Designing Multi-Team Tournament Brackets for Cross-Site Agent Competition Programs
This guide details the architecture and implementation of a multi-team tournament bracket system that aggregates cross-site agent performance metrics, manages seeding and elimination rounds, and integrates directly with CCaaS routing and WEM engines. When complete, you will have a fully operational competition framework that automatically updates team standings, triggers routing adjustments for competition periods, and exposes real-time bracket state via REST APIs.
  • Licensing Tier: Genesys Cloud CX 3 minimum, WEM (Workforce Engagement Management) add-on, Performance Analytics API access. NICE CXone requires CXone Performance Management license, WFM & WEM modules, and Advanced Analytics tier.
  • Granular Permissions: Telephony > Routing > Edit, Analytics > Performance > View, Admin > Users > Edit, WEM > Campaigns > Create, Admin > Custom Objects > Manage
  • OAuth Scopes: analytics:read, routing:edit, user:read, wem:manage, customobject:read_write
  • External Dependencies: Lightweight orchestration service (Node.js or Python) for bracket state reconciliation, or Genesys Cloud Custom Objects for native state storage. Carrier SLA visibility for cross-site latency compensation. CRM middleware for incentive delivery if external reward systems are used.
1. Metric Aggregation and Cross-Site Normalization
Cross-site competition requires a statistically fair scoring baseline. Raw metric aggregation introduces site bias because call volume, skill mix, carrier quality, and language distribution vary significantly across locations. You must normalize performance data before team seeding.
Configure a dedicated Custom Object to store normalized team scores. Create the object via Admin > Custom Objects with the following schema:
  • team_id (String, Primary Key)
  • site_id (String)
  • raw_aht (Decimal)
  • raw_csat (Decimal)
  • raw_fcr (Decimal)
  • normalized_score (Decimal)
  • weighting_factor (Decimal)
  • last_calculated (DateTime)
Use the Performance Analytics API to pull agent-level metrics. The aggregation flow must execute outside of peak routing windows to prevent tenant degradation.
API Request Example
GET /api/v2/analytics/perfmetrics/agents?dateFrom=2024-01-01T00:00:00.000Z&dateTo=2024-01-07T23:59:59.999Z&groupBy=agent&metrics=acd:handleTime,acd:firstCallResolution,csat:csatScore
Authorization: Bearer <ACCESS_TOKEN>
Calculate the normalized score using a weighted Z-score transformation. Apply a site-specific weighting factor to compensate for known carrier latency or language complexity. Store the result in the Custom Object via the following payload:
  "team_id": "TEAM_ALPHA_SITE_02",
  "site_id": "SITE_02",
  "raw_aht": 245.8,
  "raw_csat": 88.4,
  "raw_fcr": 72.1,
  "normalized_score": 91.3,
  "weighting_factor": 1.05,
  "last_calculated": "2024-01-07T23:59:59.999Z"
The Trap: Aggregating raw averages without normalization causes site bias. High-volume transactional sites will consistently outperform complex resolution sites on AHT and FCR, regardless of agent effort. The downstream effect is unfair seeding, rapid agent disengagement, and intentional metric gaming (e.g., premature call termination to inflate FCR).
Architectural Reasoning: We implement Z-score normalization because tournament fairness requires variance reduction across heterogeneous environments. Raw averages violate statistical equivalence. The weighting factor compensates for known infrastructure disparities, ensuring the bracket reflects agent performance rather than site topology.
2. Bracket State Management via Custom Objects and Architect
Tournament brackets require deterministic state transitions. You cannot rely on flat files or external spreadsheets because routing and WEM triggers must synchronize with bracket resolution in real time. Genesys Cloud Custom Objects provide ACID-compliant storage within the tenant, allowing Architect flows to read and write bracket state synchronously.
Create a second Custom Object named TournamentMatch with the following fields:
  • match_id (String, Primary Key)
  • round (Integer)
  • team_a_id (String)
  • team_b_id (String)
  • team_a_score (Decimal)
  • team_b_score (Decimal)
  • winner_id (String)
  • status (String: PENDING, SCORING, RESOLVED, ADVANCED)
  • next_match_id (String)
Build an Architect flow that triggers on On Call Ended. The flow must:
  1. Retrieve the agent’s team assignment via Get User and Get Custom Object
  2. Fetch the current match state for that team
  3. Update the team score using a weighted metric calculation
  4. Evaluate if the scoring window has closed
  5. Transition status to RESOLVED and populate winner_id
  6. Trigger the next round seeding logic
The Trap: Storing bracket state in external databases without platform-native synchronization causes latency and routing desync. Agents will be routed to competition queues before bracket state is resolved, creating metric contamination and incentive misalignment.
Architectural Reasoning: Custom Objects eliminate network latency between the routing engine and bracket state. Architect flows execute within the same tenant boundary, guaranteeing that score updates, status transitions, and routing assignments occur in a single logical transaction. This prevents race conditions during high-concurrency scoring windows.
3. Real-Time Scoring and Leaderboard Synchronization
Continuous API polling degrades tenant performance and triggers rate limiting. You must implement event-driven scoring with a lightweight aggregation buffer. The buffer accumulates call-level metrics and flushes to the Custom Object at deterministic intervals.
Configure a scheduled Architect flow that runs every 15 minutes during competition windows. The flow queries the Performance Analytics API for incremental metrics, applies the normalization formula, and updates the TournamentMatch object. Use the following API endpoint to retrieve incremental data:
GET /api/v2/analytics/perfmetrics/queues?dateFrom={INCREMENTAL_START}&dateTo={CURRENT_TIMESTAMP}&groupBy=queue&metrics=acd:handleTime,acd:firstCallResolution,csat:csatScore
Update the match record using a PATCH request:
PATCH /api/v2/customobjects/customobjecttypes/5f8a9b2c-1d3e-4a2b-9c8d-7e6f5a4b3c2d/instances/5f8a9b2c-1d3e-4a2b-9c8d-7e6f5a4b3c2d
  "team_a_score": 87.4,
  "team_b_score": 92.1,
  "status": "SCORING",
  "last_calculated": "2024-01-08T14:45:00.000Z"
Expose the leaderboard state via a dedicated endpoint that returns sorted match records. Cache the response at the load balancer level to prevent repetitive Custom Object queries.
The Trap: Polling the Performance Analytics API at high frequency causes rate limiting and tenant degradation. The downstream effect is scoring delays, bracket stalls, and agents receiving outdated leaderboard data, which breaks competition integrity.
Architectural Reasoning: We implement event-driven scoring with a 15-minute aggregation buffer because tournament metrics require stability, not volatility. Real-time call-by-call updates introduce noise from anomalous interactions. The buffer smooths variance, reduces API call volume, and aligns scoring with natural shift boundaries.
4. Routing Integration and Competition Period Enforcement
Competition periods require dedicated routing paths that isolate tournament traffic from standard operations. You must create competition-specific queues with strict skill assignments and capacity limits.
Create a routing queue named COMP_TOURNAMENT_Q with the following configuration:
  • Strategy: Longest Available Agent
  • Wrap-up Time: 0 seconds (competition traffic requires immediate requeue)
  • Max Concurrent Calls: 1 per agent
  • Queue Skills: COMP_SKILL_ALPHA, COMP_SKILL_BRAVO
Assign agents to competition queues dynamically using Architect. Do not hardcode queue assignments in user profiles. Hardcoding bypasses bracket logic and prevents dynamic realignment.
Build an Architect flow that executes on On User Status Change. The flow checks the TournamentMatch object for the user’s team. If status equals ADVANCED or SCORING, the flow executes Add to Queue with the competition queue ID. If status equals ELIMINATED, the flow executes Remove from Queue and reassigns the agent to standard routing.
The Trap: Hardcoding queue assignments in user profiles bypasses the bracket logic and prevents dynamic realignment. Eliminated agents continue receiving competition traffic, which skews metrics, violates incentive compliance, and degrades customer experience.
Architectural Reasoning: Dynamic queue assignment via Architect ensures routing state mirrors bracket state in real time. The routing engine evaluates queue membership at call arrival, guaranteeing that only active tournament participants receive competition traffic. This isolation preserves metric integrity and prevents cross-contamination between standard and tournament workloads.
5. WEM Campaign Orchestration and Incentive Delivery
Incentive delivery must trigger exclusively on final bracket resolution. Decoupling WEM campaigns from bracket state causes premature reward distribution and budget overruns.
Create a WEM campaign named TOURNAMENT_RECOGNITION with the following configuration:
  • Trigger Type: API Webhook
  • Target Audience: Dynamic User Group based on winner_id
  • Reward Type: Digital Badge + Monetary Credit
  • Delivery Channel: In-App Notification + Email
Configure a webhook endpoint that accepts bracket resolution events. The endpoint validates the status field against RESOLVED and ADVANCED. Only matched records trigger the WEM campaign.
POST /api/v2/wem/campaigns/5f8a9b2c-1d3e-4a2b-9c8d-7e6f5a4b3c2d/triggers
  "trigger_type": "webhook",
  "payload": {
    "winner_id": "TEAM_ALPHA_SITE_02",
    "round": 2,
    "match_id": "M_R2_A_V_B",
    "final_score": 94.7,
    "timestamp": "2024-01-15T18:00:00.000Z"
The WEM engine expands the winner_id into individual user records using the Custom Object mapping. Rewards distribute only after the webhook confirms bracket resolution.
The Trap: Decoupling WEM triggers from bracket resolution causes premature incentive delivery. The downstream effect is budget overruns, compliance flags, and agent frustration when rewards retract after bracket adjustments.
Architectural Reasoning: WEM campaigns must consume final bracket state via API webhook because tournament outcomes require deterministic validation. Internal thresholds trigger on partial data, violating financial controls. The webhook pattern guarantees incentive alignment with actual tournament outcomes and provides an audit trail for compliance reviews.
Edge Case 1: Cross-Timezone Metric Drift
The Failure Condition: Teams in different time zones finish scoring windows at different local times, causing asynchronous bracket resolution. Agents in later time zones receive competition traffic after their counterparts have already advanced or been eliminated.
The Root Cause: The aggregation buffer flushes based on absolute UTC timestamps rather than site-local shift boundaries. Metric accumulation continues unevenly across locations.
The Solution: Implement site-aware scoring windows using the site_id field in the Custom Object. Configure the Architect flow to evaluate scoring completion against each site’s defined shift end time. Pause queue assignment for sites with active scoring windows until normalization completes. Reference the Shift Synchronization pattern in the Workforce Management API guide for timezone alignment logic.
Edge Case 2: Bracket Deadlock on Tied Scores
The Failure Condition: Two teams finish a round with identical normalized scores. The Architect flow cannot populate winner_id, leaving the match in SCORING status indefinitely. Routing remains frozen, and WEM triggers never fire.
The Root Cause: The scoring formula lacks a deterministic tiebreaker. Floating-point comparisons without epsilon tolerance cause infinite loops in state evaluation.
The Solution: Implement a multi-tier tiebreaker hierarchy in the Architect flow. First, compare raw_fcr values. Second, compare raw_csat. Third, evaluate total handled volume. If all metrics remain identical, assign advancement to the team with the earlier team_id lexicographically. Add an epsilon tolerance of 0.05 to all decimal comparisons to prevent floating-point drift. Log tiebreaker resolution to a dedicated audit Custom Object for compliance review.
Edge Case 3: WEM Campaign Trigger Race Condition
The Failure Condition: The bracket resolution webhook fires simultaneously for multiple matches. The WEM engine processes overlapping trigger events, resulting in duplicate badge assignments and inflated reward budgets.
The Root Cause: Concurrent webhook deliveries exceed the WEM campaign’s idempotency buffer. The platform processes each event as a distinct trigger without deduplication.
The Solution: Implement idempotency keys in the webhook payload using the match_id field. Configure the WEM campaign to reject duplicate keys within a 300-second window. Add a retry mechanism with exponential backoff for failed deliveries. Monitor the WEM trigger queue depth via the GET /api/v2/wem/campaigns/{campaignId}/metrics endpoint. If queue depth exceeds 500 events, throttle Architect flow execution using a Wait block to prevent cascade failures.
