Designing Omnichannel Thread Stitching for Cross-Channel Interactions
This guide details the architectural configuration of Interaction Stitching policies, Unified Interaction API payloads, and Architect flow logic required to correlate discrete channel events into a single logical thread. When completed, agents will view a unified conversation history across voice, chat, email, and SMS within the Agent Desktop, WEM will concatenate recordings based on interaction relationships, and analytics will attribute metrics to the full customer journey rather than isolated touchpoints.
- Licensing: Genesys Cloud CX 3 (Omnichannel license) is mandatory for cross-channel stitching. CX 2 supports stitching within the same channel family but lacks full omnichannel correlation. WEM Add-on is required for recording stitching.
- Roles & Permissions:
Telephony > Interaction > Editto modify stitching policies.Architect > Editto implement flow-level stitching logic.Messaging > Threaded Messaging > Editto configure UI thread grouping.WEM > Recording > Editto enable stitched recording playback.
- API Access: OAuth client with
interaction:writeandinteraction:readscopes. Access to the Unified Interaction API (/api/v2/interactions). - External Dependencies: A CRM or middleware system capable of generating and persisting a stable
externalIdfor the customer entity. Identity resolution logic must exist upstream of the Genesys Cloud interaction creation event.
1. Configuring the Interaction Stitching Policy
Interaction Stitching operates on a policy-driven model that defines how the platform correlates interactions based on identity attributes, time windows, and channel constraints. The default policy is insufficient for enterprise deployments because it relies heavily on phone number matching, which introduces high noise and false-positive rates in shared line or mobile-first environments.
Navigate to Admin > Telephony > Interaction > Stitching Policies. Create a new policy and define the following parameters:
- Stitching Key: Set this to
externalId. Relying onphoneNumberoremailAddressas the primary key creates fragility. Phone numbers are recycled, shared among family plans, or changed by customers. AnexternalIdderived from your CRM (e.g.,CUST-992834) provides a deterministic link that survives channel changes. - Stitching Window: Configure a window of
7 days. The default is often 24 hours. A 24-hour window fails for B2B support or complex retail returns that span multiple days. However, do not exceed 7 days unless required by specific compliance workflows, as larger windows increase the computational load on the stitching engine and cause “stitch storms” when high-volume customers interact. - Channel Constraints: Enable
Cross-Channel Stitching. If this is disabled, the system will stitch a chat to a subsequent chat but will orphan a voice call that follows the chat. Enable all channels relevant to your omnichannel strategy. - Max Thread Depth: Set to
5. Unbounded thread depth allows for infinite recursion in misconfigured flows, which can degrade API performance and corrupt analytics aggregations.
The Trap: The Phone Number Collision
The most common misconfiguration is using phoneNumber as the sole stitching key without a normalization layer. In a healthcare or finance deployment, multiple patients or account holders may share a single phone number. If the policy stitches on phone number, all interactions for all individuals at that address merge into one thread. The agent sees medical records or account details for the wrong person, resulting in a critical data privacy breach. Always use a composite key or a CRM-generated externalId that represents the specific user, not just the contact endpoint.
2. Architect Flow Design for Parent-Child Relationships
Stitching is not automatic for all interactions. The platform requires explicit signaling in the interaction payload to establish parent-child relationships, particularly when initiating a new channel from an existing interaction. For example, when a voice agent transfers a customer to a chat session, the Architect flow must create the new chat interaction and attach it to the voice interaction ID.
In Architect, use the Create Interaction block to initiate the secondary channel. Configure the block as follows:
- Interaction Type: Select the target channel (e.g.,
WEB_CHAT). - Parent Interaction ID: Set this field to
{{interaction.id}}. This expression references the current running interaction. This action creates a hard link in the data model, ensuring the chat becomes a child of the voice call. - External ID: Pass the customer identifier using
{{interaction.data.externalId}}. This ensures the child interaction inherits the stitching key. - Transfer Mode: Set to
TRANSFER. This updates the state of the parent interaction to indicate a transfer occurred, which is critical for WEM recording segmentation.
For inbound interactions, use the Get Interaction Data block early in the flow to check for existing threads. Query the interaction history using the externalId. If a recent interaction exists within the stitching window, update the current interaction data to include the parentInteractionId. This allows the flow to retrieve context from the previous channel.
The Trap: The Recursive Stitch Loop
Developers often create flows that query for a parent interaction and, if found, update the current interaction to point to that parent. If the logic does not check whether the current interaction is already a child of that parent, the flow can trigger an update event that re-queries, finds the same parent, and updates again. This creates an infinite loop of interaction updates. The API logs will show rapid-fire PATCH requests, and the thread metadata becomes corrupted. Always implement a guard clause: IF interaction.parentInteractionId != null, DO NOT update parentInteractionId.
3. Unified Interaction API Payloads for External Systems
Many organizations use middleware or CRM plugins to create interactions outside of native Architect flows. The Unified Interaction API allows external systems to inject interactions into the stitching graph. The payload structure must explicitly include the threading object and externalId to participate in omnichannel stitching.
When creating an interaction via API, use the following JSON structure:
POST /api/v2/interactions
"type": "EMAIL",
"externalId": "CUST-992834-ORDER-10293",
"threading": {
"parentInteractionId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
"threadId": "THREAD-992834-20231027"
"participants": [
"id": "agent-user-id",
"role": "AGENT",
"state": "ACTIVE"
"id": "customer-id",
"role": "CUSTOMER",
"state": "ACTIVE"
"metadata": {
"channel": "EMAIL",
"subject": "Order Issue - Stitching Test"
Key fields:
externalId: Must match the format defined in your Stitching Policy. If the policy expectsexternalId, this field is mandatory.threading.parentInteractionId: Explicitly links this interaction to an existing interaction. This is required when the API call originates from a system that does not automatically inherit context from a Genesys Cloud flow.threading.threadId: An optional logical thread identifier. Use this if your CRM maintains a separate conversation thread ID that differs from the Genesys Cloud interaction hierarchy. This allows the UI to group interactions by the CRM thread even if the interaction graph is complex.
The Trap: The Orphan Interaction
If an external system creates an interaction without an externalId or parentInteractionId, the interaction becomes an orphan. It will not stitch to any existing thread. Over time, orphans accumulate in the analytics database, skewing volume reports and breaking first-contact resolution metrics. The agent sees a new conversation with no history, forcing them to ask the customer to repeat information. Enforce validation in the middleware layer to reject interaction creation requests that lack a valid externalId.
4. WEM Recording and Analytics Stitching
Stitching extends beyond the Agent Desktop. WEM uses interaction relationships to concatenate recordings. When a voice call stitches to a chat session, WEM can present a single playback view that shows the voice recording followed by the chat transcript.
In Admin > WEM > Recording, enable Stitched Recording Playback. Configure the stitching rules to match your Interaction Stitching Policy. WEM relies on the parentInteractionId relationship to order the recordings. Ensure that the transfer state is set correctly in Architect flows. If the parent interaction is not marked as transferred, WEM may treat the child interaction as a completely separate event, breaking the playback sequence.
For analytics, the Interaction Analytics dashboard uses stitching to calculate metrics like “Total Handle Time per Thread.” If stitching is misconfigured, the dashboard will report multiple interactions instead of one, inflating volume and deflating average handle time. Validate analytics by running a report on interaction.thread.parentInteractionId. A high percentage of null values indicates a stitching failure.
The Trap: WEM Stitching Lag
WEM stitching is an asynchronous process. When a child interaction ends, the WEM engine must detect the parent relationship, retrieve both recordings, and generate the stitched asset. This process can take several minutes. If agents rely on real-time access to stitched recordings for quality assurance during the interaction, they will find the stitched view unavailable. Architectural mitigation: Do not depend on stitched recordings for real-time decision-making. Use the stitched view for post-interaction review and QA. For real-time context, rely on the Agent Desktop conversation history, which updates synchronously.
Edge Case 1: The Zombie Thread
The Failure Condition: An agent ends a voice interaction, but the customer immediately initiates a chat. The chat stitches to the voice call. However, the voice interaction is marked as COMPLETED in the CRM, while the chat thread remains open in the Genesys Cloud UI. The agent sees a closed interaction linked to an open thread, causing confusion about the disposition.
The Root Cause: The CRM disposition logic runs on the parent interaction completion event. The child interaction is still active, so the thread is not truly closed. The stitching policy links them, but the state management is decoupled.
The Solution: Implement a “Thread Closure” check in the Architect flow. When the parent interaction ends, check if any child interactions are active. If active children exist, do not mark the parent as COMPLETED in the CRM. Instead, mark the parent as TRANSFERRED or HOLD. Only update the CRM to COMPLETED when the deepest child interaction ends. This requires a webhook or callback mechanism from Genesys Cloud to the CRM upon child interaction completion.
Edge Case 2: External ID Collision in B2B Hierarchies
The Failure Condition: Two distinct customers, “Acme Corp” and “Acme Logistics,” share a parent account ID in the CRM. Interactions for both companies stitch together because they share the same externalId at the parent level. Agents see interactions for a subsidiary company mixed with the parent company, violating data segregation.
The Root Cause: The externalId used for stitching is too coarse-grained. It represents the account hierarchy rather than the specific interaction entity.
The Solution: Use a composite externalId that includes the specific entity level. For example, format the ID as ACCT-100-CUST-200. This ensures that interactions stitch only to other interactions for the exact same customer entity within the hierarchy. Update the Stitching Policy to recognize the composite structure if necessary, or ensure the normalization layer generates unique IDs per entity.
Edge Case 3: Stitching Window Boundary Race Condition
The Failure Condition: A customer interacts at 11:59 PM. The next day at 12:05 AM, the customer interacts again. The stitching window is set to 24 hours. The second interaction does not stitch to the first because the time difference exceeds 24 hours by 5 minutes. The thread breaks, and analytics report two separate contacts.
The Root Cause: The stitching window is a hard cutoff based on timestamp comparison. Timezone drift or slight delays in interaction creation can push interactions just outside the window.
The Solution: Increase the stitching window to 7 days to absorb boundary conditions, or implement a “Grace Period” logic in the Architect flow. If the flow detects a recent interaction within 5 minutes of the window expiry, explicitly set the parentInteractionId to force the stitch, overriding the policy window. This requires careful governance to avoid stitching unrelated interactions.
