Designing Resilient SIP Header Manipulation Rules for Legacy PBX Migrations
This masterclass details the implementation of SIP Header Manipulation (Normalization) within a Genesys Cloud BYOC environment. By the end of this guide, you will be able to construct robust rules on your Session Border Controller (SBC) to ensure seamless interoperability between Genesys Cloud and legacy PBX systems (e.g., Avaya, Cisco, Mitel). You will learn how to normalize Diversion headers, transform To/From URIs for PAI (P-Asserted-Identity) compliance, and handle proprietary vendor headers that cause signaling failures during call transfers and conferencing.
Header manipulation occurs at the media/signaling tier and requires administrative access to the SBC.
  • Licensing: Genesys Cloud CX 1, 2, or 3 with BYOC Premise or BYOC Cloud.
  • Permissions:
    • Telephony > Trunk > View/Edit
    • SBC Administrator Access (e.g., AudioCodes, Ribbon, Cisco CUBE).
  • Tools: SIP Trace / PCAP analysis tools (Wireshark, AudioCodes Syslog Viewer).
1. The Challenge of Heterogeneous SIP Dialects
SIP is a standard, but vendors implement “Dialects.” For example, Avaya might send the original caller ID in a Diversion header, while Cisco might use History-Info. When these calls reach Genesys Cloud, if the headers aren’t in a format the cloud platform expects, features like “Callback to Original ANI” or “CLI Preservation” will fail.
Architectural Reasoning:
Do not expect the Cloud to adapt to your legacy PBX. Use the SBC as a Signaling Gateway to normalize all inbound and outbound traffic to a “Gold Standard” SIP profile.
2. Normalizing the Diversion Header for CLI Preservation
In many migration scenarios, calls are “Hairpinned” through the legacy PBX. To ensure Genesys Cloud sees the actual customer’s phone number rather than the PBX’s trunk number, you must manipulate the Diversion and From headers.
Implementation Pattern (AudioCodes Message Manipulation):
  • Trigger: Inbound INVITE from Legacy PBX.
  • Action: If Diversion header exists, copy its value to the From header and the P-Asserted-Identity header.
  • Regex: ^<sip:(.*)@.*> → sip:$1@genesys.cloud
3. Handling Proprietary “X-Headers”
Legacy systems often inject custom headers (e.g., X-Avaya-User-Context) that can be several kilobytes long.
The Trap:
Passing massive, proprietary headers to Genesys Cloud. This can exceed the maximum MTU of the SIP packet, causing fragmentation or rejection by the Genesys Cloud Edge (413 Entity Too Large).
The Solution: Implement a Header Scrubbing Rule. On the SBC, explicitly remove all X- headers that are not specifically whitelisted for your Architect Data Action logic.
4. URI Transformation for PAI/RPID Compliance
Carriers often require a specific format for P-Asserted-Identity (PAI) or Remote-Party-ID (RPID) for emergency services (E911) or to prevent “Robocall” blocking (STIR/SHAKEN).
Implementation Step:
Construct a rule that ensures the To header always contains a + prefix and the user=phone parameter, even if the internal PBX sends a 4-digit extension.
  • Source: 1234
  • Transformation: +15550001234;user=phone
Edge Case 1: The “Double Plus” Failure
  • The failure condition: Outbound calls fail with 404 Not Found or 400 Bad Request.
  • The root cause: The SBC adds a + to the number, but the carrier also adds a +, resulting in ++1....
  • The solution: Implement a Conditional Prefix Rule. If Destination starts with + -> Do Nothing; Else -> Add +.
Edge Case 2: Transferee “Name” Corruption
  • The failure condition: During a transfer, the agent sees the caller’s name as a string of hex codes.
  • The root cause: Incompatible character encoding (e.g., UTF-16 vs UTF-8) in the Display Name portion of the Contact header.
  • The solution: Use a manipulation rule to strip all non-ASCII characters from the Display Name field or replace the entire string with a normalized “External Caller” label if the encoding cannot be safely converted.
