Designing a GDPR "Right to be Forgotten" Automation Workflow using the Conversations API
Designing a GDPR “Right to be Forgotten” Automation Workflow using the Conversations API
You will build an automated pipeline that ingests GDPR Right to be Forgotten requests, resolves customer identities to Genesys Cloud CX identifiers, enumerates all associated conversation artifacts, and executes conditional pseudonymization or hard deletion. The end result is a compliant, API-driven workflow that operates within statutory SLAs, respects enterprise retention holds, and produces cryptographically verifiable audit logs for regulatory inspection.
  • Licensing Tier: CX 2 minimum. CX 3 is required for advanced privacy controls, automated retention policy enforcement, and bulk data export capabilities.
  • Granular Permissions: Telephony > Conversation > Edit, Data > Privacy > Manage, Analytics > Conversation > View, Organization > External Client > Edit
  • OAuth 2.0 Scopes: conversations:read, conversations:write, data:export, privacy:manage, wfm:evaluation:view
  • External Dependencies: Secure request intake endpoint (AWS API Gateway, Azure Function, or equivalent), encrypted object storage for audit artifacts, IAM service account with least-privilege access, Genesys Cloud OAuth client credentials configured with PKCE or client secret rotation.
1. Architecting the Request Ingestion and Identity Resolution Layer
GDPR Article 17 requires verifiable identity confirmation before any erasure action. The workflow cannot accept raw emails or phone numbers as deletion triggers. You must design an intake endpoint that enforces cryptographic proof of identity, maps the requester to Genesys Cloud CX internal identifiers, and validates the request against your data governance policy.
The intake service receives a standardized JSON payload containing the requester identifier, verification token, and requested action. Your middleware must resolve this payload to one or more externalId values registered in Genesys Cloud CX. Genesys stores customer interactions primarily by externalId (the CRM or legacy system identifier) and userId (the agent or internal user). The resolution layer queries your master customer index, applies deduplication rules, and returns a consolidated list of Genesys identifiers.
The Trap: Mapping deletion requests directly to email addresses or phone numbers without cross-referencing the Genesys externalId. Customer contact details change. A deletion request tied to a legacy email address will either miss active conversations stored under a new identifier, or worse, delete data belonging to a different customer who reused the same contact method. This creates false negatives (non-compliance) and false positives (data destruction of unrelated parties).
Architectural Reasoning: We use an identity resolution service because Genesys Cloud CX is a conversation platform, not a master data management system. The Conversations API indexes by externalId. If your intake layer does not normalize the requester identity to the exact externalId format used during session creation, the subsequent API queries will return zero results. The resolution layer must also validate that the externalId belongs to a consumer subject under GDPR jurisdiction, not a B2B entity governed by different retention statutes.
POST /api/internal/rtbf/request
Authorization: Bearer <internal_service_jwt>
  "requestId": "rtbf-2024-8842-a1b2",
  "subjectIdentifier": "customer-uuid-7f9c2d",
  "verificationToken": "sha256:a1b2c3d4e5f6...",
  "requestedAction": "erase",
  "jurisdiction": "EU-GDPR",
  "submittedAt": "2024-05-12T08:30:00Z"
The resolution service returns a normalized payload containing the exact externalId values, associated conversationId seeds, and a confidence score. Only requests with a confidence score above your defined threshold proceed to the enumeration phase.
2. Querying the Conversations API for Data Boundaries
Once identity is resolved, the workflow must map the complete data footprint. A single customer interaction rarely exists as an isolated record. Genesys Cloud CX threads conversations across voice, digital, email, and social channels. The Conversations API returns a hierarchical structure where parent conversations reference child threads, and each thread contains media objects, transcripts, and participant metadata.
You begin with a scoped query using the resolved externalId and a date range matching your retention policy. The API supports pagination via pageToken. You must iterate until nextPageUri returns null. Each returned conversation object contains a media array and a transcripts array. These contain the actual storage pointers to recordings, chat logs, and attachments.
The Trap: Querying only the top-level conversationId and ignoring the includeMedia=true and includeTranscripts=true query parameters. This returns the conversation metadata but leaves all associated voice recordings, screen shares, and chat transcripts intact in Genesys-managed object storage. Regulators consider orphaned media files as a direct violation of erasure requirements because the PII remains accessible.
Architectural Reasoning: We enforce explicit media and transcript inclusion flags because Genesys decouples conversation metadata from binary storage for performance. The Conversations API does not delete media objects when you delete a conversation record by default. You must enumerate every mediaId and transcriptId, then issue separate deletion or masking requests against the Media API and Transcript API. The workflow must maintain a temporary manifest of all discovered artifacts before executing any modification. This manifest enables rollback capability if a downstream validation check fails.
GET /api/v2/conversations?externalId=customer-uuid-7f9c2d&from=2023-01-01T00:00:00Z&to=2024-12-31T23:59:59Z&includeMedia=true&includeTranscripts=true&pageToken=eyJwYWdlIjoxfQ
Authorization: Bearer <genesys_oauth_token>
Accept: application/json
The response payload contains nested arrays. Your pipeline extracts conversationId, media[].id, transcripts[].id, and participants[].externalId. You store these in a transactional queue. The next phase evaluates each artifact against retention holds and legal exceptions before determining the disposal method.
3. Executing Pseudonymization versus Hard Deletion Logic
GDPR permits pseudonymization when data must be retained for legal, tax, or quality assurance purposes. The workflow cannot blindly issue DELETE commands. You must evaluate each conversation against your organization’s retention policy, WFM quality monitoring tags, and litigation hold flags. The Conversations API supports conditional modification through PATCH operations. Hard deletion uses DELETE, but requires explicit override headers when holds are active.
The evaluation engine checks three conditions:
  1. Active WFM quality evaluation in progress
  2. Litigation or regulatory hold status
  3. Retention period expiration
If condition 1 or 2 is true, the workflow applies pseudonymization. This replaces all PII fields with cryptographic hashes while preserving conversation structure for scoring or legal review. If all conditions are false and the retention period has expired, the workflow executes hard deletion.
The Trap: Attempting hard deletion on conversations tagged with active WFM evaluations or quality monitoring assignments. Genesys Cloud CX returns a 409 Conflict response and blocks the operation. The pipeline fails silently if you do not implement conditional branching, leaving the RTBF request in a pending state indefinitely. Additionally, using PATCH for masking when retention has expired creates unnecessary data bloat and violates the principle of storage limitation.
Architectural Reasoning: We implement a state machine that evaluates holds before issuing API calls because compliance frameworks require tiered data handling. WFM modules lock conversation records for a configurable scoring window. The Conversations API respects these locks to prevent evaluation data corruption. The workflow queries the WFM evaluation status, pauses deletion until the scoring window closes, then applies the appropriate action. Pseudonymization uses field-level masking on participants[].name, participants[].email, and transcripts[].text. Hard deletion removes the record and cascades to media storage.
PATCH /api/v2/conversations/{conversationId}
  "isDeleted": false,
  "participants": [
      "externalId": "customer-uuid-7f9c2d",
      "name": "HASH:7f9c2d-masked",
      "email": "HASH:7f9c2d-masked@example.com",
      "role": "CUSTOMER"
  "retentionPolicy": {
    "override": true,
    "action": "pseudonymize"
For hard deletion, the pipeline issues a DELETE request with the X-Genesys-Force-Delete: true header when licensed for compliance overrides. The API returns 204 No Content on success. The workflow records the HTTP status, response headers, and timestamp for each artifact. Failed operations retry with exponential backoff up to three attempts before escalating to the compliance review queue.
4. Generating Immutable Audit Trails and Compliance Handoff
GDPR Article 30 requires documentation of processing activities, including erasure actions. The workflow must produce an append-only audit log that proves what data was located, what action was taken, and when the action completed. This log cannot reside in Genesys Cloud CX. It must be stored in an external, encrypted, tamper-evident repository.
The audit generator aggregates the transaction manifest, API response codes, OAuth token metadata, and cryptographic hashes of the original and masked payloads. It computes a SHA-256 hash of the complete audit record, signs it with an HMAC using a rotating key, and writes the entry to an immutable storage layer (AWS S3 Object Lock, Azure Immutable Storage, or equivalent). The workflow then pushes a compliance notification to your data protection officer dashboard.
The Trap: Storing audit logs in Genesys Cloud Analytics, custom objects, or architect flow variables. These storage mechanisms are designed for operational telemetry, not legal evidence. They lack cryptographic immutability, retain mutable access permissions, and subject the audit trail to the same retention policies as the data you are trying to erase. This creates a recursive compliance violation.
Architectural Reasoning: We externalize the audit trail because regulatory auditors require independent verification of deletion events. The audit log must survive platform migrations, tenant decommissioning, and internal permission changes. Cryptographic signing ensures that any tampering attempt breaks the hash chain, triggering immediate detection. The workflow separates the processing environment (Genesys Cloud CX) from the evidentiary environment (external immutable storage) to maintain clear data governance boundaries. You must also implement log rotation and access logging to satisfy GDPR accountability requirements.
  "auditId": "aud-rtbf-2024-8842-x9y8",
  "subjectExternalId": "customer-uuid-7f9c2d",
  "executionTimestamp": "2024-05-12T09:15:22Z",
  "artifactsProcessed": 14,
  "actions": [
      "conversationId": "conv-7742-a1",
      "action": "pseudonymize",
      "reason": "active_wfm_evaluation",
      "httpStatus": 200,
      "mediaIds": ["media-001", "media-002"],
      "transcriptIds": ["trans-001"]
      "conversationId": "conv-7742-a2",
      "action": "hard_delete",
      "reason": "retention_expired",
      "httpStatus": 204,
      "mediaIds": ["media-003"],
      "transcriptIds": []
  "hmacSignature": "a1b2c3d4e5f6...",
  "storageLocation": "s3://compliance-audit/rtbf/2024/05/aud-rtbf-2024-8842-x9y8.json"
The pipeline finalizes by updating the request status to COMPLETED, notifying the requester through the secure communication channel, and archiving the transaction manifest. The workflow then resets to idle state, ready for the next ingestion cycle.
Edge Case 1: Cross-Channel Conversation Threading Breaks Deletion Scope
The Failure Condition: The workflow deletes the primary chat conversation but leaves associated voice follow-ups and email threads intact. The regulator flags incomplete erasure.
The Root Cause: Genesys Cloud CX uses parentConversationId and threadId to link multi-channel interactions. The initial GET /api/v2/conversations query returns only the top-level conversation. Child threads are not included in the first page unless explicitly traversed.
The Solution: Implement recursive traversal logic. After retrieving the initial conversation list, query GET /api/v2/conversations?parentConversationId={id} for each result. Continue iterating until the response returns zero child records. Maintain a visited set to prevent infinite loops caused by circular reference misconfigurations. Add the child conversationId values to the artifact manifest before proceeding to the deletion phase.
Edge Case 2: OAuth Token Expiration During Batch Deletion Operations
The Failure Condition: The pipeline stalls after processing approximately 400 conversations. Subsequent API calls return 401 Unauthorized. The RTBF request remains partially completed.
The Root Cause: Genesys Cloud CX OAuth 2.0 client credentials tokens expire after 60 minutes. Large customer footprints require extensive pagination and media enumeration that exceed the token lifespan. The workflow does not implement automatic token refresh.
The Solution: Implement token lifecycle management with sliding expiration checks. Query the token expiry timestamp from the initial OAuth response. If the remaining validity falls below 10 minutes, trigger a silent refresh using the stored refresh token or re-authenticate via client credentials. Cache the new token securely, update all pending HTTP clients, and retry failed batches. Implement exponential backoff with jitter to avoid rate limiting during refresh windows. Reference the Genesys Cloud OAuth 2.0 Authentication Guide for token rotation best practices.
Edge Case 3: WFM Quality Monitoring Overrides Retention Policies
The Failure Condition: The workflow issues a DELETE request and receives a 409 Conflict response. The conversation remains intact. The compliance dashboard reports a failure.
The Root Cause: NICE CXone or Genesys Cloud WFM modules lock conversation records when an evaluator assigns a quality score or flags an interaction for coaching. The Conversations API enforces these locks to prevent data corruption during scoring periods. Hard deletion is blocked until the evaluation window closes.
The Solution: Query the WFM evaluation status before attempting deletion. Use GET /api/v2/wfm/evaluations?conversationId={id} to check for active assignments. If an evaluation exists, calculate the remaining scoring window. Queue the deletion for execution after the window expires. If immediate erasure is legally mandated, escalate to the data protection officer for a manual hold override. Document the override reason in the audit trail. Cross-reference the WFM evaluation lifecycle guide to align your pipeline with your organization’s quality monitoring configuration.
