Designing WebSocket Event Replay Systems for Recovering Missed Messages After Disconnection
You will build a stateful WebSocket client with an automated replay mechanism that synchronizes missed CCaaS events after network partitions or platform restarts. The end result is a fault-tolerant integration that maintains exact event ordering, handles sequence gaps, prevents duplicate processing during reconnection, and complies with platform rate limits without degrading live event throughput.
  • Licensing Tier: Genesys Cloud CX 2 or CX 3 (Event Streams API requires CX 2+). NICE CXone requires Real-Time Events license add-on. WEM real-time metrics require separate WEM licensing.
  • Granular Permissions: Telephony > Call Control > View, Routing > Queue > View, Architect > Flow > View, Event Streams > Subscribe. For custom integrations, assign the Event Streams Consumer built-in role or create a custom role with read:events and view:events permissions.
  • OAuth Scopes: view:events, read:events, read:architect, read:telephony, read:queue. Scope requirements map directly to the event types you subscribe to. Request only the scopes your replay pipeline consumes to avoid least-privilege violations.
  • External Dependencies: Durable sequence store (Redis or PostgreSQL), message queue (Kafka, RabbitMQ, or AWS SQS) for decoupling replay ingestion from business logic, HTTP client library with retry/backoff support, and a load balancer or service mesh for WebSocket connection management.
1. Establishing the Sequence Tracking and State Persistence Layer
Genesys Cloud and CXone do not guarantee delivery over WebSocket. The platform treats the connection as a best-effort broadcast channel. Every event payload contains a monotonically increasing sequence identifier. Your client must treat this sequence as the source of truth for state synchronization.
You must persist the last successfully processed sequence to durable storage before acknowledging receipt. In-memory tracking fails during process restarts, container evictions, or garbage collection pauses. The persistence layer must support atomic reads and writes to prevent race conditions when multiple consumer instances scale horizontally.
Use a Redis sorted set or a PostgreSQL table with a client_id and last_sequence column. Update the sequence only after the event has been written to your message queue. This creates an exactly-once processing boundary at the ingestion layer.
Configuration Pattern:
  "sequence_store": {
    "type": "redis",
    "key_prefix": "ccaws:events:seq:",
    "ttl_seconds": 86400,
    "sync_interval_ms": 500,
    "ack_mode": "post_queue"
The Trap: Acknowledging a sequence before writing to the downstream queue, or storing the sequence in volatile application memory. When a container restarts, the client resumes from a stale sequence. The platform replays events that your downstream system already processed. Duplicate events corrupt transactional workloads, trigger duplicate API calls to external CRMs, and cause financial or compliance violations in regulated environments.
Architectural Reasoning: We separate the ingestion contract from the processing contract. The WebSocket client owns the sequence. The message queue owns the processing. By persisting the sequence only after successful queue publication, we guarantee that replay never duplicates work. The platform does not track consumer state. Your architecture must absorb the blast radius of disconnections without requiring manual intervention or full-state rehydration.
2. Implementing the Reconnection and Replay Request Workflow
When the WebSocket connection terminates, the client must detect the disconnect, calculate the sequence gap, and request missing events via the HTTP replay endpoint. The platform provides a dedicated replay API that returns paginated event batches. You must request replay only after implementing exponential backoff. Immediate reconnection attempts trigger platform rate limiting and degrade global event delivery performance.
The replay endpoint accepts the last_sequence header and returns events starting from last_sequence + 1. You must parse the next_sequence header from the replay response to continue pagination. The response body contains an array of event objects. Each object includes the sequence, event_type, timestamp, and payload.
Replay Request Payload and Headers:
GET /api/v2/events/replay?event_types=architect:flow:call,telephony:call:created
Host: myorg.mypurecloud.com
Last-Sequence: 894201
Accept: application/json
X-Genesys-Client-Id: replay-consumer-v1
Replay Response Structure:
  "items": [
      "sequence": 894202,
      "event_type": "architect:flow:call",
      "timestamp": "2024-05-12T14:22:01.102Z",
      "payload": {
        "call_id": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
        "flow_id": "x9y8z7w6-v5u4-t3s2-r1q0-p9o8n7m6l5k4",
        "step": "route_to_agent"
  "next_sequence": 894203,
  "has_more": true
The Trap: Requesting replay immediately after disconnect without implementing jittered exponential backoff. The platform enforces strict rate limits on replay endpoints. Aggressive polling triggers HTTP 429 responses. The client enters a retry loop, consuming thread pools and network bandwidth. Live WebSocket connections for other tenants experience latency spikes. The platform may temporarily suspend replay access for your org until the request rate normalizes.
Architectural Reasoning: We treat replay as a secondary pipeline with independent backoff controls. The client calculates the disconnect duration. If the gap exceeds 30 seconds, the client initiates replay with a base delay of 2 seconds, multiplied by a backoff factor of 2, capped at 30 seconds, with 20 percent jitter. This pattern aligns with platform capacity planning. Replay endpoints share compute resources with live event streaming. Controlled pacing prevents resource contention and ensures your integration does not degrade platform stability. You must also validate the has_more flag and continue pagination until the flag returns false or the next_sequence matches the live stream cursor.
3. Building the Idempotent Event Processing and Gap Resolution Engine
Replay responses may contain events that your client already processed before the disconnect. Network partitions often cause duplicate delivery. Your processing engine must deduplicate events using the sequence identifier. You must also handle sequence gaps where the platform purged events due to retention policies.
Implement a sequence validation algorithm that compares incoming replay sequences against the persisted last sequence. If a replay sequence is less than or equal to the persisted sequence, discard the event. If a replay sequence exceeds the persisted sequence by more than one, log a gap warning. The platform retains standard events for 24 hours. High-volume events may be retained for 12 hours. WEM real-time events have a 6-hour retention window. Gaps beyond retention windows require full-state reconciliation, not replay.
Idempotency Validation Logic:
def process_replay_event(event, persisted_sequence):
    event_seq = event["sequence"]
    if event_seq <= persisted_sequence:
        return "DUPLICATE_DISCARDED"
    if event_seq > persisted_sequence + 1:
        log_gap_warning(persisted_sequence, event_seq)
        trigger_state_reconciliation(event["event_type"])
    # Proceed to queue publication
    publish_to_queue(event)
    update_persisted_sequence(event_seq)
    return "PROCESSED"
The Trap: Assuming replay fills all sequence gaps. The platform does not guarantee event persistence beyond the retention window. If your client disconnects for longer than the retention period, replay returns an empty array or a truncated batch. Processing logic that blocks waiting for missing sequences causes consumer starvation. Downstream systems experience data staleness. Routing decisions rely on outdated state. Agents receive incorrect disposition codes.
Architectural Reasoning: We design replay as a synchronization tool, not a backup system. The engine must tolerate gaps without halting. When a gap exceeds the configured threshold, the system triggers a full-state reconciliation job that queries the platform REST API for current entity states. For example, a missing telephony:call:updated event triggers a GET /api/v2/telephony/calls/{callId} request to fetch the current call state. This hybrid approach combines fast replay recovery with reliable state reconciliation. You must also implement sequence ordering guarantees. Replay batches may arrive out of order due to platform pagination. Sort events by sequence before processing to maintain causal consistency.
4. Managing Backpressure and Rate Limit Compliance
Replay amplifies incoming event volume. A 5-minute disconnect can generate thousands of replayed events. Your processing pipeline must handle burst traffic without exhausting memory or blocking live WebSocket ingestion. You must implement independent backpressure controls for live and replay pipelines.
The platform returns rate limit headers on replay requests: X-RateLimit-Remaining, X-RateLimit-Reset, and X-RateLimit-Limit. You must parse these headers and adjust your request frequency accordingly. When X-RateLimit-Remaining drops below 10, pause replay requests until X-RateLimit-Reset timestamp passes. Implement a token bucket algorithm for replay consumption. Allocate tokens based on your downstream queue capacity.
Backpressure Configuration:
  "replay_pipeline": {
    "max_concurrent_requests": 2,
    "batch_size": 100,
    "rate_limit_buffer": 15,
    "backpressure_threshold": 0.8,
    "live_event_priority": true,
    "queue_capacity_check_interval_ms": 1000
The Trap: Consuming replay batches faster than the downstream queue can process. The replay pipeline fills application memory with buffered events. Garbage collection pauses increase. The live WebSocket thread blocks on queue publication. New live events drop. The platform detects high error rates and terminates the WebSocket connection. The client enters a death spiral of disconnect, replay request, memory exhaustion, and crash.
Architectural Reasoning: We isolate replay ingestion from live event processing. The live pipeline uses a dedicated thread pool with high priority. The replay pipeline uses a separate thread pool with dynamic scaling. We monitor queue depth and CPU utilization. When queue depth exceeds 80 percent, the replay pipeline throttles request frequency. We also implement circuit breaker patterns for replay endpoints. If replay requests fail consecutively due to rate limits or platform errors, the circuit opens. The client falls back to state reconciliation instead of retrying replay. This design prevents resource exhaustion and maintains system stability during extended outages.
Edge Case 1: Sequence Wraparound and Long-Running Streams
Sequence identifiers eventually wrap around when they exceed the maximum integer limit. Long-running integrations spanning months or years may encounter wraparound conditions. If your client uses signed 32-bit integers, sequences wrap at 2,147,483,647. The platform uses unsigned 64-bit integers, but client implementations must account for language-specific integer limits.
Root Cause: The client compares sequences using signed integer arithmetic. When the platform sequence wraps to a lower value, the comparison logic incorrectly identifies new events as duplicates. The client discards valid events. State drift occurs.
Solution: Use unsigned 64-bit integers for sequence storage and comparison. Implement modular arithmetic for wraparound detection. When the platform sequence drops below the persisted sequence by more than 100,000, treat it as a wraparound event. Reset the sequence store and trigger full-state reconciliation. Log the wraparound event for audit compliance.
Edge Case 2: Event Type Mismatch During Replay
Your client subscribes to specific event types via the WebSocket connection. The replay endpoint returns events based on the event_types query parameter. If the subscription configuration changes between disconnect and replay request, the replay response may contain event types your pipeline does not handle.
Root Cause: The replay request uses a static event type list. The platform configuration changes dynamically. Agents move between queues. Flows update. New event types deploy. The replay response includes events outside your processing schema. The parser throws exceptions. The consumer crashes.
Solution: Dynamically fetch the current event subscription configuration before initiating replay. Compare the requested event types against the active WebSocket subscription. Filter replay responses to match your processing capabilities. Implement a schema registry for event payloads. Validate replay events against the registry before processing. Discard unrecognized event types with structured logging. This approach ensures forward compatibility and prevents parser failures during platform updates.
Edge Case 3: Platform Maintenance Window Purge
Scheduled platform maintenance may purge event streams or reset sequence counters. During major version upgrades, the platform may clear event retention buffers. Your client reconnects after maintenance and requests replay. The replay endpoint returns an empty array or throws a 404 error.
Root Cause: The platform sequence counter resets to zero. The persisted sequence in your store exceeds the new maximum. Replay requests fail. The client enters an infinite retry loop.
Solution: Implement a maintenance window detection mechanism. Monitor platform status endpoints for scheduled maintenance notices. Before maintenance begins, flush the sequence store and archive the current state. After maintenance completes, reset the persisted sequence to zero. Trigger full-state reconciliation instead of replay. Update your client configuration to handle sequence resets gracefully. Log the maintenance event for compliance auditing. This design ensures your integration survives platform lifecycle events without manual intervention.
