Descriptions for AttributeCallState codes
Can anyone provide me the descriptions for AttributeCallState Codes ?
I was referring “Genesys 7 Events and Models Reference Manual”. The document says, the value of AttributeCallState would be like, “Consult”, “Conference”.
But in the log files, i don’t have the descriptions instead i have some codes in AttributeCallState field,
some of the values are 0, 1, and 23
Please provide me and direct me to the document/link to get the descriptions for AttributeCallState codes
Jagadish
You may find CallState values and meanings in SDK documents.
They could be found in 7.2 or earlier version tlib header file or tlib programming reference; tlib was put to EOL at 2008. SDK documents may contain equivalent info.
typedef enum _TCallState {
CallStateOk, /* <---- this is 0 / zero /
CallStateTransferred, /
<— 1 if not assigned to value explicityly /
CallStateConferenced, /
← and incremented by 1 … */
CallStateGeneralError,
CallStateSystemError,
CallStateRemoteRelease,
CallStateBusy,
CallStateNoAnswer,
CallStateSitDetected,
CallStateAnsweringMachineDetected,
CallStateAllTrunksBusy,
CallStateSitInvalidnum,
CallStateSitVacant,
CallStateSitIntercept,
CallStateSitUnknown,
CallStateSitNocircuit,
CallStateSitReorder,
CallStateFaxDetected,
CallStateQueueFull,
CallStateCleared,
CallStateOverflowed,
CallStateAbandoned,
CallStateRedirected,
CallStateForwarded,
CallStateConsult,
CallStatePickedup,
CallStateDropped,
CallStateDroppednoanswer,
CallStateUnknown,
CallStateCovered,
CallStateConverseOn,
CallStateBridged,
CallStateDeafened = 49,
CallStateHeld = 50
TCallState;
***NB: codes might be changed or enhanced after 7.2
http://nsa05.casimages.com/img/2009/02/23/090223104428260262.jpg
Trace_ID TimeSTAMP ThisDN OtherDN Events
045701a85cfbb319, 1237200917, 52050, 6414729073, EventQueued
045701a85cfbb319, 1237200917, 52050, , EventDiverted
045701a85cfbb319, 1237200917, 52960, 6414729073, EventRinging
045701a85cfbb319, 1237200918, 52960, 6414729073, EventEstablished
045701a85cfbb319, 1237200996, 52960, , EventAttachedDataChanged
045701a85cfbb319, 1237200996, RRG_VRP, , EventAttachedDataChanged
045701a85cfbb319, 1237200996, RRG_VRP, , EventRouteRequest
045701a85cfbb319, 1237200997, 52960, 6414729073, EventHeld
045701a85cfbb319, 1237200997, 17965, 52960, EventQueued
045701a85cfbb319, 1237200997, 51016, 52960, EventQueued
045701a85cfbb319, 1237200997, 56373, 52960, EventEstablished
045701a85cfbb319, 1237200997, 52960, 56373, EventEstablished
045701a85cfbb319, 1237200997, 52960, 6414729073, EventReleased
045701a85cfbb319, 1237200997, 52960, 56373, EventReleased
045701a85cfbb319, 1237200997, 56373, 6414729073, EventPartyChanged
045701a85cfbb319, 1237200997, RRG_VRP, , EventAttachedDataChanged
045701a85cfbb319, 1237200997, RRG_VRP, 17965, RequestRouteCall
045701a85cfbb319, 1237200997, RRG_VRP, , EventRouteUsed
045701a85cfbb319, 1237200997, 52960, , EventAttachedDataChanged
045701a85cfbb319, 1237200997, RRG_VRP, 52960, EventReleased
045701a85cfbb319, 1237200997, sw_ohbhw01::, , EventReleased
045701a85cfbb319, 1237200997, 52960, , EventOffHook
045701a85cfbb319, 1237200997, 52960, 17965, EventDialing
045701a85cfbb319, 1237200997, 17965, 52960, EventDiverted
045701a85cfbb319, 1237200997, 51016, 52960, EventDiverted
045701a85cfbb319, 1237200997, 56373, 52960, EventRinging
045701a85cfbb319, 1237201332, 56373, 6414729073, EventReleased
045701a85cfbb319, 1237201332, sw_ohbhw01::, , EventReleased
This is the event flow in the raw log.Can anyone explain about the call flow .
