Diagnosing and Resolving Session Handover Failures Between NICE Cognigy and CXone Studio
  • A diagnostic script that validates the integrity of the transferContext payload passed from NICE Cognigy to CXone Studio during a voicebot handover.
  • A Python-based utility that simulates the handover handshake, checks for missing mandatory fields, and verifies agent availability via the CXone APIs.
  • This tutorial uses Python with the requests library to interact with NICE CXone REST APIs.
  • OAuth Client: A CXone OAuth client with offline access type.
  • Required Scopes: agent:view, interaction:initiate, flow:execute, user:read.
  • SDK/API: NICE CXone REST API v2 (no specific SDK required, raw HTTP requests used for maximum visibility into payloads).
  • Language/Runtime: Python 3.8+.
  • Dependencies: requests, pyyaml (for config management). Install via pip install requests pyyaml.
  • Environment: Access to a CXone organization with an active Studio Flow configured to accept transfers, and a Cognigy bot configured to trigger the transfer action.
Before diagnosing handover failures, you must establish a valid session. Handover failures often stem from expired tokens used by the integration layer. We will implement a simple token manager that handles the OAuth2 Client Credentials flow.
import requests
import json
class CXoneAuth:
    def __init__(self, client_id, client_secret, base_url="https://api.us-east-1.my.nicecxone.com"):
        self.client_id = client_id
        self.base_url = base_url
        self.access_token = None
        self.token_expiry = 0
    def get_token(self):
        Retrieves an OAuth2 access token using Client Credentials flow.
        Returns the token string.
        if self.access_token and time.time() < self.token_expiry:
            return self.access_token
        url = f"{self.base_url}/oauth/token"
        headers = {
        data = {
            "client_id": self.client_id,
        response = requests.post(url, headers=headers, data=data)
        if response.status_code != 200:
            raise Exception(f"Auth Failed: {response.status_code} - {response.text}")
        token_data = response.json()
        self.token_expiry = time.time() + token_data["expires_in"] - 60 # Buffer 60s
    def get_headers(self):
        """Returns standard headers for API calls."""
            "Authorization": f"Bearer {self.get_token()}",
Step 1: Validate the Transfer Payload Structure
When Cognigy triggers a handover, it sends a JSON payload to the CXone Studio Flow. The most common cause of failure is a malformed transferContext or missing queueId. We will construct a validation function that mirrors the schema expected by CXone.
def validate_cognigy_payload(payload: Dict[str, Any]) -> List[str]:
    Validates the JSON payload sent from Cognigy to CXone.
    Returns a list of error messages. Empty list means valid.
    errors = []
    # 1. Check for mandatory top-level keys
    if "transferContext" not in payload:
        errors.append("Missing 'transferContext' root key.")
        return errors # Cannot proceed without root context
    context = payload["transferContext"]
    # 2. Validate Queue ID
    if "queueId" not in context or not context["queueId"]:
        errors.append("Missing or empty 'queueId' in transferContext. CXone cannot route without a target queue.")
    # 3. Validate Participant Data (Caller)
    if "participant" not in context:
        errors.append("Missing 'participant' object. CXone needs caller details.")
    else:
        participant = context["participant"]
        if "name" not in participant:
            errors.append("Missing 'name' in participant object.")
        if "phoneNumber" not in participant:
            errors.append("Missing 'phoneNumber' in participant object. Required for voice callbacks.")
        if "phoneNumber" in participant and not participant["phoneNumber"].startswith("+"):
            errors.append("Phone number must be in E.164 format (starting with +).")
    # 4. Validate Custom Attributes (Optional but common failure point if schema mismatch)
    if "customAttributes" in context:
        if not isinstance(context["customAttributes"], dict):
            errors.append("'customAttributes' must be a JSON object (dict).")
    # 5. Check for 'flowVersionId' if targeting a specific flow variant
    if "flowVersionId" in context:
        if not isinstance(context["flowVersionId"], str) or len(context["flowVersionId"]) != 36: # UUID check
            errors.append("'flowVersionId' appears to be invalid. It must be a valid UUID.")
    return errors
# Example Usage
sample_payload = {
    "transferContext": {
        "queueId": "a1b2c3d4-5678-90ab-cdef-123456789012",
        "participant": {
            "name": "John Doe",
            "phoneNumber": "+15551234567"
        "customAttributes": {
            "intent": "billing_inquiry",
            "confidence": 0.95
errors = validate_cognigy_payload(sample_payload)
if errors:
    print("Validation Errors:", errors)
else:
    print("Payload structure is valid.")
Step 2: Verify Target Queue and Agent Availability
A frequent “silent” failure occurs when the handover succeeds technically (HTTP 200/201), but the call drops because no agents are available in the target queue, or the queue is paused. We query the CXone API to check the current status of the queue and the availability of agents.
def check_queue_status(auth: CXoneAuth, queue_id: str) -> Dict[str, Any]:
    Retrieves the current status and agent availability of a specific queue.
    url = f"{auth.base_url}/api/v2/routing/queues/{queue_id}"
    headers = auth.get_headers()
        response = requests.get(url, headers=headers)
        response.raise_for_status()
        return response.json()
        if response.status_code == 404:
            raise Exception(f"Queue ID {queue_id} does not exist in this CXone org.")
        raise e
def check_agent_availability(auth: CXoneAuth, queue_id: str) -> List[Dict[str, Any]]:
    Fetches agents currently available in the queue.
    url = f"{auth.base_url}/api/v2/routing/queues/{queue_id}/agents"
        agents = response.json().get("items", [])
        # Filter for agents who are actually available
        available_agents = [
            agent for agent in agents
            if agent.get("available", False) and agent.get("status", {}).get("name") == "Available"
        return available_agents
        print(f"Warning: Could not fetch agent list for queue {queue_id}. Error: {e}")
        return []
def diagnose_routing_issue(auth: CXoneAuth, queue_id: str):
    Combines queue status and agent availability to provide a diagnostic report.
    print(f"--- Diagnosing Queue: {queue_id} ---")
        queue_data = check_queue_status(auth, queue_id)
        print(f"Queue Name: {queue_data.get('name')}")
        print(f"Queue Status: {queue_data.get('status')}")
        print(f"Max Concurrent Calls: {queue_data.get('maxConcurrentCalls')}")
        # Check if queue is paused
        if queue_data.get("status") == "paused":
            print("CRITICAL: Queue is PAUSED. Handovers will fail or queue indefinitely.")
        available_agents = check_agent_availability(auth, queue_id)
        print(f"Available Agents: {len(available_agents)}")
        if len(available_agents) == 0:
            print("WARNING: No agents are currently available. Handover will result in long wait or abandonment.")
        # Check Wrap-up codes (sometimes misconfigured wrap-up prevents agents from returning to pool)
        if "wrapUpCodes" in queue_data:
            print(f"Active Wrap-up Codes: {len(queue_data['wrapUpCodes'])}")
        print(f"Error diagnosing queue: {e}")
Step 3: Simulate the Handover Initiation
To confirm the handover mechanism works, we will simulate the creation of an interaction using the interaction:create API. This mimics what the Studio Flow does when it receives the transfer from Cognigy. This step confirms that the credentials and scopes are sufficient to actually place the call into the queue.
def simulate_handover(auth: CXoneAuth, payload: Dict[str, Any]) -> Dict[str, Any]:
    Simulates the handover by creating a new interaction.
    Note: This creates a real interaction in CXone. Use with caution in production.
    url = f"{auth.base_url}/api/v2/interactions"
    # Construct the interaction body based on Cognigy payload
    # We assume the Cognigy payload maps to the 'routingData' or 'participants'
    # This is a simplified mapping for diagnostic purposes
    interaction_body = {
        "type": "voice",
        "routingData": {
            "queueId": payload["transferContext"]["queueId"],
            "priority": 1
        "participants": [
                "id": "bot-initiated",
                "direction": "inbound",
                "address": payload["transferContext"]["participant"]["phoneNumber"],
                "name": payload["transferContext"]["participant"].get("name", "Unknown"),
                "customAttributes": payload["transferContext"].get("customAttributes", {})
        response = requests.post(url, headers=headers, json=interaction_body)
        if response.status_code == 201:
            result = response.json()
            print(f"SUCCESS: Interaction created. ID: {result.get('id')}")
            return result
        elif response.status_code == 400:
            print(f"BAD REQUEST: {response.text}")
            print("Likely cause: Invalid phone number format or missing required fields.")
            return {}
        elif response.status_code == 403:
            print(f"FORBIDDEN: Check OAuth scopes. You need 'interaction:initiate'.")
            return {}
        elif response.status_code == 429:
            print("RATE LIMITED: CXone API rate limit exceeded. Back off and retry.")
            return {}
        else:
            print(f"ERROR: {response.status_code} - {response.text}")
            return {}
        print(f"Network Error: {e}")
        return {}
Below is the complete, consolidated script. Save this as cxone_handover_diagnostic.py. Ensure you have a config.yaml file with your credentials.
import requests
import json
import yaml
# --- Configuration ---
def load_config(path="config.yaml"):
    with open(path, 'r') as f:
        return yaml.safe_load(f)
# --- Authentication Class ---
class CXoneAuth:
        data = {
# --- Validation Logic ---
    errors = []
        return ["Missing 'transferContext' root key."]
    if not context.get("queueId"):
        errors.append("Missing or empty 'queueId'.")
    if not context.get("participant"):
        errors.append("Missing 'participant' object.")
    else:
        if not participant.get("phoneNumber"):
            errors.append("Missing 'phoneNumber'.")
        elif not participant["phoneNumber"].startswith("+"):
            errors.append("Phone number must be in E.164 format.")
    return errors
# --- Diagnostic Logic ---
def check_queue_health(auth: CXoneAuth, queue_id: str):
    print(f"\n[CHECK] Queue Health for {queue_id}")
        # 1. Get Queue Details
        response = requests.get(url, headers=auth.get_headers())
            print("  [FAIL] Queue not found. Check the Queue ID in Cognigy.")
            return False
            print(f"  [FAIL] Error fetching queue: {response.status_code}")
            return False
        queue = response.json()
        print(f"  [OK] Queue Name: {queue.get('name')}")
        print(f"  [INFO] Status: {queue.get('status')}")
        if queue.get("status") == "paused":
            print("  [WARN] Queue is PAUSED. Agents cannot receive calls.")
        # 2. Get Agent Availability
        agent_url = f"{auth.base_url}/api/v2/routing/queues/{queue_id}/agents"
        agent_response = requests.get(agent_url, headers=auth.get_headers())
        if agent_response.status_code == 200:
            agents = agent_response.json().get("items", [])
            available = [a for a in agents if a.get("available")]
            print(f"  [INFO] Total Agents in Queue: {len(agents)}")
            print(f"  [INFO] Available Agents: {len(available)}")
            if len(available) == 0:
                print("  [WARN] No agents available. Handover will queue or abandon.")
        return True
        print(f"  [ERROR] {str(e)}")
        return False
def simulate_handover(auth: CXoneAuth, payload: Dict[str, Any]):
    print(f"\n[TEST] Simulating Handover Initiation")
    # Map Cognigy payload to CXone Interaction API structure
        "type": "voice",
        "routingData": {
            "priority": 1
        "participants": [
                "id": "diag-test",
                "name": payload["transferContext"]["participant"].get("name", "Test Caller"),
        response = requests.post(url, headers=auth.get_headers(), json=interaction_body)
            print(f"  [SUCCESS] Interaction Created: {data.get('id')}")
            print(f"  [SUCCESS] Handover mechanism is functional.")
            return True
            print(f"  [FAIL] Bad Request: {response.text}")
            print("  [HINT] Check phone number format or queue ID validity.")
            print(f"  [FAIL] Forbidden. Missing 'interaction:initiate' scope.")
            print(f"  [FAIL] Rate Limited.")
        else:
            print(f"  [FAIL] HTTP {response.status_code}: {response.text}")
        return False
        return False
# --- Main Execution ---
    # Load Config
        config = load_config()
    except FileNotFoundError:
        print("Error: config.yaml not found. Please create it with 'client_id', 'client_secret', and 'test_payload'.")
        exit(1)
    # Initialize Auth
    auth = CXoneAuth(
        client_id=config["client_id"],
        client_secret=config["client_secret"],
        base_url=config.get("base_url", "https://api.us-east-1.my.nicecxone.com")
    # Get Test Payload
    test_payload = config.get("test_payload", {})
    if not test_payload:
        # Default fallback for testing
        test_payload = {
                "queueId": "REPLACE_WITH_VALID_QUEUE_ID",
                "participant": {
                    "name": "Diagnostic Test",
                    "phoneNumber": "+15550000000"
    print("=== CXone/Cognigy Handover Diagnostic Tool ===")
    # Step 1: Validate Payload
    print("\n[STEP 1] Validating Cognigy Payload Structure")
    errors = validate_cognigy_payload(test_payload)
    if errors:
        print("  [FAIL] Payload Validation Errors:")
        for err in errors:
            print(f"    - {err}")
        exit(1)
    else:
        print("  [OK] Payload structure is valid.")
    # Step 2: Check Queue Health
    queue_id = test_payload["transferContext"]["queueId"]
    if queue_id == "REPLACE_WITH_VALID_QUEUE_ID":
        print("\n[WARN] Please update config.yaml with a real Queue ID.")
        exit(1)
    check_queue_health(auth, queue_id)
    # Step 3: Simulate Handover
    simulate_handover(auth, test_payload)
Create a config.yaml file in the same directory:
client_id: "your_oauth_client_id"
client_secret: "your_oauth_client_secret"
base_url: "https://api.us-east-1.my.nicecxone.com" # Adjust for your region
test_payload:
  transferContext:
    queueId: "your-real-queue-uuid"
    participant:
      phoneNumber: "+15551234567"
    customAttributes:
      intent: "billing"
Error: 400 Bad Request - “Invalid phone number format”
  • Cause: Cognigy sends the phone number without the country code prefix + or in a non-E.164 format (e.g., (555) 123-4567).
  • Fix: Ensure the Cognigy action sets the phoneNumber attribute to strict E.164 format. In Cognigy, use a regex transformation or ensure the input data source provides E.164.
  • Code Fix: In validate_cognigy_payload, we check for the + prefix. If missing, prefix the appropriate country code.
Error: 403 Forbidden - “Missing Scope”
  • Cause: The OAuth client used by the integration does not have the interaction:initiate or routing:queue:view scopes.
  • Fix: Go to CXone Admin > Integrations > OAuth Clients. Edit the client and add interaction:initiate, routing:queue:view, and agent:view.
  • Debugging: Run the auth section of the script. If the token is retrieved but the API call fails with 403, it is a scope issue, not a credential issue.
  • Cause: The handover frequency exceeds CXone’s rate limits (typically 20-50 requests per second depending on the endpoint).
  • Fix: Implement exponential backoff in your Cognigy integration logic or CXone middleware. Do not retry immediately. Wait 1-5 seconds before retrying.
  • Code Fix: Wrap the requests.post in a retry decorator with backoff_factor=0.5.
Error: Interaction Created but Call Drops
  • Cause: The handover succeeded (HTTP 201), but the call was disconnected immediately.
  • Fix: Check the Media Server logs in CXone. This often indicates a SIP trunk issue or a missing callControl configuration in the Studio Flow. Ensure the Studio Flow has a “Connect to Agent” or “Queue” node properly configured with a valid media server.
