Designing Phishing Simulation and Security Awareness Training Pipelines for Agents
This guide details the architectural design and implementation of an automated pipeline connecting external phishing simulation tools to contact center workforce management (WFM) platforms. You will configure the data flow to enforce training completion before granting access to production queues. The end result is a system where security compliance becomes a prerequisite for login status, with automated reporting validating adherence through API integrations.
Before implementing this architecture, you must verify specific licensing and permission sets within your CCaaS environment. This pipeline relies on programmatic access to User profiles and WFM Skill assignments.
Licensing Requirements
- Genesys Cloud CX: PureCloud Professional or Enterprise license. Essential for accessing the Users API (
/api/v2/users) and Workforce Management API (/api/v2/wfm). - NICE CXone: Enterprise licensing with WEM Add-on enabled. Required for granular skill-based routing control via API.
Granular Permissions
You must assign specific permissions to the Service Account or Integration User responsible for this pipeline.
Users > ReadandEdit: Necessary to update Agent skills based on training status.WFM Skill Assignments > Edit: Required to remove access to production queues automatically.Reports > Read: To fetch completion metrics for dashboarding.
External Dependencies
- Security Simulation Platform: A third-party tool (e.g., KnowBe4, Proofpoint) capable of sending webhook events upon simulation completion or failure.
- Middleware/Integration Layer: An iPaaS solution (e.g., MuleSoft, Azure Logic Apps) or custom microservice to normalize data between the security tool and CCaaS API. This layer handles rate limiting and error buffering.
OAuth Scopes
The integration user requires the following OAuth scopes for token generation:
cloudplatform:user.readcloudplatform:user.writecloudplatform:wfm.skill_assignment.editcloudplatform:reporting.read
1. Architecture and Data Flow Design
The core of this system is the event-driven handshake between the security simulation tool and the CCaaS platform. You must avoid direct API calls from the security vendor to the contact center, as vendor stability varies. Instead, implement a middleware buffer.
The Pipeline Logic
- Trigger: Agent clicks a simulated phishing link or fails a quiz within the external security tool.
- Event: The security tool sends a JSON payload via webhook to your integration layer endpoint.
- Normalization: The middleware maps the vendor-specific agent identifier (email, ID) to the CCaaS User ID.
- Action: The system queries the CCaaS API to update the Agent’s skill assignments or status.
- Feedback: A confirmation webhook is sent back to the security tool for audit logging.
The Trap: Direct Mapping Failures
A common misconfiguration involves mapping email addresses directly as User IDs without a canonical lookup service. Email addresses change, and agents often share aliases. If you rely on email == email logic, you risk blocking the wrong user or failing to block the correct one during a campaign.
Architectural Reasoning
Use a persistent lookup table in your middleware database that maps security_tool_agent_id to cc_user_uuid. This decouples the identity layer from the operational layer. If an agent changes their email address, you only update the mapping table once, rather than reconfiguring API logic across multiple tools.
Sample Payload (Security Tool → Middleware)
The webhook payload must contain the following fields for deterministic processing:
"event_id": "sim_8f9a2b1c",
"timestamp": "2023-10-27T14:30:00Z",
"agent_identifier": "jsmith@company.com",
"simulation_type": "phishing_credential_harvest",
"outcome": "failed",
"required_training_module_id": "SEC-TRN-001"
Sample Payload (Middleware → CCaaS API)
When instructing the CCaaS platform to restrict access, you do not toggle the user status directly. You modify their skill assignments. This allows the system to keep the agent logged in for non-production tasks while blocking them from receiving voice traffic.
"skillAssignments": [
"skillId": "prod_voice_queue_skill_01",
"action": "delete"
"skillId": "training_required_skill_blocker",
"action": "add"
2. Automated WFM Integration and Skill Enforcement
Once the pipeline is established, you must configure the Workforce Management (WFM) logic to respect the security status changes in real time. This section covers how to programmatically enforce the training block without human intervention.
Skill Assignment Strategy
Do not use the User Status API (PATCH /api/v2/users/{id}) to set agents to “Away” or “Offline.” This disrupts WFM forecasting and reporting data integrity. Instead, utilize skill-based routing logic. You will create a specific security control skill (e.g., SEC_TRAINING_BLOCKED) that has no associated queues or is routed to a dead-end queue.
Configuration Steps
- Create Security Control Skill: Define a new skill in the CCaaS UI named
SECURITY_COMPLIANCE_BLOCK. Assign it a value of 0. - Queue Routing Rule: Ensure no production voice or chat queues route to agents with this skill active. If a queue requires multiple skills, ensure the agent does not meet the “AND” logic requirement for that specific block.
- API Enforcement Script: The middleware must call the WFM Skill Assignment API upon receiving a failure event.
The Trap: Skill Value Conflicts
A frequent error involves assigning a skill value (e.g., 10) to the blocker skill without ensuring the routing logic accounts for it. If your production queues use a “Best Match” algorithm and the blocker skill has a high value, the agent might still receive calls because the system prioritizes the skill value over the security intent.
Set the SECURITY_COMPLIANCE_BLOCK skill to a value of 0 or -1. Configure production queues to require skills with a minimum value of 1 for routing eligibility. This creates a hard dependency where the blocker skill effectively nullifies the agent’s ability to match against production queues regardless of other active skills like “English” or “Technical Support”.
API Endpoint for Skill Update
Use the PUT /api/v2/wfm/users/{userId}/skillassignments endpoint. Note that this requires a full replacement payload, not an update patch. You must retrieve the current skill assignments first to avoid overwriting existing valid skills.
// GET Current Skills
GET /api/v2/wfm/users/{agent_id}/skillassignments
// POST New Assignment (Full Replacement)
PUT /api/v2/wfm/users/{agent_id}/skillassignments
"userId": "{agent_id}",
"skillId": "{existing_skill_1_id}",
"value": 5,
"languageId": null
"skillId": "{security_blocker_skill_id}",
"value": 0,
"languageId": null
Reinstatement Logic
When the agent completes the training in the external tool, the webhook must trigger a reverse operation. The middleware must call the API again to remove the blocker skill and restore the production skills. This process should be idempotent, meaning running it multiple times does not cause errors or duplicate entries.
3. Reporting and Compliance Tracking
Visibility into security posture is as critical as the enforcement mechanism. You must build a reporting pipeline that aggregates training data from the CCaaS API and correlates it with simulation results from the external tool.
Data Aggregation Strategy
Do not rely on standard CCaaS reporting exports for this specific metric. Standard reports track talk time and handle time, not security events. You must construct a custom aggregation query or use the Reporting API to pull skill assignment change logs.
Implementation Steps
- Define Custom Report Definition: Create a report in the CCaaS platform that filters by Skill Assignment Event Type (
ADD,DELETE). - Schedule Export: Configure the system to export these logs daily to a secure S3 bucket or data warehouse.
- Join Logic: In your analytics layer, join the CCaaS skill change logs with the security simulation tool’s outcome data using the
timestampanduserId.
The Trap: Data Latency in Reporting
A critical failure mode occurs when reporting is queried immediately after an API call returns a success code. The CCaaS API response indicates the request was processed, but the WFM engine may take several seconds to propagate the change to the real-time dashboard. If your compliance dashboard queries the system within 5 seconds of a status change, it may display stale data.
Implement an exponential backoff strategy for reporting queries regarding security status. Wait at least 60 seconds after a skill assignment event before flagging the agent as “Compliant” in your compliance dashboard. This ensures the WFM state has fully propagated through the system cluster.
API Query for Audit Log
To verify compliance, query the events API to retrieve changes made by the integration user.
GET /api/v2/users/{userId}/events?eventType=SkillAssignment&after=2023-10-27T14:30:00Z
Sample Response Snippet
"entities": [
"id": "event_12345",
"timestamp": "2023-10-27T14:35:00Z",
"type": "SkillAssignment",
"userId": "user_abc123",
"details": {
"skillId": "SECURITY_COMPLIANCE_BLOCK",
"action": "delete",
"previousValue": 0,
"newValue": null
"total": 1
Edge Case 1: Timezone and Timestamp Mismatches
The security simulation tool operates on UTC, while the CCaaS platform may report timestamps in the local agent timezone or a specific regional server time. If your middleware does not normalize these timestamps before writing to the database, audit trails will fail to correlate events.
The Failure Condition: An agent completes training at 23:00 UTC. The CCaaS event logs it as 18:00 EST. Your reporting script filters for “Today” and misses the entry because the date boundaries do not align.
The Solution: Enforce ISO 8601 standard timestamps (with Z suffix) in all database writes. Perform all timestamp comparisons in UTC within your middleware logic before converting to local time for display. Ensure your CCaaS API authentication token includes timestamp headers if required by your specific deployment region.
Edge Case 2: API Rate Limiting During Mass Campaigns
Security tools often run phishing campaigns across the entire organization simultaneously. If 500 agents fail a simulation at 9:00 AM, the middleware must make 500 API calls to update WFM skills. CCaaS platforms have strict rate limits (e.g., 100 requests per minute for specific endpoints).
The Failure Condition: The integration layer hits the HTTP 429 Too Many Requests error. The system queues the remaining agents, but the security tool times out waiting for a success response, leading to false positives where agents are never blocked because the API call failed silently.
The Solution: Implement a circuit breaker pattern in the middleware. Use a queueing mechanism (e.g., RabbitMQ or AWS SQS) to buffer the requests. Configure the consumer workers with a rate limiter that adheres strictly to the platform’s documented limits. Add a retry logic with exponential backoff specifically for HTTP 429 responses.
Edge Case 3: Agent Status State Machine Conflicts
Agents can manually override their status (e.g., switching from “Ready” to “Break”). If an agent fails a simulation and is blocked via API, but then manually changes their status to “Offline,” the system may not detect they are still active in the queue logic.
The Failure Condition: The security block removes skills, but the agent manually sets status to “Offline.” Later, they switch back to “Ready” automatically. The WFM engine might restore the skills based on a cached state or a scheduled refresh that ignores the security flag.
The Solution: Store the security compliance state in a persistent configuration store (e.g., Redis) outside of the CCaaS API. The middleware should check this state before allowing any status change to “Ready” for agents with active blocks. If a block exists, the system must force the skill assignment update regardless of the manual status change.
Edge Case 4: Duplicate Training Module Execution
Agents may receive multiple phishing simulations in a short period. If the middleware does not deduplicate events, it could trigger multiple API calls to add and remove skills rapidly.
The Failure Condition: Race conditions occur where one “block” request is processed after an “unblock” request from a subsequent simulation event that has already been marked as complete by the agent. The final state of the skill assignment becomes unpredictable.
The Solution: Implement a transactional lock on the user ID within your middleware. When processing a security event for user_id, acquire a distributed lock. Ensure the logic checks the current status in the database before applying any changes. If an agent is already blocked, do not trigger another block request; wait for the completion event to trigger the unlock.
