-10-01T00:00:00.000Z")
to_date: ISO 8601 datetime string
endpoint = f"{self.base_url}/analytics/conversations/details/query"
# Query body to find voice conversations with short durations or specific error types
query_body = {
"dateRange": {
"from": from_date,
"to": to_date
"interval": "PT1H", # Hourly intervals
"groupBy": ["conversation.type"],
"filters": [
"type": "conversation.type",
"op": "eq",
"value": "voice"
"sort": [
"field": "duration",
"direction": "asc"
"page": {
"size": 100,
"cursor": None
all_results = []
cursor = None
while True:
if cursor:
query_body["page"]["cursor"] = cursor
response = requests.post(endpoint, json=query_body, headers=headers)
# Process entities
if "entities" in data:
all_results.extend(data["entities"])
# Handle pagination
pagination = data.get("pagination", {})
if not pagination.get("nextPage"):
break
cursor = pagination["nextPage"]
# Rate limit protection
time.sleep(1)
if e.response.status_code == 429:
retry_after = int(e.response.headers.get("Retry-After", 5))
print(f"[Rate Limit] Waiting {retry_after} seconds...")
time.sleep(retry_after)
else:
raise Exception(f"Analytics API Error: {e.response.text}") from e
return all_results
def analyze_latency_distribution(self, conversations: list) -> Dict[str, float]:
Analyzes the duration and hold times of conversations to identify latency spikes.
total_duration = 0
count = 0
short_calls = 0
for conv in conversations:
duration = conv.get("duration", 0)
total_duration += duration
count += 1
# Identify calls that ended very quickly (potential WebSocket drop)
if duration < 5000: # Less than 5 seconds
short_calls += 1
avg_duration = total_duration / count if count > 0 else 0
"total_conversations": count,
"avg_duration_ms": avg_duration,
"potential_drops_count": short_calls,
"potential_drops_percentage": (short_calls / count * 100) if count > 0 else 0
This script combines authentication, integration health checks, and analytics querying into a single diagnostic tool.
import sys
import os
from datetime import datetime, timezone, timedelta
def main():
# Configuration
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
ORG_ID = os.getenv("GENESYS_ORG_ID")
INTEGRATION_ID = os.getenv("GENESYS_INTEGRATION_ID")
if not all([CLIENT_ID, CLIENT_SECRET, ORG_ID]):
print("Error: Missing environment variables. Set GENESYS_CLIENT_ID, CLIENT_SECRET, ORG_ID.")
sys.exit(1)
# 1. Initialize Auth
auth = GenesysAuth(CLIENT_ID, CLIENT_SECRET, ORG_ID)
print("OAuth Authentication successful.")
print(f"Authentication Failed: {e}")
sys.exit(1)
# 2. Check Integration Status
health_checker = IntegrationHealthChecker(auth)
if INTEGRATION_ID:
is_healthy = health_checker.check_websocket_endpoint_health(INTEGRATION_ID)
if not is_healthy:
print("Warning: Integration is not active. Check AppFoundry configuration.")
print(f"Integration Check Failed: {e}")
# 3. Analyze Recent Conversations
analyzer = ConversationAnalyzer(auth)
# Define date range: Last 24 hours
now = datetime.now(timezone.utc)
yesterday = now - timedelta(hours=24)
from_date = yesterday.isoformat()
to_date = now.isoformat()
print(f"Querying conversations from {from_date} to {to_date}...")
conversations = analyzer.get_dropped_conversations(from_date, to_date)
stats = analyzer.analyze_latency_distribution(conversations)
print("\n--- Conversation Analysis Results ---")
print(f"Total Voice Conversations: {stats['total_conversations']}")
print(f"Average Duration: {stats['avg_duration_ms']:.2f} ms")
print(f"Potential Premature Drops (<5s): {stats['potential_drops_count']}")
print(f"Drop Percentage: {stats['potential_drops_percentage']:.2f}%")
if stats['potential_drops_percentage'] > 5:
print("\nAlert: High drop rate detected. Investigate WebSocket keep-alive settings.")
print("Check if your AppFoundry backend is sending Pong frames within 30 seconds.")
print(f"Analytics Query Failed: {e}")
main()
Error: 401 Unauthorized on WebSocket Handshake
Cause: The Genesys Cloud gateway is sending a WebSocket upgrade request, but your AppFoundry backend is rejecting it due to missing or invalid authentication headers.
Fix: Ensure your WebSocket server accepts the Sec-WebSocket-Key and validates any custom headers you configured in the Genesys Cloud Integration settings. If you are using Basic Auth, ensure the credentials in Genesys Cloud match your server.
Error: 403 Forbidden on Analytics API
Cause: The OAuth client lacks the analytics:read scope.
Fix: Go to the Genesys Cloud Admin console, navigate to Admin > Security > OAuth Clients, edit your client, and add the analytics:read scope. Re-generate the access token.
Error: Connection Closed by Remote Peer (WebSocket)
Cause: The Genesys Cloud gateway has a keep-alive timeout. If your backend does not respond to ping frames or send data within the timeout window (typically 30-60 seconds), the gateway closes the connection.
Fix: Implement ping/pong handling in your WebSocket server. In the websockets library, this is handled automatically if you use the standard server protocol. If you are using a custom framework, ensure you send a ping frame every 15-20 seconds.
# Example of manual ping handling if not using auto-ping
async def keep_alive(websocket):
while True:
await asyncio.sleep(15)
await websocket.ping()
except websockets.ConnectionClosed:
pass
Error: High Audio Latency (>2000ms)
Cause: Your backend is taking too long to process the NICE Cognigy intent or generate the response.
Fix: Optimize your backend logic. Ensure that you are sending the initial response (e.g., a “thinking” message or audio chunk) as soon as possible, rather than waiting for the entire response to be generated. Use streaming responses if supported by your integration pattern.
