Diagnosing and Resolving Session Handover Failures in CXone Studio with Cognigy Voicebots
- You will build a diagnostic script that traces a failed handover between NICE Cognigy and NICE CXone Studio by correlating conversation IDs across the two platforms.
- You will use the NICE CXone REST API to retrieve detailed conversation logs and the Cognigy SDK to inspect bot context states.
- You will use Python to automate the retrieval of failure reasons and validate the required OAuth scopes and webhook configurations.
- OAuth Client Type: A CXone Integration User with
conversation:viewandanalytics:conversation:viewscopes. A Cognigy Service Account withbot:readandsession:readpermissions. - SDK/API Version: CXone API v2 (current stable), Cognigy Python SDK v2.1+.
- Language/Runtime: Python 3.9+ with
requestsandcognigypackages installed. - External Dependencies:
pip install requests cognigy- Access to a CXone environment where a Cognigy voicebot is deployed.
- Access to a Cognigy Studio project with the corresponding bot.
Before querying data, you must secure valid access tokens for both platforms. CXone uses standard OAuth 2.0 Client Credentials flow. Cognigy uses a simpler token-based authentication or API key depending on the SDK version, but for production scripts, the SDK handles token management internally if configured correctly.
CXone OAuth Token Acquisition
import requests
import base64
import json
from typing import Optional
class CXoneAuth:
def __init__(self, client_id: str, client_secret: str, org_id: str):
self.client_id = client_id
self.org_id = org_id
self.base_url = f"https://{org_id}.mypurecloud.com"
self.token_url = f"{self.base_url}/oauth/token"
def get_token(self) -> str:
Acquires an OAuth2 access token using Client Credentials flow.
Required Scopes: conversation:view, analytics:conversation:view
credentials = f"{self.client_id}:{self.client_secret}"
encoded_credentials = base64.b64encode(credentials.encode('utf-8')).decode('utf-8')
headers = {
"Authorization": f"Basic {encoded_credentials}",
data = {
"scope": "conversation:view analytics:conversation:view"
response = requests.post(self.token_url, headers=headers, data=data)
if response.status_code != 200:
raise Exception(f"Failed to acquire CXone token: {response.text}")
self.access_token = response.json().get("access_token")
return self.access_token
if not self.access_token:
self.get_token()
"Authorization": f"Bearer {self.access_token}",
"Accept": "application/json"
Cognigy SDK Initialization
from cognigy import Responses
from cognigy.sdk import Cognigy
class CognigyClient:
def __init__(self, access_token: str, project_id: str):
Initializes the Cognigy SDK client.
Note: In production, use Cognigy's internal API endpoints for session retrieval,
but the SDK provides helper methods for context inspection.
self.cognigy = Cognigy(access_token=access_token)
self.project_id = project_id
Step 1: Identify the Failed Conversation in CXone
The first step in troubleshooting a handover failure is locating the specific conversation instance in CXone. You cannot debug what you cannot find. Use the GET /api/v2/analytics/conversations/details/query endpoint to search for conversations that originated from the Cognigy bot but did not successfully transfer to an agent or queue.
OAuth Scope: analytics:conversation:view
class CXoneConversationAnalyzer:
def __init__(self, auth: CXoneAuth):
self.auth = auth
self.base_url = auth.base_url
def find_failed_handovers(self, bot_name: str, start_time: str, end_time: str) -> list:
Queries CXone analytics for conversations that started with the specified bot
and ended in a failed or abandoned state.
Args:
bot_name: The name of the Cognigy bot as defined in CXone IVR.
start_time: ISO 8601 start timestamp.
end_time: ISO 8601 end timestamp.
Returns:
List of conversation summaries.
endpoint = f"{self.base_url}/api/v2/analytics/conversations/details/query"
# Define the query filter
query_payload = {
"dateFrom": start_time,
"dateTo": end_time,
"groupBy": [],
"filter": {
"type": "AND",
"predicates": [
"type": "EQUALS",
"name": "channelType",
"value": "voice"
"type": "CONTAINS",
"name": "botId",
"value": bot_name # Partial match for bot ID or Name
"type": "IN",
"name": "conversationState",
"value": ["abandoned", "failed"]
"size": 10,
"page": 1
headers = self.auth.get_headers()
response = requests.post(endpoint, headers=headers, json=query_payload)
response.raise_for_status()
results = response.json()
return results.get("results", [])
if e.response.status_code == 403:
raise Exception("Missing 'analytics:conversation:view' scope.")
elif e.response.status_code == 429:
raise Exception("Rate limited. Implement exponential backoff.")
else:
raise e
Step 2: Retrieve Detailed Conversation Timeline
Once you have the conversationId, you need the detailed timeline to see exactly where the handover failed. Did the bot call the webhook? Did CXone reject the transfer? Did the agent queue reject it?
OAuth Scope: conversation:view
def get_conversation_details(self, conversation_id: str) -> dict:
Retrieves the full timeline and metadata for a specific conversation.
endpoint = f"{self.base_url}/api/v2/conversations/details/{conversation_id}"
response = requests.get(endpoint, headers=headers)
return response.json()
if e.response.status_code == 404:
return None
raise e
def analyze_handover_failure(self, conversation_data: dict) -> dict:
Parses the conversation timeline to identify the point of failure.
timeline = conversation_data.get("timeline", [])
bot_session_id = None
failure_reason = "Unknown"
for event in timeline:
event_type = event.get("type")
# Identify when the bot session started
if event_type == "botSessionStarted":
bot_session_id = event.get("botSessionId")
# Look for handover attempts
elif event_type == "queueMemberAdded":
# Check if it was added to a queue successfully
pass
elif event_type == "queueMemberRemoved":
failure_reason = f"Removed from queue: {event.get('reason', 'No reason specified')}"
elif event_type == "error":
failure_reason = f"System Error: {event.get('message', 'No message')}"
elif event_type == "abandoned":
failure_reason = "Caller abandoned before handover"
"conversationId": conversation_data.get("id"),
"botSessionId": bot_session_id,
"failureReason": failure_reason,
"lastEventType": timeline[-1].get("type") if timeline else None
Step 3: Inspect Cognigy Session Context
If CXone shows the bot session started but no handover occurred, the issue is likely within the Cognigy logic. You need to inspect the session state at the time of the failure. This requires the botSessionId extracted in Step 2.
Note: Cognigy does not provide a direct public REST API for retrieving historical session states in the same way CXone does. However, you can use the Cognigy SDK to simulate a context check or, more commonly, rely on the Cognigy Logs if you have access to the underlying infrastructure. For this tutorial, we will assume you are using a custom logging middleware or the Cognigy API available to developers with session:read scope via the internal API structure.
Correction: In standard production environments, direct historical session retrieval via public API is limited. The most reliable method is to correlate the botSessionId with Cognigy Studio’s Debug Mode logs or a custom Webhook that logs session states to a database (like DynamoDB or PostgreSQL) during runtime.
However, to demonstrate the integration point, we will show how to construct the Webhook Payload that should have been sent to CXone. If this payload is malformed, the handover fails.
def construct_cognigy_to_cxone_handover_payload(session_context: dict) -> dict:
Validates the structure of the payload sent from Cognigy to CXone via Webhook.
This is the payload that triggers the handover.
required_fields = ['externalContactId', 'queueId', 'transferType']
# Check for missing fields
missing = [f for f in required_fields if f not in session_context]
if missing:
raise ValueError(f"Missing required handover fields: {missing}")
# Validate Queue ID format (CXone requires a valid UUID or Queue ID string)
if not session_context['queueId']:
raise ValueError("Queue ID is empty. Ensure the Queue ID is passed from Cognigy variables.")
# Validate Transfer Type
if session_context['transferType'] not in ['consult', 'blind']:
raise ValueError(f"Invalid transfer type: {session_context['transferType']}. Must be 'consult' or 'blind'.")
# Construct the expected CXone Webhook Payload
handover_payload = {
"contactId": session_context['externalContactId'],
"queueId": session_context['queueId'],
"transferType": session_context['transferType'],
"metadata": {
"botSessionId": session_context.get('botSessionId'),
"intent": session_context.get('intent'),
"confidence": session_context.get('confidence')
return handover_payload
Step 4: Cross-Platform Correlation Script
This script ties everything together. It fetches failed conversations from CXone, analyzes them, and then attempts to validate if the handover payload was theoretically correct based on stored metadata or logs.
import datetime
def troubleshoot_handover_flow(cxone_auth: CXoneAuth, bot_name: str, days_back: int = 1):
Main execution function to troubleshoot recent handover failures.
analyzer = CXoneConversationAnalyzer(cxone_auth)
# Calculate time range
end_time = datetime.datetime.utcnow().isoformat() + "Z"
start_time = (datetime.datetime.utcnow() - datetime.timedelta(days=days_back)).isoformat() + "Z"
print(f"Searching for failed handovers for bot '{bot_name}' in the last {days_back} day(s)...")
failed_conversations = analyzer.find_failed_handovers(bot_name, start_time, end_time)
if not failed_conversations:
print("No failed handovers found in the specified timeframe.")
return
for conv_summary in failed_conversations:
conv_id = conv_summary['id']
print(f"\n--- Analyzing Conversation ID: {conv_id} ---")
# Step 1: Get Details
conv_details = analyzer.get_conversation_details(conv_id)
if not conv_details:
print("Conversation not found or deleted.")
analysis = analyzer.analyze_handover_failure(conv_details)
print(f"Failure Reason: {analysis['failureReason']}")
print(f"Bot Session ID: {analysis['botSessionId']}")
# Step 2: Diagnose based on failure reason
if "Removed from queue" in analysis['failureReason']:
print("DIAGNOSIS: The call was removed from the queue. Check if the agent group was offline or the caller abandoned.")
elif "System Error" in analysis['failureReason']:
print("DIAGNOSIS: Internal CXone error. Check CXone system status or retry.")
elif "abandoned" in analysis['failureReason']:
print("DIAGNOSIS: Caller hung up. Check IVR wait times.")
else:
# Check if the bot session ID exists but no queue action occurred
if analysis['botSessionId'] and not any('queue' in str(analysis['failureReason']).lower() or 'abandoned' in str(analysis['failureReason']).lower()):
print("DIAGNOSIS: Bot session started but no handover action recorded in CXone timeline.")
print("ACTION: Check Cognigy Webhook logs. Did the webhook return 200 OK?")
print("ACTION: Verify the 'queueId' variable in Cognigy is mapped correctly to the CXone Queue ID.")
print(f"Error analyzing conversation {conv_id}: {str(e)}")
# Usage Example
# Replace with your actual credentials
CXONE_CLIENT_ID = "your_client_id"
CXONE_CLIENT_SECRET = "your_client_secret"
CXONE_ORG_ID = "your_org_id"
BOT_NAME = "MyCognigyBot"
auth = CXoneAuth(CXONE_CLIENT_ID, CXONE_CLIENT_SECRET, CXONE_ORG_ID)
troubleshoot_handover_flow(auth, BOT_NAME)
The following is a consolidated, runnable Python script. Save this as troubleshoot_handover.py.
import requests
import base64
import json
import datetime
from typing import Optional, List, Dict
class CXoneAuth:
headers = {"Authorization": f"Basic {encoded_credentials}", "Content-Type": "application/x-www-form-urlencoded"}
data = {"grant_type": "client_credentials", "scope": "conversation:view analytics:conversation:view"}
self.get_token()
return {"Authorization": f"Bearer {self.access_token}", "Content-Type": "application/json", "Accept": "application/json"}
self.auth = auth
def find_failed_handovers(self, bot_name: str, start_time: str, end_time: str) -> List[Dict]:
query_payload = {
"dateTo": end_time,
"groupBy": [],
"filter": {
"type": "AND",
"predicates": [
{"type": "EQUALS", "name": "channelType", "value": "voice"},
{"type": "CONTAINS", "name": "botId", "value": bot_name},
{"type": "IN", "name": "conversationState", "value": ["abandoned", "failed"]}
"size": 10,
"page": 1
return response.json().get("results", [])
def get_conversation_details(self, conversation_id: str) -> Optional[Dict]:
if response.status_code == 404:
return None
def analyze_handover_failure(self, conversation_data: Dict) -> Dict:
def troubleshoot_handover_flow(client_id: str, client_secret: str, org_id: str, bot_name: str, days_back: int = 1):
auth = CXoneAuth(client_id, client_secret, org_id)
analyzer = CXoneConversationAnalyzer(auth)
print("No failed handovers found.")
return
print("Conversation not found.")
if "Bot session started" in str(analysis) and not any(k in analysis['failureReason'] for k in ['queue', 'abandoned']):
print("ACTION: Check Cognigy Webhook configuration. Ensure the 'queueId' variable is populated.")
print(f"Error: {str(e)}")
# CONFIGURE THESE VARIABLES
client_id="YOUR_CLIENT_ID",
client_secret="YOUR_CLIENT_SECRET",
org_id="YOUR_ORG_ID",
bot_name="YourBotName",
days_back=1
Error: 403 Forbidden on Analytics Query
- Cause: The OAuth token lacks the
analytics:conversation:viewscope. - Fix: Update the
scopeparameter in theCXoneAuth.get_token()method to includeanalytics:conversation:view. Ensure the Integration User in CXone has this permission assigned in the Admin Console.
Error: Bot Session ID is Null in Timeline
- Cause: The IVR did not correctly route the call to the Cognigy bot, or the bot session failed to initialize in CXone’s eyes.
- Fix: Check the CXone IVR configuration. Ensure the “Bot” node in the IVR is correctly linked to the Cognigy bot ID. Verify that the Cognigy bot is published and active.
Error: Webhook Returns 400 Bad Request
- Cause: The payload sent from Cognigy to CXone is malformed. Common issues include missing
queueIdor invalid JSON structure. - Fix: In Cognigy Studio, check the Webhook action configuration. Ensure the “Body” tab contains valid JSON. Use the
construct_cognigy_to_cxone_handover_payloadfunction logic to validate your variables. EnsurequeueIdmatches an active CXone Queue ID.
Error: Rate Limiting (429 Too Many Requests)
- Cause: You are querying analytics data too frequently.
- Fix: Implement exponential backoff in your
requestscalls. For bulk troubleshooting, cache the results and avoid polling the API in a tight loop.
