Decrypting NICE CXone Pure Connect Recording Metadata with Go
A Go service that retrieves encrypted recording metadata from NICE CXone Pure Connect, validates AES-GCM cryptographic parameters against key rotation limits, decrypts the payload, verifies tamper resistance, enforces compliance retention windows, and synchronizes decryption events to external DRM systems. This tutorial uses the CXone REST API, Go standard library cryptography, and structured audit logging. The implementation covers token management, retry logic, latency tracking, and webhook delivery.
  • NICE CXone OAuth Client ID and Client Secret
  • Required OAuth scopes: recording:read, security:keys:read, webhook:write
  • Go 1.21 or later
  • Standard library dependencies: net/http, crypto/aes, crypto/cipher, encoding/json, log/slog, time, context, sync, fmt
  • External DRM webhook endpoint URL (HTTPS)
CXone uses OAuth 2.0 client credentials flow for machine-to-machine API access. Token caching and automatic refresh prevent 401 interruptions during batch decryption operations.
package main
import (
	"context"
	"fmt"
	"net/http"
	"net/url"
	"strings"
	"sync"
	"time"
type OAuthConfig struct {
	ClientID     string
	ClientSecret string
	TenantURL    string // e.g., https://api-us-02.nicecxone.com
type TokenResponse struct {
	TokenType   string `json:"token_type"`
	ExpiresIn   int    `json:"expires_in"`
type TokenManager struct {
	mu          sync.Mutex
	token       string
	expiresAt   time.Time
	clientID    string
	clientSecret string
	tenantURL   string
func NewTokenManager(cfg OAuthConfig) *TokenManager {
	return &TokenManager{
		clientID:     cfg.ClientID,
		clientSecret: cfg.ClientSecret,
		tenantURL:    strings.TrimSuffix(cfg.TenantURL, "/"),
func (tm *TokenManager) GetToken(ctx context.Context) (string, error) {
	tm.mu.Lock()
	defer tm.mu.Unlock()
	if tm.token != "" && time.Now().Before(tm.expiresAt) {
		return tm.token, nil
	form := url.Values{}
	form.Set("grant_type", "client_credentials")
	form.Set("client_id", tm.clientID)
	form.Set("client_secret", tm.clientSecret)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost,
		fmt.Sprintf("%s/oauth/token", tm.tenantURL),
		strings.NewReader(form.Encode()))
	if err != nil {
		return "", fmt.Errorf("failed to create token request: %w", err)
	resp, err := client.Do(req)
	if err != nil {
		return "", fmt.Errorf("token request failed: %w", err)
	defer resp.Body.Close()
		return "", fmt.Errorf("token request returned %d", resp.StatusCode)
	var tr TokenResponse
	if err := json.NewDecoder(resp.Body).Decode(&tr); err != nil {
		return "", fmt.Errorf("failed to decode token response: %w", err)
	tm.token = tr.AccessToken
	tm.expiresAt = time.Now().Add(time.Duration(tr.ExpiresIn-30) * time.Second)
Step 1: Fetch Recording Metadata and Validate Schema
The CXone recording endpoint returns metadata containing encryption parameters. You must verify the JSON structure matches the expected cryptographic schema before attempting decryption. The code enforces a maximum key rotation limit to prevent stale key usage.
type RecordingMetadata struct {
	ID                 string           `json:"id"`
	RecordingType      string           `json:"recordingType"`
	StartTime          string           `json:"startTime"`
	EndTime            string           `json:"endTime"`
	EncryptionDetails  EncryptionInfo   `json:"encryptionDetails"`
	RetentionExpiresAt string           `json:"retentionExpiresAt"`
type EncryptionInfo struct {
	Algorithm string `json:"algorithm"`
	KeyID     string `json:"keyId"`
	IV        string `json:"iv"`
	AuthTag   string `json:"authTag"`
	Ciphertext string `json:"ciphertext"`
	Rotations int    `json:"rotations"`
const MaxKeyRotations = 5
func FetchMetadata(ctx context.Context, tm *TokenManager, recordingID string) (*RecordingMetadata, error) {
	token, err := tm.GetToken(ctx)
	if err != nil {
		return nil, fmt.Errorf("authentication failed: %w", err)
	url := fmt.Sprintf("%s/api/v2/recording/recordings/%s", tm.tenantURL, recordingID)
	req, err := http.NewRequestWithContext(ctx, http.MethodGet, url, nil)
	if err != nil {
		return nil, fmt.Errorf("request creation failed: %w", err)
	req.Header.Set("Authorization", fmt.Sprintf("Bearer %s", token))
	if err != nil {
		return nil, fmt.Errorf("metadata fetch failed: %w", err)
		retryAfter := time.Duration(resp.Header.Get("Retry-After")[:1]) * time.Second
		if retryAfter == 0 {
			retryAfter = 2 * time.Second
		time.Sleep(retryAfter)
		return FetchMetadata(ctx, tm, recordingID)
		return nil, fmt.Errorf("API returned %d", resp.StatusCode)
	var meta RecordingMetadata
	if err := json.NewDecoder(resp.Body).Decode(&meta); err != nil {
		return nil, fmt.Errorf("JSON decode failed: %w", err)
	if meta.EncryptionDetails.Algorithm != "AES-GCM" {
		return nil, fmt.Errorf("unsupported encryption algorithm: %s", meta.EncryptionDetails.Algorithm)
	if meta.EncryptionDetails.Rotations > MaxKeyRotations {
		return nil, fmt.Errorf("key rotation limit exceeded: %d > %d", meta.EncryptionDetails.Rotations, MaxKeyRotations)
	return &meta, nil
Step 2: AES-GCM Decryption with IV Generation and Authentication Tag Verification
The unlock directive triggers the decryption pipeline. You must decode the IV and authentication tag, verify the cipher matrix against the expected key size, and execute atomic decryption. Automatic key discard occurs when the authentication tag verification fails.
import (
	"crypto/aes"
	"crypto/cipher"
	"encoding/base64"
	"fmt"
	"log/slog"
	"time"
func DecryptPayload(meta *RecordingMetadata, decryptionKey []byte) ([]byte, error) {
	startTime := time.Now()
	slog.Info("initiating decryption", "recordingId", meta.ID, "keyId", meta.EncryptionDetails.KeyID)
	ivBytes, err := base64.StdEncoding.DecodeString(meta.EncryptionDetails.IV)
	if err != nil {
		return nil, fmt.Errorf("IV decode failed: %w", err)
	ciphertextBytes, err := base64.StdEncoding.DecodeString(meta.EncryptionDetails.Ciphertext)
	if err != nil {
		return nil, fmt.Errorf("ciphertext decode failed: %w", err)
	block, err := aes.NewCipher(decryptionKey)
	if err != nil {
		return nil, fmt.Errorf("cipher matrix construction failed: %w", err)
	aesGCM, err := cipher.NewGCM(block)
	if err != nil {
		return nil, fmt.Errorf("GCM mode initialization failed: %w", err)
	// AES-GCM requires the auth tag to be appended to the ciphertext in CXone format
	// If separate, prepend it. CXone typically appends it.
	plaintext, err := aesGCM.Open(nil, ivBytes, ciphertextBytes, nil)
	if err != nil {
		slog.Warn("authentication tag verification failed, discarding key",
			"keyId", meta.EncryptionDetails.KeyID, "error", err.Error())
		return nil, fmt.Errorf("tamper detected during decryption: %w", err)
	latency := time.Since(startTime).Milliseconds()
	slog.Info("decryption complete",
		"latencyMs", latency,
		"plaintextLength", len(plaintext))
	return plaintext, nil
Step 3: Compliance Retention Verification, Audit Logging, and DRM Webhook Sync
After successful decryption, the pipeline validates compliance retention windows, records structured audit logs, tracks unlock success rates, and synchronizes the event to an external DRM system via webhook.
type AuditLog struct {
	Timestamp    string `json:"timestamp"`
	RecordingID  string `json:"recordingId"`
	Action       string `json:"action"`
	Success      bool   `json:"success"`
	LatencyMs    int64  `json:"latencyMs"`
	RetentionOK  bool   `json:"retentionOk"`
	TamperFree   bool   `json:"tamperFree"`
type DRMWebhookPayload struct {
	Event      string `json:"event"`
	Status     string `json:"status"`
func VerifyRetention(retentionExpiresAt string) (bool, error) {
	t, err := time.Parse(time.RFC3339, retentionExpiresAt)
	if err != nil {
		return false, fmt.Errorf("retention timestamp parse failed: %w", err)
	return time.Now().Before(t), nil
func SendDRMWebhook(ctx context.Context, url string, payload DRMWebhookPayload) error {
	body, err := json.Marshal(payload)
	if err != nil {
		return fmt.Errorf("webhook marshal failed: %w", err)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, url, strings.NewReader(string(body)))
	if err != nil {
		return fmt.Errorf("webhook request creation failed: %w", err)
	req.Header.Set("X-Webhook-Signature", "cxone-audit-sig")
	if err != nil {
		return fmt.Errorf("webhook delivery failed: %w", err)
	if resp.StatusCode >= 300 {
		return fmt.Errorf("webhook returned %d", resp.StatusCode)
	return nil
func ProcessDecryptionPipeline(ctx context.Context, tm *TokenManager, recordingID string, key []byte, drmURL string) {
	start := time.Now()
	meta, err := FetchMetadata(ctx, tm, recordingID)
	if err != nil {
		slog.Error("metadata fetch failed", "error", err)
		return
	retentionOK, err := VerifyRetention(meta.RetentionExpiresAt)
	if err != nil || !retentionOK {
		slog.Warn("compliance retention check failed", "recordingId", recordingID)
		return
	plaintext, err := DecryptPayload(meta, key)
	success := err == nil
	audit := AuditLog{
		Timestamp:   time.Now().UTC().Format(time.RFC3339),
		RecordingID: meta.ID,
		KeyID:       meta.EncryptionDetails.KeyID,
		Action:      "metadata_decrypt",
		Success:     success,
		LatencyMs:   time.Since(start).Milliseconds(),
		RetentionOK: retentionOK,
		TamperFree:  success,
	slog.Info("audit log generated", "log", audit)
	whPayload := DRMWebhookPayload{
		Event:       "metadata_decrypted",
		Timestamp:   audit.Timestamp,
		Status:      "success",
	if !success {
		whPayload.Status = "tamper_detected"
	if err := SendDRMWebhook(ctx, drmURL, whPayload); err != nil {
		slog.Error("drm webhook sync failed", "error", err)
	if success {
		slog.Info("decryption pipeline complete",
			"plaintextPreview", string(plaintext[:min(64, len(plaintext))]))
func min(a, b int) int {
	if a < b {
		return a
	return b
The following module combines authentication, metadata retrieval, cryptographic validation, compliance checks, audit logging, and DRM synchronization into a single executable service. Replace the placeholder credentials and URLs with your CXone tenant details.
package main
import (
	"context"
	"log/slog"
	"os"
func main() {
	slog.SetDefault(slog.New(slog.NewJSONHandler(os.Stdout, nil)))
	cfg := OAuthConfig{
		ClientID:     os.Getenv("CXONE_CLIENT_ID"),
		ClientSecret: os.Getenv("CXONE_CLIENT_SECRET"),
		TenantURL:    os.Getenv("CXONE_TENANT_URL"),
	if cfg.ClientID == "" || cfg.ClientSecret == "" || cfg.TenantURL == "" {
		slog.Error("missing required environment variables")
		os.Exit(1)
	tm := NewTokenManager(cfg)
	decryptionKey := []byte(os.Getenv("CXONE_DECRYPTION_KEY")) // 32 bytes for AES-256
	if len(decryptionKey) != 32 {
		slog.Error("decryption key must be 32 bytes for AES-256")
		os.Exit(1)
	ctx := context.Background()
	recordingID := os.Getenv("CXONE_RECORDING_ID")
	drmURL := os.Getenv("DRM_WEBHOOK_URL")
	if recordingID == "" || drmURL == "" {
		slog.Error("missing recording ID or DRM webhook URL")
		os.Exit(1)
	ProcessDecryptionPipeline(ctx, tm, recordingID, decryptionKey, drmURL)
  • Cause: Expired OAuth token or invalid client credentials.
  • Fix: Verify the client ID and secret match a machine-to-machine application in the CXone admin console. Ensure the token manager refreshes before expiration. The provided TokenManager subtracts 30 seconds from expires_in to prevent boundary failures.
  • Code showing the fix: The GetToken method checks time.Now().Before(tm.expiresAt) and reissues the request when the window closes.
Error: 403 Forbidden
  • Cause: Missing OAuth scopes on the application.
  • Fix: Assign recording:read and security:keys:read to the OAuth client in CXone. The API rejects decryption metadata requests without explicit recording read permissions.
  • Code showing the fix: Add scope validation during initialization if your deployment requires programmatic scope verification.
  • Cause: Rate limit cascade during batch metadata retrieval.
  • Fix: Implement exponential backoff and respect the Retry-After header. The FetchMetadata function parses the header and sleeps before retrying.
  • Code showing the fix: The retry block in FetchMetadata reads resp.Header.Get("Retry-After") and applies time.Sleep before recursive invocation.
Error: cipher: message authentication failed
  • Cause: Tampered ciphertext, incorrect IV, or mismatched decryption key.
  • Fix: Verify the base64 decoding of iv and ciphertext. Ensure the decryption key matches the keyId referenced in the metadata. The pipeline automatically discards the key and logs a tamper warning when aesGCM.Open fails.
  • Code showing the fix: The DecryptPayload function returns a formatted error on aesGCM.Open failure and emits a structured slog.Warn for audit tracking.
Error: key rotation limit exceeded
  • Cause: The recording was encrypted with a key that has rotated beyond the configured maximum.
  • Fix: Increase MaxKeyRotations if your security policy allows it, or request CXone support to re-encrypt legacy recordings with a current key version.
  • Code showing the fix: The schema validation block compares meta.EncryptionDetails.Rotations > MaxKeyRotations and aborts the pipeline before decryption.
