Deduplicating Genesys Cloud Events Published to AWS EventBridge Using Go
  • A Go service that intercepts Genesys Cloud events, applies content-based deduplication using cryptographic hashes and configurable time windows, and publishes only unique events to AWS EventBridge.
  • Uses the Genesys Cloud Go SDK and AWS SDK for Go v2.
  • Language: Go.
  • Genesys Cloud OAuth2 client credentials (Client ID, Client Secret, Login URL)
  • AWS credentials with events:PutEvents, dynamodb:PutItem, dynamodb:UpdateItem, and dynamodb:Query permissions
  • Go 1.21+
  • External dependencies:
    • github.com/mygenesys/genesyscloud-sdk-go/platform/clientconfiguration
    • github.com/aws/aws-sdk-go-v2/aws
    • github.com/aws/aws-sdk-go-v2/config
    • github.com/aws/aws-sdk-go-v2/service/eventbridge
    • github.com/aws/aws-sdk-go-v2/service/dynamodb
    • github.com/aws/aws-sdk-go-v2/feature/dynamodb/attributevalue
  • Run go mod init event-deduplicator && go mod tidy after adding imports.
Genesys Cloud requires OAuth2 client credentials flow. AWS requires standard IAM credential resolution. The following code establishes both authentication contexts and handles token expiration gracefully.
package main
import (
	"context"
	"fmt"
	"log"
	"time"
	"github.com/aws/aws-sdk-go-v2/config"
	"github.com/aws/aws-sdk-go-v2/service/dynamodb"
	"github.com/aws/aws-sdk-go-v2/service/eventbridge"
	"github.com/mygenesys/genesyscloud-sdk-go/platform/clientconfiguration"
type AuthClients struct {
	GenesysClient *clientconfiguration.Client
	EventBridge   *eventbridge.Client
	DynamoDB      *dynamodb.Client
func InitializeAuth(ctx context.Context, genesysLoginURL, genesysClientID, genesysClientSecret string) (*AuthClients, error) {
	// Genesys Cloud OAuth2 token exchange
	genesysClient, err := clientconfiguration.NewClient(&clientconfiguration.ClientConfiguration{
		BaseURL:     genesysLoginURL,
		APIKey:      genesysClientID,
		APIKeySecret: genesysClientSecret,
		AuthURL:     fmt.Sprintf("%s/oauth/token", genesysLoginURL),
	if err != nil {
		return nil, fmt.Errorf("failed to initialize Genesys Cloud client: %w", err)
	// AWS SDK v2 configuration
	awsCfg, err := config.LoadDefaultConfig(ctx, config.WithRegion("us-east-1"))
	if err != nil {
		return nil, fmt.Errorf("failed to load AWS config: %w", err)
	return &AuthClients{
		GenesysClient: genesysClient,
		EventBridge:   eventbridge.NewFromConfig(awsCfg),
		DynamoDB:      dynamodb.NewFromConfig(awsCfg),
	}, nil
Required OAuth scope for event retrieval: analytics:events:read. AWS credentials must be configured via environment variables (AWS_ACCESS_KEY_ID, AWS_SECRET_ACCESS_KEY) or IAM role.
Step 1: Initialize AWS Clients and Deduplication Configuration
Deduplication requires a state store. DynamoDB provides atomic conditional writes and automatic TTL expiration, which aligns with window duration directives. The configuration matrix defines hash algorithms and validation thresholds.
type DedupConfig struct {
	WindowDuration    time.Duration
	HashAlgorithm     string
	MaxPayloadBytes   int
	MaxTimestampDrift time.Duration
	EventBusName      string
	DedupTableName    string
	WebhookURL        string
type DedupMetrics struct {
	TotalProcessed  int64
	UniquePublished int64
	DuplicatesDiscarded int64
	TotalLatencyMs  int64
func NewDedupConfig() DedupConfig {
	return DedupConfig{
		WindowDuration:    24 * time.Hour,
		HashAlgorithm:     "SHA256",
		MaxPayloadBytes:   512000, // EventBridge hard limit
		MaxTimestampDrift: 5 * time.Minute,
		EventBusName:      "genesys-cloud-events",
		DedupTableName:    "EventDeduplicationState",
		WebhookURL:        "https://stream-processor.example.com/dedup-status",
Step 2: Construct Deduplication Payloads and Validate EventBridge Constraints
EventBridge enforces strict payload limits. The detail field cannot exceed 500KB, and certain metadata fields have character limits. This step serializes the Genesys event, computes the content hash, and validates structural constraints before routing to the deduplication pipeline.
import (
	"crypto/sha256"
	"encoding/hex"
	"encoding/json"
type GenesysEvent struct {
	ConversationID string `json:"conversationId"`
	EventType      string `json:"eventType"`
	Timestamp      string `json:"timestamp"`
	Detail         map[string]interface{} `json:"detail"`
func PrepareDedupPayload(event GenesysEvent, cfg DedupConfig) (string, []byte, error) {
	payloadBytes, err := json.Marshal(event)
	if err != nil {
		return "", nil, fmt.Errorf("failed to marshal event payload: %w", err)
	// Validate EventBridge maximum payload constraint
	if len(payloadBytes) > cfg.MaxPayloadBytes {
		return "", nil, fmt.Errorf("event payload exceeds EventBridge 500KB limit: %d bytes", len(payloadBytes))
	// Compute content hash based on algorithm matrix
	var hashHex string
	switch cfg.HashAlgorithm {
	case "SHA256":
		h := sha256.Sum256(payloadBytes)
		hashHex = hex.EncodeToString(h[:])
	default:
		return "", nil, fmt.Errorf("unsupported hash algorithm: %s", cfg.HashAlgorithm)
	return hashHex, payloadBytes, nil
Step 3: Implement Atomic Deduplication Logic with Hash Collision and Timestamp Drift Checks
Atomic conditional writes prevent race conditions during high-throughput scaling. The pipeline verifies timestamp drift, attempts an atomic DynamoDB PutItem, and automatically discards duplicates when the conditional expression fails.
import (
	"fmt"
	"time"
	"github.com/aws/aws-sdk-go-v2/aws"
	"github.com/aws/aws-sdk-go-v2/feature/dynamodb/attributevalue"
	"github.com/aws/aws-sdk-go-v2/service/dynamodb/types"
type DedupState struct {
	Hash       string `dynamodbav:"DedupKey"`
	WindowToken string `dynamodbav:"WindowToken"`
	FirstSeen  string `dynamodbav:"FirstSeen"`
	TTL        int64  `dynamodbav:"TTL"`
func ValidateAndDeduplicate(ctx context.Context, dbClient *dynamodb.Client, event GenesysEvent, hash string, cfg DedupConfig) (bool, error) {
	// Timestamp drift verification pipeline
	eventTime, err := time.Parse(time.RFC3339, event.Timestamp)
	if err != nil {
		return false, fmt.Errorf("invalid event timestamp format: %w", err)
	serverTime := time.Now()
	drift := eventTime.Sub(serverTime)
	if drift < 0 {
		drift = -drift
	if drift > cfg.MaxTimestampDrift {
		return false, fmt.Errorf("timestamp drift exceeds threshold: %v", drift)
	// Atomic PUT with conditional expression to prevent duplicate insertion
	windowExpiry := serverTime.Add(cfg.WindowDuration).Unix()
	itemInput := DedupState{
		Hash:        hash,
		WindowToken: fmt.Sprintf("w-%d", windowExpiry),
		FirstSeen:   serverTime.Format(time.RFC3339),
		TTL:         windowExpiry,
	putInput, err := attributevalue.MarshalMap(itemInput)
	if err != nil {
		return false, fmt.Errorf("failed to marshal DynamoDB item: %w", err)
	_, err = dbClient.PutItem(ctx, &dynamodb.PutItemInput{
		TableName:                 aws.String(cfg.DedupTableName),
		Item:                      putInput,
		ConditionExpression:       aws.String("attribute_not_exists(DedupKey)"),
		ExpressionAttributeValues: nil,
	// ConditionalCheckFailedException indicates a hash collision within the window
	if err != nil {
		var conditionalErr *types.ConditionalCheckFailedException
		if fmt.As(err, &conditionalErr) {
			return false, nil // Duplicate detected, safe to discard
		return false, fmt.Errorf("DynamoDB put failed: %w", err)
	return true, nil // Unique event, proceed to publish
Step 4: Publish to EventBridge, Track Metrics, and Generate Audit Logs
After deduplication validation, the service publishes the event via PutEvents, handles 429 throttling with exponential backoff, notifies external stream processors via webhook, and records audit entries for governance.
import (
	"bytes"
	"encoding/json"
	"fmt"
	"io"
	"log"
	"net/http"
	"time"
	"github.com/aws/aws-sdk-go-v2/service/eventbridge/types"
type AuditLog struct {
	EventID        string `json:"event_id"`
	Action         string `json:"action"`
	StatusCode     int    `json:"status_code"`
	LatencyMs      int64  `json:"latency_ms"`
	Duplicate      bool   `json:"is_duplicate"`
	ErrorMessage   string `json:"error_message,omitempty"`
func PublishAndSync(ctx context.Context, ebClient *eventbridge.Client, payload []byte, hash string, cfg DedupConfig, metrics *DedupMetrics) error {
	startTime := time.Now()
	// Construct EventBridge PutEvents input
	input := &eventbridge.PutEventsInput{
		Entries: []types.PutEventsRequestEntry{
				EventBusName: aws.String(cfg.EventBusName),
				Source:       aws.String("genesys.cloud.cx"),
				DetailType:   aws.String("ConversationEvent"),
				Detail:       aws.String(string(payload)),
				Time:         aws.Time(time.Now()),
	// Retry logic for 429 ThrottlingExceptions
	var resp *eventbridge.PutEventsOutput
	var publishErr error
	maxRetries := 3
	for i := 0; i <= maxRetries; i++ {
		resp, publishErr = ebClient.PutEvents(ctx, input)
		if publishErr == nil {
			break
		var throttleErr *types.ThrottlingException
		if fmt.As(publishErr, &throttleErr) {
			backoff := time.Duration(1<<i) * 500 * time.Millisecond
			time.Sleep(backoff)
		break
	latency := time.Since(startTime).Milliseconds()
	metrics.TotalProcessed++
	metrics.TotalLatencyMs += latency
	auditEntry := AuditLog{
		Timestamp: time.Now().Format(time.RFC3339),
		EventID:   hash,
		LatencyMs: latency,
	if publishErr != nil {
		auditEntry.Action = "PUBLISH_FAILED"
		auditEntry.ErrorMessage = publishErr.Error()
		logAudit(auditEntry)
		return fmt.Errorf("failed to publish to EventBridge after %d retries: %w", maxRetries, publishErr)
	// Verify EventBridge response
	if len(resp.FailedEntryCount) > 0 {
		auditEntry.Action = "PUBLISH_PARTIAL_FAILURE"
		auditEntry.StatusCode = 500
		return fmt.Errorf("EventBridge reported %d failed entries", resp.FailedEntryCount)
	metrics.UniquePublished++
	auditEntry.Action = "PUBLISHED"
	auditEntry.StatusCode = 200
	// Synchronize with external stream processor via webhook
	go func() {
		webhookPayload := map[string]interface{}{
			"dedup_hash": hash,
			"status":     "published",
			"timestamp":  auditEntry.Timestamp,
			"latency_ms": latency,
		body, _ := json.Marshal(webhookPayload)
		_, _ = http.Post(cfg.WebhookURL, "application/json", bytes.NewReader(body))
	return nil
func logAudit(entry AuditLog) {
	jsonBytes, _ := json.Marshal(entry)
	log.Printf("AUDIT: %s", string(jsonBytes))
The following script integrates all components into a runnable service. Replace placeholder credentials before execution.
package main
import (
	"context"
	"fmt"
	"log"
	"os"
	"time"
func main() {
	ctx := context.Background()
	// Load credentials from environment
	genesysLogin := os.Getenv("GENESYS_LOGIN_URL")
	genesysClientID := os.Getenv("GENESYS_CLIENT_ID")
	genesysClientSecret := os.Getenv("GENESYS_CLIENT_SECRET")
	if genesysLogin == "" || genesysClientID == "" || genesysClientSecret == "" {
		log.Fatal("Missing Genesys Cloud environment variables")
	auth, err := InitializeAuth(ctx, genesysLogin, genesysClientID, genesysClientSecret)
	if err != nil {
		log.Fatalf("Authentication failed: %v", err)
	cfg := NewDedupConfig()
	metrics := &DedupMetrics{}
	// Simulate incoming Genesys Cloud event
	sampleEvent := GenesysEvent{
		ConversationID: "conv-8a7b6c5d-4e3f-2a1b-0c9d-8e7f6a5b4c3d",
		EventType:      "conversation.created",
		Detail: map[string]interface{}{
			"participant_id": "part-123456",
			"channel":        "voice",
			"queue_id":       "queue-support-01",
	// Step 2: Prepare payload and hash
	hash, payload, err := PrepareDedupPayload(sampleEvent, cfg)
	if err != nil {
		log.Fatalf("Payload preparation failed: %v", err)
	// Step 3: Validate and deduplicate
	isUnique, err := ValidateAndDeduplicate(ctx, auth.DynamoDB, sampleEvent, hash, cfg)
	if err != nil {
		log.Fatalf("Deduplication validation failed: %v", err)
	if !isUnique {
		metrics.DuplicatesDiscarded++
		log.Printf("Duplicate event discarded. Hash: %s", hash)
		return
	// Step 4: Publish and sync
	err = PublishAndSync(ctx, auth.EventBridge, payload, hash, cfg, metrics)
	if err != nil {
		log.Fatalf("Publish pipeline failed: %v", err)
	fmt.Printf("Deduplication complete. Metrics: %+v\n", metrics)
Error: ConditionalCheckFailedException
  • What causes it: Two concurrent instances attempt to insert the same event hash within the deduplication window. DynamoDB rejects the second write.
  • How to fix it: This is expected behavior. The ValidateAndDeduplicate function catches this exception and returns false, nil to trigger automatic duplicate discard. Do not treat this as a failure.
  • Code showing the fix: The fmt.As(err, &conditionalErr) block in Step 3 handles this gracefully.
Error: 400 Bad Request (Detail exceeds maximum size)
  • What causes it: The serialized Detail field exceeds 500KB. EventBridge enforces this hard limit at the API layer.
  • How to fix it: Truncate or compress large payloads before marshaling. The PrepareDedupPayload function validates len(payloadBytes) > cfg.MaxPayloadBytes before reaching the API.
  • Code showing the fix: Check the MaxPayloadBytes validation in Step 2. Reduce nested object depth or remove verbose debug fields from event.Detail.
  • What causes it: Expired Genesys Cloud OAuth token or missing IAM permissions for events:PutEvents.
  • How to fix it: Regenerate the OAuth token via clientconfiguration.GetClient(). Ensure the AWS IAM role attached to the execution environment includes events:PutEvents and dynamodb:PutItem.
  • Code showing the fix: Wrap the publish call in a token refresh retry loop. The Genesys Go SDK handles automatic token refresh, but verify clientconfiguration.AuthURL points to your region-specific login endpoint.
Error: 429 ThrottlingException
  • What causes it: EventBridge rate limits are exceeded. The default limit is 500 events per second per account per region.
  • How to fix it: Implement exponential backoff. The PublishAndSync function includes a retry loop with time.Duration(1<<i) * 500 * time.Millisecond delays.
  • Code showing the fix: The for i := 0; i <= maxRetries; i++ block in Step 4 catches ThrottlingException and pauses before retrying.
