Designing Spatial Audio Routing for Virtual Reality Customer Support
This guide details the architecture and configuration required to route spatial audio metadata alongside standard telephony streams within Genesys Cloud CX. You will configure WebRTC Media Streams to support native Data Channels, build Architect flows that inject positional coordinates (azimuth, elevation, distance) into the session, and structure the JSON payloads required for a VR client to render agent audio at precise 3D coordinates. The end result is a contact center flow where agent voices dynamically anchor to virtual avatars, maintaining correct spatial positioning during transfers, queues, and multi-party consultations.
  • Licensing: Genesys Cloud CX 3 license is required for advanced WebRTC Media Stream capabilities and Data Channel support.
  • Roles:
    • Architect > Flow > Edit to create spatial metadata injection flows.
    • Telephony > WebRTC > Media Stream > Edit to configure Data Channel parameters.
    • Admin > Org > Edit if configuring custom OAuth clients for the VR SDK.
  • OAuth Scopes:
    • media:web-rtc:read_write for session management.
    • user:read for agent profile retrieval.
    • flow:interaction:read for routing context.
  • External Dependencies:
    • VR Client SDK implementing the W3C WebRTC Data Channel specification.
    • Unity, Unreal, or WebXR environment capable of parsing binaural audio or HRTF (Head-Related Transfer Function) metadata.
    • Network environment permitting UDP ports 50000-59999 for WebRTC media and data transport.
1. WebRTC Media Stream Configuration for Data Channels
Standard SIP telephony does not support out-of-band metadata transmission reliably across carrier networks. SIP INFO messages are frequently stripped by middleboxes, and custom headers are not standardized for spatial data. We utilize the native WebRTC Data Channel, which runs peer-to-peer over the existing DTLS-SRTP encryption context. This guarantees that spatial metadata travels with the same latency and reliability characteristics as the audio stream.
Configuration Steps:
  1. Navigate to Telephony > WebRTC > Media Streams.
  2. Create a new Media Stream or edit an existing one dedicated to VR interactions.
  3. Enable Data Channels. This is the critical switch that allocates the SCTP stream within the WebRTC connection.
  4. Set the Data Channel Label to spatial_metadata. The label must match the label requested by the VR client SDK during createDataChannel().
  5. Configure Ordered Delivery to true. Spatial coordinates must arrive in strict sequence. If coordinate set N arrives after coordinate set N+1, the VR client will render the agent in the wrong position, causing a jarring “teleport” effect.
  6. Set Max Retransmits to 3. We limit retransmissions because stale spatial data is worse than no spatial data. If a packet is dropped, the VR client should interpolate the position rather than render a coordinate from 200ms ago.
The Trap: Configuring the Media Stream without defining the Data Channel label or expecting the VR client to auto-negotiate the label. WebRTC Data Channels require an explicit label match. If the client requests spatial_metadata and the Media Stream label is default, the data channel handshake fails. The audio will connect, but the VR client will receive no positional data, defaulting the agent voice to mono/stereo center-channel, breaking the spatial illusion.
Architectural Reasoning: We enforce ordered delivery with low retransmission limits because spatial audio rendering is highly sensitive to jitter. Unordered delivery allows the VR engine to receive a “left” coordinate after a “right” coordinate, causing the audio source to flicker. The low retransmission limit ensures the data stream remains lightweight and does not compete for bandwidth with the Opus audio stream, which takes absolute precedence.
2. Architect Flow for Spatial Metadata Injection
The VR client typically initiates the call, but the Genesys Cloud Architect controls the routing logic. We must inject spatial context into the interaction so that when the agent answers, the VR client receives the initial position payload. Additionally, if the call transfers, the new agent’s position must be injected immediately.
  1. Open Architect and create a new flow for VR inbound routing.
  2. Add a Set Data Channel Message block. This block pushes JSON payloads directly into the WebRTC Data Channel associated with the interaction.
  3. Configure the Data Channel Label to spatial_metadata.
  4. Construct the Message Payload using the following JSON structure. We use relative coordinates tied to the customer’s avatar origin point.
  "event_type": "agent_position_update",
  "agent_id": "{{interaction.agent.id}}",
  "spatial_data": {
    "x": -2.5,
    "y": 1.2,
    "z": 4.0,
    "yaw": 0,
    "pitch": 0,
    "roll": 0
  "audio_profile": "binaural_hrtf_v2",
  "timestamp_ms": "{{system.current_epoch_ms}}"
  1. Connect the Set Data Channel Message block to the Transfer To Queue or Transfer To Agent block.
  2. Add a second Set Data Channel Message block on the success path of the transfer to inject the new agent’s coordinates.
The Trap: Blocking the Architect flow on the completion of the Data Channel write. The Set Data Channel Message block is asynchronous. If you route the flow based on a “Success” condition that waits for an acknowledgment from the VR client, you will introduce significant latency into the call setup. The VR client may not be fully rendered when the call connects. We must fire-and-forget the spatial payload. The VR client is responsible for buffering the data. Blocking the flow causes the media stream to pause waiting for the data channel confirmation, resulting in silence and dropped calls under load.
Architectural Reasoning: We inject the payload at the transfer boundary rather than relying on a continuous stream from the VR client alone. The VR client handles continuous head-movement updates, but the CCaaS platform must provide the authoritative “agent location” when the routing context changes. This separates concerns: the VR client owns the customer’s head rotation, while Genesys Cloud owns the agent’s world-space coordinates.
3. VR Client Payload Structure and Frequency Tuning
The VR client must continuously update the customer’s head orientation so the spatial audio remains anchored to the agent’s avatar, even as the customer looks around. This requires a high-frequency data channel stream. We must define the payload schema and throttling logic to prevent Data Channel congestion.
VR Client Implementation Logic:
The VR client must send orientation updates at a fixed interval. We recommend 60Hz (every 16.6ms) for high-end headsets, throttling to 30Hz (every 33.3ms) if network jitter exceeds 50ms.
Payload Schema:
  "event_type": "customer_orientation",
  "customer_id": "{{interaction.customer.id}}",
  "orientation": {
    "x": 0.15,
    "y": -0.02,
    "z": 0.99,
    "w": 0.05
  "sequence_id": 1042
Frequency Tuning Configuration:
In the VR client SDK, implement a delta-encoding logic. Do not send a payload if the orientation change is less than 0.5 degrees. This reduces Data Channel payload volume by up to 40% during periods of head stillness.
The Trap: Sending high-fidelity HRTF convolution data over the Data Channel. Some developers attempt to send the full HRTF filter coefficients from the VR client to the Genesys platform for server-side spatial mixing. This is architecturally invalid. The Data Channel has a limited MTU (Maximum Transmission Unit), typically 16KB. HRTF datasets are large. Attempting to stream HRTF data will fragment the packets, saturate the Data Channel, and cause the Opus audio stream to drop packets due to SCTP congestion control. The CCaaS platform does not perform spatial rendering. The rendering must happen on the VR client. The Data Channel only transports metadata.
Architectural Reasoning: We rely on client-side binaural rendering because the Genesys Cloud media servers are designed for low-latency mono/stereo pass-through. Introducing server-side spatial mixing would require custom DSP plugins, increase CPU load on the media servers, and add unacceptable latency. By keeping the audio stream as clean Opus and sending only lightweight metadata, we leverage the VR headset’s native spatial audio engine, which already possesses the HRTF profiles for the specific user.
4. Agent Transfer and Spatial State Handoff
When a call transfers from a Tier 1 agent to a Tier 2 specialist, the spatial audio source must seamlessly migrate from the Tier 1 avatar to the Tier 2 avatar. If the spatial state is not updated, the customer continues to hear the new agent’s voice coming from the old agent’s avatar, causing severe disorientation.
  1. In the Architect flow, locate the Transfer To Agent block.
  2. On the Success path, add a Set Data Channel Message block.
  3. Inject a spatial_handoff payload that includes a fade-out duration for the old agent and a fade-in for the new agent.
  "event_type": "spatial_handoff",
  "old_agent_id": "{{interaction.previous_agent.id}}",
  "new_agent_id": "{{interaction.current_agent.id}}",
  "new_position": {
    "x": 3.0,
    "y": 1.2,
    "z": -1.5,
    "yaw": 90,
    "pitch": 0,
    "roll": 0
  "transition_ms": 500
  1. Ensure the VR client SDK parses transition_ms to crossfade the audio sources. The old spatial audio node should fade to zero gain over 500ms, while the new node fades in from zero to full gain.
The Trap: Assuming the Data Channel persists across the transfer. In some complex routing scenarios involving external SIP trunks or legacy CTI integrations, the WebRTC session may tear down and re-establish. If the session resets, the Data Channel label and state are lost. The VR client must implement a heartbeat mechanism. If the spatial metadata stream stops for more than 2 seconds, the VR client should revert to a safe default position (center channel) and request a re-sync from the Genesys Cloud interaction API. Failing to handle the session reset causes the spatial audio to freeze at the last known coordinate, which is now incorrect.
Architectural Reasoning: We mandate a crossfade transition because an instantaneous jump in spatial coordinates creates a “pop” in the audio signal. The human auditory system is highly sensitive to sudden changes in interaural time difference (ITD) and interaural level difference (ILD). A 500ms crossfade smooths the ILD transition, making the transfer feel natural, as if the customer is turning their head to face the new specialist.
Edge Case 1: Metadata-Audio Desynchronization
The Failure Condition: The agent speaks, but the audio appears to come from a different avatar than the one currently speaking. The spatial position lags behind the video/avatar state by 300-500ms.
The Root Cause: The Data Channel and the Media Stream travel over different UDP sockets. While they share the same DTLS context, network congestion can affect the SCTP stream (Data Channel) differently than the RTP stream (Audio). If the network experiences packet loss, the SCTP retransmission logic may delay spatial packets while the audio stream continues playing.
The Solution: Implement client-side timestamp alignment. The VR client must compare the timestamp_ms in the spatial payload against the local audio buffer timestamp. If the spatial packet arrives late, the client should discard the coordinate update rather than applying it. The spatial position should only update if the timestamp is within a 100ms window of the current audio playback head. This prevents the avatar from “snapping” to a position that the audio has already passed.
Edge Case 2: Cross-Realm Routing Latency
The Failure Condition: The customer is in the US, the VR client is hosted in Europe, and the Genesys Cloud Media Server is in the US. Spatial updates experience high jitter, causing the audio to drift left and right erratically.
The Root Cause: WebRTC Data Channels are peer-to-peer between the VR client and the Genesys Media Server. If the Media Server is far from the VR client, the RTT increases. The VR client sends orientation updates, but the Genesys platform does not need to process them for routing. However, if the VR client is waiting for an acknowledgment or if the return spatial data (agent position) is delayed, the jitter buffer on the client side expands.
The Solution: Configure the VR client to use a local spatial prediction algorithm. The VR client should extrapolate the agent’s position based on the last known velocity and direction for up to 200ms. This hides the network latency. Additionally, ensure the Genesys Cloud Media Stream is assigned to a Media Server region geographically closest to the VR client hosting environment, even if the agents are in a different region. Genesys Cloud supports cross-region media routing with low latency. Prioritize media proximity over agent proximity for VR workloads.
Edge Case 3: Data Channel MTU Fragmentation on Mobile VR
The Failure Condition: Mobile VR headsets (e.g., Quest 3 in browser mode) drop the data connection entirely after 10 minutes of the call.
The Root Cause: Mobile browsers have stricter memory constraints and different SCTP implementations. If the VR client sends complex JSON with nested objects, the payload size may approach the MTU limit. When fragmentation occurs, mobile browsers may fail to reassemble the SCTP packets correctly, leading to a Data Channel stall.
The Solution: Flatten the JSON payload. Remove nested objects and use dot-notation keys. Compress the payload using a lightweight schema like MessagePack before sending over the Data Channel, if the VR client SDK supports binary payloads. If using JSON, ensure the payload size never exceeds 1KB. The spatial payload example provided earlier is approximately 200 bytes, which is well within safe limits. Monitor the dataChannel.bufferedAmount property in the VR client SDK. If this value exceeds 64KB, the client must throttle the update frequency immediately.
