Developing Custom NICE CXone Data Actions with Python SDK
You will build a Python module that defines JSON Schema templates for a CXone Data Action, implements a business logic handler for interaction events, validates payloads locally, deploys the action via the CXone REST API, manages version lifecycles, and queries execution metrics. This tutorial uses the CXone v2 Data Actions API and Analytics API with Python 3.9+ and httpx.
- OAuth client type: Machine-to-Machine (M2M) or JWT
- Required scopes:
data-actions:write,data-actions:read,analytics:read - SDK/API version: CXone REST API v2
- Language/runtime: Python 3.9+
- External dependencies:
httpx,pydantic,pydantic-settings,jsonschema
CXone uses standard OAuth 2.0 for API authentication. You must request a bearer token from your environment token endpoint and cache it for subsequent requests. The following implementation uses httpx with an exponential backoff retry mechanism for rate limits.
import os
import logging
from typing import Optional
import httpx
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
CXONE_BASE_URL = os.getenv("CXONE_BASE_URL", "https://api-us-1.nicecxone.com")
CLIENT_ID = os.getenv("CXONE_CLIENT_ID")
CLIENT_SECRET = os.getenv("CXONE_CLIENT_SECRET")
class CXoneAuth:
def __init__(self, client_id: str, client_secret: str, base_url: str):
self.client_id = client_id
self.base_url = base_url
def _fetch_token(self) -> str:
payload = {
"client_id": self.client_id,
with httpx.Client() as client:
response = client.post(
f"{self.base_url}/oauth/token",
data=payload,
headers={"Content-Type": "application/x-www-form-urlencoded"}
response.raise_for_status()
token_data = response.json()
self.token = token_data["access_token"]
self.token_expiry = time.time() + token_data["expires_in"] - 60
return self.token
def get_token(self) -> str:
if not self.token or time.time() >= self.token_expiry:
logger.info("Token expired or missing. Refreshing.")
return self._fetch_token()
return self.token
"Authorization": f"Bearer {self.get_token()}",
"Accept": "application/json"
Step 1: Define Schema Templates for Input and Output Payloads
CXone Data Actions require strict JSON Schema definitions for both input and output. You will use pydantic to enforce types locally and export the schema to JSON for the API deployment.
import json
class InteractionEventInput(BaseModel):
interaction_id: str = Field(..., description="Unique identifier for the interaction")
channel_type: str = Field(..., pattern="^(voice|chat|email|sms)$")
customer_phone: Optional[str] = None
sentiment_score: Optional[float] = Field(None, ge=-1.0, le=1.0)
tags: List[str] = []
class ActionOutputPayload(BaseModel):
enriched_data: dict = Field(default_factory=dict)
routing_recommendation: str = Field(default="default-queue")
confidence_score: float = Field(default=0.0, ge=0.0, le=1.0)
processed_at: str
# Export to JSON Schema for CXone API
INPUT_SCHEMA = InteractionEventInput.model_json_schema()
OUTPUT_SCHEMA = ActionOutputPayload.model_json_schema()
Step 2: Implement Business Logic Handlers That Process Interaction Events
The handler receives the validated input, applies business rules, and returns a structured output. You will implement synchronous processing here, but the pattern scales to async workers or external microservices.
import datetime
import jsonschema
def validate_payload(payload: dict, schema: dict) -> None:
jsonschema.validate(instance=payload, schema=schema)
def process_interaction_event(raw_payload: dict) -> dict:
validate_payload(raw_payload, INPUT_SCHEMA)
input_data = InteractionEventInput(**raw_payload)
routing_target = "default-queue"
confidence = 0.5
enriched = {}
if input_data.sentiment_score is not None:
if input_data.sentiment_score < -0.3:
routing_target = "priority-escalation-queue"
confidence = 0.92
enriched["escalation_reason"] = "negative_sentiment"
elif input_data.sentiment_score > 0.4:
routing_target = "retention-specialists"
confidence = 0.85
enriched["retention_flag"] = True
if "vip" in input_data.tags:
routing_target = "vip-dedicated-queue"
confidence = 0.95
enriched["vip_tier"] = "platinum"
output = ActionOutputPayload(
enriched_data=enriched,
routing_recommendation=routing_target,
confidence_score=confidence,
processed_at=datetime.datetime.utcnow().isoformat() + "Z"
return output.model_dump()
Step 3: Test Actions Locally Using the CXone Simulator
Before deployment, you must simulate the exact payload structure CXone injects into Data Actions. This local harness validates against the schema and measures execution time.
SIMULATOR_PAYLOAD = {
"interaction_id": "int_8f3a9c2d-4e1b-4a7c-9d2e-1f8a3b4c5d6e",
"channel_type": "voice",
"customer_phone": "+15550199887",
"sentiment_score": -0.42,
"tags": ["vip", "repeat_caller"]
def run_local_simulation(payload: dict) -> dict:
start = time.perf_counter()
result = process_interaction_event(payload)
elapsed = time.perf_counter() - start
logger.info(f"Local simulation successful. Latency: {elapsed*1000:.2f}ms")
return {"status": "success", "output": result, "latency_ms": round(elapsed * 1000, 2)}
except jsonschema.ValidationError as ve:
logger.error(f"Schema validation failed: {ve.message}")
return {"status": "error", "type": "validation", "message": ve.message}
logger.error(f"Handler execution failed: {str(e)}")
return {"status": "error", "type": "runtime", "message": str(e)}
Step 4: Deploy Actions Via the Data Actions API
You will POST the action definition to /api/v2/data-actions. The payload includes the JSON schemas, a handler reference, and metadata. OAuth scope required: data-actions:write.
class CXoneDataActionsClient:
def __init__(self, auth: CXoneAuth):
self.auth = auth
self.base_url = auth.base_url
self.client = httpx.Client(
base_url=self.base_url,
timeout=30.0,
headers=auth.get_headers()
def _retry_on_429(self, method, url, **kwargs):
max_retries = 3
response = method(url, **kwargs)
wait_time = 2 ** attempt
logger.warning(f"Rate limited (429). Retrying in {wait_time}s...")
time.sleep(wait_time)
response.headers["Authorization"] = f"Bearer {self.auth.get_token()}"
kwargs["headers"] = response.headers
return response
return response
def deploy_action(self, action_name: str, version: str, handler_url: str) -> dict:
payload = {
"name": action_name,
"version": version,
"isDeprecated": False,
"inputSchema": INPUT_SCHEMA,
"outputSchema": OUTPUT_SCHEMA,
"handlerUrl": handler_url,
"timeoutMs": 5000,
"description": "Sentiment-based routing enrichment action"
response = self._retry_on_429(
self.client.post,
"/api/v2/data-actions",
json=payload
if response.status_code == 201:
logger.info(f"Action deployed successfully: {response.json()['id']}")
return response.json()
Step 5: Manage Versioning and Deprecation Strategies
CXone supports multiple versions of a Data Action. You will update the version field and mark older versions as deprecated using PATCH requests. OAuth scope required: data-actions:write.
def update_version(self, action_id: str, new_version: str) -> dict:
payload = {"version": new_version}
self.client.patch,
f"/api/v2/data-actions/{action_id}",
json=payload
def deprecate_action(self, action_id: str) -> dict:
payload = {"isDeprecated": True}
self.client.patch,
json=payload
logger.info(f"Action {action_id} marked as deprecated.")
Step 6: Monitor Execution Latency and Error Rates
You will query the CXone Analytics API to retrieve execution metrics. The endpoint requires a JSON body with date ranges and filters. OAuth scope required: analytics:read.
def query_execution_metrics(self, action_id: str, start_date: str, end_date: str) -> dict:
query_body = {
"dateFrom": start_date,
"dateTo": end_date,
"groupBy": ["status", "version"],
"interval": "P1D",
"filters": [
"dimension": "actionId",
"operator": "EQUALS",
"value": action_id
"metrics": ["count", "avgLatencyMs", "errorRate"]
self.client.post,
"/api/v2/analytics/data-actions/details/query",
json=query_body
if response.status_code == 200:
return data.get("data", [])
The following script combines authentication, schema definition, local testing, deployment, version management, and monitoring into a single executable module. Replace the environment variables with your tenant credentials before running.
import os
import logging
import httpx
import jsonschema
import datetime
from typing import List, Optional as TypingOptional
# --- Configuration ---
# --- Authentication ---
class CXoneAuth:
payload = {
data=payload,
return self.token
return self.token
# --- Schema Definitions ---
customer_phone: TypingOptional[str] = None
sentiment_score: TypingOptional[float] = Field(None, ge=-1.0, le=1.0)
processed_at: str
# --- Business Logic Handler ---
confidence = 0.5
enriched = {}
confidence = 0.92
confidence = 0.85
confidence = 0.95
# --- Local Simulator ---
# --- API Client ---
self.auth = auth
timeout=30.0,
max_retries = 3
return response
return response
payload = {
"version": version,
"timeoutMs": 5000,
self.client.post,
json=payload
self.client.patch,
json=payload
self.client.patch,
json=payload
query_body = {
"dateTo": end_date,
"interval": "P1D",
"filters": [
"value": action_id
self.client.post,
json=query_body
return response.json().get("data", [])
# --- Execution Flow ---
auth = CXoneAuth(CLIENT_ID, CLIENT_SECRET, CXONE_BASE_URL)
client = CXoneDataActionsClient(auth)
logger.info("Running local simulation...")
sim_result = run_local_simulation(SIMULATOR_PAYLOAD)
logger.info(f"Simulation result: {sim_result}")
logger.info("Deploying Data Action...")
deployed = client.deploy_action(
action_name="SentimentRoutingAction",
version="1.0.0",
handler_url="https://your-handler-endpoint.example.com/process"
action_id = deployed["id"]
logger.info("Querying execution metrics...")
metrics = client.query_execution_metrics(
action_id=action_id,
start_date="2024-01-01T00:00:00Z",
end_date="2024-01-31T23:59:59Z"
logger.info(f"Metrics: {metrics}")
- What causes it: The OAuth token is expired, missing, or the client credentials are invalid.
- How to fix it: Verify
CXONE_CLIENT_IDandCXONE_CLIENT_SECRETmatch your CXone developer console. Ensure the token refresh logic runs before each request. Check that the token endpoint URL matches your region. - Code showing the fix: The
CXoneAuth.get_token()method automatically refreshes whentime.time() >= self.token_expiry. If credentials are wrong,response.raise_for_status()will throwHTTPErrorwith a clear message.
Error: 403 Forbidden
- What causes it: The OAuth token lacks the required scope for the endpoint.
- How to fix it: Regenerate the token with
data-actions:writefor deployment andanalytics:readfor metrics. CXone scopes are enforced strictly per endpoint. - Code showing the fix: Add scope verification during token acquisition:
if "data-actions:write" not in token_data.get("scope", ""):
raise ValueError("Missing required scope: data-actions:write")
Error: 400 Bad Request
- What causes it: The JSON Schema definitions contain invalid syntax, or the payload violates CXone field constraints.
- How to fix it: Validate your Pydantic models against JSON Schema draft-07. Ensure
inputSchemaandoutputSchemado not containdefinitionsthat CXone does not support. Remove$refpointers if the API rejects them. - Code showing the fix: Use
jsonschema.Draft7Validator.check_schema(INPUT_SCHEMA)before deployment to catch structural errors early.
- What causes it: You exceeded the tenant API rate limit or the endpoint-specific throttle.
- How to fix it: Implement exponential backoff. The
_retry_on_429wrapper handles this automatically. If the issue persists, reduce polling frequency or batch requests. - Code showing the fix: Already implemented in
CXoneDataActionsClient._retry_on_429withtime.sleep(2 ** attempt).
- What causes it: The handler URL returns a non-2xx status, or CXone encounters a transient processing failure.
- How to fix it: Verify the handler endpoint responds within the
timeoutMswindow. Check handler logs for unhandled exceptions. Retry the deployment after 60 seconds if it is a transient platform issue. - Code showing the fix: Wrap external handler calls in try-except blocks and return structured error JSON that matches the output schema to prevent CXone from marking the action as failed.
