Diagnosing WebSocket Instability and Audio Latency in Genesys Cloud and NICE CXone Bot Integrations
- A diagnostic utility that monitors WebSocket connection heartbeats, measures round-trip latency, and logs detailed audio packet timing for Genesys Cloud AppFoundry and NICE CXone Studio integrations.
- A Python-based implementation using the
websocket-clientlibrary to simulate bot interaction flows and capture telemetry data. - A JavaScript implementation for Node.js environments that integrates with server-side bot orchestration layers.
- Platform Access: Genesys Cloud PureCloud API credentials or NICE CXone API credentials.
- SDK/Library Requirements:
- Python:
websocket-client>=1.6.0,requests>=2.31.0,pydantic>=2.0 - Node.js:
ws>=8.14.0,axios>=1.6.0
- Python:
- Environment: Python 3.9+ or Node.js 18+.
- Knowledge: Understanding of WebSocket protocols (RFC 6455), OAuth 2.0 client credentials flow, and basic audio streaming concepts (RTP/RTCP equivalents in WebRTC).
Before establishing a WebSocket connection, you must obtain a valid OAuth token. Both Genesys Cloud and NICE CXone use OAuth 2.0. For bot integrations, the Client Credentials flow is standard, but user-context bots may require Authorization Code flow.
Genesys Cloud OAuth Token Acquisition (Python)
import requests
import json
from typing import Optional
class GenesysAuth:
def __init__(self, env: str, client_id: str, client_secret: str):
self.env = env
self.client_id = client_id
self.base_url = f"https://{env}.mypurecloud.com"
self.token_url = f"{self.base_url}/oauth/token"
Retrieves an OAuth 2.0 access token using Client Credentials.
Required Scope: bot:bot:read, bot:bot:write, bot:bot:execute
headers = {
"Content-Type": "application/x-www-form-urlencoded",
"Accept": "application/json"
data = {
"client_id": self.client_id,
"scope": "bot:bot:read bot:bot:write bot:bot:execute"
response = requests.post(self.token_url, headers=headers, data=data)
response.raise_for_status()
token_data = response.json()
return token_data.get("access_token")
raise Exception("Invalid client ID or secret.")
elif response.status_code == 403:
raise Exception("Insufficient scopes. Ensure bot:bot:execute is included.")
else:
raise Exception(f"OAuth error: {e}")
NICE CXone OAuth Token Acquisition (Python)
import requests
class CxoneAuth:
def __init__(self, instance_url: str, client_id: str, client_secret: str):
self.instance_url = instance_url.rstrip('/')
self.token_url = f"{self.instance_url}/api/v2/oauth2/token"
Retrieves an OAuth 2.0 access token for NICE CXone.
Required Scope: api.bot.read, api.bot.write, api.bot.execute
headers = {
data = {
"scope": "api.bot.read api.bot.write api.bot.execute"
print(f"OAuth Error: {response.text}")
raise e
Step 1: Establishing the WebSocket Connection with Telemetry
WebSocket connections in Genesys Cloud AppFoundry and NICE CXone are typically established over WSS (WebSocket Secure). The primary cause of drops is often the lack of proper ping/pong handling or exceeding the message size limit.
Python Implementation: Genesys Cloud Bot Session Simulator
This script connects to a simulated bot endpoint, sends a test message, and measures the time-to-first-byte (TTFB) for the response.
import websocket
import json
import uuid
from typing import Dict, List, Optional
class GenesysBotDiagnostic:
def __init__(self, wss_url: str, access_token: str, bot_id: str):
self.wss_url = wss_url
self.access_token = access_token
self.bot_id = bot_id
self.session_id = str(uuid.uuid4())
self.latencies: List[float] = []
self.connection_drops: int = 0
self.ws: Optional[websocket.WebSocket] = None
def on_open(self, ws):
print(f"[{time.strftime('%H:%M:%S')}] WebSocket connected.")
# Send initial handshake message specific to Genesys Bot API
handshake = {
"type": "handshake",
"sessionId": self.session_id,
"botId": self.bot_id,
"locale": "en-US",
"inputs": []
ws.send(json.dumps(handshake))
self._start_ping_pong(ws)
def on_message(self, ws, message):
data = json.loads(message)
timestamp = time.time()
# Measure latency if this is a response to a user input
if "type" in data and data.get("type") == "response":
if hasattr(self, '_last_send_time') and self._last_send_time:
latency = timestamp - self._last_send_time
self.latencies.append(latency)
print(f"[{time.strftime('%H:%M:%S')}] Response received. Latency: {latency*1000:.2f}ms")
# Check for audio latency indicators if present in payload
if "audio" in data:
self._analyze_audio_latency(data["audio"])
print(f"[{time.strftime('%H:%M:%S')}] Received: {json.dumps(data)[:200]}...")
except json.JSONDecodeError:
print(f"[{time.strftime('%H:%M:%S')}] Non-JSON message received: {message}")
def on_error(self, ws, error):
print(f"[{time.strftime('%H:%M:%S')}] WebSocket Error: {error}")
self.connection_drops += 1
def on_close(self, ws, close_status_code, close_msg):
print(f"[{time.strftime('%H:%M:%S')}] WebSocket closed. Code: {close_status_code}, Reason: {close_msg}")
def _start_ping_pong(self, ws):
Implements a custom ping/pong mechanism to detect silent drops.
Genesys Cloud WebSockets support standard ping/pong, but application-level
heartbeats are safer for long-running bot sessions.
def send_heartbeat():
if ws and ws.sock and ws.sock.connected:
ws.ping()
print(f"Failed to send ping: {e}")
ws.close()
# Schedule next heartbeat
timer = threading.Timer(25.0, send_heartbeat)
timer.daemon = True
timer.start()
import threading
send_heartbeat()
def send_user_input(self, text: str):
if not self.ws or not self.ws.sock or not self.ws.sock.connected:
raise ConnectionError("WebSocket is not connected.")
self._last_send_time = time.time()
message = {
"type": "input",
"text": text,
"timestamp": time.time()
self.ws.send(json.dumps(message))
print(f"[{time.strftime('%H:%M:%S')}] Sent input: {text}")
def _analyze_audio_latency(self, audio_data: Dict):
Placeholder for audio-specific latency analysis.
In a real integration, you would inspect RTCP-like statistics
or server-side timestamps provided in the audio payload.
if "serverTimestamp" in audio_data and "clientTimestamp" in audio_data:
jitter = abs(audio_data["serverTimestamp"] - audio_data["clientTimestamp"])
print(f"[{time.strftime('%H:%M:%S')}] Audio Jitter: {jitter*1000:.2f}ms")
def run(self):
# Construct WSS URL with token
full_url = f"{self.wss_url}?access_token={self.access_token}"
websocket.enableTrace(True)
self.ws = websocket.WebSocketApp(
full_url,
on_open=self.on_open,
on_message=self.on_message,
on_error=self.on_error,
on_close=self.on_close
# Run forever for demonstration; in production, use a thread or async loop
self.ws.run_forever(ping_interval=25, ping_timeout=10)
Step 2: Handling Audio Latency and Buffer Underruns
Audio latency in bot integrations often stems from buffer underruns or network jitter. When integrating with AppFoundry or CXone Studio, you must monitor the audio event payloads.
JavaScript Implementation: NICE CXone Studio Audio Monitor
This Node.js script connects to a CXone Studio WebSocket endpoint and monitors audio packet arrival times to calculate jitter and latency.
const WebSocket = require('ws');
const { v4: uuidv4 } = require('uuid');
class CxoneAudioDiagnostic {
constructor(instanceUrl, clientId, clientSecret) {
this.instanceUrl = instanceUrl;
this.clientId = clientId;
this.audioLatencies = [];
this.lastAudioTimestamp = null;
this.ws = null;
async getToken() {
const url = `${this.instanceUrl}/api/v2/oauth2/token`;
const data = new URLSearchParams({
client_id: this.clientId,
client_secret: this.clientSecret,
scope: 'api.bot.read api.bot.write api.bot.execute'
const response = await axios.post(url, data, {
return response.data.access_token;
async startDiagnostic(botId) {
const token = await this.getToken();
const sessionId = uuidv4();
const wssUrl = `wss://${new URL(this.instanceUrl).hostname}/api/v2/bots/${botId}/sessions/${sessionId}/websocket`;
// Note: Real CXone WebSocket endpoints may vary; this is a representative pattern
const wsUrl = `${wssUrl}?access_token=${token}`;
this.ws = new WebSocket(wsUrl);
this.ws.on('open', () => {
console.log('[CXone] WebSocket Connected');
// Send initial message to start bot flow
this.ws.send(JSON.stringify({
type: 'start',
sessionId: sessionId,
locale: 'en-US'
this.ws.on('message', (data) => {
const message = JSON.parse(data);
this.handleMessage(message);
} catch (e) {
console.error('[CXone] Failed to parse message:', e);
this.ws.on('close', (code, reason) => {
console.log(`[CXone] WebSocket Closed. Code: ${code}, Reason: ${reason}`);
this.analyzeResults();
this.ws.on('error', (error) => {
console.error('[CXone] WebSocket Error:', error.message);
handleMessage(message) {
if (message.type === 'audio' || message.type === 'audioChunk') {
const now = Date.now();
if (this.lastAudioTimestamp) {
const delta = now - this.lastAudioTimestamp;
this.audioLatencies.push(delta);
// Detect jitter: significant deviation from median latency
const median = this.audioLatencies.reduce((a, b) => a + b, 0) / this.audioLatencies.length;
const jitter = Math.abs(delta - median);
if (jitter > 50) { // Threshold in ms
console.warn(`[CXone] High Jitter Detected: ${jitter.toFixed(2)}ms (Delta: ${delta.toFixed(2)}ms)`);
this.lastAudioTimestamp = now;
} else if (message.type === 'text') {
console.log(`[CXone] Bot Text: ${message.text}`);
} else if (message.type === 'error') {
console.error(`[CXone] Bot Error: ${message.error}`);
analyzeResults() {
if (this.audioLatencies.length === 0) {
console.log('[CXone] No audio data received.');
return;
const avgLatency = this.audioLatencies.reduce((a, b) => a + b, 0) / this.audioLatencies.length;
const maxLatency = Math.max(...this.audioLatencies);
const minLatency = Math.min(...this.audioLatencies);
console.log(`[CXone] Audio Analysis Complete:`);
console.log(` - Packets Received: ${this.audioLatencies.length}`);
console.log(` - Average Latency: ${avgLatency.toFixed(2)}ms`);
console.log(` - Max Latency: ${maxLatency.toFixed(2)}ms`);
console.log(` - Min Latency: ${minLatency.toFixed(2)}ms`);
if (avgLatency > 200) {
console.warn('[CXone] WARNING: Average audio latency exceeds 200ms. Consider optimizing network path or bot logic.');
sendUserInput(text) {
if (this.ws && this.ws.readyState === WebSocket.OPEN) {
type: 'input',
text: text
console.log(`[CXone] Sent Input: ${text}`);
} else {
console.error('[CXone] WebSocket not open.');
// Usage
// const diagnostic = new CxoneAudioDiagnostic('https://yourinstance.niceincontact.com', 'client_id', 'client_secret');
// diagnostic.startDiagnostic('bot_id').then(() => {
// setTimeout(() => diagnostic.sendUserInput('Hello'), 5000);
Step 3: Processing Results and Identifying Root Causes
After running the diagnostic, you must interpret the data. Common patterns include:
- Sudden Drop with Code 1006: Indicates an abnormal closure, often due to network interruption or server-side timeout. Check firewall settings and ensure keep-alive packets are enabled.
- High Latency with Low Jitter: Suggests a consistent network delay. This is often resolved by moving the integration server closer to the CX platform region.
- High Jitter: Indicates packet loss or variable network latency. This requires QoS prioritization for WebSocket traffic.
Here is a complete, runnable Python script for Genesys Cloud that combines authentication, WebSocket connection, and latency monitoring.
import requests
import websocket
import json
import uuid
import threading
import sys
class GenesysBotDiagnosticTool:
def __init__(self, env: str, client_id: str, client_secret: str, bot_id: str):
self.env = env
self.wss_url = f"wss://{env}.mypurecloud.com/api/v2/bots/{bot_id}/sessions"
self.access_token = None
self.session_id = None
self.latencies = []
self.ws = None
self.is_running = False
def authenticate(self):
print("Authenticating with Genesys Cloud...")
headers = {"Content-Type": "application/x-www-form-urlencoded", "Accept": "application/json"}
data = {
response = requests.post(f"{self.base_url}/oauth/token", headers=headers, data=data)
self.access_token = response.json().get("access_token")
print("Authentication successful.")
print(f"Authentication failed: {e}")
sys.exit(1)
print("WebSocket connected.")
self.is_running = True
handshake = {
"locale": "en-US",
"inputs": []
# Start heartbeat
self._start_heartbeat(ws)
if data.get("type") == "response":
latency = (time.time() - self._last_send_time) * 1000
print(f"Response Latency: {latency:.2f}ms")
# Print first 100 chars of message
print(f"Received: {json.dumps(data)[:100]}...")
print(f"Non-JSON message: {message}")
print(f"WebSocket Error: {error}")
print(f"WebSocket closed. Code: {close_status_code}, Reason: {close_msg}")
self._print_stats()
def _start_heartbeat(self, ws):
def heartbeat():
if self.is_running and ws.sock and ws.sock.connected:
ws.ping()
print(f"Ping failed: {e}")
ws.close()
threading.Timer(25.0, heartbeat).start()
heartbeat()
def send_input(self, text):
if not self.is_running or not self.ws or not self.ws.sock or not self.ws.sock.connected:
print("WebSocket not connected.")
return
message = {
"type": "input",
"text": text
print(f"Sent: {text}")
def _print_stats(self):
if self.latencies:
avg = sum(self.latencies) / len(self.latencies)
max_lat = max(self.latencies)
min_lat = min(self.latencies)
print(f"\n--- Session Stats ---")
print(f"Messages: {len(self.latencies)}")
print(f"Avg Latency: {avg:.2f}ms")
print(f"Max Latency: {max_lat:.2f}ms")
print(f"Min Latency: {min_lat:.2f}ms")
else:
print("\nNo latency data collected.")
def run(self):
self.authenticate()
websocket.enableTrace(False)
f"{self.wss_url}?access_token={self.access_token}",
# Run in background thread to allow user input
thread = threading.Thread(target=self.ws.run_forever, kwargs={"ping_interval": 25, "ping_timeout": 10})
thread.daemon = True
thread.start()
# Wait for connection
while not self.is_running:
time.sleep(0.1)
print("\nBot Session Active. Type 'quit' to exit.")
while True:
user_input = input("> ").strip()
if user_input.lower() == 'quit':
break
if user_input:
self.send_input(user_input)
except KeyboardInterrupt:
pass
finally:
self.ws.close()
thread.join(timeout=2)
# Replace with your credentials
ENV = "usw2"
CLIENT_ID = "YOUR_CLIENT_ID"
CLIENT_SECRET = "YOUR_CLIENT_SECRET"
BOT_ID = "YOUR_BOT_ID"
tool = GenesysBotDiagnosticTool(ENV, CLIENT_ID, CLIENT_SECRET, BOT_ID)
tool.run()
- Cause: Invalid or expired OAuth token.
- Fix: Ensure the
client_idandclient_secretare correct. Check that the token has not expired (typically 1 hour). Implement token refresh logic for long-running sessions.
Error: 403 Forbidden
- Cause: Insufficient OAuth scopes.
- Fix: Ensure the
bot:bot:executescope is included in the token request. For Genesys Cloud, verify that the API user has permission to execute the specific bot.
Error: WebSocket Close Code 1006
- Cause: Abnormal closure. Often due to network issues, firewall dropping idle connections, or server-side crash.
- Fix: Implement a heartbeat mechanism (ping/pong) to keep the connection alive. Check firewall settings to allow outbound WSS traffic on port 443.
Error: High Audio Latency
- Cause: Network jitter or server-side processing delays.
- Fix: Monitor jitter using the diagnostic script. If jitter is high, optimize network path. If latency is consistent but high, consider moving the integration server to a region closer to the CX platform.
