Designing Keyword and Phrase Spotting Engines for Compliance and Quality Monitoring
  • Architecting a real-time and post-call “Phrase Spotting” engine for automated quality assurance.
  • Implementing Fuzzy Matching and Phonetic Search to overcome ASR (Speech-to-Text) errors.
  • Designing compliance alerts for mandatory disclosures (e.g., “This call is recorded”) and prohibited language.
  • Licensing: Genesys Cloud CX 3 (for Speech and Text Analytics).
  • Permissions:
    • Quality > Program > Add/Edit
    • Speech > Topic > Add/Edit
  • Standards: Compliance frameworks like PCI-DSS, HIPAA, or FSR (Financial Services Regulation).
1. The Strategy: Automated 100% Quality Monitoring
Manual QM usually only covers 1-2% of calls. Phrase spotting allows you to audit 100% of interactions for specific compliance triggers, significantly reducing the organization’s risk profile.
The Strategy:
  1. The Dictionary: Create “Topics” (collections of related phrases).
  2. The Logic: Use Boolean logic (AND, OR, NOT) to define complex compliance rules.
  3. The Workflow:
    • Mandatory: “Call is recorded” AND “recorded for quality.”
    • Prohibited: “Password” OR “Credit Card Number” (when not in a secure IVR).
2. Implementing Phonetic and Fuzzy Phrase Spotting
ASR is not perfect. “Genesys” might be transcribed as “Genesis” or “Jennie’s.”
The Implementation:
  1. In the Topic Editor, use the Fuzzy Match setting (Distance 1 or 2).
  2. The Logic: Instead of just Genesys, use Genesys~ or Jennies~.
  3. The Trick: Use Phonetic Expansion. Include common misinterpretations in your topic definition: {"Genesys", "Genesis", "Jennies", "Gen-sis"}.
  4. The Benefit: This increases your “Compliance Hit Rate” by up to 40% by catching interactions where the word was said but poorly transcribed.
3. Designing Temporal Compliance Rules (Phase Spotting)
Compliance often depends on when a phrase was said. A disclosure is only valid if said within the first 30 seconds.
The Strategy:
  1. Use Relative Timing Filters in the Topic definition.
  2. The Logic:
    • Phrase: "This call is recorded"
  3. The Workflow: If the phrase is detected at 2 minutes, mark the compliance check as FAILED.
  4. Architectural Reasoning: This prevents agents from “Ticking the Box” at the end of a call when the regulatory requirement was for an upfront disclosure.
4. Implementing Real-Time Agent Assist via Phrase Spotting
Don’t just audit the failure after it happens; prevent it.
The Implementation:
  1. Use Genesys Cloud Agent Assist.
  2. The Workflow:
    • The engine spots the keyword “Cancel my account.”
    • The engine immediately triggers a “Retention Script” pop-up on the agent’s screen.
  3. The Benefit: This turns phrase spotting from a “Police Tool” into a “Coaching Tool,” improving FCR (First Call Resolution) and reducing churn in real-time.
Edge Case 1: “False Positives” from Background Noise
Failure Condition: The customer has a TV on in the background, and the ASR picks up a prohibited word from the TV, triggering a false QM alert for the agent.
Solution: Use Speaker Diarization. Only apply phrase spotting to the Agent Channel. If the prohibited word is on the “Customer Channel,” it should be ignored for agent compliance scoring.
Edge Case 2: Homophones and Contextual Confusion
Failure Condition: An agent says “I’ll be right back,” and the ASR hears “I’ll be write back,” missing a keyword for “Right.”
Solution: Use Proximity Operators. Instead of searching for a single word, search for a cluster: (Right /1 Back). This tells the engine to look for “Right” within 1 word of “Back,” providing the context needed to validate the match.
Edge Case 3: Over-Categorization (Topic Overlap)
Failure Condition: A call is tagged as “Billing,” “Shipping,” and “General,” making reporting messy.
Solution: Implement Mutually Exclusive Topics. Use negative constraints: Topic: Billing = "invoice" NOT "shipping". This ensures that interactions are categorized into the most specific bucket possible.
