Designing Peer Collaboration Network Analysis Using Interaction Transfer and Consultation Data
This guide details the architectural and data engineering approach for extracting, modeling, and analyzing agent-to-agent collaboration patterns derived from transfer and consultation interactions. You will build a pipeline that transforms raw interaction logs into a directed weighted graph, enabling you to identify expertise clusters, routing inefficiencies, and collaboration bottlenecks across your contact center.
  • Licensing Tier: Genesys Cloud CX 2 or CX 3 (WEM Add-on required for quality correlation), NICE CXone Standard or Professional with Analytics & Reporting bundle
  • Genesys Permissions: Analytics > Report > Read, Interaction > Interaction > Read, User > User > Read, Routing > Skill > Read, Routing > Queue > Read
  • NICE CXone Permissions: Analytics > Reports > View, Interactions > View, Users > View, Routing > Skills > View
  • OAuth Scopes: analytics:report:read, interaction:read, user:read, routing:read, wem:campaign:create
  • External Dependencies: Graph database (Neo4j 5.x or Amazon Neptune), data processing engine (Python 3.10+ with networkx, pandas, requests), scheduling orchestrator (Apache Airflow or system cron)
  • Rate Limit Considerations: Genesys Cloud enforces 100 requests per second for the Interaction API and 30 requests per minute for the Report API. NICE CXone enforces 60 requests per minute for data exports. Your extraction pipeline must implement exponential backoff and cursor-based pagination.
1. Extracting and Normalizing Transfer and Consultation Events
Platform interaction logs do not expose collaboration patterns in a graph-ready format. You must extract event-level transfer data, filter for collaboration-relevant interactions, and normalize the payload into a unified schema. Genesys Cloud exposes this via the Interaction API v2, while NICE CXone requires report-based extraction with event-level drill-down. We prioritize the Interaction API because report aggregation masks consult-to-blind transfer transitions.
Execute a paginated GET request to retrieve voice interactions containing transfer events. Filter by mediaType=voice and event.type=transfer to reduce payload size.
GET /api/v2/interactions?mediaType=voice&event.type=transfer&pageSize=100&cursor=eyJpZCI6IjEyMyJ9
Authorization: Bearer <ACCESS_TOKEN>
The response contains an array of interaction objects. Each object includes a participants array and an events array. You must iterate through events to locate transfer objects. Extract the following fields:
  • interactionId
  • fromAgentId (source participant UUID)
  • toAgentId (destination participant UUID)
  • transferType (consult, warm, blind)
  • timestamp
  • queueId
  • skillIds (array of matched routing skills)
The Trap: Treating all transfer types as identical collaboration signals. A blind transfer is a unilateral handoff. A warm transfer is a supervised handoff. A consultation is a bidirectional knowledge exchange where both agents remain on the bridge. Aggregating these into a single edge type inflates network density, masks true peer-to-peer learning patterns, and creates false expertise hubs.
Architectural Reasoning: We normalize events into a directional schema before graph ingestion. Consultation events become bidirectional weighted edges because knowledge flows both ways during the bridge. Warm and blind transfers become unidirectional edges representing request-to-resolver handoffs. We store the normalized schema in a staging table before graph construction to allow replayability and audit trails.
  "interaction_id": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
  "timestamp": "2024-06-15T14:32:10Z",
  "from_agent_id": "usr-001-abc",
  "to_agent_id": "usr-002-def",
  "transfer_type": "consult",
  "queue_id": "q-voice-support",
  "skill_ids": ["skill-escalation", "skill-billing"]
We apply a 15-minute deduplication window per interaction_id to prevent duplicate event ingestion caused by platform retry mechanisms. We also tag events with a collaboration_weight multiplier: consultations receive 1.0, warm transfers receive 0.7, and blind transfers receive 0.3. This weighting reflects the actual knowledge transfer intensity.
2. Constructing the Directed Collaboration Graph
Raw event streams do not reveal structural patterns. You must map agents to nodes and transfers to edges within a graph database or in-memory network structure. We use Neo4j for persistence and NetworkX for metric computation. The graph must be directed because collaboration is asymmetrical: Agent A frequently consulting Agent B does not imply Agent B consults Agent A with equal frequency.
Ingest the normalized events into Neo4j using the apoc.load.json procedure or a direct Python driver. Define node properties for agent metadata and edge properties for collaboration metrics.
import neo4j
import pandas as pd
driver = neo4j.GraphDatabase.driver("bolt://graph-endpoint:7687", auth=("neo4j", "password"))
def create_collaboration_graph(df):
    with driver.session() as session:
        session.execute_write(create_nodes, df)
        session.execute_write(create_edges, df)
def create_nodes(tx, df):
    tx.run("""
        UNWIND $agents AS agent
        MERGE (n:Agent {id: agent.id})
        SET n.tenure_months = agent.tenure_months,
            n.queue_id = agent.queue_id,
            n.skill_count = agent.skill_count
    """, {"agents": df[['agent_id', 'tenure_months', 'queue_id', 'skill_count']].to_dict('records')})
def create_edges(tx, df):
    tx.run("""
        UNWIND $events AS e
        MATCH (src:Agent {id: e.from_agent_id})
        MATCH (dst:Agent {id: e.to_agent_id})
        MERGE (src)-[r:COLLABORATES_WITH]->(dst)
        SET r.transfer_type = e.transfer_type,
            r.weight = e.collaboration_weight,
            r.timestamp = e.timestamp,
            r.queue_context = e.queue_id
    """, {"events": df.to_dict('records')})
The Trap: Using raw transfer counts as edge weights without normalization. High-volume agents naturally create dense hubs that skew centrality metrics and drown out meaningful collaboration signals. Unweighted or linearly weighted graphs misrepresent expertise distribution and produce routing recommendations that overload top performers.
Architectural Reasoning: We apply a logarithmic transformation to edge weights during graph construction: normalized_weight = log(1 + raw_count) * collaboration_weight. This compresses the dynamic range of high-frequency transfers while preserving the relative ordering of collaboration intensity. We also partition the graph by calendar week. Collaboration patterns shift with product launches, seasonal volume, and staff turnover. Weekly partitions enable temporal drift analysis and prevent stale routing recommendations.
3. Computing Network Metrics and Identifying Collaboration Patterns
A graph without computed metrics is merely a visualization. You must calculate structural indicators to identify bridge agents, expertise clusters, and collaboration silos. We compute four core metrics: betweenness centrality, eigenvector centrality, clustering coefficient, and edge reciprocity.
Betweenness centrality identifies agents who frequently appear on shortest paths between other agents. These individuals act as knowledge bridges. Eigenvector centrality identifies agents who collaborate with other highly connected agents, indicating deep expertise networks. Clustering coefficient measures how tightly agents collaborate within local groups. Edge reciprocity calculates the ratio of bidirectional collaborations to unidirectional handoffs.
import networkx as nx
import pandas as pd
# Load graph data from Neo4j export or direct query
G = nx.DiGraph()
for _, row in df.iterrows():
    G.add_edge(row['from_agent_id'], row['to_agent_id'], weight=row['normalized_weight'])
# Compute metrics
betweenness = nx.betweenness_centrality(G, weight='weight')
eigenvector = nx.eigenvector_centrality(G, weight='weight', max_iter=1000)
clustering = nx.clustering(G.to_undirected())
reciprocity = nx.algorithms.reciprocity(G)
metrics_df = pd.DataFrame({
    'agent_id': list(G.nodes()),
    'betweenness_centrality': list(betweenness.values()),
    'eigenvector_centrality': list(eigenvector.values()),
    'local_clustering': list(clustering.values())
The Trap: Interpreting high betweenness centrality as positive leadership potential. High betweenness frequently indicates a routing bottleneck or a single point of failure. When one agent absorbs all escalation traffic, the network becomes fragile. That agent becomes a collaboration choke point rather than a knowledge multiplier.
Architectural Reasoning: We treat high betweenness as a risk signal, not a promotion signal. We cross-reference betweenness scores with wrap-up time averages and WEM quality scores. An agent with high betweenness, low quality, and high wrap-up time indicates a toxic escalation pattern that requires routing adjustment and coaching. We also compute reciprocity thresholds. Networks with reciprocity below 0.3 indicate a command-and-control handoff culture rather than peer collaboration. We flag these segments for structured peer-to-peer coaching programs.
4. Operationalizing Graph Insights in Routing and Quality Workflows
Graph analysis produces no value if it remains isolated in a data warehouse. You must integrate findings into routing configurations, skill matrix design, and quality campaigns. We operationalize insights through three channels: routing capacity caps, WEM coaching triggers, and skill alignment recommendations.
Update routing configurations to prevent collaboration hub overload. We use the Genesys Cloud Routing API to adjust queue capacity and skill match thresholds for high-centrality agents.
PUT /api/v2/routing/queues/{queueId}
  "name": "Voice Support Escalations",
  "outboundEmailDomainId": null,
  "description": "High-priority escalation queue",
  "skillsRequired": [{"id": "skill-escalation", "level": 5}],
  "overflowBehavior": "QUEUE",
  "overflowThreshold": 5,
  "capacity": 10,
  "wrapUpCodeRequired": true,
  "routingType": "LONGEST_AVAILABLE_AGENT",
  "status": "ACTIVE",
  "queueSkillRequirements": [
      "skillId": "skill-escalation",
      "level": 5
Trigger WEM coaching campaigns for agents flagged by low reciprocity or high betweenness with declining quality scores. We use the WEM Campaign API to assign targeted coaching content.
POST /api/v2/wem/campaigns
  "name": "Peer Collaboration Coaching - Q3",
  "description": "Targeted coaching for high-bridge agents with declining quality",
  "schedule": {
    "startDate": "2024-07-01T00:00:00Z",
    "endDate": "2024-07-31T23:59:59Z"
  "users": ["usr-001-abc", "usr-004-ghi"],
  "items": [
      "type": "form",
      "id": "form-collab-coaching-01",
      "status": "assigned"
The Trap: Automatically routing interactions to high-centrality agents based on graph scores. This creates a positive feedback loop that burns out subject matter experts, increases average handle time, and degrades network resilience. Routing engines require real-time state evaluation. Static graph scores do not account for wrap-up status, concurrent interaction limits, or shift schedules.
Architectural Reasoning: We treat the collaboration graph as a diagnostic layer, not a routing rule. Routing decisions must integrate real-time agent state, skill match confidence, and capacity thresholds. The graph informs skill matrix design, peer coaching pairings, and escalation path optimization. We implement a cooldown mechanism in our orchestration layer: agents exceeding a collaboration threshold receive a 24-hour routing deprioritization to distribute load across secondary expertise nodes. This preserves network health while maintaining resolution quality.
Edge Case 1: Consultation Loops and Circular Transfer Artifacts
The failure condition: Agents bounce interactions back and forth during complex troubleshooting scenarios. The graph registers these as high-weight edges, creating false collaboration signals and inflating centrality scores for agents involved in unresolved loops.
The root cause: Missing escalation path definitions or skill mismatches in the routing configuration. When an agent lacks the required skill level or authority to resolve an interaction, they transfer to a peer who lacks the same capability. The platform logs each transfer as a valid collaboration event.
The solution: Detect cycles using depth-first search during graph construction. Prune edges where transfer.from == transfer.to within a 15-minute window on the same interaction_id. Flag loop-heavy interactions for routing review. Update skill requirements to enforce hierarchical escalation paths rather than lateral peer bouncing. Reference the WEM quality score for looped interactions to identify training gaps.
Edge Case 2: Cross-Queue Consultation Attribution and Boundary Bleed
The failure condition: Consultations between agents in different business units or queue hierarchies skew network boundaries. The graph merges distinct operational silos into a single topology, masking intra-queue collaboration patterns and producing misleading enterprise-wide metrics.
The root cause: The platform treats all voice interactions identically regardless of queue context. Cross-queue consultations are valid but require separate analytical treatment. Aggregating them without boundary awareness dilutes cluster detection and misrepresents expertise distribution.
The solution: Apply queue-level filtering during extraction. Maintain separate subgraphs per business unit or queue family. Merge subgraphs only for enterprise-wide analysis using a weighted bridge calculation that penalizes cross-boundary edges unless explicitly tagged as authorized escalation paths. Use queue_id as a node property to track intentional cross-boundary collaboration. Validate boundary bleed by comparing clustering coefficients before and after subgraph partitioning. A significant coefficient increase confirms silo isolation and validates the partitioning strategy.
