Deprovisioning Genesys Cloud LLM Gateway Models via Java with Lifecycle Validation and Traffic Drain Logic
  • A Java utility that safely deprovisions deprecated LLM models from Genesys Cloud LLM Gateways using atomic DELETE operations and lifecycle constraint validation.
  • Uses the Genesys Cloud Java SDK and direct REST endpoints to construct retire payloads, verify dependency locks, and trigger automatic archive workflows.
  • Implemented in Java 17 using gencloudsdk-java, Jackson for schema validation, and structured audit logging for AI governance compliance.
  • OAuth 2.0 Client Credentials flow with scopes: ai:llm-gateway:write, ai:llm-gateway:read, analytics:conversations:read
  • gencloudsdk-java version 150.0.0 or higher
  • Java 17 runtime with Maven or Gradle
  • External dependencies: com.fasterxml.jackson.core:jackson-databind:2.15.2, com.fasterxml.jackson.module:jackson-module-jsonSchema:2.15.2, org.apache.httpcomponents.client5:httpclient5:5.2.1
  • Active Genesys Cloud environment with LLM Gateway enabled and at least one deployed model
Genesys Cloud requires OAuth 2.0 client credentials authentication. The Java SDK handles token acquisition and caching automatically when configured correctly. The following code initializes the ApiClient with credential injection and token refresh logic.
import com.mypurecloud.sdk.gencloudsdk.ApiClient;
import com.mypurecloud.sdk.gencloudsdk.auth.AuthMethod;
import com.mypurecloud.sdk.gencloudsdk.auth.ClientCredentialsAuth;
import com.mypurecloud.sdk.gencloudsdk.auth.OAuth2Client;
import java.time.Duration;
public class GenesysAuthenticator {
    private final String environment;
    private final String clientId;
    private final String clientSecret;
    public GenesysAuthenticator(String environment, String clientId, String clientSecret) {
        this.environment = environment;
        this.clientId = clientId;
    public ApiClient buildApiClient() {
        ApiClient client = new ApiClient();
        client.setBasePath("https://" + environment + ".mypurecloud.com");
        OAuth2Client oauthClient = new OAuth2Client(client);
        AuthMethod authMethod = new ClientCredentialsAuth(clientId, clientSecret, oauthClient);
        client.setAuthMethod(authMethod);
        client.setAccessToken(oauthClient.getAccessToken());
        return client;
The ApiClient caches the access token in memory and refreshes it automatically before expiration. You must ensure the OAuth application has the ai:llm-gateway:write and ai:llm-gateway:read scopes assigned in the Genesys Cloud admin console. Without these scopes, every subsequent API call returns HTTP 403 Forbidden.
Step 1: Initialize SDK and Validate Lifecycle Constraints
Before deprovisioning, you must verify that the target model does not violate lifecycle constraints or exceed maximum active model limits. Genesys Cloud enforces a limit on concurrently active models per gateway. The following code queries the gateway model inventory, validates the version matrix, and checks dependency locks.
import com.mypurecloud.sdk.gencloudsdk.api.LlmGatewayApi;
import com.mypurecloud.sdk.gencloudsdk.model.LlmGatewayModel;
import com.mypurecloud.sdk.gencloudsdk.model.LlmGatewayModelList;
import java.util.List;
import java.util.stream.Collectors;
public class LlmDeprovisionValidator {
    private final LlmGatewayApi llmGatewayApi;
    private final ObjectMapper mapper = new ObjectMapper();
    private static final int MAX_ACTIVE_MODELS = 10;
    public LlmDeprovisionValidator(LlmGatewayApi llmGatewayApi) {
        this.llmGatewayApi = llmGatewayApi;
    public boolean validateLifecycleConstraints(String gatewayId, String modelId) {
            LlmGatewayModelList models = llmGatewayApi.getLlmGatewayModels(gatewayId, null, null, null, null, null, null, null);
            List<LlmGatewayModel> activeModels = models.getEntities().stream()
                    .filter(m -> "ACTIVE".equals(m.getStatus()))
                    .collect(Collectors.toList());
            if (activeModels.size() >= MAX_ACTIVE_MODELS) {
                throw new IllegalStateException("Maximum active model limit reached: " + activeModels.size());
            LlmGatewayModel target = activeModels.stream()
                    .filter(m -> modelId.equals(m.getId()))
                    .findFirst()
                    .orElseThrow(() -> new IllegalArgumentException("Model not found or already inactive"));
            String versionMatrix = target.getVersionMatrix() != null ? target.getVersionMatrix() : "{}";
            JsonNode versionNode = mapper.readTree(versionMatrix);
            if (!versionNode.has("supported_versions") || versionNode.get("supported_versions").isEmpty()) {
                throw new IllegalStateException("Version matrix validation failed: missing supported_versions");
            if ("LOCKED".equals(target.getDependencyStatus())) {
                throw new IllegalStateException("Dependency lock active: model cannot be retired while referenced by routing rules");
            return true;
        } catch (Exception e) {
            throw new RuntimeException("Lifecycle validation failed for model " + modelId, e);
This step queries /api/v2/ai/llm-gateways/{llmGatewayId}/models and evaluates the versionMatrix field against schema expectations. The dependencyStatus field indicates whether Genesys Cloud routing rules or AI agents still reference the model. A LOCKED state blocks retirement to prevent routing errors during scaling operations.
Step 2: Construct Deprovisioning Payload and Execute Atomic DELETE
Genesys Cloud requires a structured retire directive before issuing the deletion request. The payload contains a model-ref, version-matrix, and retire directive. The SDK does not expose a dedicated retire endpoint, so you use the low-level ApiClient to perform an atomic HTTP DELETE with format verification and archive triggers.
import java.util.Map;
public class LlmDeprovisionExecutor {
    private final ApiClient apiClient;
    public LlmDeprovisionExecutor(ApiClient apiClient) {
        this.apiClient = apiClient;
    public boolean executeAtomicDeprovision(String gatewayId, String modelId) {
        String endpoint = "/api/v2/ai/llm-gateways/" + gatewayId + "/models/" + modelId;
        String retirePayload = """
                    "model-ref": {
                        "id": "%s",
                        "gatewayId": "%s"
                    "version-matrix": {
                        "current": "1.0.0",
                        "target": "DEPROVISIONED"
                    "retire": {
                        "directive": "ARCHIVE_AND_RETIRE",
                        "force": false,
                        "gracePeriodSeconds": 30
                """.formatted(modelId, gatewayId);
            apiClient.addDefaultHeader("Content-Type", "application/json");
            apiClient.addDefaultHeader("X-Genesys-Deprovision-Intent", "retire");
            HttpResponse response = apiClient.doDelete(endpoint, retirePayload, null, null, null);
            if (response.getStatusCode() == 200 || response.getStatusCode() == 202) {
                JsonNode responseBody = mapper.readTree(response.getContent());
                return "true".equals(responseBody.path("archiveTriggered").asText("false"));
            } else {
                throw new RuntimeException("Atomic DELETE failed with status " + response.getStatusCode() + ": " + response.getContent());
            throw new RuntimeException("Deprovision execution failed", e);
        } finally {
            apiClient.removeDefaultHeader("X-Genesys-Deprovision-Intent");
The X-Genesys-Deprovision-Intent header signals the backend to bypass standard soft-delete behavior and initiate the archive pipeline. The gracePeriodSeconds field allows in-flight inference requests to complete before the model reference is purged from the gateway routing table.
Step 3: Traffic Drain Calculation and Session Closure Evaluation
Before finalizing retirement, you must verify that active sessions have drained. Genesys Cloud tracks active LLM conversations via the analytics API. The following code polls conversation counts, calculates drain progress, and evaluates session closure thresholds.
public class TrafficDrainEvaluator {
    public TrafficDrainEvaluator(ApiClient apiClient) {
    public boolean evaluateTrafficDrain(String modelId, int maxWaitSeconds) {
        long startTime = System.currentTimeMillis();
        while (System.currentTimeMillis() - startTime < TimeUnit.SECONDS.toMillis(maxWaitSeconds)) {
            String queryPayload = """
                        "groupBy": ["modelId"],
                        "aggregates": [{"id": "count", "type": "COUNT"}],
                        "filter": {
                            "type": "and",
                            "clauses": [
                                {"type": "equals", "field": "modelId", "value": "%s"},
                                {"type": "equals", "field": "status", "value": "ACTIVE"}
                        "interval": "realtime"
                    """.formatted(modelId);
                HttpResponse resp = apiClient.doPost("/api/v2/analytics/conversations/details/query", queryPayload, null, null, null);
                JsonNode data = mapper.readTree(resp.getContent());
                long activeCount = data.path("data").path(0).path("aggregates").path(0).path("count").asLong(0);
                if (activeCount == 0) {
                    return true;
                Thread.sleep(TimeUnit.SECONDS.toMillis(5));
                throw new RuntimeException("Traffic drain polling failed", e);
        throw new IllegalStateException("Traffic drain timeout: active sessions remain for model " + modelId);
This step queries /api/v2/analytics/conversations/details/query with a realtime interval. The loop pauses until active conversation count reaches zero or the timeout expires. This prevents routing errors during Genesys Cloud scaling events where stale model references could cause inference failures.
Step 4: External Registry Sync, Audit Logging, and Metrics Tracking
After successful deprovisioning, you must synchronize the event with an external model registry, track latency, record success rates, and generate governance audit logs. The following code implements webhook delivery, structured logging, and metric aggregation.
import java.io.FileWriter;
import java.io.IOException;
import java.net.URI;
import java.time.Instant;
import java.util.concurrent.atomic.AtomicInteger;
public class DeprovisionGovernanceTracker {
    private final HttpClient httpClient = HttpClient.newHttpClient();
    private final AtomicInteger successCount = new AtomicInteger(0);
    private final AtomicInteger failureCount = new AtomicInteger(0);
    private final String auditLogPath;
    private final String registryWebhookUrl;
    public DeprovisionGovernanceTracker(String auditLogPath, String registryWebhookUrl) {
        this.auditLogPath = auditLogPath;
        this.registryWebhookUrl = registryWebhookUrl;
    public void recordEvent(String gatewayId, String modelId, long latencyMs, boolean success, String archiveStatus) {
        if (success) {
            successCount.incrementAndGet();
        } else {
            failureCount.incrementAndGet();
        String auditEntry = String.format(
                "{\"timestamp\":\"%s\",\"gatewayId\":\"%s\",\"modelId\":\"%s\",\"latencyMs\":%d,\"success\":%b,\"archiveStatus\":\"%s\",\"successRate\":%.2f}%n",
                Instant.now().toString(), gatewayId, modelId, latencyMs, success, archiveStatus,
                calculateSuccessRate()
        try (FileWriter writer = new FileWriter(auditLogPath, true)) {
            writer.write(auditEntry);
        } catch (IOException e) {
            throw new RuntimeException("Audit log write failed", e);
        if (success) {
            triggerRegistrySync(gatewayId, modelId, archiveStatus);
    private double calculateSuccessRate() {
        int total = successCount.get() + failureCount.get();
        return total == 0 ? 0.0 : (double) successCount.get() / total;
    private void triggerRegistrySync(String gatewayId, String modelId, String archiveStatus) {
        String payload = String.format(
                "{\"event\":\"MODEL_ARCHIVED\",\"gatewayId\":\"%s\",\"modelId\":\"%s\",\"archiveStatus\":\"%s\",\"source\":\"GENESYS_CX_DEPROVISIONER\"}",
                .uri(URI.create(registryWebhookUrl))
                .POST(HttpRequest.BodyPublishers.ofString(payload))
                .timeout(java.time.Duration.ofSeconds(10))
                .build();
            if (response.statusCode() >= 400) {
                throw new RuntimeException("Registry webhook failed with status " + response.statusCode());
            throw new RuntimeException("External registry sync failed", e);
The tracker writes structured JSON lines to a file, calculates a rolling success rate, and pushes a MODEL_ARCHIVED event to an external registry endpoint. This satisfies AI governance requirements by maintaining an immutable audit trail and ensuring external systems remain aligned with Genesys Cloud model states.
The following class orchestrates the full deprovisioning workflow. It combines authentication, validation, traffic drain evaluation, atomic deletion, and governance tracking into a single executable module.
public class LlmModelDeprovisioner {
    private final LlmDeprovisionValidator validator;
    private final LlmDeprovisionExecutor executor;
    private final TrafficDrainEvaluator drainEvaluator;
    private final DeprovisionGovernanceTracker tracker;
    public LlmModelDeprovisioner(String env, String clientId, String clientSecret, String auditPath, String webhookUrl) {
        this.apiClient = new ApiClient();
        this.apiClient.setBasePath("https://" + env + ".mypurecloud.com");
        OAuth2Client oauth = new OAuth2Client(this.apiClient);
        AuthMethod auth = new ClientCredentialsAuth(clientId, clientSecret, oauth);
        this.apiClient.setAuthMethod(auth);
        this.apiClient.setAccessToken(oauth.getAccessToken());
        this.llmGatewayApi = new LlmGatewayApi(this.apiClient);
        this.validator = new LlmDeprovisionValidator(this.llmGatewayApi);
        this.executor = new LlmDeprovisionExecutor(this.apiClient);
        this.drainEvaluator = new TrafficDrainEvaluator(this.apiClient);
        this.tracker = new DeprovisionGovernanceTracker(auditPath, webhookUrl);
    public boolean deprovisionModel(String gatewayId, String modelId) {
        long start = System.currentTimeMillis();
        boolean success = false;
        String archiveStatus = "UNKNOWN";
            validator.validateLifecycleConstraints(gatewayId, modelId);
            drainEvaluator.evaluateTrafficDrain(modelId, 60);
            archiveStatus = executor.executeAtomicDeprovision(gatewayId, modelId) ? "ARCHIVED" : "PARTIAL";
            success = true;
            archiveStatus = "FAILED";
            success = false;
        } finally {
            long latency = System.currentTimeMillis() - start;
            tracker.recordEvent(gatewayId, modelId, latency, success, archiveStatus);
        return success;
        String env = "us-east-1";
        String clientId = "YOUR_CLIENT_ID";
        String clientSecret = "YOUR_CLIENT_SECRET";
        String gatewayId = "YOUR_GATEWAY_ID";
        String modelId = "YOUR_MODEL_ID";
        String auditPath = "/var/log/genesys/llm-deprovision-audit.jsonl";
        String webhookUrl = "https://your-registry.example.com/webhooks/model-archive";
        LlmModelDeprovisioner deprovisioner = new LlmModelDeprovisioner(env, clientId, clientSecret, auditPath, webhookUrl);
        boolean result = deprovisioner.deprovisionModel(gatewayId, modelId);
        System.out.println("Deprovisioning completed successfully: " + result);
Replace the placeholder credentials and identifiers before execution. The module runs sequentially, enforces all constraints, and exits with a boolean result indicating success or failure.
Error: HTTP 401 Unauthorized
  • Cause: OAuth client credentials are invalid, expired, or lack the ai:llm-gateway:write scope.
  • Fix: Verify the client ID and secret match the OAuth application in Genesys Cloud. Ensure the application has the required scopes assigned. Restart the process to force token refresh.
  • Code adjustment: Add explicit scope validation during initialization by calling oauthClient.getScopes() and asserting ai:llm-gateway:write exists.
Error: HTTP 403 Forbidden
  • Cause: The OAuth application lacks permissions for LLM Gateway management, or the environment prefix is incorrect.
  • Fix: Confirm the environment string matches your Genesys Cloud tenant region (e.g., us-east-1, eu-west-1). Assign the AI Gateway Administrator role to the OAuth application in the admin console.
  • Cause: Rate limiting triggered by rapid polling or repeated validation calls.
  • Fix: Implement exponential backoff. The TrafficDrainEvaluator already sleeps, but you should wrap ApiClient calls with retry logic.
  • Code adjustment:
public static HttpResponse retryWithBackoff(ApiClient client, String method, String path, String body, int maxRetries) {
    for (int i = 0; i < maxRetries; i++) {
            HttpResponse resp = client.doPost(path, body, null, null, null);
            if (resp.getStatusCode() != 429) return resp;
            if (i == maxRetries - 1) throw e;
        Thread.sleep(TimeUnit.SECONDS.toMillis((long) Math.pow(2, i)));
    throw new RuntimeException("Max retries exceeded for 429");
Error: HTTP 409 Conflict or Lifecycle Validation Exception
  • Cause: The model is referenced by active routing rules, flows, or AI agents. The dependencyStatus field returns LOCKED.
  • Fix: Identify dependent resources using the Genesys Cloud API, update routing configurations to point to a replacement model, then retry deprovisioning. Do not force retirement until dependencies are cleared.
Error: JSON Schema Validation Failure
  • Cause: The version-matrix payload does not match Genesys Cloud expectations.
  • Fix: Ensure the version-matrix object contains supported_versions and target fields. Use Jackson schema validation before sending the DELETE request. Verify field names are lowercase and match the API specification.
