Designing WebSocket Heartbeat Monitoring with Automatic Dead Connection Cleanup
You will build a production-grade WebSocket lifecycle manager that tracks connection health via bidirectional pings, enforces idle timeouts, and automatically purges dead sockets before they exhaust connection pools or corrupt real-time state. The result is a resilient middleware layer that maintains stable streaming sessions to Genesys Cloud CX and NICE CXone APIs without memory leaks, phantom session drift, or degraded WEM/Speech Analytics data pipelines.
- Licensing Tier: Genesys Cloud CX 2 or higher (Streaming API access), NICE CXone Enterprise or above (Real-Time Streaming API access). WEM Add-on required if routing agent interaction streams to speech analytics.
- Platform Permissions:
- Genesys Cloud:
Analytics > Real Time > View,Telephony > Call > View,Architect > Flow > View - NICE CXone:
Real-Time Analytics > View,Telephony > Monitor Calls,Studio > View Flows
- Genesys Cloud:
- OAuth Scopes:
analytics:realtime:view,telephony:call:view,integration:app:write(for token refresh automation) - External Dependencies: Node.js 18 LTS or higher,
wsv8+ library, Redis 7+ for distributed connection tracking, NGINX or AWS ALB for WebSocket upgrade routing, reverse proxy timeout configuration set to 3600s minimum.
1. Establishing the Bidirectional Ping/Pong Contract
WebSockets operate over TCP, which does not guarantee delivery or connection liveness without explicit application-layer verification. Both Genesys Cloud and NICE CXone streaming endpoints drop idle connections after 30 to 60 seconds of silence. You must implement an RFC 6455 compliant ping/pong cycle that runs independently of business payload processing.
Configure the heartbeat interval to 15 seconds. This provides a 3 ping cycle window before declaring a connection dead. The client must send a ping frame on the interval. The server responds with a pong frame containing the same application data. You must track the last pong receipt timestamp per socket. If the current time exceeds the last pong timestamp plus the timeout threshold, the connection transitions to DEAD.
The Trap: Setting the heartbeat interval below 5 seconds causes CPU thrashing under high concurrency and triggers rate limiting on platform load balancers. Setting it above 45 seconds aligns too closely with the platform idle timeout, leaving no recovery window for transient network jitter. The downstream effect is either unnecessary connection churn or delayed failure detection that corrupts real-time dashboards and WEM recording state.
import WebSocket from 'ws';
import { EventEmitter } from 'events';
const HEARTBEAT_INTERVAL_MS = 15_000;
const PONG_TIMEOUT_MS = 35_000;
export class HeartbeatManager extends EventEmitter {
private readonly sockets = new Map<WebSocket, { lastPong: number; pingCounter: number }>();
public register(socket: WebSocket): void {
this.sockets.set(socket, { lastPong: Date.now(), pingCounter: 0 });
socket.once('pong', (data) => {
const meta = this.sockets.get(socket);
if (meta) {
meta.lastPong = Date.now();
meta.pingCounter++;
public tick(): void {
const now = Date.now();
for (const [socket, meta] of this.sockets) {
if (socket.readyState === WebSocket.OPEN) {
socket.ping(Buffer.from(`hb-${now}`));
} else {
this.sockets.delete(socket);
public getDeadSockets(): WebSocket[] {
const dead: WebSocket[] = [];
if (now - meta.lastPong > PONG_TIMEOUT_MS) {
dead.push(socket);
return dead;
We schedule the tick() method via setInterval at exactly HEARTBEAT_INTERVAL_MS. The ping payload carries a timestamp for debugging, though RFC 6455 does not require it. The server response overwrites lastPong. This approach isolates health monitoring from message routing logic, preventing backpressure in the business pipeline from masking connection death.
2. Implementing the Dead Connection Reaper
Detecting a dead connection is only half the problem. You must safely terminate the socket, release associated memory, and notify downstream consumers without dropping in-flight events. The reaper runs on a separate interval, typically 10 seconds, and iterates through the dead socket list returned by the heartbeat manager.
For each dead socket, you must invoke socket.terminate() rather than socket.close(). The close() method waits for a graceful TCP FIN handshake, which will never complete on a dead connection. terminate() forces an immediate TCP RST, freeing the file descriptor and releasing the underlying buffer immediately. After termination, you must emit a connection.dropped event with the socket identifier and reason code. This event triggers state reconciliation in your business layer, ensuring that partial call legs or abandoned speech analytics streams are marked as INCOMPLETE rather than ACTIVE.
The Trap: Calling socket.close() on a dead connection leaves the socket in a CLOSING state indefinitely. The Node.js event loop continues to hold references to the socket buffer, causing heap growth that eventually triggers FATAL ERROR: Ineffective mark-compacts near heap limit. The downstream effect is an out-of-memory crash during peak call volume, requiring full service restart and losing all active streaming state.
export class ConnectionReaper extends EventEmitter {
private readonly heartbeat: HeartbeatManager;
constructor(heartbeatManager: HeartbeatManager) {
super();
this.heartbeat = heartbeatManager;
public runReaper(): void {
const deadSockets = this.heartbeat.getDeadSockets();
for (const socket of deadSockets) {
const socketId = (socket as any).id || crypto.randomUUID();
// Force immediate teardown
socket.terminate();
// Clean up internal tracking
this.heartbeat.sockets.delete(socket);
// Notify business logic for state reconciliation
this.emit('connection.dropped', {
socketId,
reason: 'pong_timeout',
timestamp: Date.now(),
pendingBytes: socket._bufferedAmount
The pendingBytes field in the event payload is critical. It tells your stream processor how much unacknowledged data was in flight. You must implement a checkpointing mechanism that rolls back to the last successfully acknowledged message ID. This prevents duplicate event processing when the connection eventually re-establishes.
3. Platform-Specific Streaming Handshake & Token Lifecycle
Genesys Cloud and NICE CXone handle WebSocket authentication differently. You cannot reuse a single HTTP bearer token for the entire WebSocket lifecycle. Both platforms require token rotation mid-stream without dropping the connection.
For Genesys Cloud, you establish the initial connection via HTTP upgrade to /api/v2/analytics/streaming. The endpoint expects a Authorization: Bearer <token> header. When the token approaches expiration (typically 1800 seconds), you must send a JSON control message over the existing WebSocket:
"type": "token-refresh",
"token": "eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9..."
The server validates the new token and responds with {"type": "token-refresh-ack"}. You must wait for this acknowledgment before discarding the old token.
For NICE CXone, the Real-Time API uses /api/v2/streaming/real-time. Token refresh occurs via a separate HTTP POST to /api/v2/auth/token/refresh, and the new token is injected into subsequent WebSocket frames via a platform-specific X-NICE-AUTH header or control frame. You must track token expiry timestamps and schedule refresh attempts 120 seconds before expiration.
The Trap: Attempting to reconnect the entire WebSocket when a token expires instead of performing an in-stream refresh causes a complete session reset. The downstream effect is loss of real-time agent state, dropped call leg tracking, and duplicate event ingestion when the new stream catches up. WEM recordings become fragmented, and speech analytics pipelines report false abandonment rates.
import https from 'https';
export class PlatformTokenManager {
private currentToken: string;
private expiryTimestamp: number;
public async refreshToken(platform: 'genesys' | 'cxone'): Promise<string> {
const payload = JSON.stringify({
grant_type: 'refresh_token',
refresh_token: process.env.OAUTH_REFRESH_TOKEN,
client_id: process.env.OAUTH_CLIENT_ID,
client_secret: process.env.OAUTH_CLIENT_SECRET
const options = {
hostname: platform === 'genesys' ? 'api.mypurecloud.com' : 'api.nice-incontact.com',
path: '/oauth/token',
method: 'POST',
headers: {
'Content-Length': Buffer.byteLength(payload)
return new Promise((resolve, reject) => {
const req = https.request(options, (res) => {
let data = '';
res.on('data', (chunk) => data += chunk);
res.on('end', () => {
const parsed = JSON.parse(data);
this.currentToken = parsed.access_token;
this.expiryTimestamp = Date.now() + (parsed.expires_in * 1000);
resolve(parsed.access_token);
req.on('error', reject);
req.write(payload);
req.end();
public shouldRefresh(): boolean {
return (this.expiryTimestamp - Date.now()) < 120_000;
We schedule token refresh checks every 60 seconds. If shouldRefresh() returns true, we call refreshToken() and inject the new token into the active WebSocket via the platform-specific control channel. This preserves the TCP connection, maintains sequence continuity, and prevents stream reset penalties.
4. Distributed Connection Tracking & Pool Governance
Single-node heartbeat management fails in containerized or multi-instance deployments. You must externalize connection state to a shared store. Redis is the standard choice due to its atomic operations and pub/sub capabilities.
Each WebSocket connection receives a unique connectionId upon upgrade. You store a Redis hash containing:
socketId: Platform-assigned identifierlastPong: Epoch timestampplatform:genesysorcxonetenantId: Routing contextstate:ACTIVE,DEGRADED,DEADretryCount: Consecutive failure counter
You enforce a maximum connection pool size per tenant, typically 50 concurrent streams. When the limit is reached, new connections enter a priority queue. High-priority streams (live call legs, agent desktop state) preempt low-priority streams (historical analytics, batch WFM sync).
The Trap: Using in-memory Map or Set structures in a scaled deployment creates split-brain state. Instance A believes a connection is alive while Instance B terminates it. The downstream effect is duplicate event processing, race conditions during reconnection, and inconsistent real-time dashboards that show agents in conflicting states.
# Redis tracking commands executed during lifecycle
HSET ws:conn:{connectionId} socketId:{platformId} lastPong:{timestamp} state:ACTIVE tenant:{tenantId}
EXPIRE ws:conn:{connectionId} 120
# Reaper query across instances
SCAN 0 MATCH "ws:conn:*" COUNT 100
# Evaluate lastPong against current time, set state to DEAD if expired
HSET ws:conn:{connectionId} state:DEAD
DEL ws:conn:{connectionId}
We execute the SCAN command in a background worker rather than blocking the main event loop. The EXPIRE command provides a safety net for crashed processes that never emit cleanup events. Redis pub/sub broadcasts state:DEAD transitions to all instances, ensuring coordinated teardown and preventing orphaned streams.
Edge Case 1: TCP Half-Open State with Silent Network Partition
The failure condition occurs when a firewall or NAT device drops the connection silently without sending TCP FIN or RST. The local OS keeps the socket in ESTABLISHED state, but no data flows. Your heartbeat manager detects this correctly, but the platform side may still consider the stream active for up to 90 seconds.
The root cause is asymmetric routing or stateful firewall timeout policies that differ from application-level expectations. The platform streaming API does not acknowledge ping frames if the upstream TCP stack considers the connection dead.
The solution requires implementing a dual-verification pattern. You must combine application-layer pings with TCP keepalive configuration at the OS level. Set net.ipv4.tcp_keepalive_time=30, net.ipv4.tcp_keepalive_intvl=10, and net.ipv4.tcp_keepalive_probes=3 in your container environment. When the heartbeat manager declares a socket dead, you must also issue a shutdown(socket, SHUT_RDWR) before terminate(). This forces the OS to probe the TCP stack one final time. If the probe fails within 1 second, you proceed with immediate teardown. This prevents the 90-second platform reconciliation window from causing duplicate event ingestion.
Edge Case 2: OAuth Token Rotation During Active Stream
The failure condition occurs when the token refresh control message is sent, but the platform responds with a 401 Unauthorized or drops the WebSocket before sending the acknowledgment. Your middleware holds the old token, attempts to process incoming frames, and encounters authentication validation errors.
The root cause is token clock skew between your middleware and the platform identity provider. NTP drift exceeding 60 seconds causes premature expiration detection. Additionally, sending the refresh message too early triggers platform-side rate limits on token validation endpoints.
The solution requires implementing a token validation buffer and exponential backoff for control messages. You must verify the new token via a lightweight GET /api/v2/users/me request before injecting it into the WebSocket control channel. If validation fails, you retain the old token and wait 30 seconds before retrying. You must also implement a token.mismatch event that pauses stream processing until validation succeeds. This prevents corrupted state from propagating to WEM recording pipelines or speech analytics queues. Cross-reference the WFM Real-Time Data Synchronization guide for checkpointing strategies that align with token rotation boundaries.
