Detecting Bot Traffic in Genesys Cloud Web Messaging with Python SDK
  • This tutorial builds a Python service that intercepts Genesys Cloud Web Messaging guest conversations, analyzes message velocity and device fingerprints, generates CAPTCHA challenges, and blocks malicious actors.
  • The solution uses the Genesys Cloud Python SDK (genesyscloud-python) alongside the /api/v2/webchat/conversations and /api/v2/platform/webhooks endpoints.
  • The code is written in Python 3.10+ using synchronous SDK calls and httpx for external threat intelligence synchronization.
  • OAuth Client Type: Internal or External Client Credentials flow
  • Required Scopes: webchat:read, webchat:write, conversation:read, conversation:write, webhook:read, webhook:write, routing:read
  • SDK Version: genesyscloud-python>=2.0.0
  • Runtime Requirements: Python 3.10+, pip install httpx pydantic python-dotenv
  • External Dependencies: httpx for threat feed polling, pydantic for payload validation, python-dotenv for credential management
Genesys Cloud requires a Bearer token for all API interactions. The client credentials flow exchanges a client ID and secret for an access token valid for 3600 seconds. The code below caches the token and implements automatic refresh before expiration.
import os
import httpx
from typing import Optional
class GenesysAuthManager:
    def __init__(self, client_id: str, client_secret: str, env: str = "mypurecloud.com"):
        self.client_id = client_id
        self.base_url = f"https://api.{env}"
        self.token_url = f"{self.base_url}/api/v2/oauth/token"
        self._access_token: Optional[str] = None
        self._expires_at: float = 0.0
    def get_token(self) -> str:
        if self._access_token and time.time() < self._expires_at - 60:
            return self._access_token
        payload = {
            "client_id": self.client_id,
        response = httpx.post(self.token_url, data=payload)
        response.raise_for_status()
        data = response.json()
        self._access_token = data["access_token"]
        self._expires_at = time.time() + data["expires_in"]
Required OAuth scope for token generation: webchat:read, webchat:write, conversation:read, conversation:write, webhook:read, webhook:write
Step 1: Initialize SDK and Query Web Messaging Conversations
The Python SDK requires an ApiClient configured with the authentication manager. We query active webchat conversations using pagination to respect maximum scan depth limits. The SDK handles pagination metadata, but we enforce a hard limit to prevent memory exhaustion during scaling events.
from purecloudplatformclientv2 import (
    PureCloudPlatformClientV2,
    ApiClient,
    WebChatApi,
    Configuration
from purecloudplatformclientv2.rest import ApiException
from typing import List
class WebMessagingScanner:
    def __init__(self, auth: GenesysAuthManager, max_scan_depth: int = 500):
        self.config = Configuration()
        self.config.access_token = auth.get_token()
        self.config.host = auth.base_url
        self.api_client = ApiClient(self.config)
        self.webchat_api = WebChatApi(self.api_client)
        self.max_scan_depth = max_scan_depth
        self.scan_count = 0
    def fetch_conversations(self) -> List[dict]:
        """Fetch active webchat conversations with pagination and depth limits."""
        conversations = []
        page_size = 50
        page_number = 1
        while self.scan_count < self.max_scan_depth:
                # Required scope: webchat:read
                response = self.webchat_api.get_webchat_conversations(
                    page_size=page_size,
                    page_number=page_number,
                    view="default",
                    conversation_state="active"
                if not response.entities:
                    break
                conversations.extend(response.entities)
                self.scan_count += len(response.entities)
                if self.scan_count >= self.max_scan_depth:
                    break
                if page_number >= response.page_count:
                    break
                page_number += 1
            except ApiException as e:
                if e.status == 429:
                    retry_after = int(e.headers.get("Retry-After", 2))
                    time.sleep(retry_after)
                elif e.status in (401, 403):
                    raise PermissionError(f"Authentication failed with status {e.status}")
                else:
                    raise
        return conversations
Step 2: Construct Detection Payloads and Validate Schemas Against Depth Limits
We define a detection payload structure that contains a traffic reference, signature matrix, and scan directive. Pydantic validates the schema before processing. This prevents malformed data from crashing the detection pipeline.
from typing import Dict, List, Optional
import hashlib
class DetectionPayload(BaseModel):
    traffic_reference: str = Field(..., description="Unique conversation identifier")
    signature_matrix: Dict[str, str] = Field(..., description="Device fingerprint and browser headers")
    scan_directive: str = Field(..., pattern=r"^(full|light|deep)$", description="Analysis depth")
    message_velocity: float = Field(..., ge=0.0, description="Messages per second")
    fingerprint_hash: str = Field(..., description="Consistent user identifier")
    def validate_scan_depth(self, max_depth: int) -> bool:
        if self.scan_directive == "deep" and max_depth < 100:
            return False
        return True
class BotDetector:
    def __init__(self, max_depth: int = 500):
        self.max_depth = max_depth
        self.audit_log: List[dict] = []
        self.metrics = {"latency_ms": [], "success_rate": 0, "total_scans": 0, "successful_scans": 0}
    def build_detection_payload(self, conversation: dict) -> Optional[DetectionPayload]:
            fingerprint_data = f"{conversation.get('participant', {}).get('ip_address', '')}:{conversation.get('participant', {}).get('user_agent', '')}"
            fingerprint_hash = hashlib.sha256(fingerprint_data.encode()).hexdigest()[:16]
            payload = DetectionPayload(
                traffic_reference=conversation["id"],
                signature_matrix={
                    "user_agent": conversation.get("participant", {}).get("user_agent", ""),
                    "ip_address": conversation.get("participant", {}).get("ip_address", ""),
                    "language": conversation.get("participant", {}).get("language", "")
                scan_directive="full",
                message_velocity=self.calculate_velocity(conversation),
                fingerprint_hash=fingerprint_hash
            if not payload.validate_scan_depth(self.max_depth):
                self.log_audit("SCAN_LIMIT_EXCEEDED", payload.traffic_reference)
                return None
            return payload
            self.log_audit("PAYLOAD_CONSTRUCTION_FAILED", str(e))
            return None
    def calculate_velocity(self, conversation: dict) -> float:
        messages = conversation.get("messages", [])
        if len(messages) < 2:
            return 0.0
        import datetime
        timestamps = []
        for msg in messages:
            ts = msg.get("timestamp")
            if ts:
                timestamps.append(datetime.datetime.fromisoformat(ts.replace("Z", "+00:00")))
        timestamps.sort()
        duration = (timestamps[-1] - timestamps[0]).total_seconds()
        return len(messages) / duration if duration > 0 else 0.0
Step 3: Behavioral Pattern Analysis and CAPTCHA Challenge Generation
Atomic POST operations update conversation metadata and inject CAPTCHA challenges. The SDK wraps these in a single transaction context. We verify format compliance before sending and trigger automatic blocking when velocity exceeds thresholds.
from purecloudplatformclientv2 import WebChatApi, ConversationApi, WebhookApi
class BotDetector:
    # ... previous code ...
    def analyze_and_challenge(self, payload: DetectionPayload) -> dict:
        start_time = time.time()
        self.metrics["total_scans"] += 1
        # Behavioral pattern analysis
        is_suspicious = payload.message_velocity > 5.0
        is_bot_pattern = self.check_threat_intel(payload.fingerprint_hash)
        result = {
            "traffic_reference": payload.traffic_reference,
            "status": "legitimate",
            "action": "none"
        if is_suspicious or is_bot_pattern:
            result["status"] = "flagged"
            self._inject_captcha(payload.traffic_reference)
            result["action"] = "captcha_challenged"
            if payload.message_velocity > 20.0:
                self._block_participant(payload.traffic_reference)
                result["action"] = "blocked"
                self.log_audit("BOT_BLOCKED", payload.traffic_reference)
        latency = (time.time() - start_time) * 1000
        self.metrics["latency_ms"].append(latency)
        self.metrics["successful_scans"] += 1
        return result
    def _inject_captcha(self, conversation_id: str) -> None:
        # Required scope: webchat:write, conversation:write
            conversation_api = ConversationApi(self.api_client)
            message_body = {
                "to": {"id": conversation_id, "type": "webchat"},
                "from": {"id": "system", "type": "system"},
                "text": "Please complete the CAPTCHA to verify you are a human user."
            conversation_api.post_conversations_messaging_conversation(conversation_id, body=message_body)
            if e.status == 429:
                time.sleep(int(e.headers.get("Retry-After", 2)))
                self._inject_captcha(conversation_id)
            else:
                self.log_audit("CAPTCHA_INJECTION_FAILED", f"{conversation_id}: {e.status}")
    def _block_participant(self, conversation_id: str) -> None:
        # Required scope: routing:read, conversation:write
            block_body = {"status": "closed", "reason": "bot_detected"}
            conversation_api.put_conversations_messaging_conversation(conversation_id, body=block_body)
            self.log_audit("BLOCK_TRIGGER_FAILED", f"{conversation_id}: {e.status}")
    def check_threat_intel(self, fingerprint: str) -> bool:
        # Simulated external threat feed sync
        known_bots = ["malicious_fingerprint_01", "scraper_agent_v2"]
        return fingerprint in known_bots
    def log_audit(self, event_type: str, reference: str) -> None:
        self.audit_log.append({
            "timestamp": time.time(),
            "event": event_type,
            "reference": reference,
            "latency_ms": self.metrics["latency_ms"][-1] if self.metrics["latency_ms"] else 0
Step 4: Webhook Synchronization and Metrics Tracking
We register a webhook to external threat intelligence feeds and expose detection metrics for automated Genesys Cloud management. The webhook configuration uses atomic POST operations with format verification.
    def register_threat_webhook(self, target_url: str) -> dict:
        # Required scope: webhook:write
            webhook_api = WebhookApi(self.api_client)
            webhook_body = {
                "name": "BotDetectionThreatSync",
                "description": "Syncs detected bot traffic with external threat intelligence",
                "target_url": target_url,
                "enabled": True,
                "event_filters": [
                    {"event": "webchat.conversation.created", "condition": "status == 'active'"}
                "format": "json"
            response = webhook_api.post_platform_webhooks(body=webhook_body)
            return {"webhook_id": response.id, "status": "registered"}
            if e.status == 409:
                return {"status": "already_exists"}
            raise
    def get_detection_metrics(self) -> dict:
        total = self.metrics["total_scans"]
        successful = self.metrics["successful_scans"]
        success_rate = (successful / total * 100) if total > 0 else 0.0
        avg_latency = sum(self.metrics["latency_ms"]) / len(self.metrics["latency_ms"]) if self.metrics["latency_ms"] else 0.0
            "total_scans": total,
            "successful_scans": successful,
            "success_rate_percent": round(success_rate, 2),
            "average_latency_ms": round(avg_latency, 2),
            "audit_log_count": len(self.audit_log)
Step 5: Complete Working Example
The following script ties authentication, scanning, detection, and management into a single executable module. It requires environment variables for credentials and runs a continuous detection loop with safe iteration.
import os
import sys
def main():
    load_dotenv()
        sys.exit("Missing GENESYS_CLIENT_ID or GENESYS_CLIENT_SECRET")
    auth = GenesysAuthManager(client_id, client_secret)
    scanner = WebMessagingScanner(auth, max_scan_depth=500)
    detector = BotDetector(max_depth=500)
    # Register external threat sync webhook
    detector.register_threat_webhook("https://threat-intel.example.com/api/v1/sync")
    print("Bot detection service started. Press Ctrl+C to stop.")
        while True:
            conversations = scanner.fetch_conversations()
            for conv in conversations:
                payload = detector.build_detection_payload(conv)
                if payload:
                    result = detector.analyze_and_challenge(payload)
                    print(f"Processed: {result['traffic_reference']} | Status: {result['status']} | Action: {result['action']}")
            metrics = detector.get_detection_metrics()
            print(f"Metrics: Scans={metrics['total_scans']} | Success={metrics['success_rate_percent']}% | Avg Latency={metrics['average_latency_ms']}ms")
            time.sleep(10)
    except KeyboardInterrupt:
        print("\nShutting down detection service.")
        print(f"Fatal error: {e}")
        sys.exit(1)
    main()
  • Cause: Expired OAuth token or missing scopes on the registered application.
  • Fix: Verify the client credentials match the Genesys Cloud organization. Ensure the application has webchat:read, webchat:write, conversation:read, conversation:write, webhook:write scopes enabled in the admin console. The GenesysAuthManager automatically refreshes tokens, but initial scope misconfiguration will persist until updated.
  • Code Fix: Add explicit scope validation during initialization.
if "webchat:read" not in available_scopes:
    raise ValueError("Missing required scope: webchat:read")
  • Cause: Exceeding Genesys Cloud API rate limits during high-velocity bot attacks or aggressive polling intervals.
  • Fix: The implementation includes Retry-After header parsing. Ensure polling intervals exceed 10 seconds. Implement exponential backoff if consecutive 429s occur.
  • Code Fix: Add backoff multiplier to retry logic.
backoff = 1
while attempts < 3:
        response = self.webchat_api.get_webchat_conversations(...)
        break
        if e.status == 429:
            wait_time = int(e.headers.get("Retry-After", 2)) * backoff
            time.sleep(wait_time)
            backoff *= 2
            attempts += 1
Error: 5xx Server Error or Schema Validation Failure
  • Cause: Genesys Cloud backend instability or malformed detection payloads exceeding maximum scan depth.
  • Fix: The DetectionPayload Pydantic model enforces schema validation before API calls. Catch ApiException with status codes 500-599 and implement circuit breaker logic to prevent cascade failures.
  • Code Fix: Wrap SDK calls in try-except blocks that log 5xx errors and pause scanning.
    if 500 <= e.status < 600:
        self.log_audit("SERVER_ERROR", f"Status {e.status} encountered. Pausing scan.")
        time.sleep(15)
