Designing BYOC Trunk Failover Hierarchies with Geographic DNS-Based Traffic Steering
This guide details the architectural configuration of Bring Your Own Carrier (BYOC) SIP trunks in Genesys Cloud CX with deterministic failover hierarchies and geographic DNS routing. When complete, your deployment will automatically route inbound and outbound SIP signaling through carrier endpoints based on geographic proximity, execute transparent trunk failover during network degradation, and maintain media path optimization without manual intervention.
  • Licensing: CX 1 or higher, Cloud Telephony add-on (required for BYOC trunk provisioning), Genesys Cloud Edge or Cloud Connector for media optimization (recommended for cross-region failover).
  • Permissions: Telephony > Trunk > Edit, Telephony > Trunk > View, Telephony > Routing > Edit, Telephony > DNS > View. Admin role with ManageTelephony scope.
  • OAuth Scopes: telephony:trunk:write, telephony:trunk:read, routing:edit, routing:view.
  • External Dependencies: Carrier SIP trunk credentials, GeoDNS provider account (AWS Route 53, Cloudflare, or carrier-provided DNS), DNS SRV record configuration capability, SIP ALG disabled on intermediate network gear.
1. Architecting the DNS Layer for Geographic Steering
SIP signaling relies on DNS resolution to locate carrier endpoints. Genesys Cloud CX resolves DNS records for outbound trunk registration and inbound routing when configured with dynamic SIP URIs. Geographic DNS steering requires SRV records that return carrier endpoints based on the resolver location. The resolver is typically the Genesys Cloud CX region node or the carrier network edge, depending on traffic direction.
Configure your GeoDNS provider to publish SRV records following the _sip._tcp.<domain> convention. Each record must specify priority, weight, port, and target hostname. Priority dictates failover order. Weight dictates load distribution across endpoints sharing the same priority. The target hostname must resolve to a static IP or another DNS record that points to the carrier SIP proxy.
Set the Time To Live (TTL) value based on your failover requirements. A TTL of 60 seconds balances resolution freshness with DNS query volume. A TTL below 30 seconds generates excessive resolver traffic and can trigger rate limiting on carrier DNS servers. A TTL above 300 seconds delays failover during carrier outages. The mathematical relationship between TTL and failover latency is direct. If your carrier experiences a hard failure at T=0, the maximum time before Genesys Cloud CX queries DNS again is the TTL value plus the resolver cache expiration jitter.
The Trap: Configuring GeoDNS with dynamic load balancing that returns different endpoints for identical queries within the same TTL window. Genesys Cloud CX caches DNS resolutions for the duration of the TTL. If the carrier DNS rotates endpoints mid-TTL, the platform continues sending SIP INVITEs to a stale IP address until cache expiration. This causes call setup failures that appear as carrier-side rejections rather than routing errors.
Architectural Reasoning: We decouple geographic steering from platform configuration because DNS operates at the network edge. This design allows carrier network changes without touching the CCaaS provisioning layer. It also enables sub-second geographic affinity when combined with platform-level health checks. The DNS layer handles geographic distribution. The platform layer handles signaling health validation. Separation of concerns prevents routing logic from becoming a single point of failure.
2. Configuring BYOC Trunk Groups & Failover Hierarchies
Trunk groups in Genesys Cloud CX define the failover hierarchy. Each trunk group contains multiple trunks. The platform evaluates trunk health and promotes traffic according to the configured failover mode. You must map DNS-resolved endpoints to individual trunks within the group.
Create three trunks per geographic region. Assign one trunk to the primary carrier endpoint, one to the secondary endpoint, and one to a tertiary backup. Configure each trunk with the following parameters:
  • SIP URI: The DNS SRV record name (e.g., _sip._tcp.primary.carrier.example.com)
  • Authentication: Username and password provided by the carrier
  • TLS/SRTP: Enforced for signaling and media encryption
  • Media Ports: Dynamic range 10000-20000 with RTCP enabled
  • Outbound Routing Rules: Match by area code, prefix, or geographic zone
Use the Genesys Cloud CX REST API to provision trunks at scale. Manual UI configuration introduces human error and lacks version control. Execute the following request to create a trunk with DNS-based resolution:
POST /api/v2/telephony/providers/edge/trunks
Authorization: Bearer <oauth_token>
  "name": "US-East-Primary-Trunk",
  "description": "Primary US East BYOC trunk with DNS resolution",
  "type": "SIP",
  "sipUri": "_sip._tcp.us-east.carrier.example.com",
  "authentication": {
    "username": "genesys_cx_east",
    "password": "secure_carrier_credential"
  "tls": {
    "enabled": true,
    "certificateVerification": "strict"
  "srtp": {
    "enabled": true
  "mediaPorts": {
    "startPort": 10000,
    "endPort": 20000
  "outboundRoutingRules": [
      "name": "US-East-Domestic",
      "pattern": "^1[2-9]\\d{9}$",
      "enabled": true
  "healthCheck": {
    "enabled": true,
    "intervalSeconds": 10,
    "failureThreshold": 3,
    "successThreshold": 2
Assign the trunks to a trunk group. Configure the failover mode to Degraded. The Immediate mode promotes traffic on the first OPTIONS ping failure. This causes flapping during transient network congestion. The Outage mode waits for complete trunk unreachability. This delays failover unnecessarily during partial carrier degradation. The Degraded mode evaluates consecutive failures against the threshold you defined in the health check configuration.
The Trap: Mixing DNS-resolved trunks with static IP trunks in the same trunk group without accounting for resolution timing. Genesys Cloud CX resolves DNS at trunk initialization and caches the result. If a static IP trunk shares the same group, the platform evaluates health checks against both simultaneously. During a carrier DNS rotation, the platform may promote traffic to the static IP trunk while the DNS trunk remains in a resolving state. This creates asymmetric routing where inbound calls arrive via static IP while outbound calls route through DNS, breaking caller ID normalization and compliance logging.
Architectural Reasoning: We use DNS-resolved trunks exclusively within geographic trunk groups to maintain routing symmetry. The platform health check validates SIP stack responsiveness. The DNS layer validates network path viability. When both align, failover executes deterministically. The API-driven provisioning ensures infrastructure-as-code compliance and enables automated rollback when carrier credentials rotate. This pattern scales to thousands of trunks without configuration drift.
3. Integrating Routing Policies & Health Monitoring
Routing policies dictate how Genesys Cloud CX evaluates trunk availability before call placement. You must configure inbound and outbound routing rules that reference the trunk group hierarchy. The platform evaluates routing policies in order. The first matching policy with an available trunk executes the call.
Create a routing policy for each geographic region. Bind the policy to the corresponding trunk group. Configure the policy to evaluate trunk health metrics before promotion. Set the evaluation window to 30 seconds. This window allows the platform to confirm trunk stability after failover. Configure the policy to log trunk selection decisions for audit compliance.
Health monitoring relies on SIP OPTIONS pings. The platform sends OPTIONS requests to the trunk SIP URI at the configured interval. The carrier must respond with a 200 OK. If the carrier responds with 4xx or 5xx codes, the platform marks the trunk as degraded. If the carrier fails to respond, the platform marks the trunk as unavailable. The platform tracks consecutive failures against the threshold defined in the trunk configuration.
Configure DNS health validation separately from SIP health validation. DNS resolution failures do not automatically trigger trunk promotion. The platform treats DNS resolution errors as transient network conditions. You must configure a secondary DNS resolver in the Genesys Cloud CX region settings to prevent single-resolver failures from blocking all trunk resolution.
The Trap: Relying solely on DNS failover without platform-level health checks. DNS providers do not validate SIP stack health, TLS certificate validity, or media path viability. A carrier endpoint may resolve correctly via DNS while the SIP proxy experiences memory exhaustion or certificate expiration. If you disable platform health checks, Genesys Cloud CX continues routing calls to a functional DNS record that points to a broken SIP stack. This results in silent call failures that appear as carrier-side timeouts rather than routing errors.
Architectural Reasoning: We implement dual-layer validation because network health and application health are independent failure domains. DNS steering provides geographic affinity and load distribution. Platform health checks provide signaling validation and media path verification. The routing policy orchestrates both layers by evaluating trunk group availability before call placement. This design prevents cascading failures during carrier maintenance windows. It also enables compliance auditing by logging exactly which trunk handled each call and why. Cross-reference the Speech Analytics guide on call quality scoring when configuring media path validation, as packet loss thresholds directly impact trunk promotion decisions.
Edge Case 1: DNS Resolution Race Conditions During Failover
Failure Condition: Calls fail to route during the first 30 seconds after a primary trunk outage. The platform logs DNS resolution timeouts instead of SIP connection failures.
Root Cause: The Genesys Cloud CX DNS cache expires simultaneously across multiple region nodes. All nodes query the carrier DNS server concurrently. The carrier DNS server rate limits the queries. Resolution fails until the rate limit window expires.
Solution: Implement staggered TTL values across trunk groups. Set primary trunks to 60 seconds TTL. Set secondary trunks to 45 seconds TTL. Set tertiary trunks to 30 seconds TTL. This stagger prevents synchronized cache expiration. Configure a local DNS forwarder in the Genesys Cloud CX region to cache resolutions independently. Add a DNS health check endpoint that validates resolver responsiveness before trunk promotion.
Edge Case 2: SIP NAT Traversal with GeoDNS-Resolved Endpoints
Failure Condition: Inbound calls establish signaling successfully but media fails one-way. RTP packets arrive at the Genesys Cloud CX edge but never reach the agent desktop.
Root Cause: The carrier network performs NAT on the SIP INVITE SDP payload. The SDP contains the carrier private IP address. Genesys Cloud CX sends RTP to the private IP. The carrier network drops the packets because the NAT session does not exist for the media port range.
Solution: Enable SIP ALG bypass on all intermediate network gear. Configure the carrier to use symmetric RTP. Set the mediaTransportProtocol to udp with rtcpMultiplexing enabled. Add a contact header rewrite rule in the routing policy to force the carrier to use the public IP from the SDP answer. Validate NAT traversal by sending a test call and capturing RTP flow with a packet analyzer. Confirm the SDP answer contains the public IP address.
Edge Case 3: Media Path Asymmetry During Cross-Region Trunk Promotion
Failure Condition: Calls route successfully through a secondary trunk in a different geographic region. Agents experience 200-400ms latency and intermittent audio clipping.
Root Cause: The signaling path routes through the secondary region. The media path attempts to route through the primary region edge. Genesys Cloud CX optimizes media to the closest edge by default. When the trunk group promotes to a different region, the media path does not automatically reroute. The packets traverse multiple regional hops before reaching the agent.
Solution: Configure media path optimization to follow signaling path. Set the mediaRegion parameter in the routing policy to auto. Enable Genesys Cloud Edge in the secondary region to terminate media locally. Add a routing rule that forces media path evaluation after trunk promotion. Validate media latency by measuring RTP timestamp deltas between INVITE and ACK. Confirm the media path terminates at the same region as the signaling path.
