Diagnosing and Fixing Session Handover Failures Between NICE Cognigy and CXone Studio
  • One sentence: You will build a diagnostic script that correlates Cognigy session logs with CXone Studio interaction events to identify exactly where a voicebot handover fails.
  • One sentence: This uses the NICE CXone REST API for interaction details and the Cognigy.CX API for session retrieval.
  • One sentence: The implementation is in Python using the requests library.
  • OAuth Client: A CXone API Client with view:interaction and view:analytics scopes. A Cognigy.CX Service Account with session:read permissions.
  • SDK/API Version: CXone REST API v2, Cognigy.CX API v1.
  • Language/Runtime: Python 3.9+.
  • External Dependencies: requests, python-dotenv, pyjwt (for optional token validation).
pip install requests python-dotenv pyjwt
CXone uses OAuth 2.0 Client Credentials flow. You must obtain an access token before querying any interaction data. The token expires in 3600 seconds, so caching is mandatory for production scripts, though for this diagnostic tool, a single fetch suffices.
import requests
import json
import os
from datetime import datetime
class CxoneAuth:
    def __init__(self, client_id: str, client_secret: str, org_id: str):
        self.client_id = client_id
        self.org_id = org_id
        self.token_url = f"https://api.mypurecloud.com/oauth/token"
        self.access_token = None
        self.expires_at = None
    def get_token(self) -> str:
        if self.access_token and self.expires_at and datetime.now() < self.expires_at:
            return self.access_token
        headers = {
        data = {
            "client_id": self.client_id,
        response = requests.post(self.token_url, headers=headers, data=data)
        if response.status_code != 200:
            raise Exception(f"Failed to obtain CXone token: {response.text}")
        token_data = response.json()
        self.expires_at = datetime.now().timestamp() + token_data["expires_in"]
Step 1: Retrieve the Interaction Timeline from CXone
When a handover fails, the first source of truth is the CXone Interaction. You need to pull the interaction details to see if the system marked the interaction as completed, abandoned, or failed. Crucially, you must check the wrapup code and the routing history.
The endpoint /api/v2/interactions/{interactionId} returns the full interaction object. However, for voice interactions, the detailed timeline of media streams and routing decisions is often more visible in the analytics or the specific interaction details with expand parameters. For this tutorial, we will use the interaction details endpoint with necessary expansions.
Required Scope: view:interaction
class CxoneInteractionClient:
    def __init__(self, org_id: str, auth: CxoneAuth):
        self.auth = auth
        self.base_url = f"https://{org_id}.mypurecloud.com/api/v2"
    def get_interaction_details(self, interaction_id: str) -> dict:
        Fetches detailed interaction data including routing and media streams.
        token = self.auth.get_token()
        headers = {
        # Expand routing and media to see handover attempts
        url = f"{self.base_url}/interactions/{interaction_id}"
        params = {
            "expand": "routing,media,participants"
            response = requests.get(url, headers=headers, params=params)
            response.raise_for_status()
            return response.json()
            if e.response.status_code == 404:
                print(f"Interaction {interaction_id} not found.")
            elif e.response.status_code == 403:
                print("Access denied. Check OAuth scopes.")
            else:
                print(f"HTTP Error: {e.response.status_code} - {e.response.text}")
            raise
            print(f"Network error: {e}")
            raise
    def analyze_routing_history(self, interaction: dict) -> list:
        Extracts routing events to identify handover attempts.
        routing = interaction.get("routing", {})
        history = routing.get("history", [])
        handover_events = []
        for event in history:
            # Look for queue adds or agent assignments that indicate a handover attempt
            if event.get("type") in ["queue-add", "agent-assignment"]:
                handover_events.append({
                    "timestamp": event.get("timestamp"),
                    "type": event.get("type"),
                    "queue": event.get("queue", {}).get("name"),
                    "agent": event.get("agent", {}).get("name") if "agent" in event else None
        return handover_events
Step 2: Retrieve the Cognigy Session Log
CXone Studio passes context to Cognigy via the Integration node. If the handover fails, you need to see what Cognigy received and what it attempted to return. You query the Cognigy.CX API using the conversationId or sessionId passed in the CXone interaction context.
The conversationId is usually available in the CXone interaction’s context or metadata fields. You must extract this ID from the CXone interaction first.
Required Scope: Cognigy Service Account Permissions (session:read)
class CognigySessionClient:
    def __init__(self, cognigy_api_url: str, cognigy_api_key: str):
        self.api_url = cognigy_api_url
        self.headers = {
            "Authorization": f"Bearer {cognigy_api_key}",
    def get_session(self, session_id: str) -> dict:
        Retrieves the full session log from Cognigy.CX.
        url = f"{self.api_url}/api/v1/sessions/{session_id}"
            response = requests.get(url, headers=self.headers)
                print(f"Cognigy Session {session_id} not found.")
            else:
                print(f"Cognigy API Error: {e.response.status_code} - {e.response.text}")
            raise
            print(f"Network error connecting to Cognigy: {e}")
            raise
    def extract_handover_payload(self, session: dict) -> dict:
        Parses the Cognigy session to find the last intent or output that
        should have triggered the handover.
        logs = session.get("logs", [])
        last_output = None
        # Iterate backwards to find the most recent significant event
        for log in reversed(logs):
            if log.get("type") == "output":
                last_output = log.get("data", {})
                break
        return last_output
Step 3: Correlate and Diagnose
The core logic lies in comparing the timestamps and state between the two systems. Common failure modes include:
  1. Timeout: Cognigy took too long to respond, causing CXone to drop the call.
  2. Missing Context: CXone did not pass the required userId or interactionId to Cognigy.
  3. Invalid Handover Command: Cognigy returned a valid JSON but missed the specific handover action or queue ID required by the CXone Studio Integration node.
def diagnose_handover(cxone_interaction: dict, cognigy_session: dict) -> dict:
    Compares CXone interaction data with Cognigy session data to find discrepancies.
    diagnosis = {
        "status": "unknown",
        "errors": [],
        "warnings": []
    # 1. Check CXone Interaction Status
    interaction_status = cxone_interaction.get("status")
    if interaction_status == "completed":
        diagnosis["status"] = "completed_but_verify"
    elif interaction_status == "abandoned":
        diagnosis["errors"].append("Interaction was abandoned by CXone. Check if Cognigy responded in time.")
    elif interaction_status == "failed":
        diagnosis["errors"].append("Interaction failed in CXone. Check routing configuration.")
    # 2. Extract Cognigy Session ID from CXone Metadata
    # Note: The key depends on your Studio Flow configuration.
    # Common keys: 'cognigy_session_id', 'externalId', or inside 'context'
    metadata = cxone_interaction.get("context", {})
    cognigy_session_id = metadata.get("cognigy_session_id") or metadata.get("externalId")
    if not cognigy_session_id:
        diagnosis["errors"].append("Could not find Cognigy Session ID in CXone interaction context.")
        return diagnosis
    # 3. Validate Cognigy Response
    if not cognigy_session:
        diagnosis["errors"].append(f"Cognigy session {cognigy_session_id} not found. Did the request reach Cognigy?")
        return diagnosis
    # 4. Check for Handover Action in Cognigy
    # In Cognigy, handovers are often triggered by a specific output action or intent.
    # You need to check if the expected handover intent was recognized.
    session_logs = cognigy_session.get("logs", [])
    handover_intent_found = False
    for log in session_logs:
        if log.get("type") == "intent":
            intent_name = log.get("data", {}).get("name", "")
            if "handover" in intent_name.lower() or "transfer" in intent_name.lower():
                handover_intent_found = True
                break
        # Also check outputs for handover commands
            output_data = log.get("data", {})
            # Assuming a standard structure where handover is indicated
            if output_data.get("handover") or output_data.get("transfer"):
                break
    if not handover_intent_found:
        diagnosis["warnings"].append("No explicit handover intent or output detected in Cognigy session. Check bot logic.")
    # 5. Timestamp Correlation
    cxone_start = datetime.fromisoformat(cxone_interaction.get("createdTime").replace("Z", "+00:00"))
    cognigy_start = datetime.fromisoformat(cognigy_session.get("startedAt").replace("Z", "+00:00"))
    time_diff = abs((cxone_start - cognigy_start).total_seconds())
    if time_diff > 5:
        diagnosis["warnings"].append(f"Significant time difference ({time_diff}s) between CXone creation and Cognigy start. Check network latency or integration node configuration.")
    return diagnosis
This script ties everything together. It takes a CXone Interaction ID, fetches the data, extracts the Cognigy Session ID, fetches the Cognigy data, and runs the diagnosis.
import os
from cxone_auth import CxoneAuth
from cxone_client import CxoneInteractionClient
from cognigy_client import CognigySessionClient
from diagnosis import diagnose_handover
# Load environment variables
load_dotenv()
def main():
    # Configuration
    CXONE_ORG_ID = os.getenv("CXONE_ORG_ID")
    CXONE_CLIENT_ID = os.getenv("CXONE_CLIENT_ID")
    CXONE_CLIENT_SECRET = os.getenv("CXONE_CLIENT_SECRET")
    COGNIGY_API_URL = os.getenv("COGNIGY_API_URL")
    COGNIGY_API_KEY = os.getenv("COGNIGY_API_KEY")
    INTERACTION_ID = os.getenv("INTERACTION_ID_TO_DEBUG")
    if not all([CXONE_ORG_ID, CXONE_CLIENT_ID, CXONE_CLIENT_SECRET, INTERACTION_ID]):
        print("Missing required CXone environment variables.")
        return
    # Initialize Clients
    cxone_auth = CxoneAuth(CXONE_CLIENT_ID, CXONE_CLIENT_SECRET, CXONE_ORG_ID)
    cxone_client = CxoneInteractionClient(CXONE_ORG_ID, cxone_auth)
    cognigy_client = None
    if COGNIGY_API_URL and COGNIGY_API_KEY:
        cognigy_client = CognigySessionClient(COGNIGY_API_URL, COGNIGY_API_KEY)
        print(f"Fetching CXone Interaction: {INTERACTION_ID}")
        interaction = cxone_client.get_interaction_details(INTERACTION_ID)
        # Analyze Routing
        routing_history = cxone_client.analyze_routing_history(interaction)
        print(f"Routing History: {json.dumps(routing_history, indent=2)}")
        # Get Cognigy Session
        cognigy_session = None
        if cognigy_client:
            # Extract Session ID from metadata
            metadata = interaction.get("context", {})
            if session_id:
                print(f"Fetching Cognigy Session: {session_id}")
                cognigy_session = cognigy_client.get_session(session_id)
            else:
                print("Warning: No Cognigy Session ID found in CXone context.")
        # Diagnose
        diagnosis = diagnose_handover(interaction, cognigy_session)
        print("\n--- Diagnosis Report ---")
        print(f"Status: {diagnosis['status']}")
        if diagnosis['errors']:
            print("\nErrors:")
            for err in diagnosis['errors']:
                print(f"  - {err}")
        if diagnosis['warnings']:
            print("\nWarnings:")
            for warn in diagnosis['warnings']:
                print(f"  - {warn}")
        if not diagnosis['errors'] and not diagnosis['warnings']:
            print("\nNo obvious errors detected. Check manual logs for subtle logic issues.")
        print(f"Fatal Error: {e}")
    main()
Error: 401 Unauthorized on Cognigy API
  • Cause: The API key is invalid, expired, or lacks the session:read permission.
  • Fix: Verify the Service Account in Cognigy.CX. Ensure the key is copied correctly without trailing spaces.
  • Code Fix:
    # Check if the key is empty or None
    if not cognigy_api_key:
        raise ValueError("Cognigy API Key is missing.")
Error: 404 Not Found on CXone Interaction
  • Cause: The Interaction ID is incorrect, or the interaction has aged out of the default retention period (default is often 30-90 days depending on tenant settings).
  • Fix: Verify the ID in the CXone Admin Console. If the interaction is old, you may need to query the Analytics API instead, which retains data longer but requires different scopes.
  • Code Fix:
    # Fallback to Analytics API if interaction not found
        print("Interaction not found in real-time API. Consider querying /api/v2/analytics/conversations/details/query")
Warning: No Cognigy Session ID in Context
  • Cause: The CXone Studio Integration node is not configured to pass the sessionId back to the interaction context, or the variable name is different.
  • Fix: Check the CXone Studio Flow. In the Integration node, ensure “Return Values” includes the Session ID. Update the script to look for the correct key (e.g., sessionId, cognigyId, etc.).
  • Code Fix:
    # Dynamic key search
    possible_keys = ["cognigy_session_id", "sessionId", "externalId", "cognigyId"]
    session_id = next((metadata.get(k) for k in possible_keys if metadata.get(k)), None)
  • Cause: You are querying the API too frequently. CXone has strict rate limits (typically 100-300 requests per minute depending on the endpoint).
  • Fix: Implement exponential backoff.
  • Code Fix:
    def request_with_retry(url, headers, max_retries=3):
            response = requests.get(url, headers=headers)
                wait_time = 2 ** attempt
                print(f"Rate limited. Waiting {wait_time} seconds.")
                time.sleep(wait_time)
            else:
                return response
        raise Exception("Max retries exceeded")
