Deploying NICE Cognigy.AI Models Across Multi-Tenant Environments with Go
  • A Go service that exports Cognigy.AI bot definitions, applies tenant-specific configuration overrides, validates compatibility, and pushes deployments to isolated workspaces.
  • The implementation uses the Cognigy.AI REST API surface with typed HTTP clients, exponential backoff retry logic, and structured audit logging.
  • The tutorial covers Go 1.21+ with standard library networking, JSON schema validation, and a production-ready provisioning endpoint.
  • OAuth2 Client Credentials grant type with scopes: bot:export, bot:deploy, deployment:read, user:role:assign, tenant:provision, audit:write
  • Cognigy.AI API version: v1
  • Go runtime: 1.21 or higher
  • Dependencies: go get github.com/santhosh-tekuri/jsonschema/v5 and go get golang.org/x/oauth2
  • Environment variables: COGNIGY_BASE_URL, OAUTH_CLIENT_ID, OAUTH_CLIENT_SECRET, OAUTH_TOKEN_URL, TENANT_SCHEMA_PATH
Cognigy.AI uses standard OAuth2 Client Credentials flow. The service must acquire a workspace-scoped token before issuing any API calls. The following function handles token acquisition, caching, and refresh.
package cognigy
import (
	"context"
	"encoding/json"
	"fmt"
	"net/http"
	"time"
	"golang.org/x/oauth2/clientcredentials"
type OAuthConfig struct {
	ClientID     string
	ClientSecret string
	TokenURL     string
	Scopes       []string
type TokenResponse struct {
	TokenType   string `json:"token_type"`
	ExpiresIn   int64  `json:"expires_in"`
var cachedToken *TokenResponse
var tokenExpiry time.Time
func GetOAuthToken(ctx context.Context, cfg OAuthConfig) (*http.Client, error) {
	if cachedToken != nil && time.Now().Before(tokenExpiry) {
		return &http.Client{
			Transport: &oauth2.Transport{
				Base:   http.DefaultTransport,
				Source: oauth2.ReuseTokenSource(cachedToken.AccessToken, &staticTokenSource{token: cachedToken.AccessToken}),
		}, nil
	conf := &clientcredentials.Config{
		ClientID:     cfg.ClientID,
		ClientSecret: cfg.ClientSecret,
		TokenURL:     cfg.TokenURL,
		Scopes:       cfg.Scopes,
	token, err := conf.Token(ctx)
	if err != nil {
		return nil, fmt.Errorf("oauth token acquisition failed: %w", err)
	cachedToken = &TokenResponse{
		AccessToken: token.AccessToken,
		TokenType:   token.TokenType,
		ExpiresIn:   token.Expiry.Unix(),
	tokenExpiry = token.Expiry.Add(-30 * time.Second) // Refresh 30s before expiry
	return conf.Client(ctx), nil
type staticTokenSource struct {
	token string
func (s *staticTokenSource) Token() (*oauth2.Token, error) {
	return &oauth2.Token{AccessToken: s.token}, nil
Required OAuth Scopes for Authentication: bot:export, bot:deploy, deployment:read, user:role:assign, tenant:provision, audit:write
Step 1: Export Model Definitions via the Model API
Exporting a bot definition requires a POST request to the export endpoint. The API returns a JSON payload containing intents, entities, dialog flows, and configuration metadata. The following client includes retry logic for rate limits.
package cognigy
import (
	"bytes"
	"context"
	"encoding/json"
	"fmt"
	"io"
	"net/http"
	"time"
type BotExportRequest struct {
	BotID string `json:"botId"`
	Format string `json:"format,omitempty"`
type BotExportResponse struct {
	Version   string                 `json:"version"`
	Intents   []IntentDefinition     `json:"intents"`
	Entities  []EntityDefinition     `json:"entities"`
	Dialogs   []DialogDefinition     `json:"dialogs"`
	Metadata  map[string]interface{} `json:"metadata"`
type IntentDefinition struct {
	Name        string `json:"name"`
	Examples    []string `json:"examples"`
	Actions     []string `json:"actions"`
type EntityDefinition struct {
	Values   []string `json:"values"`
	Synonyms map[string][]string `json:"synonyms"`
type DialogDefinition struct {
	ID   string `json:"id"`
	Node string `json:"node"`
	Next string `json:"next"`
func ExportBotModel(ctx context.Context, client *http.Client, baseURL string, req BotExportRequest) (BotExportResponse, error) {
	var resp BotExportResponse
	err := retryWithBackoff(ctx, func() error {
		payload, _ := json.Marshal(req)
		httpReq, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("%s/api/v1/bot/export", baseURL), bytes.NewReader(payload))
		if err != nil {
			return err
		httpReq.Header.Set("Content-Type", "application/json")
		httpResp, err := client.Do(httpReq)
		if err != nil {
			return err
		defer httpResp.Body.Close()
		if httpResp.StatusCode == http.StatusTooManyRequests {
			return fmt.Errorf("rate limited: %d", httpResp.StatusCode)
		if httpResp.StatusCode != http.StatusOK {
			body, _ := io.ReadAll(httpResp.Body)
			return fmt.Errorf("export failed with %d: %s", httpResp.StatusCode, string(body))
		return json.NewDecoder(httpResp.Body).Decode(&resp)
	return resp, err
func retryWithBackoff(ctx context.Context, fn func() error) error {
	maxRetries := 3
	baseDelay := 500 * time.Millisecond
	for attempt := 0; attempt <= maxRetries; attempt++ {
		err := fn()
		if err == nil {
			return nil
		if attempt == maxRetries {
			return err
		delay := baseDelay * (1 << uint(attempt))
		select {
		case <-ctx.Done():
			return ctx.Err()
		case <-time.After(delay):
	return nil
HTTP Request Cycle:
POST /api/v1/bot/export HTTP/1.1
Host: workspace.cognigy.ai
Authorization: Bearer <token>
{"botId": "src-bot-123", "format": "json"}
HTTP Response Cycle:
HTTP/1.1 200 OK
{"botId": "src-bot-123", "version": "1.4.2", "intents": [{"name": "order_status", "examples": ["where is my package"], "actions": ["check_tracking"]}], "entities": [], "dialogs": [], "metadata": {"exportedAt": "2024-05-20T10:00:00Z"}}
Required OAuth Scope: bot:export
Step 2: Parameterize and Validate Model Compatibility
Tenant environments require isolated configuration overrides. The following function applies tenant-specific parameters (API endpoints, webhook URLs, language settings) and validates the modified payload against a tenant schema.
package cognigy
import (
	"context"
	"encoding/json"
	"fmt"
	"os"
	"github.com/santhosh-tekuri/jsonschema/v5"
type TenantParams struct {
	WebhookURL   string `json:"webhookUrl"`
	LangCode     string `json:"langCode"`
	EnvPrefix    string `json:"envPrefix"`
	MaxRetries   int    `json:"maxRetries"`
func ParameterizeModel(model BotExportResponse, params TenantParams) BotExportResponse {
	// Apply tenant-specific overrides to metadata and dialog actions
	model.Metadata["tenantWebhook"] = params.WebhookURL
	model.Metadata["locale"] = params.LangCode
	model.Metadata["envPrefix"] = params.EnvPrefix
	model.Metadata["maxRetries"] = params.MaxRetries
	// Inject tenant routing into dialog definitions
	for i := range model.Dialogs {
		model.Dialogs[i].Next = fmt.Sprintf("%s_%s", params.EnvPrefix, model.Dialogs[i].Next)
	return model
func ValidateModelAgainstSchema(ctx context.Context, model BotExportResponse, schemaPath string) error {
	schemaBytes, err := os.ReadFile(schemaPath)
	if err != nil {
		return fmt.Errorf("failed to read tenant schema: %w", err)
	compiler := jsonschema.NewCompiler()
	if err := compiler.AddResource("schema.json", bytes.NewReader(schemaBytes)); err != nil {
		return fmt.Errorf("failed to load schema: %w", err)
	schema, err := compiler.Compile("schema.json")
	if err != nil {
		return fmt.Errorf("failed to compile schema: %w", err)
	modelBytes, _ := json.Marshal(model)
	return schema.Validate(bytes.NewReader(modelBytes))
Required OAuth Scope: None (local validation)
Step 3: Push Deployments and Monitor Status
Deploying the parameterized model requires a POST to the deployment endpoint. The API returns a deployment ID. The service must poll the status endpoint until completion or failure. Rollback triggers activate if the status indicates validation failure.
package cognigy
import (
	"bytes"
	"context"
	"encoding/json"
	"fmt"
	"io"
	"net/http"
	"time"
type DeployRequest struct {
	Model BotExportResponse `json:"model"`
	TargetWorkspace string  `json:"targetWorkspace"`
type DeployResponse struct {
	DeploymentID string `json:"deploymentId"`
	Status       string `json:"status"`
	Timestamp    string `json:"timestamp"`
type DeploymentStatus struct {
	Status       string `json:"status"` // "pending", "processing", "success", "failed"
	ErrorDetail  string `json:"errorDetail,omitempty"`
func DeployModel(ctx context.Context, client *http.Client, baseURL string, req DeployRequest) (DeployResponse, error) {
	var resp DeployResponse
		httpReq, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("%s/api/v1/bot/deploy", baseURL), bytes.NewReader(payload))
		if err != nil {
			return err
		if err != nil {
			return err
			return fmt.Errorf("rate limited")
		if httpResp.StatusCode != http.StatusCreated {
			return fmt.Errorf("deploy failed %d: %s", httpResp.StatusCode, string(body))
	return resp, err
func MonitorDeployment(ctx context.Context, client *http.Client, baseURL string, deploymentID string) (DeploymentStatus, error) {
	var status DeploymentStatus
	ticker := time.NewTicker(5 * time.Second)
	defer ticker.Stop()
	for {
		select {
		case <-ctx.Done():
			return status, ctx.Err()
		case <-ticker.C:
			httpReq, err := http.NewRequestWithContext(ctx, http.MethodGet, fmt.Sprintf("%s/api/v1/deployment/%s/status", baseURL, deploymentID), nil)
			if err != nil {
				return status, err
			if err != nil {
				return status, err
				return status, fmt.Errorf("status check failed %d", httpResp.StatusCode)
			if err := json.NewDecoder(httpResp.Body).Decode(&status); err != nil {
				return status, err
			if status.Status == "success" || status.Status == "failed" {
				return status, nil
func TriggerRollback(ctx context.Context, client *http.Client, baseURL string, deploymentID string) error {
	httpReq, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("%s/api/v1/deployment/%s/rollback", baseURL, deploymentID), nil)
	if err != nil {
		return err
	if err != nil {
		return err
	if httpResp.StatusCode != http.StatusOK && httpResp.StatusCode != http.StatusAccepted {
		return fmt.Errorf("rollback failed %d: %s", httpResp.StatusCode, string(body))
	return nil
HTTP Request Cycle (Deploy):
POST /api/v1/bot/deploy HTTP/1.1
{"model": {"botId": "src-bot-123", "version": "1.4.2", "intents": [...], "metadata": {"tenantWebhook": "https://tenant1.api.com/webhook", "locale": "en-US"}}, "targetWorkspace": "tenant-prod-01"}
HTTP Response Cycle (Status):
HTTP/1.1 200 OK
{"deploymentId": "dep-98765", "status": "success", "timestamp": "2024-05-20T10:05:00Z"}
Required OAuth Scope: bot:deploy, deployment:read
Step 4: Manage Tenant Access Controls and Audit Logging
Role assignments require POST requests to the user management endpoint. Audit logs must be written synchronously to a compliance store. The following function handles role assignment and structured logging.
package cognigy
import (
	"bytes"
	"context"
	"encoding/json"
	"fmt"
	"io"
	"log/slog"
	"net/http"
	"time"
type RoleAssignment struct {
	UserID       string `json:"userId"`
	RoleID       string `json:"roleId"`
	WorkspaceID  string `json:"workspaceId"`
	ExpiresAt    string `json:"expiresAt,omitempty"`
func AssignTenantRole(ctx context.Context, client *http.Client, baseURL string, assignment RoleAssignment) error {
	payload, _ := json.Marshal(assignment)
	httpReq, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("%s/api/v1/workspace/user/assign", baseURL), bytes.NewReader(payload))
	if err != nil {
		return err
	if err != nil {
		return err
	if httpResp.StatusCode != http.StatusOK && httpResp.StatusCode != http.StatusCreated {
		return fmt.Errorf("role assignment failed %d: %s", httpResp.StatusCode, string(body))
	return nil
func WriteAuditLog(ctx context.Context, event string, tenantID string, details map[string]interface{}) {
	logs := slog.With(
		slog.String("event", event),
		slog.String("tenant_id", tenantID),
		slog.Time("timestamp", time.Now()),
	for k, v := range details {
		logs = logs.With(k, v)
	logs.Info("deployment_audit")
	// In production, replace slog.Info with a write to SIEM, S3, or database
Required OAuth Scope: user:role:assign, audit:write
Step 5: Expose Tenant Provisioning API
The provisioning endpoint orchestrates the entire workflow. It accepts a tenant configuration, exports the base model, parameterizes it, validates it, deploys it, assigns roles, and returns a compliance audit trail.
package cognigy
import (
	"context"
	"encoding/json"
	"fmt"
	"net/http"
	"time"
type ProvisionRequest struct {
	TenantID      string      `json:"tenantId"`
	WorkspaceURL  string      `json:"workspaceUrl"`
	ModelID       string      `json:"modelId"`
	TenantParams  TenantParams `json:"tenantParams"`
	SchemaPath    string      `json:"schemaPath"`
	AdminUserID   string      `json:"adminUserId"`
	AdminRoleID   string      `json:"adminRoleId"`
type ProvisionResponse struct {
	AuditTrail    []map[string]interface{} `json:"auditTrail"`
	CompletedAt   string `json:"completedAt"`
func ProvisionTenantHandler(w http.ResponseWriter, r *http.Request) {
	if r.Method != http.MethodPost {
		http.Error(w, "method not allowed", http.StatusMethodNotAllowed)
		return
	var req ProvisionRequest
	if err := json.NewDecoder(r.Body).Decode(&req); err != nil {
		http.Error(w, "invalid payload", http.StatusBadRequest)
		return
	ctx, cancel := context.WithTimeout(r.Context(), 120*time.Second)
	defer cancel()
	auditTrail := []map[string]interface{}{}
	logEntry := func(event string, details map[string]interface{}) {
		auditTrail = append(auditTrail, details)
		WriteAuditLog(ctx, event, req.TenantID, details)
	// 1. Authenticate
	cfg := OAuthConfig{
		ClientID:     "your_client_id",
		ClientSecret: "your_client_secret",
		TokenURL:     "https://auth.cognigy.ai/oauth/token",
		Scopes:       []string{"bot:export", "bot:deploy", "deployment:read", "user:role:assign", "tenant:provision", "audit:write"},
	client, err := GetOAuthToken(ctx, cfg)
	if err != nil {
		logEntry("auth_failed", map[string]interface{}{"error": err.Error()})
		http.Error(w, "authentication failed", http.StatusUnauthorized)
		return
	// 2. Export Model
	exportReq := BotExportRequest{BotID: req.ModelID, Format: "json"}
	model, err := ExportBotModel(ctx, client, req.WorkspaceURL, exportReq)
	if err != nil {
		logEntry("export_failed", map[string]interface{}{"error": err.Error()})
		http.Error(w, "model export failed", http.StatusInternalServerError)
		return
	logEntry("model_exported", map[string]interface{}{"bot_id": req.ModelID, "version": model.Version})
	// 3. Parameterize & Validate
	model = ParameterizeModel(model, req.TenantParams)
	if err := ValidateModelAgainstSchema(ctx, model, req.SchemaPath); err != nil {
		logEntry("validation_failed", map[string]interface{}{"error": err.Error()})
		http.Error(w, "schema validation failed", http.StatusUnprocessableEntity)
		return
	logEntry("validation_passed", map[string]interface{}{"tenant_id": req.TenantID})
	// 4. Deploy
	deployReq := DeployRequest{Model: model, TargetWorkspace: req.TenantID}
	deployResp, err := DeployModel(ctx, client, req.WorkspaceURL, deployReq)
	if err != nil {
		logEntry("deploy_failed", map[string]interface{}{"error": err.Error()})
		http.Error(w, "deployment failed", http.StatusInternalServerError)
		return
	logEntry("deployment_initiated", map[string]interface{}{"deployment_id": deployResp.DeploymentID})
	// 5. Monitor & Rollback if needed
	status, err := MonitorDeployment(ctx, client, req.WorkspaceURL, deployResp.DeploymentID)
	if err != nil {
		logEntry("monitor_failed", map[string]interface{}{"error": err.Error()})
		http.Error(w, "deployment monitoring failed", http.StatusInternalServerError)
		return
	if status.Status == "failed" {
		if rbErr := TriggerRollback(ctx, client, req.WorkspaceURL, deployResp.DeploymentID); rbErr != nil {
			logEntry("rollback_failed", map[string]interface{}{"error": rbErr.Error()})
		logEntry("deployment_rolled_back", map[string]interface{}{"reason": status.ErrorDetail})
		http.Error(w, "deployment failed and rolled back", http.StatusInternalServerError)
		return
	// 6. Assign Roles
	assignment := RoleAssignment{
		UserID:      req.AdminUserID,
		RoleID:      req.AdminRoleID,
		WorkspaceID: req.TenantID,
	if err := AssignTenantRole(ctx, client, req.WorkspaceURL, assignment); err != nil {
		logEntry("role_assignment_failed", map[string]interface{}{"error": err.Error()})
		http.Error(w, "role assignment failed", http.StatusInternalServerError)
		return
	logEntry("role_assigned", map[string]interface{}{"user_id": req.AdminUserID, "role_id": req.AdminRoleID})
	resp := ProvisionResponse{
		TenantID:     req.TenantID,
		DeploymentID: deployResp.DeploymentID,
		Status:       "success",
		AuditTrail:   auditTrail,
		CompletedAt:  time.Now().UTC().Format(time.RFC3339),
	w.WriteHeader(http.StatusCreated)
	json.NewEncoder(w).Encode(resp)
Required OAuth Scope: tenant:provision (aggregates all previous scopes)
The following script initializes the HTTP server, wires the provisioning endpoint, and starts listening. It requires environment variables for credentials and schema paths.
package main
import (
	"context"
	"fmt"
	"log/slog"
	"net/http"
	"os"
	"yourmodule/cognigy"
func main() {
	port := os.Getenv("PORT")
	if port == "" {
		port = "8080"
	http.HandleFunc("/api/v1/tenant/provision", cognigy.ProvisionTenantHandler)
	slog.Info("starting tenant provisioning service", "port", port)
	if err := http.ListenAndServe(fmt.Sprintf(":%s", port), nil); err != nil {
		slog.Error("server failed", "error", err)
		os.Exit(1)
Run the service with:
export COGNIGY_BASE_URL="https://workspace.cognigy.ai"
export OAUTH_CLIENT_ID="your_client_id"
export OAUTH_CLIENT_SECRET="your_client_secret"
export TENANT_SCHEMA_PATH="./tenant_schema.json"
go run main.go
  • What causes it: Expired OAuth token, invalid client credentials, or missing scope in token request.
  • How to fix it: Verify OAUTH_CLIENT_ID and OAUTH_CLIENT_SECRET. Ensure the token request includes all required scopes. The caching logic refreshes tokens 30 seconds before expiry. If the issue persists, check workspace OAuth policy restrictions.
  • Code showing the fix: The GetOAuthToken function implements automatic refresh. Force a cache reset by setting cachedToken = nil before retrying.
Error: 403 Forbidden
  • What causes it: The authenticated user lacks the required scope for the target workspace, or workspace isolation policies block cross-tenant operations.
  • How to fix it: Grant the OAuth client the bot:export and bot:deploy scopes in the Cognigy admin console. Verify the target workspace ID matches the token scope.
  • Code showing the fix: Pass explicit workspace identifiers in DeployRequest.TargetWorkspace and verify token scopes match the workspace domain.
Error: 422 Unprocessable Entity
  • What causes it: Schema validation failure or malformed bot definition. Missing required fields in intents or dialogs.
  • How to fix it: Review the ValidateModelAgainstSchema output. Ensure tenant parameters do not overwrite mandatory bot fields. Check that dialog node references match existing IDs.
  • Code showing the fix: Log the full validation error from jsonschema and compare it against tenant_schema.json.
  • What causes it: Rate limit exceeded during export or deployment polling.
  • How to fix it: The retryWithBackoff function implements exponential backoff starting at 500 milliseconds. Increase baseDelay if the workspace enforces stricter limits.
  • Code showing the fix: Adjust baseDelay := 500 * time.Millisecond to 1 * time.Second in retryWithBackoff.
Error: Deployment Rollback Triggered
  • What causes it: The deployment status endpoint returns failed with errorDetail indicating runtime validation or dependency resolution failure.
  • How to fix it: Check the status.ErrorDetail payload. Verify webhook URLs in TenantParams are reachable. Ensure language packs referenced in langCode exist in the target workspace.
  • Code showing the fix: The MonitorDeployment function automatically calls TriggerRollback when status.Status == "failed". Review audit logs for the exact failure reason.
